ciprian28 Posted September 6, 2020 Posted September 6, 2020 2 hours ago, Kot said: Hi! I want to add R8723BS Wi-Fi support, so I have downloaded the latest Linux sources here and built it with default settings. It looks like Wi-Fi is OK (LED is blinking), but there is no keyboard anymore - when I connect a USB keyboard, I have no message and I'm not able to enter any text. HID support is enabled in menuconfig. I suppose, I didn't enable neccessary options in menuconfig. Please help to find out the reason. Many thanks for help! With regards, Maksim For Wi-Fi support https://www.acmesystems.it/dlink_wifi 0 Quote
Kot Posted September 7, 2020 Posted September 7, 2020 On 9/6/2020 at 1:05 PM, ciprian28 said: For Wi-Fi support https://www.acmesystems.it/dlink_wifi Thanks for your answer. My question is not about Wi-Fi support, but about the Keyboard, that could not be recognized by the latest kernel version. Hardware is OK and works good with previous Linux image (4.10.02). With regards, Maksim 0 Quote
rmamba Posted September 13, 2021 Posted September 13, 2021 Hey! Can some one point me to explanation how I compile my own device tree for licheepi zero? I use the licheepi zero board that has extra hardweare so I want to use 800x480 LCD and I need the eth0. Still need to see how to add touchscreen driver. It uses FT5436 capacitive touch screen. If I fail with TS driver I'll write something on my own and use ATMega32U4 as a bridge between USB and I2C for TS. LCD is working with their old images (like minmin). But I compiled newer kernel for this. End goal is to check how it works in kiosk mode with touch screen. 0 Quote
Gabor Hidvegi Posted October 28, 2021 Posted October 28, 2021 Hello all, I bought this nice little board, and after a few hours I managed it to work. When booting from mmc, how is it possible to see the flash partitions (/dev/mtdX)? Do I have to recompile the kernel (5.2), or edit the dtb file, or both? 0 Quote
nathalis Posted March 25, 2022 Posted March 25, 2022 Here are compiled kernel and uboot by me with ethernet and lcd 800x480 support: https://github.com/nathalis/Lichee_kernel_uboot_eth_lcd800x480_ also guide how to compile it... 1 Quote
e_music Posted July 5, 2022 Posted July 5, 2022 Hello everyone! Well, I have been reading through the entire post and trying to learn and apply what I learned for the past few days. In fact, many of the replies by @TheLinuxBugand @guidolhad the answers and solutions I've been looking for. I had this Licheepi thing for over two months now and I struggled a lot to get Ethernet working. Let alone the space constrained PCB that made things very awkward for soldering/de-soldering even for a pin header, though I'm well trained and experienced in soldering/de-soldering fine pitch QFP128 chips. I didn't mind paying a few bucks more to get a PCB that is less constrained and compact like this one. Well, I'm totally new to SBCs and Embedded Linux and I'm coming from another architecture, but I'm now getting more familiar with the build system and toolchain. I got this board because I needed it to control/interface with an ASIC that is fully supported since kernel 3.5. Of course, the communication is done over SPI bus and I have seen several implementations out there utilizing the Licheepi Zero Dock with the ASIC concerned. For the first time ever, I was able to get Ethernet working. Thanks again for this great and helpful post. However, I still have a few questions regarding the adaptation of SPI bus, device trees and overlays support, GPIOs, interrupts, LCD, framebuffer, and adding support for FT5406 touch screen (the one attached to my LCD at the moment). I tried the Debian image with LXDE available here: https://licheepizero.us/. It works fine with my LCD. Another website I found for Licheepi pre-compiled images, but non of them worked for some reason: https://sd-card-images.johang.se/boards/lichee_pi_zero.html If someone can help, I would love to hear from you! Thanks 1 Quote
rosenrot Posted May 10, 2023 Posted May 10, 2023 @ciprian28 Have you been able to successfully connect your display? @nathalis I would be happy if you could share your guide how you made your 800x480 lcd work. Your link is broken. 0 Quote
danielc_123 Posted April 15, 2024 Posted April 15, 2024 Hello all Lately I have been spending some time trying to update Kernel and OS to my Lichee Zero Pi. I reached to compile Kernel 5.20 and upgrade Debian from Jessie (8) (official image) to Buster (10), and stop there. I've faced the same USB Keyboard problem, as mentioned before by @Kot, and solved by simply replacing the dtb file in the SD for the one compiled. You can see a short guide how I compiled the Lichee Zero Pi Kernel here Moving from Jessie to Buster was not really complicated but it needs a lot of time, First I upgraded from Jessie (8) to Stretch (9) and Second from Stretch (9) to Buster (10) My initial LicheeZero Pi image was: mindb_dd.tar.gz you can downloaded at the unofficial Lichee Zero Pi site. MOVING FROM JESSIE TO STRETCH I followed these steps to get Jessie Support using freexian: https://www.freexian.com/lts/extended/docs/how-to-use-extended-lts/ 1. Manually installed freexian-archive-keyring package with: wget --no-check-certificate https://deb.freexian.com/extended-lts/pool/main/f/freexian-archive-keyring/freexian-archive-keyring_2022.06.08_all.deb && sudo dpkg -i freexian-archive-keyring_2022.06.08_all.deb 2. Modify the sources list to the ones from freexian config file in this location: /etc/apt/sources.list or /etc/apt/sources.list.d/multistrap-debian.list Comment all lines in the sources list file and add these other lines deb [arch=armhf] http://deb.freexian.com/extended-lts jessie main contrib non-free deb-src [arch=armhf] http://deb.freexian.com/extended-lts jessie main contrib non-free 3. Installed sudo, correct host name and enable bash history apt update # Here, I was able to install sudo apt install sudo # Correct the host name adding LicheePi together to localhost: 127.0.0.1 LicheePi localhost nano /etc/hosts # And enable bash history touch ~/.bash_history 4. Modify again source list to add Stretch sources listed here: https://debiansupport.com/mirrors/ sources file /etc/apt/sources.list.d/multistrap-debian.list deb [arch=armhf] http://archive.debian.org/debian stretch main contrib non-free deb-src [arch=armhf] http://archive.debian.org/debian stretch main contrib non-free deb [arch=armhf] http://archive.debian.org/debian-security stretch/updates main contrib non-free deb-src [arch=armhf] http://archive.debian.org/debian-security stretch/updates main contrib non-free 5. Now Update, Upgrade and dist-upgrade sudo apt clean sudo apt update sudo apt upgrade -y sudo apt dist-upgrade -y MOVING FROM STRETCH TO BUSTER Just follow again the steps 4 and 5, but replacing the sources list by the ones of Buster founded in the above link. Hope this help somebody Regards 1 Quote
