CANNOT START USB IP ON ORANGE WITH ARMBIAN
Go to solution Solved by hoov,
Posted (edited)
Hi,
i can't get usbip work, there's a tutorial or something else that i can follow to make usbip working over that soc board?
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.1 LTS"
#/usr/bin/usbip
WARNING: usbip not found for kernel 4.14.84
  You may need to install the following packages for this specific kernel:
    linux-tools-4.14.84-sunxi
    linux-cloud-tools-4.14.84-sunxi
  You may also want to install one of the following packages to keep up to date:
    linux-tools-sunxi
    linux-cloud-tools-sunxi
The board is a orange pi r1
how i can make that working?
Edited by marol94
Hi,
iv'e done what you told me, but i've got that now
root@orangepi:~# usbip
WARNING: usbip not found for kernel 4.19.13
    linux-tools-4.19.13-sunxi
    linux-cloud-tools-4.19.13-sunxi
    linux-tools-sunxi
how can i do?
9 minutes ago, marol94 said:
how can i do?
No idea. USBIP service is not related to Armbian whatsoever - check kernel configuration if modules are enabled. I never used it and can't help here.  Check manual.
Moving to general community section.
I have the same issue, I want to use usbip but it needs linux-tools
However the kernel installed on my orangepipc is 4.19.62-sunxi and there are not linux-tools for this kernel.
Is it possible to use a generic kernel?
  • Solution
Hi,
I just got usbip working on an odroid-n2 with kernel 5.10.
$ apt-get install linux-headers-current-meson64
$ apt-get install linux-source-5.10.34-current-meson64
$ apt-get install libtool
$ apt-get install libudev-dev
Unpack the kernel sources (/usr/src), go into the tools/usb/usbip directory and follow instructions in README:
$ ./autogen.sh
$ ./configure --with-tcp-wrappers=no
$ make install
Then:
$ export LD_LIBRARY_PATH=/usr/local/lib
$ cd /usr/local/sbin
$ modprobe usbip_host
$ ./usbipd
$ ./usbip list -l
$ ./usbip bind -b 2-1.3
Good luck. Cheers.
13.08.2022 в 19:47, Igor сказал:
Is there a simple way to package all those tools within a kernel compilation:
https://armbian.atlassian.net/browse/AR-1283
This is a very beautiful example - usbip.
If I understood correctly after reading this description:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/tools/usb/usbip/README?h=v5.19
we need to build a kernel module, a user-space utility, and write udev rules for loading the module and starting the server.
We need to pack all this into one or two packages and prescribe dependencies on a specific kernel. In this case, the utility
will have dependencies on system libraries. That is, it must be collected in the environment in which it will be used.
In order for this to become an easy way, we need to do the following:
1) Build packages from kernel sources without using the built-in mechanism (mkdebian, builddeb).
Instead, we have to generate files in the debian directory ourselves from our own templates.
During this process, handle some differences from the kernel version and writing all the necessary variables to files.
2) Collect packages for focal in this OS, packages for jammy in the jammy environment.
I was also looking into usbip as I want to implement it to be able to attach devices under test to USB server containing a bunch of wireless cards.
This seems covered well.
Spoiler
linux-bcm2711-current.config:CONFIG_USBIP_CORE=m
linux-bcm2711-edge.config:CONFIG_USBIP_CORE=m
linux-imx6-current.config:CONFIG_USBIP_CORE=m
linux-imx6-edge.config:CONFIG_USBIP_CORE=m
linux-imx7d-current.config:# CONFIG_USBIP_CORE is not set
linux-imx7d-legacy.config:CONFIG_USBIP_CORE=m
linux-jetson-nano-legacy.config:# CONFIG_USBIP_CORE is not set
linux-media-current.config:CONFIG_USBIP_CORE=m
linux-media-edge.config:CONFIG_USBIP_CORE=m
linux-meson64-current.config:CONFIG_USBIP_CORE=m
linux-meson64-edge.config:CONFIG_USBIP_CORE=m
linux-meson64-legacy.config:CONFIG_USBIP_CORE=m
linux-meson-current.config:CONFIG_USBIP_CORE=m
linux-meson-edge.config:CONFIG_USBIP_CORE=m
linux-meson-legacy.config:CONFIG_USBIP_CORE=m
linux-mt7623-edge.config:CONFIG_USBIP_CORE=m
linux-mt7623-legacy.config:CONFIG_USBIP_CORE=m
linux-mvebu64-current.config:CONFIG_USBIP_CORE=m
linux-mvebu64-edge.config:CONFIG_USBIP_CORE=m
linux-mvebu64-legacy.config:CONFIG_USBIP_CORE=m
linux-mvebu-current.config:CONFIG_USBIP_CORE=m
linux-mvebu-edge.config:CONFIG_USBIP_CORE=m
linux-mvebu-legacy.config:CONFIG_USBIP_CORE=m
linux-odroidxu4-current.config:CONFIG_USBIP_CORE=m
linux-odroidxu4-edge.config:CONFIG_USBIP_CORE=m
linux-odroidxu4-legacy.config:CONFIG_USBIP_CORE=m
linux-rk322x-current.config:CONFIG_USBIP_CORE=m
linux-rk322x-edge.config:CONFIG_USBIP_CORE=m
linux-rk322x-legacy.config:CONFIG_USBIP_CORE=m
linux-rk3399-legacy.config:CONFIG_USBIP_CORE=m
linux-rk35xx-legacy.config:CONFIG_USBIP_CORE=m
linux-rockchip64-current.config:CONFIG_USBIP_CORE=m
linux-rockchip64-edge.config:CONFIG_USBIP_CORE=m
linux-rockchip64-legacy.config:CONFIG_USBIP_CORE=m
linux-rockchip-current.config:CONFIG_USBIP_CORE=m
linux-rockchip-edge.config:CONFIG_USBIP_CORE=m
linux-rockchip-legacy.config:CONFIG_USBIP_CORE=m
linux-rockchip-rk3588-legacy.config:CONFIG_USBIP_CORE=m
linux-rockpis-legacy.config:CONFIG_USBIP_CORE=m
linux-s5p6818-legacy.config:CONFIG_USBIP_CORE=m
linux-station-p2-legacy.config:# CONFIG_USBIP_CORE is not set
linux-sun50iw9-legacy.config:CONFIG_USBIP_CORE=m
linux-sunxi64-current.config:CONFIG_USBIP_CORE=m
linux-sunxi64-edge.config:CONFIG_USBIP_CORE=m
linux-sunxi64-legacy.config:CONFIG_USBIP_CORE=m
linux-sunxi-current.config:CONFIG_USBIP_CORE=m
linux-sunxi-edge.config:CONFIG_USBIP_CORE=m
linux-sunxi-legacy.config:CONFIG_USBIP_CORE=m
linux-uefi-arm64-current.config:CONFIG_USBIP_CORE=m
linux-uefi-arm64-edge.config:CONFIG_USBIP_CORE=m
linux-uefi-x86-current.config:CONFIG_USBIP_CORE=m
linux-uefi-x86-edge.config:CONFIG_USBIP_CORE=m
linux-virtual-current.config:CONFIG_USBIP_CORE=m
linux-zynq-legacy.config:# CONFIG_USBIP_CORE is not set
Under this?
https://github.com/armbian/build/tree/master/packages/extras-buildpkgs
4 часа назад, Igor сказал:
Under this?
In a sense, it is a build server for the target architecture in the target operating system environment.
I have not come up with a simpler and more correct way at the moment.
I am building a library and an application using kernel sources in a chroot environment by mounting them in the following way.
From 29990c7edb920a7c5be3b898716f48d8bbc29dec Mon Sep 17 00:00:00 2001
From: The-going <48602507+The-going@users.noreply.github.com>
Date: Fri, 13 May 2022 21:31:51 +0300
Subject: [PATCH] Mount bind linux source if necessary
 lib/chroot-buildpackages.sh | 10 +++++++++-
 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/lib/chroot-buildpackages.sh b/lib/chroot-buildpackages.sh
index 9471ee3a3..b4b52fc18 100644
--- a/lib/chroot-buildpackages.sh
+++ b/lib/chroot-buildpackages.sh
@@ -258,7 +258,7 @@ chroot_build_packages()
 			for plugin in $config_for_packages; do
 				unset package_name package_repo package_ref package_builddeps package_install_chroot package_install_target \
-					package_upstream_version needs_building plugin_target_dir package_component "package_builddeps_${release}"
+					package_upstream_version needs_building plugin_target_dir package_component "package_builddeps_${release}" mount_linux_src
 				source "${plugin}"
 				# check build condition
@@ -312,11 +312,19 @@ chroot_build_packages()
 				fetch_from_repo "$package_repo" "extra/$package_name" "$package_ref"
+				if [ "$mount_linux_src" == "yes" ];then
+					mkdir -p $target_dir/root/linux
+					linuxsrc=$(realpath "${SRC}"/cache/sources/${LINUXSOURCEDIR})
+					# redefine mount_linux_src
+					mount_linux_src="--bind-ro ${linuxsrc}/:/root/linux"
+				fi
 				eval systemd-nspawn -a -q \
 					--capability=CAP_MKNOD -D "${target_dir}" \
 					--tmpfs=/root/build \
 					--tmpfs=/tmp:mode=777 \
 					--bind-ro "$(dirname $plugin)"/:/root/overlay \
+					$mount_linux_src \
 					--bind-ro "${SRC}"/cache/sources/extra/:/root/sources /bin/bash -c "/root/build.sh" 2>&1 \
 					${PROGRESS_LOG_TO_FILE:+' | tee -a $DEST/${LOG_SUBPATH}/buildpkg.log'}
2.35.3
16.08.2022 в 17:46, Igor сказал:
I have looked carefully at the build scripts of the original ubuntu kernel package.
The scripts are configured for both cross compilation and native assembly.
If there is a very big desire, then it will be possible to implement this for the armbian build system.
It is assumed that this will be a significantly reduced version.
Desire is getting bigger :) but if there is no time ... Can you at least give me some directions so I don't start from scratch?
I see two ways.
1) You can turn the user's @hoov manual into a debian/rule file.
Mount the already patched kernel into the build environment and assemble the kernel module.
Take my branch. https://github.com/The-going/armbian-build/tree/chroot_build_pkg
Use the parameter mount_linux_src=yes
https://github.com/The-going/armbian-build/blob/1e9a7a1b24e5d5aead730f58ad910124782b5576/lib/chroot-buildpackages.sh#L313
Here I help the user to build a debian package in a chroot environment, bypassing many unnecessary steps.
2) I wanted to try to rework the debian rules directly from the original ubuntu repository:
/gituser/ubuntu-kernel> mkdir jammy
/gituser/ubuntu-kernel> cd jammy/
/gituser/ubuntu-kernel/jammy> git init
/gituser/ubuntu-kernel/jammy> git remote add origin git://git.launchpad.net/~ubuntu-kernel/ubuntu/+source/linux/+git/jammy
/gituser/ubuntu-kernel/jammy> git fetch
/gituser/ubuntu-kernel/jammy> git checkout -b hwe-5.19-next origin/hwe-5.19-next
I'll take that as a basis. Everything is available here. We only need to choose what we will take.
I have similar issue. I'm trying to install usb IP on:
uname -a
Linux pineh64-b 5.15.80-sunxi64 #22.11.1 SMP Wed Nov 30 11:23:00 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
Armbian 22.11.1 Jammy
Using @hoov tutorial I went with:
apt-get install linux-source-5.15.80-current-sunxi64
apt-get install linux-headers-current-sunxi64
And I went to /usr/src/linux-headers-5.15.80-sunxi64/tools/usb/usbip
But there is no README and there is no ./autogen.sh:
root@pineh64-b:/usr/src/linux-headers-5.15.80-sunxi64/tools/usb/usbip# ls -la
total 20
drwxr-xr-x 4 root root 4096 Dec  1 00:48 .
drwxr-xr-x 4 root root 4096 Dec  1 00:48 ..
drwxr-xr-x 2 root root 4096 Dec  1 00:48 libsrc
-rw-r--r-- 1 root root  292 Dec  1 00:48 Makefile.am
drwxr-xr-x 2 root root 4096 Dec  1 00:48 src
What have I done wrong? what am I missing?
