Hi Igor and all,
after running armbian on my A20 lime2 for a long time, I decided to switch to armbian on my A10 lime, too (from jessie with a eewiki-based self-compiled kernel). So far it works as perfect as the A20, but there are two small and funny things with the
Armbian_5.00_Lime-a10_Debian_jessie_3.4.110.zip
image I used:
After login the nice armbian banner stated that my A10 lime is a cubieboard :D . I have a cubieboard, too. So I double checked...
The problem is located in /etc/init.d/armhwinfo, There all "sun4i" boards are simply "Cubieboard". I had to adapt the LED check which is
used to detect Lime and Lime2 a bit and added the Lime A10. I checked the LEDs path on my cubian based cubieboard 1 and it
was different, so hopefully the LED check correctly detects the Lime A10.
During test (restarting service armhwinfo) I saw that the detected ID is appended to /var/run/machine.id. I had a funny banner with Cubieboard and 2 times Lime A10 :) .
Here is what I changed finally:
--- armhwinfo.org	2016-02-11 23:58:47.000000000 +0100
+++ armhwinfo	2016-04-07 12:17:16.848138250 +0200
@@ -17,6 +17,8 @@
 HARDWARE=$(cat /proc/cpuinfo | grep Hardware | awk '{print $3}')
 GMAC=$(dmesg | grep "sun6i_gmac")
 LEDS=$(dmesg |grep "green:ph02:led1")
+# a10 lime
+LEDS2=$(dmesg |grep "green:ph2:led1")
 TERMINUS=$(lsusb  | grep "1a40:0101")
 SWITCH=$(dmesg | grep "BCM53125")
 INTERUPT=$(cat /proc/interrupts | grep "eth0")
@@ -55,8 +57,12 @@
 		ID="Orange H3"
     fi
     if [ $HARDWARE = "sun4i" ] || [ $HARDWARE = "Allwinner" ]; then
+	if [ "$LEDS2" != "" ]; then
+		ID="Lime A10"
+	else
 		ID="Cubieboard"
 	fi
+    fi
     if [ $HARDWARE = "sun7i" ] || [ $HARDWARE = "Allwinner" ]; then
         # redistribute irq to dedicated core
 		if [ "$INTERUPT" != "" ] && [ "$CORES" -gt 1 ]; then
@@ -115,7 +121,7 @@
 if [[ $MACHINE == *M2* ]]; then ID="Banana M2"; fi
 echo -e "[\e[0;32m ok \x1B[0m] Starting ARM hardware info: $ID"
-echo $ID  >> /var/run/machine.id
+echo $ID  > /var/run/machine.id
 stop|reload|restart|force-reload|status)
 echo -e "[\e[0;32m ok \x1B[0m] Stopping ARM hardware info ..."
The second issue was an (compared to the A20) incredibly high temperature: 72,2.
I checked /etc/update-motd.d/30-sysinfo and found out that although it is commented as "only on A20", the a20-tp-hwmon reading
is available at the A10 lime, too. Whatever this value is, the correct temperature seems to be at i2c. I got a 37,8 there.
So I commented out the A20 temp reading, but this is surely just a quick hack...
--- 30-sysinfo.org	2016-02-11 23:58:47.000000000 +0100
+++ 30-sysinfo	2016-04-06 23:06:55.713259579 +0200
@@ -106,9 +106,9 @@
 fi
 # if we are reading from A20
-if [ -d "/sys/devices/platform/a20-tp-hwmon/" ]; then
-	board_temp=$(cat /sys/devices/platform/a20-tp-hwmon/temp1_input | awk '{printf("%d",$1/1000)}')
-fi
+#if [ -d "/sys/devices/platform/a20-tp-hwmon/" ]; then
+#	board_temp=$(cat /sys/devices/platform/a20-tp-hwmon/temp1_input | awk '{printf("%d",$1/1000)}')
+#fi
 # where it should be
 if [ -d "/sys/devices/virtual/thermal/thermal_zone0/" ]; then
Finally I want to send you a big thank you for providing armbian!
Bye,
wahlm
This auto detection is giving us headaches lately :) It's a dirty approach and gives incorrect results sometime. Since boards and board clones, which are almost impossible to distinguish, are piling up, we need to completely redesign this feature.
Thanks, twice  :P
I also have a Lime-A10, but reading from the I2C is also exactly 37,8 from my board, what ever I do. But the a20-tp-hwmon gives me a range between 63~66 depending if I press my thumb on the A10 CPU. Actualy it goes from 66 to 62 when it gets warmer :P.
I don't know if Igor can answer this, but the temperature problem is a A10/A20 problem in general isn't it?
regards
With I2C you might be able to readout the thermal sensor inside the AXP209 PMU (better choice). Regarding A10/A13/A20 SoCs the thermal sensor inside is there more by accident than by design, needs different calculations/curves/calibration, is known to be off and should not be trusted at all.
http://forum.armbian.com/index.php/topic/155-testers-wanted-sunxi-adjustments-for-rpi-monitor/?p=967  (see post #13 there)
These thermal readouts are for people that love staring at numbers without meaning :)
