hi all .
i try clone  sd card on running orange pi (cone 32GB to 16GB).
original sd is 32GB ,  clone sd is 16GB .
1) insert USB sd converter ( 16GB sd is in ).
    this is recognized as sdb  because i alredy attach USB HDD.
2) i alredy install boot loader into sdb (16GB).  see -> http://forum.armbian.com/index.php/topic/897-backup-restore/
so
mkfs.ext4 /dev/sdb1
3)mount /dev/sdb1 /mb1
and run the next shell script
cd /mb1
df
pwd
cp  --archive /bin /etc /home /lib /opt /root /run /sbin /srv /tmp /usr /var /selinux /boot /media      ./
mkdir -p boot dev sys mnt proc
4) then halt , and replace sd card .
    orange pi boot with new 16GB sd card .
if this is right ,  backup is easy and time sparing because this is done on running machine . :lol:
tuyosi
What about rsync command which we use for transferring system from SD to USB / NAND / HARD drive?
https://github.com/igorpecovnik/lib/blob/master/scripts/nand-sata-install/usr/lib/nand-sata-install/nand-sata-install.sh#L55-L56
.exclude file content example:
/boot/*
/dev/*
/proc/*
/sys/*
/media/*
/mnt/*
/run/*
/tmp/*
Mount destination under /destination and execute:
rsync -avrltD --delete --exclude-from=.exclude / /destination
thanks  for great advice .
i try another orange pi PC running armbian , this is ordinaly armbian which has 32GB micro sd card only .
( i do not stop armbian , make clone sd card on runnning machine  )
i insert USB card reader which has 16GB micro sd card .
the chart is
after
mkfs.ext4  /dev/sda1
mount /dev/sda1 /ma1
shell sctipt is
df
read X
echo $X
cd /ma1
cp  --archive /bin /etc /home /lib /opt /root  /sbin /srv /usr /var /selinux /boot /SWAP    ./
cd /ma1
mkdir -p  dev proc sys media mnt run tmp
i have made  swap file as /SWAP 1 month ago on 32GB sd
after halt -p
i change 32GB for 16GB , armbian boots .
how to install boot loader into 16GB micro sd card  is  http://forum.armbian...backup-restore/  .
tuyosi
i also try the following .
then
orange pi PC also boot armbian .
clone-rsync.bat
umount /ma1
df
fdisk -l /dev/sda
read X
echo $x
mkfs.ext4 /dev/sda1
cd /ma1
mkdir -p bin etc home lib opt root sbin srv usr var selinux boot
for x in /bin /etc /home /lib /opt /root  /sbin /srv /usr /var /selinux /boot
do
rsync -avHx  --delete $x/  /ma1/$x/
done
cd /ma1
touch /ma1/SWAP
dd if=/dev/zero of=/ma1/SWAP bs=1M count=1024
mkswap /ma1/SWAP
the next ,
umount /ma1
df
fdisk -l /dev/sda
read X
echo $x
cd /ma1
do
done
if this is right ,  fast cloning is done .
regards
This project may be what you are looking for: https://github.com/billw2/rpi-clone
Although written for Raspbian, it may work for Armbian if you replace every occurrence of  'mmcblk0p2' with 'mmcblk0p1' in the script.
[ Disclaimer: I have not tried this myself and am not responsible if your house catches on fire and burns down. :-) ]
 thanks for good information .
partclone also use rsync but i have not tried it yet in order to clone sd card's partition  .
anyway it is easy to clone sd card , so we can take the risk of not booting armbian forever  to improve armbian .
  nothing ventured, nothing gained
my japanese home page is http://orange-pi-2.blogspot.jp/2016/01/orange-pi-2g.html
