  2. @shexplorer here are the first 10MB of the internal emmc. Extracted with dd if=/dev/mmcblk1 count=10 bs=1M | gzip > x88pro13_first_10MB_of_mmcblk.gz. please unzip first. see also the solutuion of this page: x88pro13_first_10MB_of_mmcblk1.gz
  3. sven-ola
    I uploaded fresh images, that includes a trixie-edge-desktop-mate image I tested with my Hardware. Mate looks good and working, but switching between internal / HDMI audio needs some fiddling with the audio setting widget (may be a misunderstanding between pulseaudio and drivers). Changeing Sound-Pref:HW:profiles seems to do the trick. There is no chromium for RISCV, thus you need to install firefox-esr or netsurf-gtk manually. I think this is ready for primetime now, so I clicked on the "Pull-Request" button (see https://github.com/armbian/build/pull/9299). Got lots of auto email from the Github robots, will check tomorrow. LG // Sven-Ola
  5. Hello. Where can I get multitul for rk3528?
  6. @user03 Given that you now have a working uboot installed on the emmc, I'm 95% confident that following the standard instructions will let you move your SD card install to emmc. But there are no guarantees.
  7. @shexplorer I did something similar to a tv box i had around, not this model. Generally, the cpu comes with some sort of uboot. Written in firmware not mmc. The catch is that that uboot usually writes its persistent environment on the MMC. And most of the time its not even a file on a partition, like in (and this is an example) between bytes 2000 to 8000 of the mmc. This uboot is only visible via serial console. no hdmi output. (and its quite old) This uboot then attempts to chainload the mmc or usb uboot. And its at this phase you get image. So on my setup, i had CPU uboot but no environment (because i smashed it with my armbian image...), and that environment was needed to boot both mmc or usb. Using a serial port (and pressing control +c ) i was able to instruct uboot it to boot armbian on the usb drive. And i mean manually with command like fatload 0x1000000 usb0.1 linux.img. But every time i reloaded would go back to the endless loop. So the next step was to find a stock image of my device and dump it into the mmc, via usb booted linux. (i actually only copied like the 1st 10MB, only needed uboot env, not the chinese android) Please know that this is not the image you download from any manufacturer website, those are snap-in upgrades that only change part of the mmc, you need a image that someone extracted with dd command from the entire mmc. After that i swore to never touch that mmc again... Maybe this is your problem too Get a serial connected to your device and check if you can see the cpu level uboot. If it is the same issue, maybe someone here can give you the 1st 10MB of their device, if you create a new thread asking for it.
  8. @kingbecher This is now off topic for this thread, but you need to look at: https://www.armbian.com/amlogic-s9xx-tv-box
  9. This is not a place for Android ROMs, only armbian here.
  10. You can set conditions on which branch uses which uboot. Like this: https://github.com/armbian/build/blob/9aa6e1e29ec2d397bbe223bebaa93bd13ef79818/config/boards/orangepi5-max.csc#L21 If the BRANCH is edge, then use mainline uboot, specifically this tag.
  11. I am working on a new version of the Luckfox Core3566 Board and Patches, as well as adding the Orange PI CM4 board to Armbian. Both rely on the Rockchip RK3566. Luckfox Core3566 Starting with the Core3566: The current board is just the vendor u-boot and kernel. It lacks PCIe support, but surely it is helpful to be as near to manufacturer configuration in their patches. My board config on the other side is not supporting the vendor specific patches, but based on a clean u-boot v2025.10 and runs nicely with current and edge kernels and also runs smoothly with nvme storage. The luckfox-core3566 config is currently maintainerless, but maybe users would like to have this vendor kernel version. My question: 1) Would the Armbian rather like to replace the vendor board config with a more future proof board config like mine or 2) Keep both board versions ( like rename config/boards/luckfox-core3566.csc to config/boards/luckfox-core3566_vendor.csc ) and let my variant replace the config/boards/luckfox-core3566.csc as default? 3)rd option would be combine both configs, but I had struggle to do so, as my version is using a different u-boot, using a simplified partition setup etc. Orange Pi cm4 I created a new board configuration to let Orange PI CM4 to work with Armbian as well. It is pretty similar to the bigtreetech cb2, but it's ethernet wiring and pcie powering device config differs from latter. Is it okay to create a MR directly in Github or does it need alignment with Moderators first? Cheers, Daniel PS: Nice to have time to work on embedded arm systems again. I did work on the sunxi based cubieboard and cubietruck back in the days, but job, family and basically life pulled me away from it for such a long time.
  12. geev03
    🦀 Rust PiCalculator on Orange Pi RV2 (riscv64, Armbian Trixie) Compiled and ran a high-precision Pi calculator in Rust on my Orange Pi RV2 (K1X, 8-core @ 1.6 GHz) running Armbian-unofficial Trixie riscv64. The goal: test rustc performance and validate big-integer workloads on RISC-V. ✅ Environment OS: Armbian-unofficial 26.02.0-trunk (Debian Trixie) Kernel: Linux 6.18.5-edge-spacemit Rust: rustc 1.85.0, cargo 1.85.0 (built from source) Display: EZCAP28X @ 1920×1080 Memory: 3.7 GiB RAM, 1.3 GiB used Disk: ext4, 28.96 GiB total GPU: Mesa llvmpipe (LLVM 19.1.7) 🧮 Project: PiCalculator Rust implementation using rug (GMP-backed) to compute 1000 digits of π: rust use rug::{float::Constant, Float}; fn main() { let digits: usize = 1000; let bits: u32 = ((digits as f64) * 3.321928).ceil() as u32 + 10; let pi = Float::with_val(bits, Constant::Pi); let s = pi.to_string_radix(10, Some(digits)); println!("{s}"); } 🧩 Build Notes Needed libgmp-dev and m4 to compile rug cleanly. cargo build --release succeeded without patching. Output verified against known π digits. ⚖️ Performance Comparison Board CPU Time (ms) Real Time (ms) Pi 400 Faster (1.8 GHz, fewer cores) Lower latency RV2 (K1X) Slower per-core, but stable Good throughput Despite having 8 cores, the RV2’s in-order K1X is slower than the Pi 400’s Cortex-A72 for single-threaded math. Still, the build was smooth and the output correct — a great stress test for rustc on riscv64.
  13. Good afternoon. I have a Rockchip 3566 tablet.oscal pad 70 wifi Is it possible to install Armbian on it? I don't have a device tree (I couldn't find anything at all for the WiFi module except the test report), no drivers, nothing. I've found a related one (the letters at the end are slightly different), but there's a little information. The original Pineta B2 costs 159, plus shipping and taxes...that's 300. But the aforementioned one costs 100 and doesn't require taxes! That's what got me thinking. Prices are in dollars. The bootloader can apparently be unlocked with a simple command (according to Google Assistant!) I need the tablet for learning Linux and watching videos in the browser...will it handle it? Is this even possible for a beginner? Best regards and gratitude... I'm writing using Google Translate, so there may be some inaccuracies... I apologize for that! motherboard R863T-RK3566-DK-V1.0 wifi module wxt42j1001s I don't know what kind of touchscreen and display it has. Will I need to unlock the bootloader? I understand it's probably very difficult...isn't the processor too old for our times? Or is installing Armbian probably not an option, and shouldn't I waste my time on it and buy something else? Thanks from the bottom of my heart to everyone who responded.
  14. It looks like mksclient is python code can be patched. Sovol3D forum Enable LED light toggle in Mainsail I followed the steps and was able to get an LED toggle in Mainsail on my SV06 Ace I did loose the touchscreen control of the LED but that's acceptable. I only need the LED when using the Camera to check for Failed prints and previously left the LED on during printing. Now I can save a little electricity😀. To me this also has pertinent implications to the thread. mksclient must be a python blob that can runs on boot. If were willing to tolerate the "black box" close source nature of mksclient, a touch screen supporting build, targeting the OEM electronics, should be possible.
  15. @HarleyyyuAs I was typing that I tried another last-ditch kind of solution (because truly you shouldn't substitute device trees) and changed the armbianEnv.txt I added 'overlays=led-conf7' to the end of the file and added 'irqpoll' to the extraargs. I'm going to try huddling them all into a single .img and try to flash it to the onboard disk, thanks for your help, and wish me good luck.
  16. @jock your armbian build (Bookworm) plus my modified version of openauto works now, its done by using kmssink for drm overlay plane for video (Added to codebase) and RTAudio patched to use ALSA. Youtube: OpenAuto - RK322x Test run with Hardware Acceleration if you want to try it here's a prebuilt version of it, armhf compiled. Github: OpenAuto RK322x Armbian, openauto-rk322x-v1 i would love to make it run better on our hardware
  17. @Dangrain ohhh that makes sense now. If SD boot works, you can just clone the SD card into a raw .img. dd if=/dev/sdX of=working_sd.img bs=4M status=progress (assuming you use linux, ubuntu recommended. Also make sure to check your sdcard path) That image already contains the correct bootloader, partitions, and rootfs. Multitool should be able to flash it to eMCP directly.
  18. @HarleyyyuI just want to have a working OS on the eMCP instead of the SD, I've tried many pre built images already but none have worked even when messing with recommended overlays. Only after I've frankenstein'd It, did it work. That's the purpose.
  19. Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 3ec5de03c (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v1.6.1 15~60fps@720p box64 environment variables: FF13 Lightning Returns
  20. @Dangrain for you to be able to flash your "frankenstein'd Image" you need to combine those pieces into one, I don't know how you will do that though. Tell me, What's the purpose of your img? like what are you trying to achieve?
  21. Thanks Werner and Gaetano I fear DIY an image exceeds my skils 😉 I tried linux-headers-arm64. Result: kernel downgraded to 6.12 and wrong links in /boot: lrwxrwxrwx 1 root root 30 Dec 29 22:28 Image -> vmlinuz-6.18.2-current-meson64 lrwxrwxrwx 1 root root 27 Jan 23 13:27 uInitrd -> uInitrd-6.12.63+deb13-arm64 Corrected, built ZFS but at the end USB not working. It's not worth the hassle. I ended up installing Armbian_25.8.1_Odroidhc4_bookworm_current_6.12.41_minimal.img Everything seams OK, especially ZFS. Anyway, the link to Armbian_community_26.2.0-trunk.151_Odroidhc4_trixie_current_6.18.2_minimal.img is not there anymore 🙂 Thanks for your time. Chris
  22. Ok then i will try with S905W images. Does these boot of an sd card like on the H313 ones ?
  23. Hello, thk work fine on my X88 pro13 Here is : Armbian_community_26.2.0-trunk.332_Hinlink-ht2_noble_vendor_6.1.115_gnome_desktop.img Armbian_community_26.2.0-trunk.332_Hinlink-ht2_noble_vendor_6.1.115_gnome_desktop.img
  24. By any chance, could someone post a link to a working image for Cubox I? I'm trying to find any working Armbian build and there is nothing that works. Thanks!
  25. What model is your device? Got a photo?
  26. @robertojTheoretically it will, as H618 supports OpenGL and Vulkan. But do not expect the same performance as RK3588. This is off the topic here and you'd better ask someone who share the same chip with you.
