When the system call # /sbin/fstrim --all   the process enters intermittent sleep, and all the following processes gradually obtain the same state.828535131_fstrim_2019-02-0617-08-31.thumb.png.90e7c85c3c9876ae6d124034ae5a2e4a.png
In crontab it appears as a task of the # fstrim -v / system, the same command if I do it manually also has the same result of never ending and blocking the other processes little by little until the system is totally blocked.
Can it be disabled? As a check that is compatible with the microsd? Any recommendation?
18 minutes ago, blackPanter28 said:
Any recommendation?
None. We are blind without
armbianmonitor -u
armbianmonitor -u
This is the output.  https://paste.ubuntu.com/p/gJ9Khgn5mX/
At this time, patch the error by deactivating the launch using cron -> sudo mv /etc/cron.weekly/fstrim/etc/cron.weekly/fstrim.bak but I need to run fstrim without the system stopping, to keep it operational and healthy as long as possible.
