UmbrellaBoy Posted November 6, 2018 Share Posted November 6, 2018 Can someone please validate the steps I am going to do is correct or does it need any changes. Please experts let me know if any changes is required to the below steps. https://github.com/150balbes/Amlogic_s905/wiki Root of s9xxx (S905 S905X S912)https://yadi.sk/d/srrtn6kpnsKz2 https://yadi.sk/d/srrtn6kpnsKz2/Linux/ARMBIAN/5.64/20181019 Step 1: From the above link download the file Armbian_5.64_Aml-s9xxx_Ubuntu_bionic_default_4.19.0-rc7_desktop_20181019.img.xz Step 2: Unzip file using 7zip in windows 7zip => Armbian_5.64_Aml-s9xxx_Ubuntu_bionic_default_4.19.0-rc7_desktop_20181019.img.xz = Armbian_5.64_Aml-s9xxx_Ubuntu_bionic_default_4.19.0-rc7_desktop_20181019.img Step 3: Write the above extracted Ubuntu Image file to USB or SD card by following the below link.https://www.askvg.com/win32-disk-imager-write-any-bootable-image-to-usb-drive-in-windows/ Step 4: How to Activate MultiBoot. 1) Insert the above prepared USB or SD card into the Device (Device: Mine is Beelink GT1 Ultimate). 2) Start Device into Android normally. 3) Open the App "Update&Backup" 4) click on "Select" local update and chose the file on the removable media (aml_autoscript) inside aml_autoscript.zip 5) start "Update" 6) The System will reboot twice and start running the System from external media. Step 5: How to Install Armbian into eMMC Using u-boot-2015 Enter the desired .dtb filename in /BOOT/uEnv.ini Run “/root/install.sh”. Using u-boot-2018 version (New version) 1) Enter the desired .dtb filename in "/BOOT/extlinux/extlinux.conf 2) Rename Sxxx-uboot.img" to “uboot.img” located at media. i) if S905x then rename s905x-uboot.img to uboot.img ii if S912 then rename s912-uboot.img to uboot.img Run “/root/install-2018.sh” if you don't know if you are using ""u-boot-2015" or "u-boot-2018" then please update both the files. (uEnv.ini and extlinux.conf). /* Notes On models with S802 S805 S812. Activation multi-boot is possible ONLY with SD card (activation of the USB stick is NOT WORKING). After a one-time activation procedure of multi-boot is done using SD Card, running variety of ystems is possible from ANY storage media (SD cards and USB storage devices). */ /* Notes Unzip file using unxz in Linux unxz --keep Armbian_5.64_Aml-s9xxx_Ubuntu_bionic_default_4.19.0-rc7_desktop_20181019.img.xz Link to comment Share on other sites More sharing options...
manuti Posted November 7, 2018 Share Posted November 7, 2018 Bear in mind that : On 5/6/2016 at 11:59 AM, balbes150 said: Install to eMMC (NAND) Kernel 4.16 does not support internal eMMC memory. Do not attempt to install to the eMMC. You get problems. Link to comment Share on other sites More sharing options...
mitico Posted February 19, 2019 Share Posted February 19, 2019 i have a question the deb file in the 5.75 version what are these files? Link to comment Share on other sites More sharing options...
AndrewDB Posted February 23, 2019 Share Posted February 23, 2019 On 2/19/2019 at 1:36 PM, mitico said: i have a question the deb file in the 5.75 version what are these files? These are header, dtb and image files packaged in .deb format but you don't need to worry about them. Link to comment Share on other sites More sharing options...
