chris1h1 Posted March 18, 2019 Posted March 18, 2019 (edited) Ethernet was working fine for me, up until I rebooted the board. The LEDs on the ethernet port blink briefly during boot, but once booted they are off, and the board does not have an IP address. Via serial console I undid the change I made prior to the fateful reboot (adding 'overlays=uart1' to '/boot/armbianEnv.txt') and rebooted again, but to no avail. Having searched for the issue, I also confirmed that my power supply is sufficient; running 'stress -c 2 -m 2', and measuring across pins 2 (5V) and 6 (GND) of the 40-pin header, I get 5.05V. As I don't have a network connection, I did not run 'sudo armbianmonitor -u', but I gathered the following information: Boot info: U-Boot SPL 2018.11-armbian (Feb 08 2019 - 11:25:07 +0100) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2018.11-armbian (Feb 08 2019 - 11:25:07 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 230454 bytes read in 22 ms (10 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3798 bytes read in 12 ms (308.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 219 bytes read in 10 ms (20.5 KiB/s) 4950770 bytes read in 253 ms (18.7 MiB/s) 7323200 bytes read in 367 ms (19 MiB/s) Found mainline kernel configuration 29097 bytes read in 45 ms (630.9 KiB/s) 502 bytes read in 96 ms (4.9 KiB/s) Applying kernel provided DT overlay sun8i-h3-uart1.dtbo 4155 bytes read in 91 ms (43.9 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4950706 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. EHCI failed to shut down host controller. Loading Ramdisk to 49b47000, end 49fffab2 ... OK reserving fdt memory region: addr=43000000 size=6d000 Loading Device Tree to 49ad7000, end 49b46fff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Debian GNU/Linux 9 OrangePi-db-4e ttyS0 OrangePi-db-4e login: The result of 'uname -a': Linux OrangePi-db-4e 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l GNU/Linux The result of 'dmesg | grep eth': [ 0.000000] psci: probing for conduit method from DT. [ 1.879134] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 1.879173] dwmac-sun8i 1c30000.ethernet: No regulator found [ 1.879482] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) [ 1.879501] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported [ 1.879506] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported [ 1.879512] dwmac-sun8i 1c30000.ethernet: COE Type 2 [ 1.879517] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported [ 1.879523] dwmac-sun8i 1c30000.ethernet: Normal descriptors [ 1.879528] dwmac-sun8i 1c30000.ethernet: Chain mode enabled [ 1.880078] dwmac-sun8i 1c30000.ethernet: Found internal PHY node [ 1.880181] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY [ 1.880190] dwmac-sun8i 1c30000.ethernet: Powering internal PHY [ 9.498459] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 9.505005] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found [ 9.505022] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 9.505030] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 9.505503] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready The result of 'cat /etc/network/interfaces': # Network is managed by Network manager auto lo iface lo inet loopback I edited the above file to add 'auto eth0' and rebooted, but the result was the same; brief flashes of the ethernet LEDs, then nothing. Any hints or tips gratefully received. Thanks. EDIT: I booted with a freshly-flashed SD card, with the same result. So I assume this is physical damage, which is unfortunate. Edited March 18, 2019 by chris1h1
guidol Posted March 18, 2019 Posted March 18, 2019 Yot eth0 link isnt ready Do you use IPv4 or IPv6? My Orange Pi One with Welcome to ARMBIAN 5.77 user-built Debian GNU/Linux 9 (stretch) 5.0.1-sunxi package bsp-kernel[5.77] u-boot[5.77] dtb[5.77] firmware[5.77] config[5.77] is showing this in dmesg for eth0: root@opi-one(192.168.6.114):~# dmesg|grep eth0 [ 6.545262] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found [ 6.545278] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 6.545288] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 6.547210] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 6.547255] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready for dhcpv4 in /etc/network/interfaces you not only need auto eth0, but auto eth0 allow-hotplug eth0 iface eth0 inet dhcp for dhcpv6 auto eth0 allow-hotplug eth0 iface eth0 inet6 dhcp If you delete eth0 in /etc/network/interfaces, then you could try to configure eth0-connection via nmtui Keep in mind that the (v4) IP-adress does need a/24 at the end like 192.168.6.114/24 BUT only for the IP-address of your board - NOT Gateway, DNS
t-minik Posted March 20, 2019 Posted March 20, 2019 I had the same problem with opi pc+ and +2e with 4.19 kernel Try it with a 4.20 build. It worked for me.
