I want to monitor the temperature of my Pine64, because I run the pine in an relatively warm environment.  Unfortunately, the usual ways do not lead to a reasonable result:
I tried the armbianmonitor: "armbianmonitor -m"
with this result:
Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
17:08:20:   ---      0.00   0%   0%   0%   0%   0%   0% -13552°C
17:08:25:   ---      0.00   0%   0%   0%   0%   0%   0% -13673°C
and read the file: /sys/devices/virtual/thermal/thermal_zone0/temp: contains the same wrong value -13552
Is there a way to activate the temperature measurement?
I am using the following system: ARMBIAN 5.49.180626 nightly Ubuntu 16.04.4 LTS 4.14.52-sunxi64
Thanks a lot
Linda
Expand
This is unsupported test build. It's pretty normal that it doesn't work. Use current stable image from the download section.
