OpenMediaVault from softys - OMV Keyring
Today I gave OpenMediaVault another try  - because 2 of my "very" old NAS-Boxes (normally sitting on a cupboard) only support SMB v1 and I dont know how long my Synology DS109 will live.
Yes - I got 2 NanoPi Neo2 with NAS-Case, but for a test-ride I compiles stretch for the Cubieboard A10 (because of the SATA-Port).
While installing OpenMediaVault vis softys in armbin-config the install-script has to install the OMV Keyring.
The packages where downloaded 100% and then softys came to to line with the keyring and did break the "install-screen".
I did see any action from the Cubieboard :(
After a while I did press Ctrl-C and did reboot and tried to install again....but that doest work because the interrupted install routine before :(
After reading some websites I did give the A10 the command
omv-firstaid
and it promptes some error (seems the installtion of OMV wasnt completed) but it gave me the first solution!:
dpkg --configure -a
So I could see the A10 installing OMV and everything wnt fine.
The Keyring command seems to be like at the manual installation of OMV with debian
see at https://openmediavault.readthedocs.io/en/latest/installation/on_debian.html :
apt-get --allow-unauthenticated install openmediavault-keyring
but (my) armbian didnt like that, so I searched the web again and found
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7E7A6C592EF35D13 24863F0C716B980B
as command.... but armbian couldnt complete this without installing first dirmngr via
apt install dirmngr
Now I can suggest to use the following command prior to the OMV installation:
apt install dirmngr
You could find these keyring-fingerprints at
https://www.openmediavault.org/download.html
  Reveal hidden contents
After the test-ride with the Cubieboard A10 I did a second install on a Intel D525MW Mainboard with a Atom D525 (DualCore 1.8Ghz) and 4GB of Ram.
I installed stretch to a USB-Drive first and then after some configurations OMV via the install-script from
but without the line
because I did install the keyring before the installation :)
At the D525 saving the OMV-Setting is much more speedy...
I dont know why saving the setting does take so long with the Cubieboard A10
( had also this long savetimes some time ago while testing with other new/faster SBCs like NanoPi/OrangePI and RPis :( )
Expand
Who told you to do that? :D // It should be more verbose install and I don't know why it isn't.
Das OMV arbeitet einwandfrei. I just did a quick test on http://ix.io/1vPo
yes it works fine ;)
I was to nervous after the install screen "break" after download package 194 of 194 and the keyring install doesnt did look right....
normally after download it starts with installing 1 of 194 :)
BTW: kannst Du Deutsch schreiben/reden?
Oder ist das der Google-Translator? ;)
