kbkpbot Posted December 17, 2018 Posted December 17, 2018 Because the device tree problem, Ethernet did not working under Armbian 4.19.x. The correct device tree as follow, this will make the T95Z Plus Ethernet working: // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2016 Endless Computers, Inc. * Author: Carlo Caione <carlo@endlessm.com> */ /dts-v1/; #include "meson-gxm.dtsi" #include "meson-gx-p23x-q20x.dtsi" / { compatible = "amlogic,q201", "amlogic,s912", "amlogic,meson-gxm"; model = "Amlogic Meson GXM (S912) Q201 Development Board"; }; ðmac { phy-mode = "rgmii"; pinctrl-0 = <ð_pins>; pinctrl-names = "default"; reg = <0x0 0xc9410000 0x0 0x10000 0x0 0xc8834540 0x0 0x8 0x0 0xc8834558 0x0 0xc>; /* Select external PHY by default */ phy-handle = <&external_phy>; amlogic,tx-delay-ns = <2>; /* External PHY reset is shared with internal PHY Led signals */ snps,reset-gpio = <&gpio GPIOZ_14 0>; snps,reset-delays-us = <0 10000 1000000>; snps,reset-active-low; }; &external_mdio { external_phy: ethernet-phy@0 { /* T95Z Plus's phy has phy id = 0381:5c11 */ compatible = "ethernet-phy-id0381.5c11", "ethernet-phy-ieee802.3-c22"; /* T95Z Plus's phy has phy addr = 1 */ reg = <1>; max-speed = <1000>; interrupt-parent = <&gpio_intc>; interrupts = <25 IRQ_TYPE_LEVEL_LOW>; }; }; &sd_emmc_a { brcmf: wifi@1 { reg = <1>; compatible = "brcm,bcm4329-fmac"; }; }; You can download the dts/dtb here: https://pan.baidu.com/s/1FJtKjyaL9rlhmJFQG8cVSg Please copy the meson-gxm-T95Z-Plus.dtb to your /boot, then modify the /boot/uEnv.ini to point to the new dtb, reboot the system make things work. Good luck! meson-gxm-T95Z-Plus.zip
balbes150 Posted December 17, 2018 Posted December 17, 2018 To get this to all the images are building, send the patch to the main Linux kernel or to this mailing list. http://www.linux-meson.com/doku.php
guidol Posted December 17, 2018 Posted December 17, 2018 4 hours ago, kbkpbot said: You can download the dts/dtb here: https://pan.baidu.com/s/1FJtKjyaL9rlhmJFQG8cVSg Is there any other place than pan.baidu.com (Google Drive or as atatchment to this mesage here in the forum)? I cant access this url Do you think it would work also with a T95K Pro? - because the T95K Pro is also a compatible = "amlogic,q201", "amlogic,s912", "amlogic,meson-gxm"; model = "Amlogic Meson GXM (S912) Q201 Development Board";
kbkpbot Posted December 18, 2018 Author Posted December 18, 2018 10 hours ago, guidol said: Is there any other place than pan.baidu.com (Google Drive or as atatchment to this mesage here in the forum)? I cant access this url Do you think it would work also with a T95K Pro? - because the T95K Pro is also a compatible = "amlogic,q201", "amlogic,s912", "amlogic,meson-gxm"; model = "Amlogic Meson GXM (S912) Q201 Development Board"; I uploaded an attachment in the message. Please try it....
guidol Posted December 18, 2018 Posted December 18, 2018 19 hours ago, kbkpbot said: Please copy the meson-gxm-T95Z-Plus.dtb to your /boot, then modify the /boot/uEnv.ini to point to the new dtb, reboot the system make things work. Good luck! meson-gxm-T95Z-Plus.zip Many Thanks for the upload via attachment, but your .dtb doenst work for my Ethernet-port Today I extracted the .dts for the Sunvell T95K Pro with the Amlogic Customization Tool v5.50 from a T95K Pro Update-file, I did compile them on the T95K Pro (which is running the 4.19.x kernel) via dtc from .dts to .dtb, but the T95K Pro wouldnt boot with this .dtb when copied to the card and configured in the 2 dtb-config-files (they are also very big against other dtbs). Linux sunvell-t95kpro 4.19.6-aml-s9xxx #5.67 SMP PREEMPT Fri Dec 7 10:50:53 MSK 2018 aarch64 GNU/Linux dtc -I dts -O dtb ./T95KPro_gxm_q201_1g.dts -o ./T95KPro_gxm_q201_1g.dtb dtc -I dts -O dtb ./T95KPro_gxm_q201_2g.dts -o ./T95KPro_gxm_q201_2g.dtb -rw-r--r-- 1 root root 44735 Dec 18 11:34 T95KPro_gxm_q201_1g.dtb -rw-r--r-- 1 root root 54276 Dec 18 11:06 T95KPro_gxm_q201_1g.dts -rw-r--r-- 1 root root 45370 Dec 18 11:34 T95KPro_gxm_q201_2g.dtb -rw-r--r-- 1 root root 54967 Dec 18 11:06 T95KPro_gxm_q201_2g.dts Has the internal format changed from a older kernel to a newer - how can I get a newer .dtb that is working wth my ethernet-port? For information and future possibilities I have attached the 2 .dts versions (for 1G or 2G of ram) Sunvell_T95KPRO_dts_extract.zip
kbkpbot Posted December 18, 2018 Author Posted December 18, 2018 Please note: The T95Z Plus use a external phy , ZTE's ZX2AA500. So the device tree use a phy_id=0381:5c11 for this phy. I just added some pr_info in the dwmac-meson8b.c and stmmac_mdio.c, then recompile the kenerl , check dmesg , to see what is happen. Then I found the phy-id . I also checked the kernel 3.14 and found that the phy addr is 1 , not 0. So by fixed the dts, and finally make the ethernet work . If you can open the box, you can check the phy chip. If the phy chip is also the ZTE's ZX2AA500, then you can just modify the phy_addr (reg = <1>) from 0 to 5(?) to see work or not.
Habibie Posted March 27, 2019 Posted March 27, 2019 On 12/17/2018 at 8:25 AM, kbkpbot said: Please copy the meson-gxm-T95Z-Plus.dtb to your /boot, then modify the /boot/uEnv.ini to point to the new dtb, reboot the system make things work. Good luck! meson-gxm-T95Z-Plus.zip I sure would like to learn how to extract a DTB file from an Android device. Can you please explain how you managed to get the DTB file from your T95Z-Plus device?
mumpitzstuff Posted January 8, 2020 Posted January 8, 2020 Many thx for the explanation and the solution to get the ethernet running on this box! I used the information to explain how to transfer the knowledge to any new armbian release. https://forum.armbian.com/topic/12657-t95z-plus-ethernet-working-for-kernel-530/
