Hello, when I run dietpi-software and select some software to install, it gives me this error. Can someone help me? I had to install armbian on my Rock64 and then ran the install dietpi script. Thank you
DietPi-Software: G_AGUG
│ - Exit code: 100
│ - DietPi version: v6.19.6 (Fourdee/master) | HW_MODEL:22 | HW_ARCH:3 | DISTRO:4
│ - Image creator: Dev
│ - Pre-image: armbian
│ Log file contents:
│ Reading package lists...
│ Building dependency tree...
│ Reading state information...
│ Calculating upgrade...
│ 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
│ 1 not fully installed or removed.
│ After this operation, 0 B of additional disk space will be used.
│ Setting up initramfs-tools (0.130) ...^M
│ update-initramfs: deferring update (trigger activated)^M
│ Processing triggers for initramfs-tools (0.130) ...^M
│ update-initramfs: Generating /boot/initrd.img-4.4.162-rockchip64^M
│ /etc/initramfs/post-update.d//99-uboot: 3: .: Can't open /etc/armbian-release^M
│ run-parts: /etc/initramfs/post-update.d//99-uboot exited with return code 2^M
│ dpkg: error processing package initramfs-tools (--configure):^M
│ subprocess installed post-installation script returned error exit status 1^M
│ Errors were encountered while processing:^M
│ initramfs-tools^M
│ E: Sub-process /usr/bin/dpkg returned an error code (1)
│ Unable to continue, DietPi-Software will now terminate.
If you ask here for help with dietPi, this is equal to got to an Apple Forum and asking for help with Microsoft Windows. Both are Operating Systems, but there are major differences.
So, if you want to install and use armbian, WELCOME.  If you want to stay with dietPi have a look at their forum.
Cheers
Tido
Hi Tido, Thank you for the reply. I understand what you said but the reason I posted this is because I installed armbian on my Rock64 and then ran the dietpi script. I just don't understand what this error code means sicne it contains the armbian local paths. Apart from dietpi forum. Can you help me identify this error at least? Thank you
I have Google'd it for you:
DietPi-Update | G_AGUP/G_AGUG:    Now runs prior to our patch system. Ensuring APT is upto date during our updates:
I looks to me like you were running general Software-Update, this is in armbian done with:
sudo apt update
sudo apt upgrade
(you can try these if you have armbian installed)
You see the difference, just as I said before.
That script severely cripples the system and security of the system, kill optimisations and install spyware. Once you do that, you lost all of our support.
It is worth to do that to be able to install some software from the menu driven utility? Rather type "softy" on a clean Armbian. If your desired app is not there, make use of those superb instructions for installing software they best and cleanest way possible:
https://www.digitalocean.com/community/tutorials
Your system will run optimally (not "optimally") and without anyone checking on you.
