0
Evgeny
Allwinner H5 SID
Friends, tell me is it possible to get the SID on the device itself?
With the article, read:
http://linux-sunxi.org/SID_Register_Guide
In my sun50i-h5.dtsi:
soc {
	sid: eeprom @ 1c14000 {
                 compatible = "allwinner, sun50i-h5-sid";
                 reg = <0x1c14000 0x400>;
#: sunxi-fel sid
> ERROR: Allwinner USB FEL device not found!
As I understand it, this utility retrieves from a remote device connected in FEL mode.
But is it possible to somehow get the SID directly on the summit device?
Share this post
Link to post
Share on other sites
Yes ! Using the method explained in the Guide you've mentioned ...
Grab this source https://bootlin.com/pub/mirror/devmem2.c , compile it, and use this from the Guide :
d0=`./devmem2 0x01c14200 w|grep Value|sed 's/^.*: 0x/ /'`
d1=`./devmem2 0x01c14204 w|grep Value|sed 's/^.*: 0x/ /'`
d2=`./devmem2 0x01c14208 w|grep Value|sed 's/^.*: 0x/ /'`
d3=`./devmem2 0x01c1420c w|grep Value|sed 's/^.*: 0x/ /'`
echo $d0 $d1 $d2 $d3
Share this post
Link to post
Thanks for your reply! It was very useful for me and I will definitely apply it in the future.
Share this post
Link to post
1 hour ago, t-bob said:
i get bus errors on memory access for 0x01c14204 & 0x01c1420c.
is this expected ?
Good catch !!!
The original file from https://bootlin.com/pub/mirror/devmem2.c is only supporting 32bits SoC, so for 64bits accesses, those 2 addresses are invalid.
I've found patches written by denix0 here : https://github.com/openembedded/meta-openembedded/tree/master/meta-oe/recipes-support/devmem2/devmem2
The first patch to apply is "devmem2-fixups-2.patch", then we can apply "0001-devmem.c-ensure-word-is-32-bit-and-add-support-for-6.patch" ...
Then run the following :
d0=`./devmem2 0x01c14200 l|grep Read|sed 's/^.*: 0x/ /'`
d1=`./devmem2 0x01c14208 l|grep Read|sed 's/^.*: 0x/ /'`
echo $d0 $d1
Share this post
Link to post
excellent. many thanks for that. now i get this which seems like an impressive SID :)
6400462092C000BA:541500CE50368518
Share this post
Link to post
0
