8 minutes ago, gounthar said:
I waited 25 minutes and got nothing.
Not that long :unsure: Huh. No idea atm.
So I tried this image found on this thread (Single Armbian image for RK + AML + AW), and it goes farther:
   21.071024] rockchip-dmc dmc: Cannot get the regulator "center"
[   21.075233] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[   21.082156] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[   21.085584] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[   21.088899] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[   21.092092] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[   21.095717] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[   21.098905] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[   21.103073] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[   21.106413] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[   21.109609] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[   21.112675] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[   21.116734] rockchip-dmc dmc: Cannot get the regulator "center"
[   21.120188] console [netcon0] enabled
[   21.123168] netconsole: network logging started
[   21.126934] input: gpio-keys as /devices/platform/gpio-keys/input/input1
And later today, I always have the infamous "mmc_init: -5, time 4" error when I try the run mmc_boot.
Go figure. I'm fed up with this card, nothing is stable. When it looks broken (EL3 errors, or kernel panic, or whatever) I can boot on the SDCard, but there isn't any image that boots until the end. When it gets back to life for whatever reason, I can't boot on the SDCard anymore.
I would just like to install Armbian, or push another version of the existing kernel so that I can at last use the camera.:wacko:
I rebuilt the image today, and I am still stuck at Starting kernel ...
=> setenv devnum 1
=> run mmc_boot
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
2940 bytes read in 43 ms (66.4 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
139 bytes read in 35 ms (2.9 KiB/s)
7106982 bytes read in 515 ms (13.2 MiB/s)
20654592 bytes read in 1378 ms (14.3 MiB/s)
73823 bytes read in 110 ms (655.3 KiB/s)
2698 bytes read in 63 ms (41 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 39000000
## Loading init Ramdisk from Legacy Image at 04000000 ...
   Image Name:   uInitrd
   Data Size:    7106918 Bytes = 6.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 7d839000, end 7df00166 ... OK
   reserving fdt memory region: addr=1f00000 size=78000
   Loading Device Tree to 000000007d7be000, end 000000007d838fff ... OK
Starting kernel ...
I guess my board may be faulty.
