malaga Posted November 15, 2018 Posted November 15, 2018 while creating an ISO on SD: Etcher says :: it looks like this is not a bootable image; the image does not appear to contain a partition table and mitht not be recognized or bootable by your device well - this makes me wonder. btw: first time i write to sd-cards. in earlier times i had to write images to DVD it looks like this is not a bootable image; the image does not appear to contain a partition table and mitht not be recognized or bootable by your device Exactly which file did you try to write? Was it one of the standard Raspbian downloads from https://www.raspberrypi.org/downloads/raspbian/? see the ressources i have chosen see - (bananian based things )http://wiki.banana-pi.org/Banana_Pi_BPI ... ge_Releasehttps://www.armbian.com/banana-pi-m2-plus/ any ideas
martinayotte Posted November 15, 2018 Posted November 15, 2018 1 hour ago, malaga said: while creating an ISO on SD: Etcher says :: Why are talking about ISO here ? Which ISO file ? A normal Armbian image should be an "img" file, and "fdisk -l <image_filename>" should shows the partitions. (BTW, ISO partitions can also been seen with "fdisk -l", this means the file you are looking at is probably corrupted)
Igor Posted November 15, 2018 Posted November 15, 2018 (edited) 1 hour ago, malaga said: see the ressources i have chosen Stop "learning" from random junk from the internet. There is a short FAQ on download page containing exactly what you need to know to get started. Edited November 15, 2018 by Igor added link to FAQ
