nananas Posted March 20, 2019 Posted March 20, 2019 Mornings all :) i was in china for a business trip and i bought 2 android box's called T1BOX , but when i returned to my country egypt i found that it's all with chinese firmware and i am unable to install google play or youtube or any app and cant go to developers mode and also cant root the box , i opened it and took a snap from he mother board as below , tried to reset the box with the reset button with no use as the power do not come up while pressing the button , i got a male to male usb cable and with phoneix i put a firmware but for sorry the box now dont want to power on , can any one support me with a firmware i can flash my box , if now i have another box how can i take the firmware from it and put it to the one i made a wrong firmware on , help is needed from you guys :) thanks in advance :) proccessor 8X ARM Cortex-A7 @ 1.01 GHZ GPU Mali-400 T1BOX ( Dolphin-FVd-p2) manufacturer Allwinner hardware sun 8i Board Exdroid root access No Java VM Dalvik1.6.0 Kernel armv7l kernel version 3.4.39 (20181217)
Tido Posted March 20, 2019 Posted March 20, 2019 Hi @nananas, In your subject you have the word 'urgent'. What exactly is urgent on your topic. And if you needed the box work immediately, wouldn't you have rather bought an Android-TV-Box in the shop around the corner?
nananas Posted March 20, 2019 Author Posted March 20, 2019 Hi tido, thanks for your reply for sorry dont have enough money to go and buy another android box from the shop around the corner and thinking of losing the box is driving me crazy thats why i said urgent for me it's a critical issue and would be pleased if you can support me
Igor Posted March 20, 2019 Posted March 20, 2019 On 3/20/2019 at 8:17 AM, nananas said: dont have enough money to go and buy another android box Expand We also don't have the money to sponsor support for yet another cheap chinese hardware. Hint: Just try a few images on the download section containing H3/H2+ chip. You might get lucky to boot Armbian with most of the things working.
Tido Posted March 20, 2019 Posted March 20, 2019 @nananas, if you want to have Armbian (Linux) on your box you can try this: https://forum.armbian.com/topic/5268-armbian-on-sunvell-r69-allwinner-h2/ If you would like to find a solution for Android go and search in this forum: https://forum.freaktab.com/forum/tv-player-support/allwinner-tv-players
nananas Posted March 20, 2019 Author Posted March 20, 2019 Dear Tido thanks alot for your support , i discovered that my box do not have SD or TFT card slot to burn the rom and tried to do so with normal USB but i failed , can you provide me with a way to burn the rom via windows or usb , regarding the android forum thanks alot i will search and try my luck again thanks for your support
Igor Posted March 20, 2019 Posted March 20, 2019 On 3/20/2019 at 10:35 AM, nananas said: do not have SD Expand OMG. Now this will be much more complicated ... You can try this: https://github.com/zador-blood-stained/fel-mass-storage
nananas Posted March 21, 2019 Author Posted March 21, 2019 i tried the steps but now after changing the usb driver by zadig it didn't work and also the box do not accept any android rom by phenix
jikkeheiden Posted August 15, 2019 Posted August 15, 2019 hi you, let try to install it from another store (apknite, apkpure,...) or hcange your IP to China
sfx2000 Posted August 25, 2019 Posted August 25, 2019 On 3/20/2019 at 10:14 AM, Tido said: if you want to have Armbian (Linux) on your box you can try this: https://forum.armbian.com/topic/5268-armbian-on-sunvell-r69-allwinner-h2/ If you would like to find a solution for Android go and search in this forum: https://forum.freaktab.com/forum/tv-player-support/allwinner-tv-players Expand yep - this board does seem to be similar to the Sunvell board - straight NAND there, so need to build a flash filesystem on it... One might hope -- http://linux-sunxi.org/FEL/USBBoot On the board - one would want to sort out the UART headers - seems there is a socket, so one should use a scope to sort them - then console output there would be quite helpful...
