obazda Posted January 19, 2019 Share Posted January 19, 2019 (edited) Hi Guys, today I've Updated from "Armbian_5.67_Nanopiduo_Debian_stretch_next_4.14.90" to Armbian_5.69_Nanopiduo_Debian_stretch_next_4.19.13" now I've the follwing problem on my nanopi duo. It has Wifi onboard (XR819), but after an Update to Kernel 4.19.13-sunxi. my wifi device was lost. Before the Update the wifi device was listet as wlan0. to avoid configuration errors i also reinstalled the system. It does not work with debian or ubuntu. If i roleback to an older kernel everything works great. uname -a Linux nanopiduo 4.19.13-sunxi #5.69 SMP Wed Jan 9 16:26:48 CET 2019 armv7l armv7l armv7l GNU/Linux ifconfig -a dummy0: flags=130<BROADCAST,NOARP> mtu 1500 ether fa:76:fc:15:3e:84 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 02:42:0f:94:b1:fc txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 37 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 nmcli radio WIFI-HW WIFI WWAN-HW WWAN enabled enabled enabled enabled Module Size Used by zstd 16384 4 evdev 20480 1 sun8i_codec_analog 24576 0 sun8i_adda_pr_regmap 16384 1 sun8i_codec_analog snd_soc_simple_card 16384 0 snd_soc_simple_card_utils 16384 1 snd_soc_simple_card sun4i_i2s 20480 0 snd_soc_core 106496 4 sun4i_i2s,sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card snd_pcm_dmaengine 16384 1 snd_soc_core snd_pcm 65536 3 sun4i_i2s,snd_pcm_dmaengine,snd_soc_core sun4i_gpadc_iio 16384 0 snd_timer 24576 1 snd_pcm industrialio 49152 1 sun4i_gpadc_iio snd 45056 3 snd_timer,snd_soc_core,snd_pcm soundcore 16384 1 snd sun8i_ths 16384 0 zram 20480 5 cpufreq_dt 16384 0 uio_pdrv_genirq 16384 0 gpio_keys 20480 0 thermal_sys 57344 3 cpufreq_dt,sun8i_ths,sun4i_gpadc_iio uio 16384 1 uio_pdrv_genirq sch_fq_codel 20480 2 usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm g_serial 16384 0 libcomposite 40960 2 g_serial,usb_f_acm ip_tables 20480 0 x_tables 20480 1 ip_tables pwrseq_simple 16384 1 lima 40960 0 gpu_sched 20480 1 lima ttm 57344 1 lima dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.13-sunxi (root@nightly) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.69 SMP Wed Jan 9 16:26:48 CET 2019 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: FriendlyARM NanoPi DUO [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 128 MiB at 0x57c00000 [ 0.000000] On node 0 totalpages: 131072 [ 0.000000] Normal zone: 1152 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 131072 pages, LIFO batch:31 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] random: get_random_bytes called from start_kernel+0x8d/0x3c2 with crng_init=0 [ 0.000000] percpu: Embedded 18 pages/cpu @(ptrval) s41484 r8192 d24052 u73728 [ 0.000000] pcpu-alloc: s41484 r8192 d24052 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920 [ 0.000000] Kernel command line: root=UUID=4184603d-f069-41c2-95e2-68f03fbdbdcc rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=ab235005-01 ubootsource=mmc usb-storage.quirks= sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 524288 bytes of page_ext [ 0.000000] Memory: 365120K/524288K available (8192K kernel code, 896K rwdata, 2420K rodata, 1024K init, 316K bss, 28096K reserved, 131072K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf800000 - 0xbfe00000 ( 6 MB) .text : 0x(ptrval) - 0x(ptrval) (9184 kB) .init : 0x(ptrval) - 0x(ptrval) (1024 kB) .data : 0x(ptrval) - 0x(ptrval) ( 897 kB) .bss : 0x(ptrval) - 0x(ptrval) ( 317 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 36585 entries in 72 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000026] Switching to timer-based delay loop, resolution 41ns [ 0.000347] Console: colour dummy device 80x30 [ 0.000434] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000455] pid_max: default: 32768 minimum: 301 [ 0.000919] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000935] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.002452] CPU: Testing write buffer coherency: ok [ 0.003214] CPU0: update cpu_capacity 1024 [ 0.003227] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.004266] Setting up static identity map for 0x40100000 - 0x40100054 [ 0.004548] rcu: Hierarchical SRCU implementation. [ 0.005946] smp: Bringing up secondary CPUs ... [ 0.017179] CPU1: update cpu_capacity 1024 [ 0.017192] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.028574] CPU2: update cpu_capacity 1024 [ 0.028585] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.039866] CPU3: update cpu_capacity 1024 [ 0.039877] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.040049] smp: Brought up 1 node, 4 CPUs [ 0.040063] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.040071] CPU: All CPU(s) started in HYP mode. [ 0.040076] CPU: Virtualization extensions available. [ 0.042073] devtmpfs: initialized [ 0.054859] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.055247] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.055276] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.064378] xor: measuring software checksum speed [ 0.103945] arm4regs : 598.000 MB/sec [ 0.144054] 8regs : 356.000 MB/sec [ 0.184188] 32regs : 365.000 MB/sec [ 0.224308] neon : 605.000 MB/sec [ 0.224316] xor: using function: neon (605.000 MB/sec) [ 0.224430] pinctrl core: initialized pinctrl subsystem [ 0.226227] NET: Registered protocol family 16 [ 0.230623] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.231531] audit: initializing netlink subsys (disabled) [ 0.231895] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1 [ 0.232704] cpuidle: using governor ladder [ 0.232763] cpuidle: using governor menu [ 0.233766] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.233776] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.328896] raid6: int32x1 gen() 89 MB/s [ 0.397151] raid6: int32x1 xor() 76 MB/s [ 0.465276] raid6: int32x2 gen() 122 MB/s [ 0.533403] raid6: int32x2 xor() 94 MB/s [ 0.601559] raid6: int32x4 gen() 123 MB/s [ 0.670046] raid6: int32x4 xor() 92 MB/s [ 0.738275] raid6: int32x8 gen() 118 MB/s [ 0.806317] raid6: int32x8 xor() 82 MB/s [ 0.874403] raid6: neonx1 gen() 235 MB/s [ 0.942731] raid6: neonx1 xor() 219 MB/s [ 1.010959] raid6: neonx2 gen() 316 MB/s [ 1.079151] raid6: neonx2 xor() 283 MB/s [ 1.147283] raid6: neonx4 gen() 379 MB/s [ 1.215543] raid6: neonx4 xor() 318 MB/s [ 1.283811] raid6: neonx8 gen() 341 MB/s [ 1.351973] raid6: neonx8 xor() 288 MB/s [ 1.351981] raid6: using algorithm neonx4 gen() 379 MB/s [ 1.351987] raid6: .... xor() 318 MB/s, rmw enabled [ 1.351994] raid6: using neon recovery algorithm [ 1.354701] SCSI subsystem initialized [ 1.355059] libata version 3.00 loaded. [ 1.355427] usbcore: registered new interface driver usbfs [ 1.355505] usbcore: registered new interface driver hub [ 1.355622] usbcore: registered new device driver usb [ 1.355930] media: Linux media interface: v0.10 [ 1.356000] videodev: Linux video capture interface: v2.00 [ 1.356282] pps_core: LinuxPPS API ver. 1 registered [ 1.356291] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.356336] PTP clock support registered [ 1.358912] clocksource: Switched to clocksource arch_sys_counter [ 1.530605] VFS: Disk quotas dquot_6.6.0 [ 1.530771] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.546050] NET: Registered protocol family 2 [ 1.547394] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 1.547445] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 1.547542] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 1.547663] TCP: Hash tables configured (established 4096 bind 4096) [ 1.547852] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 1.547912] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 1.548244] NET: Registered protocol family 1 [ 1.549147] RPC: Registered named UNIX socket transport module. [ 1.549155] RPC: Registered udp transport module. [ 1.549162] RPC: Registered tcp transport module. [ 1.549169] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.549600] Trying to unpack rootfs image as initramfs... [ 2.486968] Freeing initrd memory: 7936K [ 2.490248] Initialise system trusted keyrings [ 2.490659] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 2.502065] zbud: loaded [ 2.506251] NFS: Registering the id_resolver key type [ 2.506300] Key type id_resolver registered [ 2.506309] Key type id_legacy registered [ 2.506332] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.506340] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 2.508527] JFS: nTxBlock = 3938, nTxLock = 31508 [ 2.529389] Key type asymmetric registered [ 2.529406] Asymmetric key parser 'x509' registered [ 2.529551] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.529821] io scheduler noop registered [ 2.529830] io scheduler deadline registered [ 2.530169] io scheduler cfq registered (default) [ 2.530179] io scheduler mq-deadline registered [ 2.530187] io scheduler kyber registered [ 2.530448] io scheduler bfq registered [ 2.532647] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO [ 2.540272] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 2.543274] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [ 2.640693] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 2.645020] console [ttyS0] disabled [ 2.665272] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 40, base_baud = 1500000) is a U6_16550A [ 2.665368] console [ttyS0] enabled [ 2.675671] brd: module loaded [ 2.686214] loop: module loaded [ 2.690382] libphy: Fixed MDIO Bus: probed [ 2.691425] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 2.691495] dwmac-sun8i 1c30000.ethernet: No regulator found [ 2.692119] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported [ 2.692133] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported [ 2.692146] dwmac-sun8i 1c30000.ethernet: COE Type 2 [ 2.692157] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported [ 2.692169] dwmac-sun8i 1c30000.ethernet: Normal descriptors [ 2.692181] dwmac-sun8i 1c30000.ethernet: Chain mode enabled [ 2.692434] libphy: stmmac: probed [ 2.693278] dwmac-sun8i 1c30000.ethernet: Found internal PHY node [ 2.693450] libphy: mdio_mux: probed [ 2.693486] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY [ 2.693501] dwmac-sun8i 1c30000.ethernet: Powering internal PHY [ 2.703199] libphy: mdio_mux: probed [ 2.704792] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.704802] ehci-platform: EHCI generic platform driver [ 2.705129] ehci-platform 1c1a000.usb: EHCI Host Controller [ 2.705180] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 [ 2.706648] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000 [ 2.718931] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 [ 2.719433] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 2.719449] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.719461] usb usb1: Product: EHCI Host Controller [ 2.719472] usb usb1: Manufacturer: Linux 4.19.13-sunxi ehci_hcd [ 2.719483] usb usb1: SerialNumber: 1c1a000.usb [ 2.720468] hub 1-0:1.0: USB hub found [ 2.720554] hub 1-0:1.0: 1 port detected [ 2.721962] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.722003] ohci-platform: OHCI generic platform driver [ 2.722294] ohci-platform 1c1a400.usb: Generic Platform OHCI controller [ 2.722349] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 [ 2.722767] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400 [ 2.783385] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19 [ 2.783400] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.783412] usb usb2: Product: Generic Platform OHCI controller [ 2.783423] usb usb2: Manufacturer: Linux 4.19.13-sunxi ohci_hcd [ 2.783434] usb usb2: SerialNumber: 1c1a400.usb [ 2.784329] hub 2-0:1.0: USB hub found [ 2.784416] hub 2-0:1.0: 1 port detected [ 2.786447] usbcore: registered new interface driver usb-storage [ 2.787803] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0 [ 2.787816] sun6i-rtc 1f00000.rtc: RTC enabled [ 2.788172] i2c /dev entries driver [ 2.790642] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 2.792091] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2 [ 2.793084] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 2.793531] ledtrig-cpu: registered to indicate activity on CPUs [ 2.793659] hidraw: raw HID events driver (C) Jiri Kosina [ 2.793865] usbcore: registered new interface driver usbhid [ 2.793871] usbhid: USB HID core driver [ 2.801500] Initializing XFRM netlink socket [ 2.802745] NET: Registered protocol family 10 [ 2.818694] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB [ 2.819496] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2 [ 2.819627] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.2 [ 2.837401] Segment Routing with IPv6 [ 2.837586] NET: Registered protocol family 17 [ 2.837629] NET: Registered protocol family 15 [ 2.837729] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.837814] 8021q: 802.1Q VLAN Support v1.8 [ 2.837905] Key type dns_resolver registered [ 2.838710] Registering SWP/SWPB emulation handler [ 2.839859] registered taskstats version 1 [ 2.839868] Loading compiled-in X.509 certificates [ 2.840009] zswap: loaded using pool lzo/zbud [ 2.843651] Btrfs loaded, crc32c=crc32c-generic [ 2.855309] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.858476] mmc0: new high speed SDHC card at address aaaa [ 2.859539] Key type encrypted registered [ 2.860784] mmcblk0: mmc0:aaaa SB32G 29.7 GiB [ 2.864517] mmcblk0: p1 [ 2.878655] ehci-platform 1c1c000.usb: EHCI Host Controller [ 2.878710] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3 [ 2.879720] ehci-platform 1c1c000.usb: irq 29, io mem 0x01c1c000 [ 2.894919] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 2.895298] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 2.895313] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.895324] usb usb3: Product: EHCI Host Controller [ 2.895335] usb usb3: Manufacturer: Linux 4.19.13-sunxi ehci_hcd [ 2.895346] usb usb3: SerialNumber: 1c1c000.usb [ 2.896329] hub 3-0:1.0: USB hub found [ 2.896406] hub 3-0:1.0: 1 port detected [ 2.897870] ehci-platform 1c1d000.usb: EHCI Host Controller [ 2.897917] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4 [ 2.898375] ehci-platform 1c1d000.usb: irq 31, io mem 0x01c1d000 [ 2.910946] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 [ 2.911294] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 2.911309] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.911320] usb usb4: Product: EHCI Host Controller [ 2.911332] usb usb4: Manufacturer: Linux 4.19.13-sunxi ehci_hcd [ 2.911343] usb usb4: SerialNumber: 1c1d000.usb [ 2.912218] hub 4-0:1.0: USB hub found [ 2.912285] hub 4-0:1.0: 1 port detected [ 2.913620] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 2.913676] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 5 [ 2.914052] ohci-platform 1c1c400.usb: irq 30, io mem 0x01c1c400 [ 2.975278] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19 [ 2.975293] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.975305] usb usb5: Product: Generic Platform OHCI controller [ 2.975316] usb usb5: Manufacturer: Linux 4.19.13-sunxi ohci_hcd [ 2.975327] usb usb5: SerialNumber: 1c1c400.usb [ 2.976157] hub 5-0:1.0: USB hub found [ 2.976224] hub 5-0:1.0: 1 port detected [ 2.977540] ohci-platform 1c1d400.usb: Generic Platform OHCI controller [ 2.977582] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 6 [ 2.977963] ohci-platform 1c1d400.usb: irq 32, io mem 0x01c1d400 [ 3.039259] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19 [ 3.039274] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.039286] usb usb6: Product: Generic Platform OHCI controller [ 3.039297] usb usb6: Manufacturer: Linux 4.19.13-sunxi ohci_hcd [ 3.039308] usb usb6: SerialNumber: 1c1d400.usb [ 3.040168] hub 6-0:1.0: USB hub found [ 3.040259] hub 6-0:1.0: 1 port detected [ 3.041681] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 3.041816] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0 [ 3.044310] of_cfs_init [ 3.044466] of_cfs_init: OK [ 3.044576] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2 [ 3.044677] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4 [ 3.044734] vcc3v0: disabling [ 3.044745] vcc5v0: disabling [ 3.044752] vcc-wifi: disabling [ 3.046216] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.4 [ 3.046327] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.2 [ 3.055199] Freeing unused kernel memory: 1024K [ 3.067304] Run /init as init process [ 4.284456] lima 1c40000.gpu: bus rate = 200000000 [ 4.284475] lima 1c40000.gpu: mod rate = 384000000 [ 4.284965] [TTM] Zone kernel: Available graphics memory: 252576 kiB [ 4.284973] [TTM] Initializing pool allocator [ 4.286577] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 [ 4.286705] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 [ 4.286809] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 [ 4.287015] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus [ 4.289174] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 0 [ 4.292444] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2 [ 4.292654] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4 [ 4.295874] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.4 [ 4.296016] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.2 [ 4.300760] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2 [ 4.300881] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4 [ 4.306747] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq [ 4.471019] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB [ 4.484820] sunxi-mmc 1c10000.mmc: no support for card's volts [ 4.484839] mmc1: error -22 whilst initialising SDIO card [ 4.486595] sunxi-mmc 1c10000.mmc: no support for card's volts [ 4.486608] mmc1: error -22 whilst initialising MMC card [ 5.242439] random: fast init done [ 5.273173] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 5.945405] systemd[1]: System time before build time, advancing clock. [ 5.997248] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 5.998075] systemd[1]: Detected architecture arm. [ 6.038122] systemd[1]: Set hostname to <nanopiduo>. [ 6.734729] random: systemd: uninitialized urandom read (16 bytes read) [ 6.735374] systemd[1]: Started ntp-systemd-netif.path. [ 6.747246] random: systemd: uninitialized urandom read (16 bytes read) [ 6.747686] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 6.767131] random: systemd: uninitialized urandom read (16 bytes read) [ 6.768868] systemd[1]: Created slice User and Session Slice. [ 6.784709] systemd[1]: Created slice System Slice. [ 6.800025] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.811597] systemd[1]: Listening on Syslog Socket. [ 6.823672] systemd[1]: Listening on udev Control Socket. [ 7.020660] g_serial gadget: Gadget Serial v2.4 [ 7.020679] g_serial gadget: g_serial ready [ 7.030098] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 7.717854] systemd-journald[247]: Received request to flush runtime journal from PID 1 [ 8.532121] zram: Added device: zram0 [ 8.536882] zram: Added device: zram1 [ 8.541498] zram: Added device: zram2 [ 8.542765] zram: Added device: zram3 [ 8.547628] zram: Added device: zram4 [ 8.551948] zram: Added device: zram5 [ 8.591819] cpu cpu0: Linked as a consumer to regulator.5 [ 8.591980] cpu cpu0: Dropping the link to regulator.5 [ 8.592404] cpu cpu0: Linked as a consumer to regulator.5 [ 8.594027] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 8.594053] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000) [ 8.594221] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 8.594235] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) [ 8.594440] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 8.594455] cpu cpu0: _opp_add: OPP not supported by regulators (1152000000) [ 8.594638] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 8.594653] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000) [ 8.594801] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 8.594816] cpu cpu0: _opp_add: OPP not supported by regulators (1224000000) [ 8.595133] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 8.595152] cpu cpu0: _opp_add: OPP not supported by regulators (1248000000) [ 8.595310] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 8.595323] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) [ 8.595519] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator [ 8.595533] cpu cpu0: _opp_add: OPP not supported by regulators (1344000000) [ 8.595715] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator [ 8.595728] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000) [ 8.660881] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0 [ 8.686443] zram1: detected capacity change from 0 to 64659456 [ 8.893417] sun8i_ths 1c25000.thermal-sensor: no memory resources defined [ 8.893462] sun8i_ths: probe of 1c25000.thermal-sensor failed with error -22 [ 8.944511] thermal thermal_zone0: failed to read out thermal zone (-110) [ 9.795151] Adding 63140k swap on /dev/zram1. Priority:5 extents:1 across:63140k SSFS [ 9.809915] zram2: detected capacity change from 0 to 64659456 [ 10.853228] Adding 63140k swap on /dev/zram2. Priority:5 extents:1 across:63140k SSFS [ 10.856888] zram3: detected capacity change from 0 to 64659456 [ 11.153417] random: crng init done [ 11.153437] random: 7 urandom warning(s) missed due to ratelimiting [ 11.262534] Adding 63140k swap on /dev/zram3. Priority:5 extents:1 across:63140k SSFS [ 11.266098] zram4: detected capacity change from 0 to 64659456 [ 11.296137] Adding 63140k swap on /dev/zram4. Priority:5 extents:1 across:63140k SSFS [ 11.421362] zram0: detected capacity change from 0 to 52428800 [ 11.795961] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard [ 14.546107] EXT4-fs (mmcblk0p1): resizing filesystem from 226304 to 7712800 blocks [ 26.674028] EXT4-fs (mmcblk0p1): resized to 3145728 blocks [ 37.360914] EXT4-fs (mmcblk0p1): resized to 5767168 blocks [ 45.342118] EXT4-fs (mmcblk0p1): resized filesystem to 7712800 [ 49.293013] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 49.297171] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL) [ 49.303114] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found [ 49.303138] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 49.303151] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 49.304029] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Edited January 19, 2019 by obazda Link to comment Share on other sites More sharing options...
martinayotte Posted January 19, 2019 Share Posted January 19, 2019 4 hours ago, obazda said: [ 4.306747] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq [ 4.471019] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB [ 4.484820] sunxi-mmc 1c10000.mmc: no support for card's volts [ 4.484839] mmc1: error -22 whilst initialising SDIO card [ 4.486595] sunxi-mmc 1c10000.mmc: no support for card's volts [ 4.486608] mmc1: error -22 whilst initialising MMC card It seems to be a "mmc-pwrseq" issue, maybe using wrong gpio in DT for the power enabling ... Link to comment Share on other sites More sharing options...
obazda Posted January 20, 2019 Author Share Posted January 20, 2019 I think this is not a problem, but i downgrade my kernel with the same power supply, and wifi works again. After that i upgrade the kernel to 4.19 and 4.20 and wifi didnt work. Only with 4.19. and 4.20 exit a dummy0 interface. Link to comment Share on other sites More sharing options...
martinayotte Posted January 20, 2019 Share Posted January 20, 2019 2 hours ago, obazda said: I think this is not a problem With the part of the log I've highligthed above, for sure it is the reason why you don't have WiFi, the WiFi chip is attached on SDIO ! Link to comment Share on other sites More sharing options...
