Odroid C2 No hdmi output - Armbian 5.70 stretch 3.16.57
Hi,
I've downloaded and successfully installed Armbian_5.47_Odroidc2_Debian_stretch_default_3.16.57 on an Odroid C2 (eMMC) : HDMI output is working fine.
Then I ran: apt-get update then apt-get upgrade then I got a message saying that the kernel has been updated and that I need to reboot.
After the reboot, I have no HDMI output anymore. SSH is available and board seems to be working fine. For information, after the update:
uname -a
Linux jeedom 3.16.57-odroidc2 #72 SMP PREEMPT Wed Sep 19 12:32:15 CEST 2018 aarch64 GNU/Linux
Tried this
without success. I've tested with other cable and screen, no success.
Yes, screen goes off and on but nothing is displayed. Also tried other HDMI cables and another display.
I made another test: installed Armbian_5.59_Odroidc2_Debian_stretch_default_3.16.57, console output is displayed on my HDMI screen. Then apt-get update and upgrade and then no more console output.
Spoiler
[  406.606586] hdmitx: system: irq 80000004
[  406.606675] hdmitx: plugout
[  459.734138] hdmitx: system: irq 80000002
[  460.062195] hdmitx: plugin
[  460.192077] 00ffffffffffff004c2dd5043432494b08140103801009782a6041a6564a9c25
               125054230800a9408180814081009500b30001010101023a801871382d40582c
               4500a05a0000001e011d8018711c1620582c2500a05a0000009e000000fd0032
               3c1b5111000a202020202020000000fc0053796e634d61737465720a202001d7
[  460.192234] 02031cf148901f051404130312230907078301000066030c00100080011d0072
               51d01e206e285500a05a0000001e011d00bc52d01e20b8285540a05a0000001e
               8c0ad090204031200c405500a05a00000018011d80d0721c1620102c2580a05a
               0000009e8c0ad08a20e02d10103e9600a05a000000180000000000000000000e
[  460.192272] EDID Parser:
[  460.192345] hdmitx: edid: find IEEEOUT
[  460.192453] hdmitx: video: get current mode: 1080p60hz
[  460.192510] hdmitx: system: already init VIC = 0  Now VIC = 16
[  460.192525] hdmitx: rx no SCDC present indicator
[  460.194549] hdmitx: ddc rd8b error 0x54 0x01
[  460.196578] hdmitx: ddc rd8b error 0x54 0x01
[  460.196594] hdmirx version is 1.4 or below
[  460.196605] hdmitx: system: set pll
[  460.196617] hdmitx: system: param->VIC:16
[  460.196644] hdmitx: set clk of VIC = 16 done
[  460.196661] hdmitx: set enc for VIC: 16
[  460.196727] hdmitx_set_hw[4453] set VIC = 16
[  460.324153] hdmitx: system: phy setting done
[  460.324187] hdmitx: system: irq 80000001
[  460.324443] Start = 0x10000100   End = 0x100001ff
[  460.324469] [0x10000104]: 0x00000001
[  460.324737] [0x10000180]: 0x000000ff
[  460.324752] [0x10000181]: 0x000000ff
[  460.324766] [0x10000182]: 0x00000003
[  460.324780] [0x10000183]: 0x00000007
[  460.324794] [0x10000184]: 0x0000003f
[  460.324809] [0x10000185]: 0x00000002
[  460.324825] [0x10000187]: 0x000000ff
[  460.324839] [0x10000188]: 0x00000003
[  460.353185] Sink is HDMI device
[  460.353209] Source reading EDID
[  460.382189] hdmtix: set audio
[  460.382219] hdmitx tx_aud_src = 0
[  460.382278] hdmitx aud_n_para = 24576
[  460.382321] hdmitx set channel status
[  460.382430] hdmtix: set audio
[  460.382453] hdmitx tx_aud_src = 0
[  460.382511] hdmitx aud_n_para = 24576
[  460.382553] hdmitx set channel status
I have found the update that is causing the issue: linux-stretch-root-odroidc2 5.73
If I update this one, there is no more output on HDMI
Does someone knows where I can find the code for this package? I will check for changes from release 5.59 to release 5.70.
What can cause the external HDMI display to be on but to not have console output?
Thank you
