bazooka07 Posted November 15, 2018 Posted November 15, 2018 I have a Rock64 powered by Armbian version 5.60 kernel 4.4.162-rockchip64 Ubuntu Bionic How can I activate i2c0 and i2s0 ports for connecting a 16x2 characters LCD display like 1602LCD and a PCM5102 DAC ? I'm trying armbian-config and I'm reading https://docs.armbian.com/User-Guide_Allwinner_overlays/ but I'm getting no help. Thanks for advance.
martinayotte Posted November 15, 2018 Posted November 15, 2018 On 11/15/2018 at 2:04 PM, bazooka07 said: I'm reading https://docs.armbian.com/User-Guide_Allwinner_overlays/ but I'm getting no help. Expand The link clear states that overlays are for Allwinner SoC ... For Rockchip, it needs to be added manually in main DT. It won't be an easy task without doing lot of readings of Rockhip documentations.
bazooka07 Posted November 16, 2018 Author Posted November 16, 2018 Useful doc here : http://synfare.com/599N105E/hwdocs/rock64/index.html I am trying with Ayufan distribution : https://github.com/ayufan-rock64/linux-build/releases/download/0.7.9/bionic-minimal-rock64-0.7.9-1067-arm64.img.xz I have connecting i2c on P27 (i2c1-sda) and P28(i2c1-scl) and 3.3volts and the display is found with "i2cdetect -y 1" on 0x3f. Now, I have to install lcdproc
Boogaloo Posted November 17, 2018 Posted November 17, 2018 Hi, Have you managed to use I2C with Rock64 ? I will soon have to port part of a project under ESP8266 to Rock64, and I need to use I2C with an Oled SSD1306 controller, thanks in advance for sharing your experience.
bazooka07 Posted November 18, 2018 Author Posted November 18, 2018 Yes, I have Rock64 working with I2C and a 20x4 LCD display like this one Aliexpress and the dbrgn/RPLCD under Python 3.6.6 (Ubuntu Bionic 18.04) : git clone https://github.com/bazooka07/RPLCD.git -b test-entrypoint-1811 ( I fix a little bug for the test ) I have too an ESP8266 (Nodemcu) and a OLed 0.96" display. I'm trying for running Oled with Rock64. The following library is working but don't keep the display on when I leave my script pip3 install luma.oled My script : #!/usr/bin/env python3 from luma.core.interface.serial import i2c, spi from luma.core.render import canvas from luma.oled.device import ssd1306 serial = i2c(port=1, address=0x3C) device = ssd1306(serial) with canvas(device) as draw: draw.rectangle(device.bounding_box, outline='white', fill='black') draw.text((30, 40), 'Hello World', fill='white') Don't forget to connect on i2c-1 pin #27 (sda) and pin #28 (scl) unlike RPI3
bazooka07 Posted November 22, 2018 Author Posted November 22, 2018 I am testing with the last version of Armbian (Ubuntu Bionic) and it's working fine. i2c-1 is enabled by default. sudo apt install python3-wheel python3-setuptools python3-dev build-essential sudo apt install python3-smbus git clone --depth 1 https://github.com/rm-hull/luma.oled git clone --depth 1 https://github.com/rm-hull/luma.examples cd luma.oled/ sudo -H python3 setup.py install cd ~/luma.examples/examples python3 welcome.py Don't forget to add yourself in the "i2c" group and to connect your oled in the P27 (i2c1-sda) and P28(i2c1-scl) and 3.3volts. sudo usermod -aG i2c your-login
