rodolfo Posted May 31, 2016 Posted May 31, 2016 Added and it works, thanks Jernej. I also pushed to repository that you can test: apt-get update && apt-get upgrade @Jernej and @Igor Thank you, the solution works for OPI LITE. @Igor - Please disable gmac in orangepilite.fex as it creates non-existing eth0 interface [gmac0] gmac_used = 0 gmac_power1 = - enable 8189fs in /etc/modules-load.d/modules.conf #-------------- working internal wifi 8189fs WIFI is stable, Iperf shows similar performance to USB-dongles on OPI LITE/ONE ( 75 mbps ) in noisy environment.
tkaiser Posted May 31, 2016 Posted May 31, 2016 enable 8189fs in /etc/modules-load.d/modules.conf This has already been done in board.conf so on existing images this step has to be done by hand I would assume. Disabling eth0 is a good idea (@Igor: I'll send a PR later regarding firstrun since some things might now not work any more, can then adjust the fex file too if you want). @rodolfo: Could you have a look regarding AP and monitoring mode as asked/outlined (by jernej) here: http://forum.armbian.com/index.php/topic/942-rebuild-rtl8189es-from-git-for-opi/?view=getlastpost ?
rodolfo Posted May 31, 2016 Posted May 31, 2016 @tkaiser, @igor, @jernej AP (master) mode and monitor mode both work Working tested AP mode sudo nano /etc/default/hostapd-------------------------------- DAEMON_CONF="/etc/hostapd.conf"-------------------------------- sudo nano /etc/hostapd.conf------------------------------------------------------- ssid=xx_opilite1_xxinterface=wlan0hw_mode=gchannel=5driver=nl80211logger_syslog=0logger_syslog_level=0wmm_enabled=1ieee80211n=1wpa=3preamble=1#wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27wpa_passphrase='12345678'wpa_key_mgmt=WPA-PSKwpa_pairwise=TKIPrsn_pairwise=CCMPauth_algs=1macaddr_acl=0noscan=1#ht_capab=[HT40-][sHORT-GI-40][sHORT-GI-40][DSSS_CCK-40]country_code=CH#ieee80211d=1-------------------------------- sudo nano /etc/network/interfaces-------------------------------- allow-hotplug wlan0 iface wlan0 inet static address 192.168.4.171 netmask 255.255.255.0 network 192.168.4.0-------------------------------- Testing monitor mode A new virtual interface needs to be created for monitor mode sudo iw phy phy0 interface add wlan1 type monitor sudo ifconfig wlan1 192.168.5.171 sudo iwlist wlan1 scan ( ---> list of scanned SSIDs, just to show interface is up ) enjoy 1
rodolfo Posted May 31, 2016 Posted May 31, 2016 @igor The MAC still seems to be newly created on each restart and udev-rules force a change in interface name ( wlan1 instead of wlan0 ) Quick and dirty workaround : sudo rm /etc/udev/rules.d/70-persistent-net.rules sudo echo # >/etc/udev/rules.d/75-persistent-net-generator.rules
jernej Posted May 31, 2016 Posted May 31, 2016 Now for 8189es - is it best to use this source - with config change of course You can't. Driver has some generic code but chip dependant code is only for 8189fs. AFAIK, 8189es driver, which you added today, is the latest one. 2
LycanthroLabs Posted June 1, 2016 Posted June 1, 2016 What an amazing team! Thank all of you so much for all the work... I did a fresh install on one of my OPi Lites and wireless is up and running in no time - and it works pretty damn good, much better than a RPi3 sitting in the exact same spot on my bench! 1
paketecuento Posted August 11, 2016 Posted August 11, 2016 I have OPI lite wifi. I flashes with last image 5.14 and can only get wifi using no authentication method. No WEP, no WPA. I tried differents images but no luck. I tested server and desktop version with same result: can only be associated when the router has no encryption at all, i.e. open wifi. My OPI show rtl8189fs driver. regards,
Igor Posted August 11, 2016 Posted August 11, 2016 I have OPI lite wifi. I flashes with last image 5.14 and can only get wifi using no authentication method. No WEP, no WPA. I tried differents images but no luck. I tested server and desktop version with same result: can only be associated when the router has no encryption at all, i.e. open wifi. My OPI show rtl8189fs driver. regards, It connects to WPA for sure. I don't have any other network and it connects fine. If you are using WICD, make sure you change: wpa_driver = none in settings. We are working on to change network manager.
paketecuento Posted August 11, 2016 Posted August 11, 2016 As stated by http://forum.armbian.com/index.php/topic/1713-solved-opi-lite-wifi-cannot-connect-to-wpa/?p=13268, it is solved by changing Wext to nl80211!!!
paketecuento Posted August 11, 2016 Posted August 11, 2016 It connects to WPA for sure. I don't have any other network and it connects fine. If you are using WICD, make sure you change: wpa_driver = none in settings. We are working on to change network manager. Thank you for your answer, also "none" did the job. regards, 1
rift Posted August 14, 2016 Posted August 14, 2016 hi. I have a similar problem I have OPI lite wifi. I flashes with last image 5.14 and can only get wifi using no authentication method. No WEP, no WPA. I tried differents images but no luck. I tested server and desktop version with same result: can only be associated when the router has no encryption at all, i.e. open wifi. My OPI show rtl8189fs driver. with wifi on OPI Lite. the device sees the SSID, but cannot connect to the router. by trial and error found that by substituting in the settings of Wicd WPA suplicant driwer = none working network connection wpa-psk only encryption method WPA. network connection with WPA2 encryption, or no encryption ends with the message "bad password". is [Armbian_5.14_Orangepilite_Debian_jessie_3.4.112_desktop] , string [wpa_driver = none] the config Wicd is already there. with android image i can connect to same router (wpa2-psk) with no problem.
PiR Posted October 28, 2016 Posted October 28, 2016 Hi All. I confirm that hostapd master work with internal wifi of Orangepi Lite and rodolfo configuration. Just a point of attention if you want try with 12345678 password you need to put : wpa_passphrase=12345678 in place of wpa_passphrase='12345678' If not you will lose many time to undestand why it doesn't works
rajprakash Posted November 11, 2016 Posted November 11, 2016 Can anyone comment on the range of an OPi Lite with the onboard wireless in Access Point mode? Some of the small external-antenna-less RTL8188CUS chipset USB WiFi adapaters only have a 10-20 meter range for acceptable speeds. Since the OPi Lite has the physical external antenna, has anyone done any tests on throughput at various distances on the Lite (barring excessive interferenence or excessive number of obstacles)?
ChAoSWK Posted November 19, 2016 Posted November 19, 2016 Hello @ll, i am now trying to get this 8189ftv to work in hostapd with 150mbps brutto. Did anyone of you get this device to worj with that speed? According to my other post here in the forum i am only getting 72.2 mbps even with a patched hostapd version where the neighbor scan is disabled. In this case the opi tells me that hostapd is running with 150mbps but clients are also only connecting with 72.2mbps. my question to you guys also did these tests: did anyone get more speed than 72.2 mbps in brutto? The range is also not really good with the standard antenna. Only getting 6mbps brutto after 2 walls indoor and 10 meters distance. This belongs to the orange pi pc plus, but it is using the same 8189ftv. THX
txumino Posted January 24, 2017 Posted January 24, 2017 Update:I bought another Orange Pi Plus 2E and it works perfectly the wifi, the other one that I have and for which I opened this post is defective.
