  2. thnx. it seems latest working vendor kernel for 3566 is 6.1.115. i already tried rk35xx, with bigtreetech_cb2.dtb but it stops at u-boot (in uart console) using orangepi-3b it boots, but gives errors in dmesg. when i try to add fdtfile bigtreetech_cb2.dtb, it stops boot .... 47274496 bytes read in 3902 ms (11.6 MiB/s) Failed to load '/boot/dtb/rockchip/rk3566-bigtreetech-cb2.dtb' libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' ..... but when i boot btt_cb2 as orangepi3b board, it boots and even shows mpp venc/dec/npu/whatever modules properly loaded. not checked yet if it works really maybe need to make some hybrid dtb from btt_cb2 and orange3b ========= btw, could You share what You do for 35xx board change? when i tried to change family rockchip64 to 35xx, it comiled, but not copied bigtreeetech_cb2.dtb to boot , and not boots ewven if i copy it by myself there
  3. You can try switching the BOARDFAMILY to rk35xx and adding vendor branch to the list of build-able targets, but you will need a device tree that would work with the kernel. I did a quick try, and the device from the 6.6 folder doesn't "just work". Don't know if getting hardware acceleration to work on rk3566 would need even more tweaks.
  4. features i looking for is a MPP/NPU - quite decent video encoders/processing/npu engine support, unfortunateli it still sticks to vendor 6.1.y kernel.
  5. https://github.com/armbian/build/blob/main/config/boards/bigtreetech-cb2.conf#L8 Nope. We don't support vendor kernel for other then 3588 and more recent. We don't maintain vendor kernel for this hardware (nor any other 3566 AFAIK), so it might be some work and its all on you. Mainline support is very mature, however I don't know about the status of specific features you are interested in. IMO its not worth going vendor route on this hw.
  6. Igor
    Orange Pi CM4
    At this point, the most realistic path is to use hardware that is already officially supported. Bringing up new hardware or maintaining outdated vendor kernels requires significant engineering time and resources. Board enablement is not a small task. It involves ongoing maintenance, testing, integration work, and long-term support. This represents real cost for the project while public project funding is not even on the level to cover response of such ideas. If you are expecting someone will just emerge and spent months of his private time in exchange for: constant insults, hate and complete absence of financial coverage for the time spent (things are never in perfect state to satisfy over-spoiled customers of someone else) ... adjust expectations. We encourage users to choose hardware wisely - that already has active support and to contribute back to the project when possible. That is the only way we can avoid overextending limited resources, burnouts, collapse.
  7. Hi all i tried to compile BTT CB2 with bookworm and vendor kernel to get MPP and NPU working, but got that : sha256sum: config/kernel/linux-rockchip64-vendor.config: No such file or directory is it missed ? How to compile vendor kernel for MPP support? thanks
  8. Hello @Igor Yeah, I know that there is no simple way to achieve this. Hopefully someone will support this board or providing a newer kernel image, but as more time pass, as more difficult it become. Regards,
  9. Yesterday
  10. This Gdrive is empty now... Did we see any improvements for the Orange Pi 4A in the 26.2.1 release?
  11. That's strange 🙂 ...we have the same kernel. Maybe something's broken in the system? But I haven't messed with Bluetooth in the system. I've only updated the system: apt update /apt upgrade /reboot 🙂 root@orangepi3-lts:~# rfkill ID TYPE DEVICE SOFT HARD 0 bluetooth bluetooth unblocked unblocked 1 wlan phy0 unblocked unblocked .............................. bluetoothctl Waiting to connect to bluetoothd... it keeps reading but shows nothing? ................... bt-device -l ** ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self)) Bail out! ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self)) Aborted ............. Something must have broken in the system, but what and where? Can you give me the exact: Armbian image + version ... Contents of ..../lib/firmware/uwe5622/ also: armbianEnv.txt Output dmesg | grep -i uart i dmesg | grep -i bluetooth Maybe that will help me figure out where the errors are in my system? Or maybe I have Debian and you have Ubuntu? Ps. or, more simply, information from the file: diagnostics.txt command in terminal: ................. ( uname -a cat /etc/os-release ls -lh /lib/firmware/uwe5622/ lsmod | grep -iE "bt|sprd|uwe" dmesg | grep -i uart ls /dev/tty* | grep -i "ttyS\|ttyAMA\|ttyBT" cat /boot/armbianEnv.txt rfkill list hciconfig -a bluetoothctl list hcitool dev bt-device -l dmesg | grep -iE "bluetooth|uwe|sprd|hci" ) > diagnostics.txt .....................
  12. DKMS compilation per board, examples: https://github.com/armbian/build/blob/main/config/boards/radxa-cubie-a5e.csc#L20-L22 https://github.com/armbian/build/blob/main/config/boards/orangepirv2.wip#L13-L17 https://github.com/armbian/build/blob/main/extensions/radxa-aic8800.sh https://github.com/armbian/build/blob/main/extensions/bcmdhd-spacemit.sh
  13. @Issou thanks for the feedback, I eventually got my hands on the Orange Pi zro I had in a remote location, I will make a fresh install and see how it behaves.
  14. Testing the latest build: apt update && apt upgrade -y Hit:1 http://deb.debian.org/debian trixie InRelease Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB] Get:3 http://security.debian.org trixie-security InRelease [43.4 kB] Get:4 https://github.armbian.com/configng stable InRelease [5,467 B] Get:5 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB] Err:2 http://deb.debian.org/debian trixie-updates InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:41Z Verifying signature: Not live until 2026-03-02T13:39:55Z Err:3 http://security.debian.org trixie-security InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T02:15:55Z Verifying signature: Not live until 2026-03-02T02:15:55Z Err:4 https://github.armbian.com/configng stable InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T16:02:28Z Err:5 http://deb.debian.org/debian trixie-backports InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:27Z Verifying signature: Not live until 2026-03-02T13:39:49Z Get:6 http://fi.mirror.armbian.de/beta trixie InRelease [39.4 kB] Err:6 http://fi.mirror.armbian.de/beta trixie InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T08:25:38Z Fetched 190 kB in 1s (143 kB/s) All packages are up to date. Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://deb.debian.org/debian trixie-updates InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:41Z Verifying signature: Not live until 2026-03-02T13:39:55Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://security.debian.org trixie-security InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T02:15:55Z Verifying signature: Not live until 2026-03-02T02:15:55Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://github.armbian.com/configng stable InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T16:02:28Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://deb.debian.org/debian trixie-backports InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:27Z Verifying signature: Not live until 2026-03-02T13:39:49Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://fi.mirror.armbian.de/beta trixie InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T08:25:38Z Warning: Failed to fetch https://github.armbian.com/configng/dists/stable/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T16:02:28Z Warning: Failed to fetch http://beta.armbian.com/dists/trixie/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T08:25:38Z Warning: Failed to fetch http://deb.debian.org/debian/dists/trixie-updates/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:41Z Verifying signature: Not live until 2026-03-02T13:39:55Z Warning: Failed to fetch http://deb.debian.org/debian/dists/trixie-backports/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:27Z Verifying signature: Not live until 2026-03-02T13:39:49Z Warning: Failed to fetch http://security.debian.org/dists/trixie-security/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T02:15:55Z Verifying signature: Not live until 2026-03-02T02:15:55Z Warning: Some index files failed to download. They have been ignored, or old ones used instead. Summary: Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0 root@radxa-cubie-a5e:~# armbianmonitor -u Collecting info and sending to paste.armbian.com, wait... https://paste.armbian.com/zefutefuzi Please post the URL in the forum where you've been asked for. https://paste.armbian.com/zefutefuzi
  15. There aren't any Armbian builds for 5.15 is what I said. And it would be a lot of work to make that happen. Why do you want 5.15? How do you know that would work, when 6.12 doesn't?
  16. You can just download rock-3a edge(6.18+) images (not vendor 6.1) and change the device tree entry (sdcard/boot/armbianenv.txt) to point to "rockchip/rk3566-radxa-cm3-io.dtb" . This seems to boot fine with majority of features working.
  17. Get the recap of Nicolas Frattaroli's FOSDEM talk detailing Rockchip’s mainline progress, including Vulkan 1.4 and NPU support as a vital path to sustainable, affordable hardware. View the full article
  18. no , i ment , currently armbin version is 6.xx right ///// i want armbian 5.15 version to build to my stb
  19. @Werner Sorry for disturbing. I found that my board is actually 3 gb variant. Removed the heat sink. It is actually 3gb variant. The problem was hardware. We can close this topic.
  20. There are no Armbian builds that old, in fact Amlogic TV boxes weren't incorporated into Armbian until later Linux kernels. What you must have been using would most likely have been a fork of Armbian. What you are asking for isnt possible in the way you are asking. You essentially want Armbian ported to the 5.15 Linux kernels, which is a huge project. You would be better served but spending a month or so figuring out why current kernels don't work for you and fixing that.
  21. Hi all, I’m working with an Amlogic S805X (P241) board and I’d like to run Armbian on it, but I need a kernel 5.15 LTS build that boots reliably (especially from USB/SD). I see Armbian community builds with kernel 6.x for Amlogic TV boxes (e.g., Armbian_community_26.x), but these do not boot successfully on my P241. I previously successfully booted Armbian with kernel 5.9, but I want an image based on the 5.15 LTS kernel if possible. Is there an existing downloadable image for S805X/P241 with kernel 5.15? If not, can you share build parameters (BOARD=, BRANCH=, kernel target) to compile a minimal Armbian image with 5.15 that uses meson-gxl-s805x-p241.dtb? I also want to confirm the correct dtb file and boot configuration needed. Kernel 6.x gives me reserved-memory / CMA errors on S805X P241 and didnt boot Kernel 5.x booted , Is there any 5.15 LTS Armbian image, or how can I build one? Thanks!
  22. The Rock-s0 has the same rk3308b processor and the build uses a BL31binary, with u-boot. The SV06Ace has the same cpu and BL31/u-boot. I reviewed this thread and was trying to follow the example commit provided. It is a little difficult to work through a commit as not all of the paths to the files are present in my depth=1 git clone. Is it possible to download the commit for the Rock-s0 and use it to patch the build directory? If I could run the patch, then I would have some actual files to copy and edit. The maintainer of the Rock-s0, linked on the Armbian Info page for the s0 has not made any recent commits. The last Rock-s0 commit was where it was moved back to an older bootloader scheme. # Rockchip RK3308 quad core 512MB SoC WiFi BOARD_NAME="SV06 Ace" BOARD_VENDOR="sovol" BOARDFAMILY="rockchip64" BOARD_MAINTAINER="shep" BOOTCONFIG="sv06ace-rk3308_defconfig" BOOT_FDT_FILE="rockchip/sv06ace.dtb" KERNEL_TARGET="current" KERNEL_TEST_TARGET="current" DEFAULT_CONSOLE="serial" SERIALCON="ttyS0" MODULES_BLACKLIST="rockchipdrm analogix_dp dw_mipi_dsi dw_hdmi gpu_sched lima hantro_vpu panfrost" HAS_VIDEO_OUTPUT="no" BOOTBRANCH_BOARD="tag:v2024.10" BOOTPATCHDIR="v2024.10" BOOT_SCENARIO="binman" DDR_BLOB="rk33/rk3308_ddr_589MHz_uart0_m0_v2.07.bin" BL31_BLOB="rk33/rk3308_bl31_v2.26.elf" FORCE_UBOOT_UPDATE="yes" OVERLAY_PREFIX="rk3308" function post_family_config__rocks0() { declare -g BOOTDIR="u-boot-${BOARD}" declare -g BOOTSCRIPT="boot-rockchip64-ttyS0.cmd:boot.cmd" family_tweaks_bsp() { #overrides rockchip64_common.inc #Install udev script that derives fixed, unique MAC addresses for net interfaces #that are assigned random ones bsp=$SRC/packages/bsp/rockpis rules=etc/udev/rules.d Specifically, where are following files, referenced in /build/boards/*.csc located? BOOTCONFIG=*.defconfig" BOOT_FDT_FILE="*.dtb" The declared boot scripts Thanks
  23. What a nice picture! Would you be generous to post your NPU device info? I'm also looking for some w8a8 llm models working on NPU (the GEMM capability is perfect, isn't it).
  24. Last week
  25. I am not familiar with these images as I normally self build with the Armbian framework. A trade off of falling back to the old kernel, do you know the chipset of the WiFi dongle? I recall the old Realtek drivers being a complete pain Potentially as the USB iD pin is already exposed within the DTS, however the driver still currently ignores this. It is what requires the most work. The only thing I can think of that the dwc2 overlay initializes suxni-musb underneath along with setting some additional configurations. If you can find where it is actually stored on the image then we can see what pieces are missing then see if it is actually a driver issues or the DTS definitions have changed. Which version of Windows are you using? I can only guess that whatever windows components supporting g_mass_storage are legacy and being removed. Ryzer
  26. Welcome to Armbian! Documentation: https://docs.armbian.com | Community support: https://forum.armbian.com IP address: xx.x.x.xx Create root password: ***** Repeat root password: ***** Developer Preview Build This Armbian image was generated automatically for development and testing purpose. It may include unfinished features or unstable components. If you are not here to report issues or just test it, please do not use this image in production. Expect things to change — or even break — as improvements are made. Creating a new user account. Press <Ctrl-C> to abort Please provide a username (eg. your first name): Disabling user account creation procedure root@orangepi3-lts:~# rfkill ID TYPE DEVICE SOFT HARD 0 bluetooth bluetooth unblocked unblocked 1 wlan phy0 unblocked unblocked 2 bluetooth hci0 unblocked unblocked root@orangepi3-lts:~# bluetoothctl [NEW] Media /org/bluez/hci0 SupportedUUIDs: 0000110a-0000-1000-8000-00805f9b34fb SupportedUUIDs: 0000110b-0000-1000-8000-00805f9b34fb Agent registered [CHG] Controller 30:96:18:9E:A7:02 Pairable: yes hci0 new_settings: powered bondable ssp br/edr le secure-conn [bluetoothctl]> show Controller 30:96:18:9E:A7:02 (public) Manufacturer: 0x01ec (492) Version: 0x09 (9) Name: orangepi3-lts Alias: orangepi3-lts Class: 0x00400000 (4194304) Powered: yes PowerState: on Discoverable: no DiscoverableTimeout: 0x000000b4 (180) Pairable: yes UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb) UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb) UUID: SIM Access (0000112d-0000-1000-8000-00805f9b34fb) UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb) UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb) Modalias: usb:v1D6Bp0246d0554 Discovering: no Roles: central Roles: peripheral Advertising Features: ActiveInstances: 0x00 (0) SupportedInstances: 0x10 (16) SupportedIncludes: tx-power SupportedIncludes: appearance SupportedIncludes: local-name SupportedSecondaryChannels: 1M SupportedSecondaryChannels: 2M SupportedSecondaryChannels: Coded SupportedCapabilities.MinTxPower: 0xffffffec (-20) SupportedCapabilities.MaxTxPower: 0x0008 (8) SupportedCapabilities.MaxAdvLen: 0xfb (251) SupportedCapabilities.MaxScnRspLen: 0xfb (251) SupportedFeatures: CanSetTxPower SupportedFeatures: HardwareOffload [bluetoothctl]> exit root@orangepi3-lts:~# uname -a Linux orangepi3-lts 6.12.74-current-sunxi64 #6 SMP Thu Feb 19 15:29:56 UTC 2026 aarch64 GNU/Linux
  27. I'm not seeing any bluetooth error, are you? rfkill unblock all
