Hello.
Armbian_5.35_Orangepizero_Ubuntu_xenial_default_3.4.113.7z
Orange Pi Zero 256
I am rading the bootlog via serial console.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
# systemctl status systemd-modules-load.service
â systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
  Drop-In: /lib/systemd/system/systemd-modules-load.service.d
           ââ10-timeout.conf
   Active: failed (Result: exit-code) since Sun 2018-12-30 00:20:40 CET; 3min 8s ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 167 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 167 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Warning: systemd-modules-load.service changed on disk. Run 'systemctl daemon-reload' to reload units.
# journalctl -f -b _PID=167
-- Logs begin at Sun 2018-12-30 00:20:45 CET. --
Dec 30 00:20:45 opi-06-app-c13 systemd-modules-load[167]: Failed to insert 'xradio_wlan': Connection timed out
Dec 30 00:20:45 opi-06-app-c13 systemd-modules-load[167]: Inserted module 'g_serial'
Dec 30 00:20:45 opi-06-app-c13 systemd-modules-load[167]: Inserted module 'xradio_wlan'
^C
# cat /etc/modules
#w1-sunxi
#w1-gpio
#w1-therm
#sunxi-cir
xradio_wlan
g_serial
xradio_wlan
If I remove any xradio_wlan, then wlan0 is not available at boot.
Is there a way to fix the boot error message, without loosing wlan0 ?
Obviously, some one is aware of an issue, because some dev has put the same line twice in modules ...
I suggest to not bother too much with the onboard WiFi as it is not very good. A better and more reliable solution would be to get a supported USB WiFi dongle.
