I have a quesiton/problem: How can I access the Nano Pi Neo Air with current Ambian (Stretch) OS (Armbian_5.69_Nanopiair_Debian_stretch_next_4.19.13) using USB SSH?
Access to serial console is working fine, but I need SSH. How can I activate this, WLAN is no option for me due to requirements for the systems.
Thank you!
6 hours ago, martinayotte said:
Why ?
Did you search for "g_ether" ?
WLAN has to be disabled according to my requirements, this is not my decision. I selected the NanoPi Neo Air because it was very thin and small. I did try to enable g_ether, but it seems not to be compiled.
I followed these instructions: https://vjordan.info/log/fpga/inapp-otg-ethernet.html
Additonal, I found these: https://vjordan.info/log/fpga/nanopi-neo-usb-otg-with-armbian-mainline-4x-kernel.html (first comment). But I was unable to bring up g_ether.
In this forum, I searched in the H2&H3 section (
). But it seems that the current build is not supporting g_ether. Is there any tutorial how to install and enable g_ether with only a serial connection (I have an additonal CP2102 USB to UART module therefore). I would like to remove g_serial from the USB OTG?
I never manage to have g_ether working with mainline kernel on H3 device. Last time, I thought I had it working with FA distro ... but only one end was receiving packets.
So my nanopi -air is on the shelf and I use pi zero W (s).
