g40 Posted January 11, 2019 Posted January 11, 2019 I'm trying to get TFTP support into U-Boot but it insists that 'no ethernet found'. I've added a couple of nodes to the device tree such that it has 'status = "okay" and mac-address = [00 00 00 00 00 00]; I've also added a top level alias in sun50i-h5-nanopi-k1-plus.dts (as added by @martinayotte following this thread) as below. Not sure if the U-Boot config needs changing in any way but the network components are certainly being built. Any thoughts most welcome. AATIA. aliases { serial0 = &uart0; ethernet0 = &emac; }; U-Boot dump of the loaded DTB on running system follows: => bdinfo arch_number = 0x00000000 boot_params = 0x40000100 DRAM bank = 0x00000000 -> start = 0x40000000 -> size = 0x80000000 baudrate = 115200 bps TLB addr = 0xBFFF0000 relocaddr = 0xBDF4B000 reloc off = 0x73F4B000 irq_sp = 0xB9F27590 sp start = 0xB9F27590 Early malloc usage: 2d8 / 400 fdt_blob = 00000000b9f275a8 => fdt addr 00000000b9f275a8 => fdt print ethernet0 ethernet@1c30000 { compatible = "allwinner,sun8i-h3-emac"; syscon = <0x0000000e>; reg = <0x01c30000 0x00010000>; interrupts = <0x00000000 0x00000052 0x00000004>; interrupt-names = "macirq"; resets = <0x00000005 0x0000000c>; reset-names = "stmmaceth"; clocks = <0x00000005 0x0000001b>; clock-names = "stmmaceth"; #address-cells = <0x00000001>; #size-cells = <0x00000000>; status = "okay"; mac-address = [00 00 00 00 00 00]; mdio { #address-cells = <0x00000001>; #size-cells = <0x00000000>; compatible = "snps,dwmac-mdio"; phandle = <0x0000000f>; }; mdio-mux { compatible = "allwinner,sun8i-h3-mdio-mux"; #address-cells = <0x00000001>; #size-cells = <0x00000000>; mdio-parent-bus = <0x0000000f>; mdio@1 { compatible = "allwinner,sun8i-h3-mdio-internal"; reg = <0x00000001>; #address-cells = <0x00000001>; #size-cells = <0x00000000>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x00000001>; clocks = <0x00000005 0x00000043>; resets = <0x00000005 0x00000027>; }; }; mdio@2 { reg = <0x00000002>; #address-cells = <0x00000001>; #size-cells = <0x00000000>; }; }; };
sfx2000 Posted January 18, 2019 Posted January 18, 2019 On 1/11/2019 at 6:06 AM, g40 said: I'm trying to get TFTP support into U-Boot but it insists that 'no ethernet found'. I've added a couple of nodes to the device tree such that it has 'status = "okay" and mac-address = [00 00 00 00 00 00]; I've also added a top level alias in sun50i-h5-nanopi-k1-plus.dts (as added by @martinayotte following this thread) as below. Not sure if the U-Boot config needs changing in any way but the network components are certainly being built. Understand the boot process - uBoot is first, DT works from there...
