Batmah Posted November 26, 2018 Posted November 26, 2018 Hardware : Amlogic S905X , 3x22650 battery, SIM, EMMC SEC 8Gb, RTC with battery, AP6255 WiFi, 4G modem QUECTEL EC25-EFA-512-STD, IR, opt ZigBee Q: Please help me choose a Armbian image to write to the flash EMMC or mSD thanx in advance
TonyMac32 Posted November 27, 2018 Posted November 27, 2018 @Batmah moved to TV boxes. Actually looks somewhat interesting with the batteries, you can get far better capacities than pictured, too, I have 18650's at 2800 mAh. More or less you need to find out what's inside, then figure out if a device tree exists for it.
Batmah Posted November 27, 2018 Author Posted November 27, 2018 Upd! I tried to boot the Armbian from the mSD card and ide-usb hard disk . attached log from the terminal booting-terminal.txt
balbes150 Posted November 28, 2018 Posted November 28, 2018 9 hours ago, Batmah said: I tried to boot the Armbian from the mSD card and ide-usb hard disk . attached log from the terminal 1. Why did you erase the firmware of the eMMC. kvim#store init 3 2. Carefully read the instructions for launching Armbian. You did not follow the important step of the instruction, did not add the correct dtb. reading dtb.img ** Unable to read file dtb.img **
Batmah Posted November 28, 2018 Author Posted November 28, 2018 balbes150 Thank you ! 1. I deleted Android 7.1 eMMC because in this version of the android there was no menu to add an google account , there was no playmarket, there were no root, there was no update&upgrade / Unusable Android 7.1 2. I did not find a way to get dtb.img from eMMC , and Amlogic Burning Tool cannot detect TVBOX Then I burn to eMMC image miniM8SII rv112 , and TVBOX can start now ; hdmi , wifi and usb mouse are ok . Then I update Android with aml_autoscript s905x , and can start ArmbianMate for S912 from mSD ( works well for over a year on another S912 ) I will continue the tests
Batmah Posted December 1, 2018 Author Posted December 1, 2018 Armbian 5.32 on mSD card Ubuntu 16.04.5 LTS 3.14.29 USB Devices : 1d6b:0003 root hub 258a:1005 BT tested ok 2c7c:0125 modem 4G LTE 1a40:0801 Terminus Technology Inc. 1d6b:0002 root hub wifi tested ok
Batmah Posted June 25, 2019 Author Posted June 25, 2019 Armbian 5.89 21-06-2019 mSD card 8Gb all devices are recognized however, the LTE modem does not work. Also, the installation of the operating system on emmc from the configurator was unsuccessful. On emmc, partitions are created, files are there, the booting starts and then "no root fs"
