  2. Hello all, I am trying to host the rtsp server using gstreamer on armbian. everything is latest and updated. I found, bare rtsp server is taking 3-4% of cpu usage. when I add timestamp and text overlay, cpu goes 23-25%. I was checking if I can enable GPU support, here is output. My system is on NVME, and its working so not sure why error popped. I am connected to wifi, so again not sure why wifi drivers are having issues. however my board never shows it has gpu. can some one guide me ? I have 2 mp camera, not a huge load. again memory is 8GB but never used beyond 1GB, but CPU is most of the time on above 70% dmesg | grep -i error [ 10.423927] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found [ 10.423965] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found [ 11.550508] dw-pcie: probe of 3c0000000.pcie failed with error -22 [ 11.611235] rockchip-vop2 fe040000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found [ 11.613533] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found [ 11.616990] rockchip-drm display-subsystem: [drm] run display error_event monitor [ 12.251529] mali fde60000.gpu: error -ENXIO: IRQ JOB not found [ 12.251654] mali fde60000.gpu: error -ENXIO: IRQ MMU not found [ 12.251725] mali fde60000.gpu: error -ENXIO: IRQ GPU not found [ 12.251821] mali fde60000.gpu: Register map failed error = -5 [ 12.251912] mali: probe of fde60000.gpu failed with error -5 [ 12.257912] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found [ 19.231558] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.rockchip,rk3566-orangepi-3b.bin failed with error -2 Regards-
  3. Yesterday
  4. I was having some trouble with newer ili9488 LCD v2.1, and I didn't have ili9488 LCD v1.1, so I decided to experiment again with ili9341 LCD v1.2. I found that this DTS https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-204672 Doesn't work with the touch chip. By accident, I ran the ili9488 driver on this ili9341, and I saw garbled graphics... but the good news: touch was working. Something in the ili9488 DTS which doesn't work for the ili9488 LCD, works for ili9341. I found the difference was not in the ads7846 section, but in the spi speed for the ili9xxx part. I switched back to the ili9341 DTS (with adafruit driver), but changed the SPI speed from 24MHZ to 40MHz.... then the ili9341 DTS was working with graphics and touch again ALTHOUGH the graphics have some flashing pseudo-colors in some places. Maybe the 40MHZ is too much, but I re-gained touch. I will keep doing experiments.
  5. Images were tested. Do you perhaps use Etcher for flashing? And try minimal image. That might even work with Etcher.
  6. So I was able to reproduce the issue when trying to boot via NVMe after using armbian-config to switch from emmc. Using rkdeveloptool to flash the SPI with https://dl.radxa.com/rock5/sw/images/loader/rock-5b+/release/rock-5b+-spi-image-8ea7ee4-20240730.img (short guide in the spoiler) I was able to boot into the NVMe. Looking into fixing the broken SPI installation
  7. Hello, I try to use armbian image on SD card for my nanopi r6c, it is without emmc, can only boot with SD card. However, armbian can't boot correctly. It stop at pre-mount while booting up, please refer to attached screenshot. I tried the images that can download from armbian web site and build armbians image with my PC, none of them can work, all are same issue, but Dietpi image for r6c can boot successfully. Images tried, but not work: #download from armbian site Armbian_25.5.1_Nanopi-r6s_noble_vendor_6.1.115_gnome_desktop.img Armbian_25.5.1_Nanopi-r6s_bookworm_current_6.12.30_cinnamon-backported-mesa_desktop.img Armbian_25.5.1_Nanopi-r6s_noble_current_6.12.30_gnome_desktop.img Armbian_25.5.1_Nanopi-r6s_noble_current_6.12.30_kde-neon_desktop.img #build by compile.sh Armbian-unofficial_25.08.0-trunk_Nanopi-r6c_noble_current_6.12.33_gnome_desktop.img Armbian-unofficial_25.08.0-trunk_Nanopi-r6c_noble_edge_6.15.2_gnome_desktop.img Armbian-unofficial_25.08.0-trunk_Nanopi-r6c_bookworm_edge_6.15.2_cinnamon-backported-mesa_desktop.img Image can work: DietPi_NanoPiR6C-ARMv8-Bookworm.img Please help on this issue. Thanks.
  8. Check here https://github.com/armbian/community/releases/tag/25.5.0-trunk.256 or on a mirror with archive https://docs.armbian.com/Mirrors/#current-mirrors for what you are looking for. We're aware that some links are broken for yet to be determined reason.
  9. Hi, trying to download the latest images for amlogic-s9xx-tv-box and getting error 404 (except the last two files Plucky/Trixie at the very bottom of the page). Github seems to work fine. Firefox here, win7/win11. No problems with it aprox 2months back.. Any hint plz?
  10. I think using the ubuntu keyserver is good as well but that this is a 'small' issue, it is easy to miss a small thing in a project this huge consider the number of boards, kernels, and distributions (including the different releases). if this little thing breaks, we can fix in our installed os using these methods.
  11. A fix has been pushed. It will take up to a week until all new images have it.
  12. Hi everyone, I have wrong color in screen MPI3501 , when i test to output buffer to color red,green, blue, it seem like Red. —> blue Green —> red Blue. —> green Here is how i test (i need to stop lightdm service before this) (when boot the image should be orange not green) I am using display MPI3501 http://www.lcdwiki.com/3.5inch_RPi_Display which i heard that is a clone of waveshare 3,5 inch https://www.waveshare.com/3.5inch-RPi-LCD-C.htm I'm using Debian Bookworm. I know that it not the same as Armbian, but the config kinda the same. About driver for ili9486, here is the info To use this screen i create overlay-user. and and ili9486.dts. Here is the content of it and I add this overlay to /boot/orangepiEnv.txt Note that i think the field "bgr" and "init" not working, i try to change it to make bgr from 0x00 to 0x01, or send init different at 0x10000036 but nothing change. Also note that, i also try to cat raw data from /dev/fb0 and using ffmpeg --> It is true color Also here is the dmesg log Is anyone here familiar with this problem, or ever try to change bgr field of this ili9486 ? Best Regard !!
  13. I think this is @Igor's signing key aml-s9xx-box:~:# gpg --keyserver keyserver.ubuntu.com --recv-keys 93D6889F9F0E78D5 gpg: key 93D6889F9F0E78D5: 1 duplicate signature removed gpg: key 93D6889F9F0E78D5: public key "Igor Pecovnik <igor@armbian.com>" imported gpg: Total number processed: 1 gpg: imported: 1
  14. also getting this on latest community builds of aml-s9xx-box at https://www.armbian.com/amlogic-s9xx-tv-box/ e.g. https://dl.armbian.com/aml-s9xx-box/Bookworm_current_xfce ``` PRETTY_NAME="Armbian_community 25.8.0-trunk.90 bookworm" ``` wondering if something is broken or missing on the build
  15. this soldering is visionally not very attractive 😛 , but at lest the result is what counts 👍
  16. We don't deal with Android. Better check xda developers forums.
  17. Description As per title How Has This Been Tested? [ ] hasn't Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
  18. Description This is a draft/wip for adding https proxy caching. This is especially designed for machines hosting lots of github runners to reduce their bandwidth usage by sacrificing disk space. http caching has been merged already and only needed minor changes. Caching https however is way more complicated. Encryption needs to be broken and rewrapped and then obviously downloads will fail due to cert issues. Classic MITM. So a new certificate authority (CA) needs to be put in place to allow these "fake" certs. Why is this even necessary? Well one major part is downloads from upstream apt repositories. The other major part is downloading 3rd party repositories and artifacts from OCI/ORAS/whatever the correct name for that system is. They do not allow plain http downloads but redirect to https. So in order to cache these encryption must be broken on the fly. On custom runs this works already with the mentioned extension. However when the build framework is used within a GH Actions Runner environment it would need to detect this and enable the extension automatically. No clue how to do that or overall if it is worth diving even deeper into this topic. Therefore this RFC to collect feedback. Also lots of fail-safe checks are missing. Sometimes I had to mix run_host_command_logged and chroot_sdcard since pipes don't work using latter. Documentation summary for feature / change Yes, this would need documentation. How Has This Been Tested? [x] custom builds with ENABLE_EXTENSION [ ] Test B Checklist: [no idea] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
  19. Description as per title How Has This Been Tested? [x] build [ ] nope, no hw on hand right now Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
  20. Okay I will try that patch and the build switch that you mentioned. About the RAM: It is SKHynix 966.3MB(989480kB) https://linux-sunxi.org/File:A088_Board_Front_3.jpg I then tried an archived image for the cubieboard and so far no errors and runs quite stable: https://armbian.atomonetworks.com/archive/cubieboard/archive/ Is this a kernel issue then? Maybe I should compile with an older kernel. The stable one is 6.1.63 Thanks a lot for your continued support, Shivam
  21. Hi, Tried this Opi5-Plus with kernel-6.15.2-edge-rockchip64 but mpv doesn't seems to have vpu hardware acceleration Does this repository works on RK3588 - Orange Pi 5 Plus Debian Trixie with mainline kernel 6.15.2-edge-rockchip64?
  22. I think @amazingfate made a custom Chromium package at some point that included optimizations for rk35xx but no clue about its status. Might be even included in mesa-vpu extension? Firefox probably won't work since that would need adjustments as well and I think messing with browsers is a pita already. topics merged as duplicates.
  23. I don't know. I don't have this board nor is the Armbian team aware of its state since it is community supported. This looks like some upstream (Debian to say) uboot package which certainly does not support this board. IIRC u-boot versions for rk3588, depending on family are something like 2017.09 or 2024.01 (both vendor cases) and 2025.01 or .04 for current/edge.
  24. I installed 25.04 with kernel 6.1 on the orange pi 5 plus, then I installed vanilla gnome. Then I installed the GPU drivers & GStreamer, then I enabled the GPU in the Armbian config. This works great, hardware acceleration works on GNOME. However, chrome/firefox are both super laggy and do not have hardware acceleration. What are the proper steps to get hardware acceleration (browser & video player) on this platform? Yes I'm aware this is considered a developmental build, I'm just asking for general advice as I'm fairly new to the OPI5+ and don't know the general steps of doing so. Thanks!
  25. Last week
  26. Right, I was thinking what if you try forcing a different mirror via DOWNLOAD_MIRROR: https://docs.armbian.com/Developer-Guide_Build-Switches/#hidden-options-for-advanced-users-default-values-are-marked-bold I cant guarantee this will work though. While A2 cards offer better performance, they are not as well supported. That is still the case to the best of my knowledge. Right one of the caveats I did find with getting HDMI working was the likelihood of increased taints so I think this patch is also required: https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/commit/drivers/gpu/drm/sun4i/sun4i_hdmi_enc.c?h=v6.14.11&id=ae048fc4f96d716a2ef326bd6e894694057c078c It is a possibility that either the RAM could be faulty or just unstable and need fine tuning. The problem is that really old system images tend to be less picky about RAM issues and will still try to boot. Normally I would say try installing memtester but that seems to detect failures in the most recent kernel yet my 6.6 build found no memory issues. Besides the originally Android image, have you tested with one of the archived images? More importantly what exactly are the RAM chips used on the board? Can you confirm the actual RAM capacity? From my experience, my second pcduino2 board with the Skhynix RAM had these sorts of problems. Sorry I cant be of more help Ryzer
  27. So I kept trying to build inside VirtualBox and on my 3rd try I was able to get an image built (along with the patch that you shared). I tried that on the Class 10 card and got some "Bad Page Map in process xxx" errors, although it did boot and I was able to set it up. On running any command I keep getting these errors and most commands fail. Then I got an A2 card and tried the same image on that, with the same results. Towards the end it tries to turn HDMI on but fails because of said errors. I am attaching the terminal output from the A2 card run here: https://pastebin.com/7H70dUNN What do you think the errors are related to? The RAM? I want to mention that since I have the original Android image on the NAND, I can confirm that it runs okay. Thanks,' Shivam
