Device: OrangePi PC Plus
OS: Debian 9.3 (stretch) armv71
In my sd card, i separated Debian partition into 2: root and home.
When i use nand-sata-install, it only transfers root to emmc.
How do i modify nand-sata-install so that it copies both partition into
emmc?
sdcard storage capacity = 8GB
sdcard lsblk:
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk0      179:0    0  7.4G  0 disk
├─mmcblk0p1  179:1    0    4G  0 part /
└─mmcblk0p2  179:2    0  3.4G  0 part /home
OrangePi emmc storage capacity = 8GB
emmc lsblk (after run nand-sata-install):
mmcblk1      179:0    0  7.3G  0 disk
└─mmcblk1p1  179:1    0  7.2G  0 part /
Hi!
Sorry to say this, but the "nand-stat-install" script is nuts.
I looked at it and would like to rewrite the script, but at the moment I'm trying to capture exactly what was done there.
I only have boards with SATA that I can test. And I do this in my limited free time.
My tip! If you want to change it in a running system, don't try the "nand-stat-install" script, do everything manually! This is the better and safer solution!
On 3/8/2019 at 8:26 PM, RSU said:
Hi!
ok. i will just run the script to separate partition after run nand-sata-install.
https://github.com/armbian/build/issues/1144
So far this https://github.com/armbian/build/issues/1279 is the only critical problem found that is not fixed yet. It is very unlikely to bump into it ...
