  2. I also saw that both apt and beta repo's do not contain recent rockchip64 kernels at the moment. There is only a recent generic arm64 one. So it is not only my rock3a, also my nanopi-r6c would be affected, but I use own/other/vendor kernels as well, so specific 6.18.8 is not an issue for me. I use extlinux or grub to select a certain kernel (6.19 flavor on nanopi-r6c for example). For my rock3a, I need vendor kernel, but if you use mainline based, you could use standard Debian backports kernel: https://packages.debian.org/trixie-backports/linux-image-arm64 You need to get the .dtb manually and I just assume most features are supported when the rock3a has mainline U-Boot in SPI. You need of course add that to sources.list and specifically select it. You could also use Armbian build framwork to build a 6.18.x yourself, you will also get a header files package then. For Debian14 I see there is: /usr/lib/linux-image-6.18.15+deb14-arm64/rockchip/rk3568-rock-3a.dtb But as indicated, this is total DIY, I have not tested it. I only know that on rock5b I could run standard distro since quite some months, but use 6.1.115 vendor one as I need all RK3588 HW to work.
  3. Ok, after doing more tests the issue was the boot switch on the board. It must be switched to boot from SD/eMMC and not SPI (BIOS). Then reboot works fine.
  4. ha extension is not a part of the framework. Copy from here https://github.com/armbian/os/tree/main/userpatches/extensions
  5. If you’re thinking about running Armbian on the OnePlus 8T, basic functionality like calls, SMS, and mobile data will really depend on how well the device drivers are supported in the current build. From what most community discussions suggest, Wi-Fi and some hardware features may work, but cellular, camera, and other components can still be hit-or-miss compared to more mature options like Sailfish OS or Ubuntu Touch on officially supported devices. It’s a good idea to check active developer threads and user reports before installing.
  6. sven-ola
    Hi @maxsub, two annotations. Firstly, it's not the Wifi driver but the firmware. Thus echo "options bcmdhd firmware_path=brcm/ nvram_path=brcm/" > /etc/modprobe.d/orangepirv2.conf will get you going. And secondly no, there is no GPU change currently. GPU not working in "current" but may work with dirty tricks using "legacy". That's why it may pay to do some maintenance on the ancient 6.6 kernel.
  7. Hello, I'm getting an error when building the kernel.
  8. Ah I didn't know about that. I just created a systemd service that runs cpupower at boot.
  9. ## Description After a fresh installation of Armbian for Rockchip64 (Rock 3A), the system ships with `linux-image-current-rockchip64` version **26.2.1** (kernel 6.18.8), but the corresponding `linux-headers-current-rockchip64` package for version 26.2.1 is **not available** in the public APT repositories. This prevents installation of kernel headers required for DKMS modules, out-of-tree drivers, or any kernel module compilation. ## Steps to Reproduce 1. Flash the latest Armbian image for `rock-3a` (branch: `current`) from the official download page. 2. Boot the device and connect to the network. 3. Run `apt update` with any standard mirror (e.g., `mirrors.tuna.tsinghua.edu.cn`, `mirror.yandex.ru`). 4. Check installed kernel version: ```bash uname -r # Output: 6.18.8-current-rockchip64 ``` 5. Check available headers: ```bash apt policy linux-headers-current-rockchip64 ``` ## Actual Behavior - Installed image packages: ``` linux-image-current-rockchip64 26.2.1 [installed,local] linux-dtb-current-rockchip64 26.2.1 [installed,local] armbian-bsp-cli-rock-3a-current 26.2.1 [installed] ``` - `apt policy` output for headers: ``` linux-headers-current-rockchip64: Installed: (none) Candidate: 25.11.2 Version table: 25.11.2 500 500 http://<mirror>/armbian noble/main arm64 Packages ... (no 26.2.1 available) ``` ## Expected Behavior - The `linux-headers-current-rockchip64` package version **26.2.1** should be available in the `current` branch repository, matching the kernel shipped in the image. - Alternatively, the image should ship with packages that are already published and synchronized in the public repository. ## Impact - Users cannot install DKMS modules (ZFS, VirtualBox, WiFi drivers, etc.). - Development workflows requiring kernel headers are blocked. - Confusion for users performing a "clean install" who expect a consistent system. ## System Information - **Board:** Radxa Rock 3A - **Armbian version:** 26.2.1 (from image filename/release) - **Kernel:** 6.18.8-current-rockchip64 - **APT branch:** `current` - **Distribution:** Ubuntu Noble (24.04) - **Mirrors tested:** - `http://mirrors.tuna.tsinghua.edu.cn/armbian` - `http://mirror.yandex.ru/mirrors/armbian/apt` - `http://apt.armbian.com` (redirector) ## Possible Causes (hypothesis) 1. **Publishing race condition:** The image was built after `linux-image-26.2.1` was compiled but before `linux-headers-26.2.1` was published to the public repository. 2. **Branch mislabeling:** Version 26.2.1 may have been moved to `edge` after the image was built, but the image metadata was not updated. 3. **Mirror sync delay:** The master repository has the package, but mirrors have not yet synchronized (though multiple mirrors were tested over several days).
  10. Hi, sorry to interrupt, but could you tell me how to do hardware acceleration? I have an Allwinner H313 v5.1
  11. Yesterday
  12. Read post on October 27 2024 Worked for me but with a couple extra steps burn .iso cfcard boot into device dd mmblk to nvme edit UUID for nvme -- Request new UUID for NVME (when dd I had the same UUID for cf card and nvme) edit orangpiEnv.txt in the armbian-config /System/Kernel/Edit Boot Env and apply the new UUID to the rootdev="New UUID" Edit fstab to add this line: /dev/mmcblk1p1 /boot vfat defaults 0 2 itd
  13. maxsub
    Excellent. Thank you so much. I will try the newer brcm driver today. So the GPU change is now in main?
  14. Note that I believe Armbian will reset the max CPU frequency on boot. There is code in /usr/lib/armbian/armbian-hardware-optimization that uses the values defined in /etc/default/cpufrequtils to initialize the governor, min and max frequencies at boot time. So even though cpufrequtils is no longer an installed set of tools, Armbian is still doing some of the same work based on its old configuration files. So assuming this works as it used to, all you should need to do is set the max speed you want in /etc/default/cpufrequtils
  15. sven-ola
    Status Update: There is already a suitable FW file for Wifi AP mode. It's located in the /lib/firmware/brcm subdir: the newer fw_bcm43456c5_ag.bin can be used by adding firmware_path=brcm/ nvram_path=brcm/ when loading the bcmdhd.ko kernel module. The necessary change is now in Armbian::main. Also, the RV2 legacy 6.6.99 kernel has an advantage: with the Xunlong Ubuntu userspace (from Xunlong image downloads) it supports Wayland and thus GPU when applying the following hack: diff --git a/drivers/gpu/drm/spacemit/spacemit_drm.c b/drivers/gpu/drm/spacemit/spacemit_drm.c index da25ec8b3f..073de3c7ca 100644 --- a/drivers/gpu/drm/spacemit/spacemit_drm.c +++ b/drivers/gpu/drm/spacemit/spacemit_drm.c @@ -23,7 +23,7 @@ #include "spacemit_dmmu.h" #include "spacemit_gem.h" -#define DRIVER_NAME "spacemit" +#define DRIVER_NAME "rvdisplay" #define DRIVER_DESC "Spacemit SoCs' DRM Driver" #define DRIVER_DATE "20231115" #define DRIVER_MAJOR 1 For that reason, we added the LOAD fix also to the legacy/6.6 kernel (thus the uptime output shows a reassuring 0.00). Wayland support for current/6.18 kernel is still under investigation. Also, the edge/7.0 kernel does not boot on the RV2 currently.
  16. Bug Description eMMC is not detected on Radxa Zero 3W when booting Armbian Trixie from SD card. The eMMC controller initializes but fails to find power supply regulators, resulting in no block device being created. Hardware Board: Radxa Zero 3W (4GB RAM / 8GB eMMC) Boot media: SD card Image Armbian Trixie (current kernel) for Radxa Zero 3 DTB: rk3566-radxa-zero3.dtb Symptoms WiFi and SD card work fine eMMC does not appear in lsblk dmesg shows the SDHCI controller at fe310000.mmc loading but failing regulator lookups: sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA No mmcblk0 device is created. Only the SD card (mmcblk1) appears. Expected Behavior eMMC should appear as /dev/mmcblk0 in lsblk. Notes The DTB (rk3566-radxa-zero3.dtb) appears to be missing vmmc-supply and vqmmc-supply regulator definitions for the eMMC node (/mmc@fe310000) A rk3566-radxa-zero-3w.dtb (with proper 3W-specific regulators) does not exist in the image — only rk3566-radxa-zero3.dtb and rk3566-radxa-zero3-ap6212.dtb are present Related: #8776 (wrong DTB filename for Zero 3W) This causes me to not be able to install to EMMC using armbian-install
  17. Issues for the actual image (no UI): no HDMI; Ethernet got address with DHCP, but cannot connect with SSH, even ping (ICMP) is not stable. Wifi works fine. The board is OK - tested with official debian image.
  18. using cpupower to limit the max cpiu frequency to 1.61Ghz fixed the thermal issues. Default was 1.8Ghz. I'll might even reduce the max to 1.42, because USB hard disk mount drops when CPU usage is too high.
  19. I suggest to get a better heatsink and/or thermal paste/glue. Next I would at the device tree if there are thermal points defined. Perhaps they are missing. You can use the dtc tool to decompile the device tree from /boot. Output values might be in hex instead of decimal, so just in case you wonder.
  20. I have a RK3588 (Radxa Rock 5C) system running Armbian Debian Trixie. I have the heatsink and the fan installed as well. I set the fan PWM to 255 as soon as temperature reaches 50 degrees via a systemd service. When using all 8 cores, the system overheats (>110 degrees) and eventually shuts down. For example, when compiling ffmpeg, it works fine with 'make -j6', but 'make -j8' results in a shutdown before compilation is complete. Likewise I had thermal issues when using llama.cpp. Shouldn't the OS throttle the CPU when temperature reaches high levels? I think that is not happening at the moment. Online search referred me to cpufrequtils to set a conservative governor, but it looks like cpufrequtils does not exist for Trixie. Any suggestions on how I should approach this?
  21. i also added a hp now: https://langerma.github.io/dumpstore/
  22. I am extremely excited! This really worked! Successfully booted into the system from NVMe! Thx!!!! 😘😘
  23. UPDATE I was able to figure out what was happening. The board initially boots with the LEDs enabled. Because of this, applying the device tree overlay alone did not seem to disable them, even across reboots. However, after manually turning the LEDs off once using: echo 0 | tee /sys/class/leds/blue_led/brightness echo 0 | tee /sys/class/leds/green_led/brightness and then enabling the overlay, the LEDs remained disabled, and the overlay appeared to work as expected. So it seems the LEDs needed to be turned off once manually before the overlay behaviour became consistent. Everything now works as intended. It appears that when overlay_prefix is either not defined or is empty, the system behaves unexpectedly during overlay lookup. In such cases, the loader seems to attempt resolving overlays starting with -, rather than correctly resolving the overlay name.
  24. Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-pro-disable-leds.dtbo Meaning the overlay was applied successful. If it does not work, perhaps this means some pin definitions or whatever differ from opi sources vs ours.
  25. Related to Again, you are using the wrong image. You cannot assume an image for the opi5+ works for the opi5b. Those are different boards.
  26. Dear team, On Armbian_25.11.1_Orangepi5-plus_trixie_vendor_6.1.115_minimal.img not possible to boot completely kernel, sytem reboot in infinie loop Bellow is the debug log on tty DDR V1.13 25cee80c4f cym 23/08/11-09:31:58 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB Manufacturer ID:0xff CH0 RX Vref:28.9%, TX Vref:22.8%,21.8% CH1 RX Vref:27.1%, TX Vref:21.8%,20.8% CH2 RX Vref:27.9%, TX Vref:21.8%,22.8% CH3 RX Vref:28.9%, TX Vref:20.8%,20.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Nov 15 2023 - 16:53:25) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(d41c62e80b...) + OK ## Checking fdt 0x00355940 ... sha256(7146109403...) + OK ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 741.571 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 usb dr_mode not found usb dr_mode not found U-Boot 2017.09_armbian-2017.09-S3f41-Pdfdd-H6539-Ve691-Bbf55-R448a (Nov 19 2025 - 17:07:00 +0000) Model: Orange Pi 5 Plus MPIDR: 0x0 PreSerial: 2, raw, 0xfeb50000 DRAM: 31.7 GiB Sysmem: init Relocation Offset: eda09000 Relocation fdt: eb9f7610 - eb9fecd0 CR: M/C/I usb dr_mode not found usb dr_mode not found Using default environment DM: v2 RESC: No bootdev Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Orange Pi 5 Plus [Vendor ERROR]:Invalid boot device type(0) ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 [Vendor ERROR]:Invalid boot device type(0) rockchip_set_ethaddr: vendor_storage_write failed -19 [Vendor ERROR]:Invalid boot device type(0) mmc@fe2c0000: 1, mmc@fe2e0000: 0 Card did not respond to voltage select! mmc_init: -95, time 14 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 No bootdev dev_desc is NULL! boot mode: None No bootdev CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz MMC1: Legacy, 52Mhz PartType: EFI No bootdev dev_desc is NULL! No bootdev Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 Bus usb@fc400000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc800000 for devices... 1 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning bus usb@fc400000 for devices... cannot reset port 1!? 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Could not find misc partition ANDROID: reboot reason: "(none)" Not AVB images, AVB skip android_image_load_by_partname: Can't find part: boot Android image load failed Android boot failed, error -1. Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 4149 bytes read in 24 ms (168 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 200 bytes read in 23 ms (7.8 KiB/s) 14756344 bytes read in 1221 ms (11.5 MiB/s) 48886272 bytes read in 3964 ms (11.8 MiB/s) 278734 bytes read in 249 ms (1.1 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14756280 Bytes = 14.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=aa000 Using Device Tree in place at 0000000008300000, end 00000000083acfff ## reserved-memory: cma: addr=10000000 size=10000000 ramoops@110000: addr=110000 size=e0000 Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x400000000 - 0x800000000 (size: 0x400000000) Total: 14513.438/14546.469 ms Starting kernel ... [ 14.549838] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 14.549866] Linux version 6.1.115-vendor-rk35xx (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Fri Nov 21 14:02:48 UTC 2025 [ 14.557926] Machine model: Orange Pi 5 Plus [ 14.558092] efi: UEFI not found. [ 14.561609] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB [ 14.561630] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB [ 14.561723] Reserved memory: bypass cma node, using cmdline CMA params instead [ 14.561729] OF: reserved mem: node cma compatible matching fail [ 15.092501] Zone ranges: [ 15.092509] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 15.092521] DMA32 empty [ 15.092526] Normal [mem 0x0000000100000000-0x00000007ffffffff] [ 15.092533] Movable zone start for each node [ 15.092535] Early memory node ranges [ 15.092537] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 15.092546] node 0: [mem 0x0000000100000000-0x00000003fbffffff] [ 15.092555] node 0: [mem 0x00000003fc500000-0x00000003ffefffff] [ 15.092560] node 0: [mem 0x0000000400000000-0x00000007ffffffff] [ 15.092571] Initmem setup node 0 [mem 0x0000000000200000-0x00000007ffffffff] [ 15.112932] On node 0, zone DMA: 512 pages in unavailable ranges [ 15.178027] On node 0, zone Normal: 1280 pages in unavailable ranges [ 15.264742] On node 0, zone Normal: 256 pages in unavailable ranges [ 15.264773] cma: Reserved 256 MiB at 0x00000000e0000000 [ 15.264968] psci: probing for conduit method from DT. [ 15.264977] psci: PSCIv1.1 detected in firmware. [ 15.264982] psci: Using standard PSCI v0.2 function IDs [ 15.264987] psci: MIGRATE_INFO_TYPE not supported. [ 15.265029] psci: SMC Calling Convention v1.2 [ 15.265418] percpu: Embedded 30 pages/cpu s82728 r8192 d31960 u122880 [ 15.265623] Detected VIPT I-cache on CPU0 [ 15.265675] CPU features: detected: GIC system register CPU interface [ 15.265680] CPU features: detected: Virtualization Host Extensions [ 15.265695] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 15.265699] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 15.265705] alternatives: applying boot alternatives [ 15.266244] Built 1 zonelists, mobility grouping on. Total pages: 8190984 [ 15.266258] Kernel command line: root=UUID=21f59e6d-0e11-4ba2-85d3-e5fab5604f14 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 usb-storage.quirks= cma=256M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=bl31-v1.48,uboot-rmbian-201-11/19/2025 [ 15.266782] Unknown kernel command line parameters "splash=verbose ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 15.269843] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear) [ 15.271375] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 15.271384] mem auto-init: stack:off, heap alloc:off, heap free:off [ 15.271390] software IO TLB: area num 8. [ 15.283936] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [ 15.542056] Memory: 32255616K/33284096K available (19072K kernel code, 4028K rwdata, 16148K rodata, 8320K init, 700K bss, 766336K reserved, 262144K cma-reserved) [ 15.542219] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 15.542258] ftrace: allocating 72100 entries in 282 pages [ 15.670937] ftrace: allocated 282 pages with 4 groups [ 15.671046] trace event string verifier disabled [ 15.671273] rcu: Hierarchical RCU implementation. [ 15.671278] rcu: RCU event tracing is enabled. [ 15.671282] Rude variant of Tasks RCU enabled. [ 15.671285] Tracing variant of Tasks RCU enabled. [ 15.671288] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 15.689264] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 15.692345] GICv3: GIC: Using split EOI/Deactivate mode [ 15.692350] GICv3: 480 SPIs implemented [ 15.692355] GICv3: 0 Extended SPIs implemented [ 15.692386] Root IRQ handler: gic_handle_irq [ 15.692402] GICv3: GICv3 features: 16 PPIs [ 15.692445] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 15.692832] ITS [mem 0xfe640000-0xfe65ffff] [ 15.692889] ITS@0x00000000fe640000: allocated 8192 Devices @100170000 (indirect, esz 8, psz 64K, shr 0) [ 15.692921] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100180000 (flat, esz 2, psz 64K, shr 0) [ 15.692937] ITS: using cache flushing for cmd queue [ 15.692973] ITS [mem 0xfe660000-0xfe67ffff] [ 15.693021] ITS@0x00000000fe660000: allocated 8192 Devices @1001a0000 (indirect, esz 8, psz 64K, shr 0) [ 15.693051] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1001b0000 (flat, esz 2, psz 64K, shr 0) [ 15.693066] ITS: using cache flushing for cmd queue [ 15.693320] GICv3: using LPI property table @0x00000001001c0000 [ 15.693452] GIC: using cache flushing for LPI property table [ 15.693461] GICv3: CPU0: using allocated LPI pending table @0x00000001001d0000 [ 15.693519] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 15.852397] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 15.852409] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 15.852420] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 15.853909] Console: colour dummy device 80x25 [ 15.854617] printk: console [tty1] enabled [ 15.854661] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 15.854686] pid_max: default: 32768 minimum: 301 [ 15.854763] LSM: Security Framework initializing [ 15.854894] AppArmor: AppArmor initialized [ 15.855036] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.855112] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.857168] cblist_init_generic: Setting adjustable number of callback queues. [ 15.857191] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.857309] cblist_init_generic: Setting adjustable number of callback queues. [ 15.857329] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.857568] rcu: Hierarchical SRCU implementation. [ 15.857584] rcu: Max phase no-delay instances is 1000. [ 15.859156] Platform MSI: msi-controller@fe640000 domain created [ 15.859188] Platform MSI: msi-controller@fe660000 domain created [ 15.859624] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 15.859665] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 15.859918] EFI services will not be available. [ 15.860378] smp: Bringing up secondary CPUs ... [ 15.861025] Detected VIPT I-cache on CPU1 [ 15.861121] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 15.861144] GICv3: CPU1: using allocated LPI pending table @0x00000001001e0000 [ 15.861186] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 15.861927] Detected VIPT I-cache on CPU2 [ 15.862021] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 15.862044] GICv3: CPU2: using allocated LPI pending table @0x00000001001f0000 [ 15.862082] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 15.862741] Detected VIPT I-cache on CPU3 [ 15.862832] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 15.862854] GICv3: CPU3: using allocated LPI pending table @0x0000000100200000 [ 15.862889] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 15.863555] CPU features: detected: Spectre-v4 [ 15.863560] CPU features: detected: Spectre-BHB [ 15.863564] CPU features: detected: SSBS not fully self-synchronizing [ 15.863566] Detected PIPT I-cache on CPU4 [ 15.863616] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 15.863629] GICv3: CPU4: using allocated LPI pending table @0x0000000100210000 [ 15.863652] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 15.864307] Detected PIPT I-cache on CPU5 [ 15.864365] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 15.864378] GICv3: CPU5: using allocated LPI pending table @0x0000000100220000 [ 15.864402] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 15.865031] Detected PIPT I-cache on CPU6 [ 15.865087] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 15.865100] GICv3: CPU6: using allocated LPI pending table @0x0000000100230000 [ 15.865123] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 15.865804] Detected PIPT I-cache on CPU7 [ 15.865862] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 15.865874] GICv3: CPU7: using allocated LPI pending table @0x0000000100240000 [ 15.865897] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 15.865964] smp: Brought up 1 node, 8 CPUs [ 15.866251] SMP: Total of 8 processors activated. [ 15.866264] CPU features: detected: 32-bit EL0 Support [ 15.866276] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 15.866293] CPU features: detected: Common not Private translations [ 15.866306] CPU features: detected: CRC32 instructions [ 15.866320] CPU features: detected: RCpc load-acquire (LDAPR) [ 15.866332] CPU features: detected: LSE atomic instructions [ 15.866344] CPU features: detected: Privileged Access Never [ 15.866356] CPU features: detected: RAS Extension Support [ 15.866369] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 15.866461] CPU: All CPU(s) started at EL2 [ 15.866474] alternatives: applying system-wide alternatives [ 15.876522] devtmpfs: initialized [ 15.892812] Registered cp15_barrier emulation handler [ 15.892826] Registered setend emulation handler [ 15.892915] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 15.892929] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 15.895047] pinctrl core: initialized pinctrl subsystem [ 15.895276] DMI not present or invalid. [ 15.895585] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 15.896383] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations [ 15.896740] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 15.896987] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 15.897014] audit: initializing netlink subsys (disabled) [ 15.897123] audit: type=2000 audit(0.043:1): state=initialized audit_enabled=0 res=1 [ 15.897701] Registered FIQ tty driver [ 15.897851] thermal_sys: Registered thermal governor 'fair_share' [ 15.897854] thermal_sys: Registered thermal governor 'step_wise' [ 15.897859] thermal_sys: Registered thermal governor 'user_space' [ 15.897864] thermal_sys: Registered thermal governor 'power_allocator' [ 15.897891] cpuidle: using governor menu [ 15.898100] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 15.898232] ASID allocator initialised with 65536 entries [ 15.900305] ramoops: dmesg-0 0x18000@0x0000000000110000 [ 15.900313] ramoops: dmesg-1 0x18000@0x0000000000128000 [ 15.900332] ramoops: console 0x80000@0x0000000000140000 [ 15.900343] ramoops: pmsg 0x30000@0x00000000001c0000 [ 15.900607] printk: console [ramoops-1] enabled [ 15.900614] pstore: Registered ramoops as persistent store backend [ 15.900620] ramoops: using 0xe0000@0x110000, ecc: 0 [ 15.938715] platform fdd90000.vop: Fixed dependency cycle(s) with /dp@fde50000 [ 15.938752] platform fde50000.dp: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.939044] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fde80000 [ 15.939082] platform fde80000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.944532] platform fed80000.phy: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22/connector [ 15.950230] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 15.950502] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 15.950726] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 15.950968] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 15.951246] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 15.951299] rockchip-pinctrl pinctrl: probed pinctrl [ 15.952701] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fdea0000 [ 15.952737] platform fdea0000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.956761] KASLR disabled due to lack of seed [ 15.961962] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 15.961972] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 15.961981] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 15.961987] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 15.961995] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 15.962001] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 15.962008] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 15.962015] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 16.019202] raid6: neonx8 gen() 5414 MB/s [ 16.075957] raid6: neonx4 gen() 5491 MB/s [ 16.132711] raid6: neonx2 gen() 5094 MB/s [ 16.189467] raid6: neonx1 gen() 4266 MB/s [ 16.246230] raid6: int64x8 gen() 1354 MB/s [ 16.302982] raid6: int64x4 gen() 1714 MB/s [ 16.359740] raid6: int64x2 gen() 2426 MB/s [ 16.416500] raid6: int64x1 gen() 2007 MB/s [ 16.416506] raid6: using algorithm neonx4 gen() 5491 MB/s [ 16.473245] raid6: .... xor() 4224 MB/s, rmw enabled [ 16.473252] raid6: using neon recovery algorithm [ 16.474461] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found [ 16.474476] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found [ 16.474486] fiq_debugger_probe: could not install nmi irq handler [ 16.474761] printk: console [ttyFIQ0] enabled [ 16.474907] Registered fiq debugger ttyFIQ0 [ 16.536509] debugfs: Directory 'vcc_mipicsi1' with parent 'regulator' already present! [ 16.536530] debugfs: Directory 'vcc_mipicsi1' with parent 'vcc_mipicsi1' already present! [ 16.536993] iommu: Default domain type: Translated [ 16.537004] iommu: DMA domain TLB invalidation policy: strict mode [ 16.537176] SCSI subsystem initialized [ 16.537262] usbcore: registered new interface driver usbfs [ 16.537283] usbcore: registered new interface driver hub [ 16.537301] usbcore: registered new device driver usb [ 16.537355] mc: Linux media interface: v0.10 [ 16.537378] videodev: Linux video capture interface: v2.00 [ 16.537418] pps_core: LinuxPPS API ver. 1 registered [ 16.537426] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 16.537440] PTP clock support registered [ 16.537645] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16 [ 16.537703] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 16.537736] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 16.538652] Advanced Linux Sound Architecture Driver Initialized. [ 16.538913] Bluetooth: Core ver 2.22 [ 16.538933] NET: Registered PF_BLUETOOTH protocol family [ 16.538940] Bluetooth: HCI device and connection manager initialized [ 16.538951] Bluetooth: HCI socket layer initialized [ 16.538959] Bluetooth: L2CAP socket layer initialized [ 16.538969] Bluetooth: SCO socket layer initialized [ 16.539017] NetLabel: Initializing [ 16.539023] NetLabel: domain hash size = 128 [ 16.539030] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 16.539060] NetLabel: unlabeled traffic allowed by default [ 16.539239] vgaarb: loaded [ 16.539864] clocksource: Switched to clocksource arch_sys_counter [ 16.539999] VFS: Disk quotas dquot_6.6.0 [ 16.540025] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 16.540234] AppArmor: AppArmor Filesystem Enabled [ 16.545799] NET: Registered PF_INET protocol family [ 16.545984] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.552972] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear) [ 16.553150] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 16.553184] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.554512] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 16.555774] TCP: Hash tables configured (established 262144 bind 65536) [ 16.555924] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear) [ 16.556093] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.556591] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.557136] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 16.557409] RPC: Registered named UNIX socket transport module. [ 16.557419] RPC: Registered udp transport module. [ 16.557425] RPC: Registered tcp transport module. [ 16.557432] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 16.557855] PCI: CLS 0 bytes, default 64 [ 16.558243] Trying to unpack rootfs image as initramfs... [ 16.558611] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 16.559505] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 16.568269] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 16.568770] kvm [1]: IPA Size Limit: 40 bits [ 16.568788] kvm [1]: GICv3: no GICV resource entry [ 16.568795] kvm [1]: disabling GICv2 emulation [ 16.568802] kvm [1]: GIC system register CPU interface enabled [ 16.573423] kvm [1]: vgic interrupt IRQ9 [ 16.578406] kvm [1]: VHE mode initialized successfully [ 16.663543] Initialise system trusted keyrings [ 16.663678] workingset: timestamp_bits=46 max_order=23 bucket_order=0 [ 16.665943] zbud: loaded [ 16.666774] NFS: Registering the id_resolver key type [ 16.666796] Key type id_resolver registered [ 16.666803] Key type id_legacy registered [ 16.666840] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 16.666849] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 16.687921] NET: Registered PF_ALG protocol family [ 16.687937] xor: measuring software checksum speed [ 16.688466] 8regs : 6294 MB/sec [ 16.688870] 32regs : 8271 MB/sec [ 16.689210] arm64_neon : 9884 MB/sec [ 16.689217] xor: using function: arm64_neon (9884 MB/sec) [ 16.689227] Key type asymmetric registered [ 16.689235] Asymmetric key parser 'x509' registered [ 16.959955] Freeing initrd memory: 14404K [ 16.973962] alg: self-tests for CTR-KDF (hmac(sha256)) passed [ 16.974009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241) [ 16.974123] io scheduler mq-deadline registered [ 16.974132] io scheduler kyber registered [ 16.975423] rockchip-csi2-dphy-hw fedc8000.csi2-dphy1-hw: csi2 dphy hw probe successfully! [ 16.984662] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 16.985526] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy init success [ 16.987970] dw-pcie fe180000.pcie: invalid resource [ 16.987986] dw-pcie fe180000.pcie: Failed to initialize host [ 16.987994] dw-pcie: probe of fe180000.pcie failed with error -22 [ 16.988064] dw-pcie fe190000.pcie: invalid resource [ 16.988073] dw-pcie fe190000.pcie: Failed to initialize host [ 16.988080] dw-pcie: probe of fe190000.pcie failed with error -22 [ 16.988190] dw-pcie fe150000.pcie: invalid resource [ 16.988200] dw-pcie fe150000.pcie: Failed to initialize host [ 16.988219] dw-pcie: probe of fe150000.pcie failed with error -22 [ 16.988338] dw-pcie fe170000.pcie: invalid resource [ 16.988348] dw-pcie fe170000.pcie: Failed to initialize host [ 16.988355] dw-pcie: probe of fe170000.pcie failed with error -22 [ 16.988727] rk-pcie fe180000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.988880] rk-pcie fe190000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.988961] rk-pcie fe180000.pcie: invalid prsnt-gpios property in node [ 16.988963] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 16.989036] rk-pcie fe190000.pcie: no vpcie3v3 regulator found [ 16.989154] rk-pcie fe180000.pcie: no vpcie3v3 regulator found [ 16.989171] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node [ 16.989361] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node [ 16.989389] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 16.989409] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 16.989439] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 16.989461] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 16.989516] rk-pcie fe190000.pcie: iATU unroll: enabled [ 16.989519] iep: Module initialized. [ 16.989530] rk-pcie fe190000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.989549] mpp_service mpp-srv: 6c47657a381c author: Yandong Lin 2025-01-16 video: rockchip: mpp: Fix missing enable_irq in timeout work [ 16.989553] mpp_service mpp-srv: probe start [ 16.989687] rk-pcie fe180000.pcie: host bridge /pcie@fe180000 ranges: [ 16.989832] rk-pcie fe180000.pcie: IO 0x00f3100000..0x00f31fffff -> 0x00f3100000 [ 16.989847] rk-pcie fe180000.pcie: MEM 0x00f3200000..0x00f3ffffff -> 0x00f3200000 [ 16.989868] rk-pcie fe180000.pcie: MEM 0x09c0000000..0x09ffffffff -> 0x09c0000000 [ 16.989915] rk-pcie fe180000.pcie: iATU unroll: enabled [ 16.989924] rk-pcie fe180000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.991571] mpp_vepu2 jpege-ccu: probing start [ 16.991584] mpp_vepu2 jpege-ccu: probing finish [ 16.994566] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 16.994639] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 16.994649] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 16.995008] mpp_rkvenc2 rkvenc-ccu: probing start [ 16.995019] mpp_rkvenc2 rkvenc-ccu: probing finish [ 16.995612] mpp_service mpp-srv: probe success [ 17.005549] rk-pcie fe150000.pcie: can't get current limit. [ 17.005806] rk-pcie fe150000.pcie: host bridge /pcie@fe150000 ranges: [ 17.005828] rk-pcie fe150000.pcie: IO 0x00f0100000..0x00f01fffff -> 0x00f0100000 [ 17.005846] rk-pcie fe150000.pcie: MEM 0x00f0200000..0x00f0ffffff -> 0x00f0200000 [ 17.005861] rk-pcie fe150000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000 [ 17.005915] rk-pcie fe150000.pcie: iATU unroll: enabled [ 17.005925] rk-pcie fe150000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.007528] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.007548] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.008470] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.008485] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.009395] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.009410] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.009891] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 17.009963] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 17.010025] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 17.010083] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 17.010137] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 17.010798] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 17.011715] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 17.012307] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 45, base_baud = 1500000) is a 16550A [ 17.013669] random: crng init done [ 17.013743] led_vk2c21_init [ 17.013743] ============================================= [ 17.019335] rk_iommu fdca0000.iommu: av1d iommu enabled [ 17.021625] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 17.031191] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Esmart0[0x5], primary plane phy id: Cluster0[0] [ 17.031226] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: Cluster1 | Esmart1[0xa], primary plane phy id: Cluster1[1] [ 17.031245] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: Cluster2 | Esmart2[0x140], primary plane phy id: Cluster2[6] [ 17.031263] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: Cluster3 | Esmart3[0x280], primary plane phy id: Cluster3[7] [ 17.031373] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 17.031474] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 17.031563] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 17.031592] [drm] failed to init overlay plane Cluster0-win1 [ 17.031601] [drm] failed to init overlay plane Cluster1-win1 [ 17.031610] [drm] failed to init overlay plane Cluster2-win1 [ 17.031648] [drm] failed to init overlay plane Cluster3-win1 [ 17.043446] rockchip-vop2 fdd90000.vop: bin=0 [ 17.043668] rockchip-vop2 fdd90000.vop: leakage=35 [ 17.043683] rockchip-vop2 fdd90000.vop: leakage-volt-sel=1 [ 17.043748] rockchip-vop2 fdd90000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found [ 17.043779] rockchip-vop2 fdd90000.vop: failed to set opp config [ 17.043790] rockchip-vop2 fdd90000.vop: failed to init opp info [ 17.043799] rockchip-vop2 fdd90000.vop: Unsupported VOP aclk dvfs [ 17.043821] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000093fe4a8) [ 17.044446] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 17.045062] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff800009417528) [ 17.045612] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver [ 17.046208] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffff800009417528) [ 17.046452] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff80000941a588) [ 17.047805] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 [ 17.047837] rockchip-drm display-subsystem: failed to parse loader memory [ 17.047916] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.047987] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.048017] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.048190] rockchip-drm display-subsystem: [drm] run display error_event monitor [ 17.048860] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.2.auto: dw_hdcp_qp_hdcp_probe success [ 17.048988] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.5.auto: dw_hdcp_qp_hdcp_probe success [ 17.049605] Registered IR keymap rc-cec [ 17.049672] rc rc0: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0 [ 17.049776] input: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0/input0 [ 17.049983] rk-pcie fe170000.pcie: can't get current limit. [ 17.050179] Registered IR keymap rc-cec [ 17.050246] rc rc1: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1 [ 17.050340] input: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1/input1 [ 17.050375] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges: [ 17.050435] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff -> 0x00f2100000 [ 17.050491] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff -> 0x00f2200000 [ 17.050535] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000 [ 17.050626] rk-pcie fe170000.pcie: iATU unroll: enabled [ 17.050653] rk-pcie fe170000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.052457] brd: module loaded [ 17.055442] loop: module loaded [ 17.055673] rbd: loaded (major 254) [ 17.055842] lkdtm: No crash points registered, enable through debugfs [ 17.058049] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 17.058457] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/regulators/DCDC_REG7 [ 17.058508] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_pwrdn [ 17.058528] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs3_null [ 17.058546] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs2_null [ 17.058565] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_null [ 17.059094] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 17.059226] rk806 spi2.0: ON: 0x40 OFF:0x0 [ 17.059353] rk806 spi2.0: shutdown-sequence missing! [ 17.059365] rk806 spi2.0: vb-shutdown-sequence missing! [ 17.059375] rk806 spi2.0: dvs-suspend-control-by missing! [ 17.068300] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 17.073038] rk806 spi2.0: no sleep-setting state [ 17.073056] rk806 spi2.0: no reset-setting pinctrl state [ 17.073066] rk806 spi2.0: no dvs-setting pinctrl state [ 17.073767] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 17.073782] rockchip-spi feb20000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0 [ 17.075148] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 17.075192] 1 fixed-partitions partitions found on MTD device sfc_nor [ 17.075205] Creating 1 MTD partitions on "sfc_nor": [ 17.075215] 0x000000000000-0x000001000000 : "loader" [ 17.078062] usbcore: registered new interface driver rndis_wlan [ 17.078095] usbcore: registered new interface driver asix [ 17.078117] usbcore: registered new interface driver cdc_ether [ 17.078140] usbcore: registered new interface driver rndis_host [ 17.078165] usbcore: registered new interface driver cdc_ncm [ 17.078294] VFIO - User Level meta-driver version: 0.3 [ 17.078835] platform fc000000.usb: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22 [ 17.092634] phy phy-fd5d4000.syscon:usb2-phy@4000.3: illegal mode [ 17.092658] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.092676] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1 [ 17.092771] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0002008002010010 [ 17.092804] xhci-hcd xhci-hcd.12.auto: irq 86, io mem 0xfc400000 [ 17.092890] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.092905] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2 [ 17.092920] xhci-hcd xhci-hcd.12.auto: Host supports USB 3.0 SuperSpeed [ 17.093014] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.093031] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.093043] usb usb1: Product: xHCI Host Controller [ 17.093053] usb usb1: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.093064] usb usb1: SerialNumber: xhci-hcd.12.auto [ 17.093386] hub 1-0:1.0: USB hub found [ 17.093412] hub 1-0:1.0: 1 port detected [ 17.093604] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 17.093672] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 17.093687] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.093699] usb usb2: Product: xHCI Host Controller [ 17.093709] usb usb2: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.093719] usb usb2: SerialNumber: xhci-hcd.12.auto [ 17.093981] hub 2-0:1.0: USB hub found [ 17.094005] hub 2-0:1.0: 1 port detected [ 17.094125] ehci-platform fc800000.usb: EHCI Host Controller [ 17.094135] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 17.094173] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 3 [ 17.094174] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 4 [ 17.094191] ehci-platform fc880000.usb: EHCI Host Controller [ 17.094203] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 5 [ 17.094221] usbcore: registered new interface driver cdc_acm [ 17.094220] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 17.094231] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 17.094240] ohci-platform fc840000.usb: irq 89, io mem 0xfc840000 [ 17.094267] ehci-platform fc800000.usb: irq 87, io mem 0xfc800000 [ 17.094266] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 6 [ 17.094283] ehci-platform fc880000.usb: irq 88, io mem 0xfc880000 [ 17.094374] usbcore: registered new interface driver uas [ 17.094393] ohci-platform fc8c0000.usb: irq 90, io mem 0xfc8c0000 [ 17.094417] usbcore: registered new interface driver usb-storage [ 17.094723] mousedev: PS/2 mouse device common for all mice [ 17.095302] .. rk pwm remotectl v2.0 init [ 17.095448] input: febf0030.pwm as /devices/platform/febf0030.pwm/input/input2 [ 17.095659] remotectl-pwm febf0030.pwm: Controller support pwrkey capture [ 17.095892] i2c_dev: i2c /dev entries driver [ 17.106548] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 17.106740] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.106758] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.106771] usb usb3: Product: EHCI Host Controller [ 17.106781] usb usb3: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.106791] usb usb3: SerialNumber: fc800000.usb [ 17.107120] hub 3-0:1.0: USB hub found [ 17.107157] hub 3-0:1.0: 1 port detected [ 17.119879] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 17.120221] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.120267] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.120300] usb usb5: Product: EHCI Host Controller [ 17.120335] usb usb5: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.120363] usb usb5: SerialNumber: fc880000.usb [ 17.120868] hub 5-0:1.0: USB hub found [ 17.120919] hub 5-0:1.0: 1 port detected [ 17.127739] rtc-hym8563 6-0051: rtc information is valid [ 17.130401] rtc-hym8563 6-0051: registered as rtc0 [ 17.130688] rtc-hym8563 6-0051: setting system clock to 2021-01-01T12:03:53 UTC (1609502633) [ 17.132176] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 17.133045] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 17.133815] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: enter mipi csi2 hw probe! [ 17.133938] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: probe success, v4l2_dev:mipi0-csi2-hw! [ 17.133986] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: enter mipi csi2 hw probe! [ 17.134073] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: probe success, v4l2_dev:mipi1-csi2-hw! [ 17.134116] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: enter mipi csi2 hw probe! [ 17.134200] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: probe success, v4l2_dev:mipi2-csi2-hw! [ 17.134242] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: enter mipi csi2 hw probe! [ 17.134325] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: probe success, v4l2_dev:mipi3-csi2-hw! [ 17.134366] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: enter mipi csi2 hw probe! [ 17.134447] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: probe success, v4l2_dev:mipi4-csi2-hw! [ 17.134488] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: enter mipi csi2 hw probe! [ 17.134571] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: probe success, v4l2_dev:mipi5-csi2-hw! [ 17.135646] rkisp_hw fdcb0000.rkisp: Adding to iommu group 15 [ 17.135752] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 17.135764] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 17.135785] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 17.135908] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 17.137135] usbcore: registered new interface driver uvcvideo [ 17.138844] cpu cpu0: bin=0 [ 17.139033] cpu cpu0: leakage=12 [ 17.140485] cpu cpu0: pvtm=1415 [ 17.140639] cpu cpu0: pvtm-volt-sel=1 [ 17.142692] cpu cpu4: bin=0 [ 17.142876] cpu cpu4: leakage=9 [ 17.149519] cpu cpu4: pvtm=1633 [ 17.153602] cpu cpu4: pvtm-volt-sel=2 [ 17.154125] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.154175] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.154209] usb usb6: Product: Generic Platform OHCI controller [ 17.154236] usb usb6: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.154263] usb usb6: SerialNumber: fc8c0000.usb [ 17.154806] hub 6-0:1.0: USB hub found [ 17.154880] hub 6-0:1.0: 1 port detected [ 17.156435] cpu cpu6: bin=0 [ 17.156619] cpu cpu6: leakage=9 [ 17.157284] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.157304] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.157316] usb usb4: Product: Generic Platform OHCI controller [ 17.157326] usb usb4: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.157337] usb usb4: SerialNumber: fc840000.usb [ 17.157593] hub 4-0:1.0: USB hub found [ 17.157618] hub 4-0:1.0: 1 port detected [ 17.163211] cpu cpu6: pvtm=1620 [ 17.167264] cpu cpu6: pvtm-volt-sel=2 [ 17.169311] cpu cpu0: avs=0 [ 17.169371] cpu cpu0: rockchip_pvtpll_set_volt_sel: error cfg clk_id=0 voltsel (-1) [ 17.170661] cpu cpu4: avs=0 [ 17.170714] cpu cpu4: rockchip_pvtpll_set_volt_sel: error cfg clk_id=2 voltsel (-1) [ 17.171817] cpu cpu6: avs=0 [ 17.171871] cpu cpu6: rockchip_pvtpll_set_volt_sel: error cfg clk_id=3 voltsel (-1) [ 17.171980] cpu cpu0: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 17.172346] cpu cpu0: EM: created perf domain [ 17.172801] cpu cpu4: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.181309] cpu cpu4: EM: created perf domain [ 17.181880] cpu cpu6: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.191235] cpu cpu6: EM: created perf domain [ 17.191709] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.192109] rk-pcie fe180000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.198244] sdhci: Secure Digital Host Controller Interface driver [ 17.198283] sdhci: Copyright(c) Pierre Ossman [ 17.198304] Synopsys Designware Multimedia Card Interface Driver [ 17.199227] sdhci-pltfm: SDHCI platform and OF driver helper [ 17.200341] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state [ 17.200382] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state [ 17.200471] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 17.200513] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 17.200541] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 17.200611] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 118,32 bit host data width,256 deep fifo [ 17.202407] mmc0: CQHCI version 5.10 [ 17.202927] ledtrig-cpu: registered to indicate activity on CPUs [ 17.202984] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 17.203043] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 17.203954] cryptodev: driver 1.12 loaded. [ 17.204005] hid: raw HID events driver (C) Jiri Kosina [ 17.204223] usbcore: registered new interface driver usbhid [ 17.204241] usbhid: USB HID core driver [ 17.207705] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.210156] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600 [ 17.210188] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602 [ 17.210206] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605 [ 17.210223] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622 [ 17.210699] optee: probing for conduit method. [ 17.210719] optee: api uid mismatch [ 17.210731] optee: probe of firmware:optee failed with error -22 [ 17.211532] usbcore: registered new interface driver snd-usb-audio [ 17.212221] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 17.214974] [Awinic] aw87xxx_pa_init:driver version: v2.2.0 [ 17.216655] rockchip-i2s-tdm fddf0000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.217536] rockchip-i2s-tdm fe470000.i2s: Register PCM for TRCM mode [ 17.218219] rockchip-i2s-tdm fddf4000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.218428] rockchip-i2s-tdm fddf8000.i2s: Init RX wait-time-ms: 50 [ 17.220863] debugfs: File 'Capture' in directory 'dapm' already present! [ 17.221896] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input3 [ 17.223005] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input4 [ 17.223839] input: rockchip-hdmi1 rockchip-hdmi1 as /devices/platform/hdmi1-sound/sound/card2/input5 [ 17.224333] input: headset-keys as /devices/platform/es8388-sound/input/input6 [ 17.228832] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x210022 [ 17.233792] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 17.253053] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.266722] rk-pcie fe180000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.266775] rk-pcie fe180000.pcie: PCIe Gen.2 x1 link up [ 17.266822] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.266876] rk-pcie fe190000.pcie: PCIe Gen.2 x1 link up [ 17.267011] rk-pcie fe180000.pcie: PCI host bridge to bus 0003:30 [ 17.267046] pci_bus 0003:30: root bus resource [bus 30-3f] [ 17.267075] pci_bus 0003:30: root bus resource [io 0x100000-0x1fffff] (bus address [0xf3100000-0xf31fffff]) [ 17.267108] pci_bus 0003:30: root bus resource [mem 0xf3200000-0xf3ffffff] [ 17.267114] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 17.267128] pci_bus 0003:30: root bus resource [mem 0x9c0000000-0x9ffffffff pref] [ 17.267144] pci_bus 0004:40: root bus resource [bus 40-4f] [ 17.267186] pci 0003:30:00.0: [1d87:3588] type 01 class 0x060400 [ 17.267201] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 17.267229] pci 0003:30:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.267243] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 17.267283] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 17.267313] pci 0003:30:00.0: supports D1 D2 [ 17.267340] pci 0003:30:00.0: PME# supported from D0 D1 D3hot [ 17.267338] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 17.267400] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.267484] pci 0004:40:00.0: supports D1 D2 [ 17.267508] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 17.274238] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.285932] pci 0003:30:00.0: Primary bus is hard wired to 0 [ 17.285949] pci 0003:30:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.286042] pci 0004:40:00.0: Primary bus is hard wired to 0 [ 17.286054] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.286074] pci 0003:31:00.0: [10ec:8125] type 00 class 0x020000 [ 17.286134] pci 0003:31:00.0: reg 0x10: [io 0x0000-0x00ff] [ 17.286236] pci 0004:41:00.0: [10ec:8125] type 00 class 0x020000 [ 17.286247] pci 0003:31:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.286326] pci 0004:41:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 17.286330] pci 0003:31:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.286338] pci 0004:41:00.0: reg 0x10: [io size 0x0100] [ 17.286452] pci 0004:41:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.286530] pci 0004:41:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.287035] pci 0003:31:00.0: supports D1 D2 [ 17.287046] pci 0003:31:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.287104] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card3/input7 [ 17.287133] pci 0004:41:00.0: supports D1 D2 [ 17.287138] pci 0004:41:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.295300] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.296615] pci_bus 0003:31: busn_res: [bus 31-3f] end is updated to 31 [ 17.296637] pci 0003:30:00.0: BAR 8: assigned [mem 0xf3200000-0xf32fffff] [ 17.296644] pci 0003:30:00.0: BAR 6: assigned [mem 0xf3300000-0xf330ffff pref] [ 17.296650] pci 0003:30:00.0: BAR 7: assigned [io 0x100000-0x100fff] [ 17.296657] pci 0003:31:00.0: BAR 2: assigned [mem 0xf3200000-0xf320ffff 64bit] [ 17.296687] pci 0003:31:00.0: BAR 4: assigned [mem 0xf3210000-0xf3213fff 64bit] [ 17.296718] pci 0003:31:00.0: BAR 0: assigned [io 0x100000-0x1000ff] [ 17.296730] pci 0003:30:00.0: PCI bridge to [bus 31] [ 17.296735] pci 0003:30:00.0: bridge window [io 0x100000-0x100fff] [ 17.296741] pci 0003:30:00.0: bridge window [mem 0xf3200000-0xf32fffff] [ 17.297536] pcieport 0003:30:00.0: PME: Signaling with IRQ 135 [ 17.302780] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 17.306649] rk-pcie fe150000.pcie: PCIe Link up, LTSSM is 0x230011 [ 17.306685] rk-pcie fe150000.pcie: PCIe Gen.3 x4 link up [ 17.306760] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 17.306809] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 17.306832] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 17.306849] rk-pcie fe150000.pcie: PCI host bridge to bus 0000:00 [ 17.306853] pci 0004:40:00.0: BAR 7: assigned [io 0x1000-0x1fff] [ 17.306866] pci_bus 0000:00: root bus resource [bus 00-0f] [ 17.306876] pci_bus 0000:00: root bus resource [io 0x200000-0x2fffff] (bus address [0xf0100000-0xf01fffff]) [ 17.306883] pci_bus 0000:00: root bus resource [mem 0xf0200000-0xf0ffffff] [ 17.306901] pci 0004:41:00.0: BAR 2: assigned [mem 0xf4200000-0xf420ffff 64bit] [ 17.306909] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref] [ 17.306947] pci 0004:41:00.0: BAR 4: assigned [mem 0xf4210000-0xf4213fff 64bit] [ 17.306965] pci 0000:00:00.0: [1d87:3588] type 01 class 0x060400 [ 17.306998] pci 0004:41:00.0: BAR 0: assigned [io 0x1000-0x10ff] [ 17.307007] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.307026] pci 0004:40:00.0: PCI bridge to [bus 41] [ 17.307045] pci 0004:40:00.0: bridge window [io 0x1000-0x1fff] [ 17.307065] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 17.307072] pci 0000:00:00.0: supports D1 D2 [ 17.307078] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 17.310864] Initializing XFRM netlink socket [ 17.310895] NET: Registered PF_PACKET protocol family [ 17.311074] [BT_RFKILL]: Enter rfkill_rk_init [ 17.311079] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 17.314541] pcieport 0004:40:00.0: PME: Signaling with IRQ 145 [ 17.316392] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.316925] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 17.317003] pci 0000:01:00.0: [c0a9:5427] type 00 class 0x010802 [ 17.317047] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 17.317064] [WLAN_RFKILL]: can't find rockchip,grf property [ 17.317069] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p [ 17.317073] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 17.317071] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 17.317078] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 17.317103] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0. [ 17.317112] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 17.317116] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 17.317121] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [ 17.317126] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 17.317391] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 148. [ 17.317411] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 21. [ 17.317425] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 150. [ 17.317439] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0. [ 17.317468] [BT_RFKILL]: Request irq for bt wakeup host [ 17.317510] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link) [ 17.317657] [BT_RFKILL]: ** disable irq [ 17.317702] [BT_RFKILL]: bt shut off power [ 17.326625] pci 0000:00:00.0: BAR 8: assigned [mem 0xf0200000-0xf02fffff] [ 17.326659] pci 0000:00:00.0: BAR 6: assigned [mem 0xf0300000-0xf030ffff pref] [ 17.326686] pci 0000:01:00.0: BAR 0: assigned [mem 0xf0200000-0xf0203fff 64bit] [ 17.326729] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 17.326747] pci 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff] [ 17.328210] pcieport 0000:00:00.0: PME: Signaling with IRQ 156 [ 17.328517] nvme nvme0: pci function 0000:01:00.0 [ 17.328614] nvme 0000:01:00.0: enabling device (0000 -> 0002) [ 17.336856] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.343221] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 17.343263] [BT_RFKILL]: bt_default device registered. [ 17.343442] input: bt-powerkey as /devices/platform/wireless-bluetooth/input/input8 [ 17.343902] Key type dns_resolver registered [ 17.343955] Key type ceph registered [ 17.344580] libceph: loaded (mon/osd proto 15/24) [ 17.347220] registered taskstats version 1 [ 17.347271] Loading compiled-in X.509 certificates [ 17.351701] zswap: loaded using pool zstd/zbud [ 17.352322] Key type .fscrypt registered [ 17.352341] Key type fscrypt-provisioning registered [ 17.353408] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no [ 17.354271] pstore: Using crash dump compression: deflate [ 17.354796] Key type encrypted registered [ 17.355144] AppArmor: AppArmor sha1 policy hashing enabled [ 17.357936] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.368673] rga3 fdb60000.rga: Adding to iommu group 2 [ 17.369476] rga3 fdb60000.rga: probe successfully, irq = 50, hw_version:3.0.76831 [ 17.369736] rga3 fdb70000.rga: Adding to iommu group 3 [ 17.370447] rga3 fdb70000.rga: probe successfully, irq = 51, hw_version:3.0.76831 [ 17.371705] rga2 fdb80000.rga: probe successfully, irq = 158, hw_version:3.2.63318 [ 17.372080] rga: IOMMU binding successfully, default mapping core[0x1] [ 17.372305] rga: Module initialized. v1.3.7 [ 17.411406] mpp_vdpu1 fdb51000.avsd-plus: Adding to iommu group 1 [ 17.411965] mpp_vdpu1 fdb51000.avsd-plus: probe device [ 17.412347] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.412388] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.412509] mpp_vdpu1 fdb51000.avsd-plus: probing finish [ 17.412897] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 17.413012] mpp_vdpu2 fdb50400.vdpu: probe device [ 17.413316] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.413350] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.413392] mpp_vdpu2 fdb50400.vdpu: probing finish [ 17.413725] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 17.413838] mpp_vepu2 fdb50000.vepu: probing start [ 17.414117] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.414148] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.414217] mpp_vepu2 fdb50000.vepu: probing finish [ 17.414574] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 17.414766] mpp_vepu2 fdba0000.jpege-core: probing start [ 17.414982] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 17.415004] mpp_vepu2 fdba0000.jpege-core: probing finish [ 17.415090] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 17.415160] mpp_vepu2 fdba4000.jpege-core: probing start [ 17.415245] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 17.415265] mpp_vepu2 fdba4000.jpege-core: probing finish [ 17.415372] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 17.415444] mpp_vepu2 fdba8000.jpege-core: probing start [ 17.415527] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 17.415545] mpp_vepu2 fdba8000.jpege-core: probing finish [ 17.415654] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 17.415723] mpp_vepu2 fdbac000.jpege-core: probing start [ 17.415808] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 17.415828] mpp_vepu2 fdbac000.jpege-core: probing finish [ 17.415938] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 17.416016] mpp-iep2 fdbb0000.iep: probe device [ 17.416595] mpp-iep2 fdbb0000.iep: probing finish [ 17.416782] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 17.416978] mpp_jpgdec fdb90000.jpegd: probe device [ 17.417155] mpp_jpgdec fdb90000.jpegd: probing finish [ 17.417324] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 17.417576] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 17.417692] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 17.417700] rkvdec2_init:1198: No niu aclk reset resource define [ 17.417706] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 17.417712] rkvdec2_init:1201: No niu hclk reset resource define [ 17.419384] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 17.419454] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 17.419461] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 17.419580] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 17.419587] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 17.419592] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 17.419597] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 17.419603] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 17.419609] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 17.419614] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 17.419619] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 17.419625] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 17.419630] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 17.419635] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 17.419640] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 17.419645] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 17.419650] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 17.419655] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 17.419661] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 17.419683] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 17.419776] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 17.419943] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 17.420028] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 17.420034] rkvdec2_init:1198: No niu aclk reset resource define [ 17.420040] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 17.420045] rkvdec2_init:1201: No niu hclk reset resource define [ 17.420070] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 17.420099] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 17.420116] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 17.420234] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 17.420241] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 17.420246] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 17.420251] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 17.420256] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 17.420263] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 17.420268] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 17.420273] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 17.420278] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 17.420283] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 17.420288] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 17.420293] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 17.420298] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 17.420303] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 17.420308] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 17.420313] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 17.420334] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 17.420437] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 17.420538] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 17.420645] mpp_rkvenc2 fdbd0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.420653] mpp_rkvenc2 fdbd0000.rkvenc-core: bin=0 [ 17.420840] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage=11 [ 17.420847] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage-volt-sel=0 [ 17.420897] mpp_rkvenc2 fdbd0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.420916] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to set opp config [ 17.420922] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init opp info [ 17.420927] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init_opp_table [ 17.420931] rkvenc_init:2147: failed to add venc devfreq [ 17.420954] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 17.420973] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 17.421052] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 17.421155] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 17.421249] mpp_rkvenc2 fdbe0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.421256] mpp_rkvenc2 fdbe0000.rkvenc-core: bin=0 [ 17.421425] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage=11 [ 17.421445] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage-volt-sel=0 [ 17.421474] mpp_rkvenc2 fdbe0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.421486] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to set opp config [ 17.421491] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init opp info [ 17.421496] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init_opp_table [ 17.421501] rkvenc_init:2147: failed to add venc devfreq [ 17.421540] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 17.421556] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 17.421642] mpp_av1dec fdc70000.av1d: Adding to iommu group 14 [ 17.421788] mpp_av1dec fdc70000.av1d: probing start [ 17.421892] mpp_av1dec fdc70000.av1d: probing finish [ 17.422332] rockchip-dmc dmc: bin=0 [ 17.422343] mali fb000000.gpu: Kernel DDK version g25p0-00eac0 [ 17.422462] mali fb000000.gpu: GPU metrics tracepoint support enabled [ 17.422502] rockchip-dmc dmc: leakage=35 [ 17.422546] rockchip-dmc dmc: leakage-volt-sel=1 [ 17.422553] rockchip-dmc dmc: soc version=0, speed=1 [ 17.423430] rockchip-dmc dmc: avs=0 [ 17.423441] rockchip-dmc dmc: current ATF version 0x100 [ 17.423598] rockchip-dmc dmc: normal_rate = 1560000000 [ 17.423605] rockchip-dmc dmc: reboot_rate = 2112000000 [ 17.423610] rockchip-dmc dmc: suspend_rate = 528000000 [ 17.423615] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 17.423620] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 17.423625] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 17.423630] rockchip-dmc dmc: boost_rate = 2112000000 [ 17.423635] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 17.423641] rockchip-dmc dmc: performance_rate = 2112000000 [ 17.423646] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 17.423651] rockchip-dmc dmc: deep_suspend_rate = 2112000000 [ 17.423659] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 17.423664] rockchip-dmc dmc: failed to get vop pn to msch rl [ 17.423884] rockchip-dmc dmc: l=15000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 17.425052] mali fb000000.gpu: bin=0 [ 17.425257] mali fb000000.gpu: leakage=14 [ 17.425325] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.426684] WCN: marlin_init entry! [ 17.426706] mali fb000000.gpu: pvtm=816 [ 17.426950] mali fb000000.gpu: pvtm-volt-sel=1 [ 17.427052] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.427460] RKNPU fdab0000.npu: Adding to iommu group 0 [ 17.427576] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 17.428673] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 17.428697] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 17.428713] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 17.428958] [drm] Initialized rknpu 0.9.8 20240828 for fdab0000.npu on minor 1 [ 17.429012] mali fb000000.gpu: avs=0 [ 17.429109] mali fb000000.gpu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=5 voltsel (-1) [ 17.429162] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 144; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 17.429703] mali fb000000.gpu: Register LUT 000a0800 initialized for GPU arch 0x000a0806 [ 17.429756] mali fb000000.gpu: r0p0 status 5 not found in HW issues table; [ 17.429780] mali fb000000.gpu: falling back to closest match: r0p0 status 0 [ 17.429803] mali fb000000.gpu: Execution proceeding normally with fallback match [ 17.429828] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 17.430001] mali fb000000.gpu: CSF_GPU_RESET_TIMEOUT is capped from 20666ms to 4500ms [ 17.430032] mali fb000000.gpu: KBASE_PRFCNT_ACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.430058] mali fb000000.gpu: KBASE_AS_INACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.430083] mali fb000000.gpu: CSF_FIRMWARE_STOP_TIMEOUT is capped from 40000ms to 4500ms [ 17.430193] mali fb000000.gpu: No priority control manager is configured [ 17.430219] mali fb000000.gpu: Large page allocation set to false after hardware feature check [ 17.430617] mali fb000000.gpu: No memory group manager is configured [ 17.430680] mali fb000000.gpu: Protected memory allocator not available [ 17.431315] RKNPU fdab0000.npu: RKNPU: bin=0 [ 17.431519] RKNPU fdab0000.npu: leakage=8 [ 17.431560] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.432338] mali fb000000.gpu: EM: created perf domain [ 17.432948] mali fb000000.gpu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.438898] mali fb000000.gpu: * MALI kbase_mmap_min_addr compiled to CONFIG_DEFAULT_MMAP_MIN_ADDR, no runtime update possible! * [ 17.438952] mali fb000000.gpu: Probed as mali0 [ 17.439012] RKNPU fdab0000.npu: pvtm=814 [ 17.446487] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 225 [ 17.446562] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 17.447474] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 17.450941] RKNPU fdab0000.npu: pvtm-volt-sel=0 [ 17.451086] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.453460] RKNPU fdab0000.npu: avs=0 [ 17.453560] RKNPU fdab0000.npu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=6 voltsel (-1) [ 17.453737] RKNPU fdab0000.npu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.455683] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 17.455704] GPT:3235839 != 31116287 [ 17.455713] GPT:Alternate GPT header not at the end of the disk. [ 17.455722] GPT:3235839 != 31116287 [ 17.455729] GPT: Use GNU Parted to correct GPT errors. [ 17.455748] mmcblk1: p1 [ 17.465863] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 17.466942] hwmon hwmon8: temp1_input not attached to any thermal zone [ 17.467045] hwmon hwmon8: temp2_input not attached to any thermal zone [ 17.475432] nvme nvme0: allocated 64 MiB host memory buffer. [ 17.487725] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 17.488498] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 17.489147] clk: Disabling unused clocks [ 17.489781] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91 [ 17.489817] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.489837] usb 1-1: Product: USB2.1 Hub [ 17.489853] usb 1-1: Manufacturer: GenesysLogic [ 17.490814] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 17.491810] rockchip-suspend not set sleep-mode-config for mem-lite [ 17.491827] rockchip-suspend not set wakeup-config for mem-lite [ 17.491846] rockchip-suspend not set sleep-mode-config for mem-ultra [ 17.491863] rockchip-suspend not set wakeup-config for mem-ultra [ 17.493567] ALSA device list: [ 17.493584] #0: rockchip-dp0 [ 17.493597] #1: rockchip-hdmi0 [ 17.493610] #2: rockchip-hdmi1 [ 17.493623] #3: rockchip-es8388 [ 17.541575] hub 1-1:1.0: USB hub found [ 17.542058] hub 1-1:1.0: 4 ports detected [ 17.597989] nvme nvme0: 8/0/0 default/read/poll queues [ 17.610482] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 17.632846] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91 [ 17.632929] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.632981] usb 2-1: Product: USB3.2 Hub [ 17.633021] usb 2-1: Manufacturer: GenesysLogic [ 17.653898] hub 2-1:1.0: USB hub found [ 17.654527] hub 2-1:1.0: 4 ports detected [ 17.666492] Freeing unused kernel memory: 8320K [ 17.667221] Run /init as init process [ 18.013752] input: adc-keys as /devices/platform/adc-keys/input/input9 DDR V1.13 25cee80c4f cym 23/08/11-09:31:58 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB Manufacturer ID:0xff CH0 RX Vref:28.5%, TX Vref:22.8%,21.8% CH1 RX Vref:27.1%, TX Vref:21.8%,20.8% CH2 RX Vref:27.9%, TX Vref:21.8%,21.8% CH3 RX Vref:28.9%, TX Vref:20.8%,20.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Nov 15 2023 - 16:53:25) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(d41c62e80b...) + OK ## Checking fdt 0x00355940 ... sha256(7146109403...) + OK ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 741.510 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 usb dr_mode not found usb dr_mode not found U-Boot 2017.09_armbian-2017.09-S3f41-Pdfdd-H6539-Ve691-Bbf55-R448a (Nov 19 2025 - 17:07:00 +0000) Model: Orange Pi 5 Plus MPIDR: 0x0 PreSerial: 2, raw, 0xfeb50000 DRAM: 31.7 GiB Sysmem: init Relocation Offset: eda09000 Relocation fdt: eb9f7610 - eb9fecd0 CR: M/C/I usb dr_mode not found usb dr_mode not found Using default environment DM: v2 RESC: No bootdev Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Orange Pi 5 Plus [Vendor ERROR]:Invalid boot device type(0) ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 [Vendor ERROR]:Invalid boot device type(0) rockchip_set_ethaddr: vendor_storage_write failed -19 [Vendor ERROR]:Invalid boot device type(0) mmc@fe2c0000: 1, mmc@fe2e0000: 0 Card did not respond to voltage select! mmc_init: -95, time 13 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 No bootdev dev_desc is NULL! boot mode: None No bootdev CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz MMC1: Legacy, 52Mhz PartType: EFI No bootdev dev_desc is NULL! No bootdev Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 Bus usb@fc400000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc800000 for devices... 1 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning bus usb@fc400000 for devices... cannot reset port 1!? 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Could not find misc partition ANDROID: reboot reason: "(none)" Not AVB images, AVB skip android_image_load_by_partname: Can't find part: boot Android image load failed Android boot failed, error -1. Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 4149 bytes read in 24 ms (168 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 200 bytes read in 23 ms (7.8 KiB/s) 14756344 bytes read in 1221 ms (11.5 MiB/s) 48886272 bytes read in 3965 ms (11.8 MiB/s) 278734 bytes read in 249 ms (1.1 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14756280 Bytes = 14.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=aa000 Using Device Tree in place at 0000000008300000, end 00000000083acfff ## reserved-memory: cma: addr=10000000 size=10000000 ramoops@110000: addr=110000 size=e0000 Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x400000000 - 0x800000000 (size: 0x400000000) Total: 14512.764/14545.751 ms Starting kernel ... [ 14.549110] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 14.549137] Linux version 6.1.115-vendor-rk35xx (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Fri Nov 21 14:02:48 UTC 2025 [ 14.557192] Machine model: Orange Pi 5 Plus [ 14.557356] efi: UEFI not found. [ 14.560874] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB [ 14.560893] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB [ 14.560986] Reserved memory: bypass cma node, using cmdline CMA params instead [ 14.560994] OF: reserved mem: node cma compatible matching fail [ 15.091709] Zone ranges: [ 15.091717] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 15.091728] DMA32 empty [ 15.091733] Normal [mem 0x0000000100000000-0x00000007ffffffff] [ 15.091740] Movable zone start for each node [ 15.091742] Early memory node ranges [ 15.091744] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 15.091753] node 0: [mem 0x0000000100000000-0x00000003fbffffff] [ 15.091762] node 0: [mem 0x00000003fc500000-0x00000003ffefffff] [ 15.091767] node 0: [mem 0x0000000400000000-0x00000007ffffffff] [ 15.091779] Initmem setup node 0 [mem 0x0000000000200000-0x00000007ffffffff] [ 15.112139] On node 0, zone DMA: 512 pages in unavailable ranges [ 15.177227] On node 0, zone Normal: 1280 pages in unavailable ranges [ 15.263945] On node 0, zone Normal: 256 pages in unavailable ranges [ 15.263976] cma: Reserved 256 MiB at 0x00000000e0000000 [ 15.264171] psci: probing for conduit method from DT. [ 15.264180] psci: PSCIv1.1 detected in firmware. [ 15.264186] psci: Using standard PSCI v0.2 function IDs [ 15.264191] psci: MIGRATE_INFO_TYPE not supported. [ 15.264232] psci: SMC Calling Convention v1.2 [ 15.264621] percpu: Embedded 30 pages/cpu s82728 r8192 d31960 u122880 [ 15.264826] Detected VIPT I-cache on CPU0 [ 15.264880] CPU features: detected: GIC system register CPU interface [ 15.264884] CPU features: detected: Virtualization Host Extensions [ 15.264899] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 15.264903] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 15.264909] alternatives: applying boot alternatives [ 15.265448] Built 1 zonelists, mobility grouping on. Total pages: 8190984 [ 15.265462] Kernel command line: root=UUID=21f59e6d-0e11-4ba2-85d3-e5fab5604f14 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 usb-storage.quirks= cma=256M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=bl31-v1.48,uboot-rmbian-201-11/19/2025 [ 15.265987] Unknown kernel command line parameters "splash=verbose ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 15.269048] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear) [ 15.270582] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 15.270591] mem auto-init: stack:off, heap alloc:off, heap free:off [ 15.270597] software IO TLB: area num 8. [ 15.283145] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [ 15.541302] Memory: 32255616K/33284096K available (19072K kernel code, 4028K rwdata, 16148K rodata, 8320K init, 700K bss, 766336K reserved, 262144K cma-reserved) [ 15.541467] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 15.541506] ftrace: allocating 72100 entries in 282 pages [ 15.670160] ftrace: allocated 282 pages with 4 groups [ 15.670271] trace event string verifier disabled [ 15.670499] rcu: Hierarchical RCU implementation. [ 15.670504] rcu: RCU event tracing is enabled. [ 15.670508] Rude variant of Tasks RCU enabled. [ 15.670510] Tracing variant of Tasks RCU enabled. [ 15.670514] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 15.688489] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 15.691607] GICv3: GIC: Using split EOI/Deactivate mode [ 15.691613] GICv3: 480 SPIs implemented [ 15.691617] GICv3: 0 Extended SPIs implemented [ 15.691648] Root IRQ handler: gic_handle_irq [ 15.691664] GICv3: GICv3 features: 16 PPIs [ 15.691707] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 15.692106] ITS [mem 0xfe640000-0xfe65ffff] [ 15.692163] ITS@0x00000000fe640000: allocated 8192 Devices @100170000 (indirect, esz 8, psz 64K, shr 0) [ 15.692196] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100180000 (flat, esz 2, psz 64K, shr 0) [ 15.692212] ITS: using cache flushing for cmd queue [ 15.692248] ITS [mem 0xfe660000-0xfe67ffff] [ 15.692295] ITS@0x00000000fe660000: allocated 8192 Devices @1001a0000 (indirect, esz 8, psz 64K, shr 0) [ 15.692325] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1001b0000 (flat, esz 2, psz 64K, shr 0) [ 15.692340] ITS: using cache flushing for cmd queue [ 15.692598] GICv3: using LPI property table @0x00000001001c0000 [ 15.692730] GIC: using cache flushing for LPI property table [ 15.692739] GICv3: CPU0: using allocated LPI pending table @0x00000001001d0000 [ 15.692796] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 15.851599] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 15.851612] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 15.851622] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 15.853115] Console: colour dummy device 80x25 [ 15.853822] printk: console [tty1] enabled [ 15.853866] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 15.853891] pid_max: default: 32768 minimum: 301 [ 15.853968] LSM: Security Framework initializing [ 15.854097] AppArmor: AppArmor initialized [ 15.854239] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.854316] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.856375] cblist_init_generic: Setting adjustable number of callback queues. [ 15.856398] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.856517] cblist_init_generic: Setting adjustable number of callback queues. [ 15.856536] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.856776] rcu: Hierarchical SRCU implementation. [ 15.856792] rcu: Max phase no-delay instances is 1000. [ 15.858362] Platform MSI: msi-controller@fe640000 domain created [ 15.858395] Platform MSI: msi-controller@fe660000 domain created [ 15.858827] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 15.858868] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 15.859121] EFI services will not be available. [ 15.859580] smp: Bringing up secondary CPUs ... [ 15.860229] Detected VIPT I-cache on CPU1 [ 15.860325] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 15.860349] GICv3: CPU1: using allocated LPI pending table @0x00000001001e0000 [ 15.860390] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 15.861132] Detected VIPT I-cache on CPU2 [ 15.861225] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 15.861247] GICv3: CPU2: using allocated LPI pending table @0x00000001001f0000 [ 15.861285] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 15.861947] Detected VIPT I-cache on CPU3 [ 15.862037] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 15.862059] GICv3: CPU3: using allocated LPI pending table @0x0000000100200000 [ 15.862095] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 15.862758] CPU features: detected: Spectre-v4 [ 15.862763] CPU features: detected: Spectre-BHB [ 15.862767] CPU features: detected: SSBS not fully self-synchronizing [ 15.862769] Detected PIPT I-cache on CPU4 [ 15.862820] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 15.862833] GICv3: CPU4: using allocated LPI pending table @0x0000000100210000 [ 15.862856] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 15.863509] Detected PIPT I-cache on CPU5 [ 15.863566] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 15.863580] GICv3: CPU5: using allocated LPI pending table @0x0000000100220000 [ 15.863603] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 15.864232] Detected PIPT I-cache on CPU6 [ 15.864288] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 15.864301] GICv3: CPU6: using allocated LPI pending table @0x0000000100230000 [ 15.864324] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 15.865005] Detected PIPT I-cache on CPU7 [ 15.865062] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 15.865074] GICv3: CPU7: using allocated LPI pending table @0x0000000100240000 [ 15.865097] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 15.865164] smp: Brought up 1 node, 8 CPUs [ 15.865451] SMP: Total of 8 processors activated. [ 15.865464] CPU features: detected: 32-bit EL0 Support [ 15.865476] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 15.865493] CPU features: detected: Common not Private translations [ 15.865506] CPU features: detected: CRC32 instructions [ 15.865520] CPU features: detected: RCpc load-acquire (LDAPR) [ 15.865532] CPU features: detected: LSE atomic instructions [ 15.865544] CPU features: detected: Privileged Access Never [ 15.865556] CPU features: detected: RAS Extension Support [ 15.865569] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 15.865661] CPU: All CPU(s) started at EL2 [ 15.865674] alternatives: applying system-wide alternatives [ 15.875720] devtmpfs: initialized [ 15.892004] Registered cp15_barrier emulation handler [ 15.892018] Registered setend emulation handler [ 15.892108] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 15.892123] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 15.894244] pinctrl core: initialized pinctrl subsystem [ 15.894472] DMI not present or invalid. [ 15.894782] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 15.895581] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations [ 15.895938] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 15.896183] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 15.896214] audit: initializing netlink subsys (disabled) [ 15.896323] audit: type=2000 audit(0.043:1): state=initialized audit_enabled=0 res=1 [ 15.896895] Registered FIQ tty driver [ 15.897047] thermal_sys: Registered thermal governor 'fair_share' [ 15.897050] thermal_sys: Registered thermal governor 'step_wise' [ 15.897056] thermal_sys: Registered thermal governor 'user_space' [ 15.897061] thermal_sys: Registered thermal governor 'power_allocator' [ 15.897088] cpuidle: using governor menu [ 15.897308] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 15.897439] ASID allocator initialised with 65536 entries [ 15.899515] ramoops: dmesg-0 0x18000@0x0000000000110000 [ 15.899523] ramoops: dmesg-1 0x18000@0x0000000000128000 [ 15.899542] ramoops: console 0x80000@0x0000000000140000 [ 15.899553] ramoops: pmsg 0x30000@0x00000000001c0000 [ 15.899819] printk: console [ramoops-1] enabled [ 15.899826] pstore: Registered ramoops as persistent store backend [ 15.899833] ramoops: using 0xe0000@0x110000, ecc: 0 [ 15.937963] platform fdd90000.vop: Fixed dependency cycle(s) with /dp@fde50000 [ 15.938001] platform fde50000.dp: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.938299] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fde80000 [ 15.938333] platform fde80000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.943755] platform fed80000.phy: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22/connector [ 15.949452] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 15.949725] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 15.949949] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 15.950189] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 15.950466] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 15.950520] rockchip-pinctrl pinctrl: probed pinctrl [ 15.951920] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fdea0000 [ 15.951957] platform fdea0000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.955986] KASLR disabled due to lack of seed [ 15.961192] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 15.961203] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 15.961211] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 15.961218] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 15.961225] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 15.961232] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 15.961239] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 15.961246] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 16.018416] raid6: neonx8 gen() 5472 MB/s [ 16.075155] raid6: neonx4 gen() 5618 MB/s [ 16.131893] raid6: neonx2 gen() 5158 MB/s [ 16.188636] raid6: neonx1 gen() 4247 MB/s [ 16.245374] raid6: int64x8 gen() 1332 MB/s [ 16.302114] raid6: int64x4 gen() 1651 MB/s [ 16.358854] raid6: int64x2 gen() 2422 MB/s [ 16.415589] raid6: int64x1 gen() 2006 MB/s [ 16.415595] raid6: using algorithm neonx4 gen() 5618 MB/s [ 16.472329] raid6: .... xor() 4303 MB/s, rmw enabled [ 16.472336] raid6: using neon recovery algorithm [ 16.472953] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found [ 16.472969] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found [ 16.472979] fiq_debugger_probe: could not install nmi irq handler [ 16.473257] printk: console [ttyFIQ0] enabled [ 16.473372] Registered fiq debugger ttyFIQ0 [ 16.532300] debugfs: Directory 'vcc_mipicsi1' with parent 'regulator' already present! [ 16.532321] debugfs: Directory 'vcc_mipicsi1' with parent 'vcc_mipicsi1' already present! [ 16.532746] iommu: Default domain type: Translated [ 16.532757] iommu: DMA domain TLB invalidation policy: strict mode [ 16.532928] SCSI subsystem initialized [ 16.533014] usbcore: registered new interface driver usbfs [ 16.533035] usbcore: registered new interface driver hub [ 16.533053] usbcore: registered new device driver usb [ 16.533105] mc: Linux media interface: v0.10 [ 16.533124] videodev: Linux video capture interface: v2.00 [ 16.533165] pps_core: LinuxPPS API ver. 1 registered [ 16.533173] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 16.533186] PTP clock support registered [ 16.533387] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16 [ 16.533442] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 16.533475] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 16.534410] Advanced Linux Sound Architecture Driver Initialized. [ 16.534669] Bluetooth: Core ver 2.22 [ 16.534689] NET: Registered PF_BLUETOOTH protocol family [ 16.534697] Bluetooth: HCI device and connection manager initialized [ 16.534706] Bluetooth: HCI socket layer initialized [ 16.534714] Bluetooth: L2CAP socket layer initialized [ 16.534724] Bluetooth: SCO socket layer initialized [ 16.534771] NetLabel: Initializing [ 16.534777] NetLabel: domain hash size = 128 [ 16.534784] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 16.534814] NetLabel: unlabeled traffic allowed by default [ 16.534987] vgaarb: loaded [ 16.535312] clocksource: Switched to clocksource arch_sys_counter [ 16.535451] VFS: Disk quotas dquot_6.6.0 [ 16.535477] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 16.535688] AppArmor: AppArmor Filesystem Enabled [ 16.541390] NET: Registered PF_INET protocol family [ 16.541587] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.548590] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear) [ 16.548775] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 16.548810] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.550133] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 16.551395] TCP: Hash tables configured (established 262144 bind 65536) [ 16.551562] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear) [ 16.551736] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.552239] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.552787] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 16.553093] RPC: Registered named UNIX socket transport module. [ 16.553103] RPC: Registered udp transport module. [ 16.553110] RPC: Registered tcp transport module. [ 16.553116] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 16.553571] PCI: CLS 0 bytes, default 64 [ 16.554000] Trying to unpack rootfs image as initramfs... [ 16.554359] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 16.555253] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 16.569340] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 16.569901] kvm [1]: IPA Size Limit: 40 bits [ 16.569921] kvm [1]: GICv3: no GICV resource entry [ 16.569929] kvm [1]: disabling GICv2 emulation [ 16.569935] kvm [1]: GIC system register CPU interface enabled [ 16.570431] kvm [1]: vgic interrupt IRQ9 [ 16.571014] kvm [1]: VHE mode initialized successfully [ 16.571739] Initialise system trusted keyrings [ 16.571868] workingset: timestamp_bits=46 max_order=23 bucket_order=0 [ 16.574131] zbud: loaded [ 16.574935] NFS: Registering the id_resolver key type [ 16.574956] Key type id_resolver registered [ 16.574963] Key type id_legacy registered [ 16.575000] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 16.575009] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 16.595061] NET: Registered PF_ALG protocol family [ 16.595075] xor: measuring software checksum speed [ 16.595607] 8regs : 6245 MB/sec [ 16.596013] 32regs : 8271 MB/sec [ 16.596353] arm64_neon : 9876 MB/sec [ 16.596359] xor: using function: arm64_neon (9876 MB/sec) [ 16.596370] Key type asymmetric registered [ 16.596377] Asymmetric key parser 'x509' registered [ 16.949079] Freeing initrd memory: 14404K [ 16.967740] alg: self-tests for CTR-KDF (hmac(sha256)) passed [ 16.967781] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241) [ 16.967911] io scheduler mq-deadline registered [ 16.967920] io scheduler kyber registered [ 16.969233] rockchip-csi2-dphy-hw fedc8000.csi2-dphy1-hw: csi2 dphy hw probe successfully! [ 16.978456] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 16.979311] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy init success [ 16.981707] dw-pcie fe180000.pcie: invalid resource [ 16.981723] dw-pcie fe180000.pcie: Failed to initialize host [ 16.981731] dw-pcie: probe of fe180000.pcie failed with error -22 [ 16.981800] dw-pcie fe190000.pcie: invalid resource [ 16.981809] dw-pcie fe190000.pcie: Failed to initialize host [ 16.981816] dw-pcie: probe of fe190000.pcie failed with error -22 [ 16.981925] dw-pcie fe150000.pcie: invalid resource [ 16.981934] dw-pcie fe150000.pcie: Failed to initialize host [ 16.981954] dw-pcie: probe of fe150000.pcie failed with error -22 [ 16.982087] dw-pcie fe170000.pcie: invalid resource [ 16.982097] dw-pcie fe170000.pcie: Failed to initialize host [ 16.982104] dw-pcie: probe of fe170000.pcie failed with error -22 [ 16.982476] rk-pcie fe180000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.982619] rk-pcie fe190000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.982667] rk-pcie fe180000.pcie: invalid prsnt-gpios property in node [ 16.982746] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 16.982810] rk-pcie fe180000.pcie: no vpcie3v3 regulator found [ 16.982874] rk-pcie fe190000.pcie: no vpcie3v3 regulator found [ 16.982890] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node [ 16.983140] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node [ 16.983294] iep: Module initialized. [ 16.983392] mpp_service mpp-srv: 6c47657a381c author: Yandong Lin 2025-01-16 video: rockchip: mpp: Fix missing enable_irq in timeout work [ 16.983391] rk-pcie fe180000.pcie: host bridge /pcie@fe180000 ranges: [ 16.983404] mpp_service mpp-srv: probe start [ 16.983449] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 16.983454] rk-pcie fe180000.pcie: IO 0x00f3100000..0x00f31fffff -> 0x00f3100000 [ 16.983474] rk-pcie fe180000.pcie: MEM 0x00f3200000..0x00f3ffffff -> 0x00f3200000 [ 16.983488] rk-pcie fe180000.pcie: MEM 0x09c0000000..0x09ffffffff -> 0x09c0000000 [ 16.983541] rk-pcie fe180000.pcie: iATU unroll: enabled [ 16.983549] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 16.983568] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 16.983582] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 16.983593] rk-pcie fe180000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.983649] rk-pcie fe190000.pcie: iATU unroll: enabled [ 16.983673] rk-pcie fe190000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.984874] mpp_vepu2 jpege-ccu: probing start [ 16.984886] mpp_vepu2 jpege-ccu: probing finish [ 16.988319] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 16.988389] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 16.988398] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 16.988771] mpp_rkvenc2 rkvenc-ccu: probing start [ 16.988782] mpp_rkvenc2 rkvenc-ccu: probing finish [ 16.989377] mpp_service mpp-srv: probe success [ 16.999314] rk-pcie fe150000.pcie: can't get current limit. [ 16.999580] rk-pcie fe150000.pcie: host bridge /pcie@fe150000 ranges: [ 16.999606] rk-pcie fe150000.pcie: IO 0x00f0100000..0x00f01fffff -> 0x00f0100000 [ 16.999625] rk-pcie fe150000.pcie: MEM 0x00f0200000..0x00f0ffffff -> 0x00f0200000 [ 16.999640] rk-pcie fe150000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000 [ 16.999696] rk-pcie fe150000.pcie: iATU unroll: enabled [ 16.999706] rk-pcie fe150000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.001264] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.001284] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.002214] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.002230] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.003141] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.003156] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.003619] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 17.003685] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 17.003744] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 17.003801] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 17.003855] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 17.004518] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 17.005440] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 17.006039] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 45, base_baud = 1500000) is a 16550A [ 17.007378] random: crng init done [ 17.007451] led_vk2c21_init [ 17.007451] ============================================= [ 17.013034] rk_iommu fdca0000.iommu: av1d iommu enabled [ 17.015293] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 17.024843] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Esmart0[0x5], primary plane phy id: Cluster0[0] [ 17.024878] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: Cluster1 | Esmart1[0xa], primary plane phy id: Cluster1[1] [ 17.024897] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: Cluster2 | Esmart2[0x140], primary plane phy id: Cluster2[6] [ 17.024915] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: Cluster3 | Esmart3[0x280], primary plane phy id: Cluster3[7] [ 17.025023] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 17.025118] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 17.025207] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 17.025235] [drm] failed to init overlay plane Cluster0-win1 [ 17.025244] [drm] failed to init overlay plane Cluster1-win1 [ 17.025253] [drm] failed to init overlay plane Cluster2-win1 [ 17.025294] [drm] failed to init overlay plane Cluster3-win1 [ 17.037197] rockchip-vop2 fdd90000.vop: bin=0 [ 17.037419] rockchip-vop2 fdd90000.vop: leakage=35 [ 17.037433] rockchip-vop2 fdd90000.vop: leakage-volt-sel=1 [ 17.037499] rockchip-vop2 fdd90000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found [ 17.037530] rockchip-vop2 fdd90000.vop: failed to set opp config [ 17.037540] rockchip-vop2 fdd90000.vop: failed to init opp info [ 17.037550] rockchip-vop2 fdd90000.vop: Unsupported VOP aclk dvfs [ 17.037571] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000093fe4a8) [ 17.038217] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 17.038833] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff800009417528) [ 17.039405] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver [ 17.039987] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffff800009417528) [ 17.040222] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff80000941a588) [ 17.041489] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 [ 17.041520] rockchip-drm display-subsystem: failed to parse loader memory [ 17.041600] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.041665] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.041696] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.041860] rockchip-drm display-subsystem: [drm] run display error_event monitor [ 17.042549] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.2.auto: dw_hdcp_qp_hdcp_probe success [ 17.042707] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.5.auto: dw_hdcp_qp_hdcp_probe success [ 17.043265] Registered IR keymap rc-cec [ 17.043333] rc rc0: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0 [ 17.043436] input: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0/input0 [ 17.043811] Registered IR keymap rc-cec [ 17.043874] rc rc1: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1 [ 17.043968] input: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1/input1 [ 17.045378] rk-pcie fe170000.pcie: can't get current limit. [ 17.045647] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges: [ 17.045673] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff -> 0x00f2100000 [ 17.045691] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff -> 0x00f2200000 [ 17.045706] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000 [ 17.045766] rk-pcie fe170000.pcie: iATU unroll: enabled [ 17.045776] rk-pcie fe170000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.046259] brd: module loaded [ 17.049196] loop: module loaded [ 17.049418] rbd: loaded (major 254) [ 17.049585] lkdtm: No crash points registered, enable through debugfs [ 17.051799] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 17.052208] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/regulators/DCDC_REG7 [ 17.052260] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_pwrdn [ 17.052280] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs3_null [ 17.052299] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs2_null [ 17.052317] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_null [ 17.052836] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 17.052969] rk806 spi2.0: ON: 0x20 OFF:0x2 [ 17.053046] rk806 spi2.0: shutdown-sequence missing! [ 17.053058] rk806 spi2.0: vb-shutdown-sequence missing! [ 17.053068] rk806 spi2.0: dvs-suspend-control-by missing! [ 17.061782] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 17.066440] rk806 spi2.0: no sleep-setting state [ 17.066457] rk806 spi2.0: no reset-setting pinctrl state [ 17.066467] rk806 spi2.0: no dvs-setting pinctrl state [ 17.067053] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 17.067068] rockchip-spi feb20000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0 [ 17.068444] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 17.068491] 1 fixed-partitions partitions found on MTD device sfc_nor [ 17.068504] Creating 1 MTD partitions on "sfc_nor": [ 17.068514] 0x000000000000-0x000001000000 : "loader" [ 17.071365] usbcore: registered new interface driver rndis_wlan [ 17.071398] usbcore: registered new interface driver asix [ 17.071420] usbcore: registered new interface driver cdc_ether [ 17.071443] usbcore: registered new interface driver rndis_host [ 17.071468] usbcore: registered new interface driver cdc_ncm [ 17.071585] VFIO - User Level meta-driver version: 0.3 [ 17.072156] platform fc000000.usb: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22 [ 17.085814] phy phy-fd5d4000.syscon:usb2-phy@4000.3: illegal mode [ 17.085838] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.085855] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1 [ 17.085949] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0002008002010010 [ 17.085984] xhci-hcd xhci-hcd.12.auto: irq 86, io mem 0xfc400000 [ 17.086068] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.086081] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2 [ 17.086096] xhci-hcd xhci-hcd.12.auto: Host supports USB 3.0 SuperSpeed [ 17.086190] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.086206] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.086218] usb usb1: Product: xHCI Host Controller [ 17.086228] usb usb1: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.086239] usb usb1: SerialNumber: xhci-hcd.12.auto [ 17.086534] hub 1-0:1.0: USB hub found [ 17.086559] hub 1-0:1.0: 1 port detected [ 17.086759] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 17.086826] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 17.086841] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.086853] usb usb2: Product: xHCI Host Controller [ 17.086862] usb usb2: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.086873] usb usb2: SerialNumber: xhci-hcd.12.auto [ 17.087132] hub 2-0:1.0: USB hub found [ 17.087155] hub 2-0:1.0: 1 port detected [ 17.087354] usbcore: registered new interface driver cdc_acm [ 17.087366] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 17.087412] ehci-platform fc800000.usb: EHCI Host Controller [ 17.087437] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 3 [ 17.087442] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 17.087477] usbcore: registered new interface driver uas [ 17.087486] ehci-platform fc880000.usb: EHCI Host Controller [ 17.087499] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 4 [ 17.087507] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 5 [ 17.087515] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 17.087521] usbcore: registered new interface driver usb-storage [ 17.087528] ehci-platform fc800000.usb: irq 87, io mem 0xfc800000 [ 17.087540] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 6 [ 17.087610] ehci-platform fc880000.usb: irq 88, io mem 0xfc880000 [ 17.087637] ohci-platform fc840000.usb: irq 89, io mem 0xfc840000 [ 17.087672] ohci-platform fc8c0000.usb: irq 90, io mem 0xfc8c0000 [ 17.087807] mousedev: PS/2 mouse device common for all mice [ 17.088351] .. rk pwm remotectl v2.0 init [ 17.088497] input: febf0030.pwm as /devices/platform/febf0030.pwm/input/input2 [ 17.088711] remotectl-pwm febf0030.pwm: Controller support pwrkey capture [ 17.088942] i2c_dev: i2c /dev entries driver [ 17.098664] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 17.098846] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.098868] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.098880] usb usb3: Product: EHCI Host Controller [ 17.098891] usb usb3: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.098901] usb usb3: SerialNumber: fc800000.usb [ 17.099188] hub 3-0:1.0: USB hub found [ 17.099225] hub 3-0:1.0: 1 port detected [ 17.111996] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 17.112186] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.112206] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.112219] usb usb5: Product: EHCI Host Controller [ 17.112229] usb usb5: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.112240] usb usb5: SerialNumber: fc880000.usb [ 17.112541] hub 5-0:1.0: USB hub found [ 17.112579] hub 5-0:1.0: 1 port detected [ 17.119357] rtc-hym8563 6-0051: rtc information is valid [ 17.122027] rtc-hym8563 6-0051: registered as rtc0 [ 17.122310] rtc-hym8563 6-0051: setting system clock to 2021-01-01T12:04:12 UTC (1609502652) [ 17.123836] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 17.124707] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 17.125519] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: enter mipi csi2 hw probe! [ 17.125626] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: probe success, v4l2_dev:mipi0-csi2-hw! [ 17.125675] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: enter mipi csi2 hw probe! [ 17.125761] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: probe success, v4l2_dev:mipi1-csi2-hw! [ 17.125803] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: enter mipi csi2 hw probe! [ 17.125884] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: probe success, v4l2_dev:mipi2-csi2-hw! [ 17.125925] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: enter mipi csi2 hw probe! [ 17.126008] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: probe success, v4l2_dev:mipi3-csi2-hw! [ 17.126049] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: enter mipi csi2 hw probe! [ 17.126130] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: probe success, v4l2_dev:mipi4-csi2-hw! [ 17.126174] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: enter mipi csi2 hw probe! [ 17.126254] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: probe success, v4l2_dev:mipi5-csi2-hw! [ 17.127328] rkisp_hw fdcb0000.rkisp: Adding to iommu group 15 [ 17.127460] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 17.127473] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 17.127494] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 17.127612] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 17.128874] usbcore: registered new interface driver uvcvideo [ 17.130538] cpu cpu0: bin=0 [ 17.130724] cpu cpu0: leakage=12 [ 17.132184] cpu cpu0: pvtm=1415 [ 17.132337] cpu cpu0: pvtm-volt-sel=1 [ 17.134384] cpu cpu4: bin=0 [ 17.134569] cpu cpu4: leakage=9 [ 17.141177] cpu cpu4: pvtm=1631 [ 17.145225] cpu cpu4: pvtm-volt-sel=2 [ 17.146236] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.146285] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.146318] usb usb4: Product: Generic Platform OHCI controller [ 17.146336] usb usb4: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.146364] usb usb4: SerialNumber: fc840000.usb [ 17.146918] hub 4-0:1.0: USB hub found [ 17.146986] hub 4-0:1.0: 1 port detected [ 17.147605] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.147648] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.147680] usb usb6: Product: Generic Platform OHCI controller [ 17.147707] usb usb6: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.147734] usb usb6: SerialNumber: fc8c0000.usb [ 17.148054] cpu cpu6: bin=0 [ 17.148238] cpu cpu6: leakage=9 [ 17.148316] hub 6-0:1.0: USB hub found [ 17.148386] hub 6-0:1.0: 1 port detected [ 17.154875] cpu cpu6: pvtm=1620 [ 17.158965] cpu cpu6: pvtm-volt-sel=2 [ 17.161011] cpu cpu0: avs=0 [ 17.161071] cpu cpu0: rockchip_pvtpll_set_volt_sel: error cfg clk_id=0 voltsel (-1) [ 17.162343] cpu cpu4: avs=0 [ 17.162396] cpu cpu4: rockchip_pvtpll_set_volt_sel: error cfg clk_id=2 voltsel (-1) [ 17.163497] cpu cpu6: avs=0 [ 17.163550] cpu cpu6: rockchip_pvtpll_set_volt_sel: error cfg clk_id=3 voltsel (-1) [ 17.163656] cpu cpu0: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 17.164019] cpu cpu0: EM: created perf domain [ 17.164469] cpu cpu4: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.172863] cpu cpu4: EM: created perf domain [ 17.173582] cpu cpu6: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.185881] rk-pcie fe180000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.185958] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.191130] cpu cpu6: EM: created perf domain [ 17.193012] sdhci: Secure Digital Host Controller Interface driver [ 17.193037] sdhci: Copyright(c) Pierre Ossman [ 17.193051] Synopsys Designware Multimedia Card Interface Driver [ 17.193849] sdhci-pltfm: SDHCI platform and OF driver helper [ 17.194318] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state [ 17.194337] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state [ 17.194395] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 17.194419] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 17.194437] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 17.194477] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 118,32 bit host data width,256 deep fifo [ 17.196461] mmc0: CQHCI version 5.10 [ 17.197225] ledtrig-cpu: registered to indicate activity on CPUs [ 17.197323] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 17.197388] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 17.198275] cryptodev: driver 1.12 loaded. [ 17.198324] hid: raw HID events driver (C) Jiri Kosina [ 17.198511] usbcore: registered new interface driver usbhid [ 17.198520] usbhid: USB HID core driver [ 17.201596] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600 [ 17.201610] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602 [ 17.201619] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605 [ 17.201628] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622 [ 17.201904] optee: probing for conduit method. [ 17.201915] optee: api uid mismatch [ 17.201922] optee: probe of firmware:optee failed with error -22 [ 17.201994] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.202412] usbcore: registered new interface driver snd-usb-audio [ 17.204456] [Awinic] aw87xxx_pa_init:driver version: v2.2.0 [ 17.205398] rockchip-i2s-tdm fddf0000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.205952] rockchip-i2s-tdm fe470000.i2s: Register PCM for TRCM mode [ 17.206350] rockchip-i2s-tdm fddf4000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.206474] rockchip-i2s-tdm fddf8000.i2s: Init RX wait-time-ms: 50 [ 17.208277] debugfs: File 'Capture' in directory 'dapm' already present! [ 17.208855] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input3 [ 17.209912] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input4 [ 17.210820] input: rockchip-hdmi1 rockchip-hdmi1 as /devices/platform/hdmi1-sound/sound/card2/input5 [ 17.211616] input: headset-keys as /devices/platform/es8388-sound/input/input6 [ 17.214912] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 17.223172] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x210022 [ 17.228179] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 17.247966] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.262142] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.262214] rk-pcie fe190000.pcie: PCIe Gen.2 x1 link up [ 17.262233] rk-pcie fe180000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.262256] rk-pcie fe180000.pcie: PCIe Gen.2 x1 link up [ 17.262524] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 17.262578] pci_bus 0004:40: root bus resource [bus 40-4f] [ 17.262589] rk-pcie fe180000.pcie: PCI host bridge to bus 0003:30 [ 17.262614] pci_bus 0004:40: root bus resource [io 0x100000-0x1fffff] (bus address [0xf4100000-0xf41fffff]) [ 17.262637] pci_bus 0003:30: root bus resource [bus 30-3f] [ 17.262662] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 17.262685] pci_bus 0003:30: root bus resource [io 0x0000-0xfffff] (bus address [0xf3100000-0xf31fffff]) [ 17.262703] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 17.262731] pci_bus 0003:30: root bus resource [mem 0xf3200000-0xf3ffffff] [ 17.262795] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 17.262834] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.262920] pci_bus 0003:30: root bus resource [mem 0x9c0000000-0x9ffffffff pref] [ 17.262923] pci 0004:40:00.0: supports D1 D2 [ 17.262935] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 17.262992] pci 0003:30:00.0: [1d87:3588] type 01 class 0x060400 [ 17.263028] pci 0003:30:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.263126] pci 0003:30:00.0: supports D1 D2 [ 17.263169] pci 0003:30:00.0: PME# supported from D0 D1 D3hot [ 17.268681] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.284557] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card3/input7 [ 17.287639] pci 0004:40:00.0: Primary bus is hard wired to 0 [ 17.287665] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.287819] pci 0004:41:00.0: [10ec:8125] type 00 class 0x020000 [ 17.287867] pci 0003:30:00.0: Primary bus is hard wired to 0 [ 17.287882] pci 0004:41:00.0: reg 0x10: [io 0x0000-0x00ff] [ 17.287886] pci 0003:30:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.287951] pci 0004:41:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.288003] pci 0004:41:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.288094] pci 0003:31:00.0: [10ec:8125] type 00 class 0x020000 [ 17.288194] pci 0003:31:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 17.288209] pci 0003:31:00.0: reg 0x10: [io size 0x0100] [ 17.288329] pci 0003:31:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.288412] pci 0003:31:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.288550] pci 0004:41:00.0: supports D1 D2 [ 17.288564] pci 0004:41:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.288955] pci 0003:31:00.0: supports D1 D2 [ 17.288970] pci 0003:31:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.289399] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 17.289435] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 17.289453] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 17.289471] pci 0004:40:00.0: BAR 7: assigned [io 0x100000-0x100fff] [ 17.289490] pci 0004:41:00.0: BAR 2: assigned [mem 0xf4200000-0xf420ffff 64bit] [ 17.289535] pci 0004:41:00.0: BAR 4: assigned [mem 0xf4210000-0xf4213fff 64bit] [ 17.289588] pci 0004:41:00.0: BAR 0: assigned [io 0x100000-0x1000ff] [ 17.289613] pci 0004:40:00.0: PCI bridge to [bus 41] [ 17.289627] pci 0004:40:00.0: bridge window [io 0x100000-0x100fff] [ 17.289631] pci_bus 0003:31: busn_res: [bus 31-3f] end is updated to 31 [ 17.289646] pci 0003:30:00.0: BAR 8: assigned [mem 0xf3200000-0xf32fffff] [ 17.289653] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 17.289661] pci 0003:30:00.0: BAR 6: assigned [mem 0xf3300000-0xf330ffff pref] [ 17.289667] pci 0003:30:00.0: BAR 7: assigned [io 0x1000-0x1fff] [ 17.289700] pci 0003:31:00.0: BAR 2: assigned [mem 0xf3200000-0xf320ffff 64bit] [ 17.289745] pci 0003:31:00.0: BAR 4: assigned [mem 0xf3210000-0xf3213fff 64bit] [ 17.289789] pci 0003:31:00.0: BAR 0: assigned [io 0x1000-0x10ff] [ 17.289812] pci 0003:30:00.0: PCI bridge to [bus 31] [ 17.289826] pci 0003:30:00.0: bridge window [io 0x1000-0x1fff] [ 17.289831] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.289851] pci 0003:30:00.0: bridge window [mem 0xf3200000-0xf32fffff] [ 17.292635] pcieport 0004:40:00.0: PME: Signaling with IRQ 135 [ 17.292842] pcieport 0003:30:00.0: PME: Signaling with IRQ 144 [ 17.298789] rk-pcie fe150000.pcie: PCIe Link up, LTSSM is 0x230011 [ 17.298835] rk-pcie fe150000.pcie: PCIe Gen.3 x4 link up [ 17.299039] rk-pcie fe150000.pcie: PCI host bridge to bus 0000:00 [ 17.299071] pci_bus 0000:00: root bus resource [bus 00-0f] [ 17.299100] pci_bus 0000:00: root bus resource [io 0x200000-0x2fffff] (bus address [0xf0100000-0xf01fffff]) [ 17.299133] pci_bus 0000:00: root bus resource [mem 0xf0200000-0xf0ffffff] [ 17.299159] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref] [ 17.299211] pci 0000:00:00.0: [1d87:3588] type 01 class 0x060400 [ 17.299251] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.299326] pci 0000:00:00.0: supports D1 D2 [ 17.299350] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 17.308621] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 17.310964] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.313985] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 17.314101] pci 0000:01:00.0: [c0a9:5427] type 00 class 0x010802 [ 17.314199] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 17.314790] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link) [ 17.325574] pci 0000:00:00.0: BAR 8: assigned [mem 0xf0200000-0xf02fffff] [ 17.325632] pci 0000:00:00.0: BAR 6: assigned [mem 0xf0300000-0xf030ffff pref] [ 17.325672] pci 0000:01:00.0: BAR 0: assigned [mem 0xf0200000-0xf0203fff 64bit] [ 17.325735] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 17.325762] pci 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff] [ 17.328988] pcieport 0000:00:00.0: PME: Signaling with IRQ 154 [ 17.329785] nvme nvme0: pci function 0000:01:00.0 [ 17.330019] nvme 0000:01:00.0: enabling device (0000 -> 0002) [ 17.332003] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.344648] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 17.353051] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.359070] Initializing XFRM netlink socket [ 17.359119] NET: Registered PF_PACKET protocol family [ 17.359307] [BT_RFKILL]: Enter rfkill_rk_init [ 17.359314] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 17.359725] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 17.359747] [WLAN_RFKILL]: can't find rockchip,grf property [ 17.359753] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p [ 17.359759] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 17.359765] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 17.359810] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0. [ 17.359820] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 17.359826] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 17.359832] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [ 17.359838] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 17.360248] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 148. [ 17.360275] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 21. [ 17.360295] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 150. [ 17.360314] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0. [ 17.360354] [BT_RFKILL]: Request irq for bt wakeup host [ 17.360463] [BT_RFKILL]: ** disable irq [ 17.360553] [BT_RFKILL]: bt shut off power [ 17.385416] [BT_RFKILL]: bt_default device registered. [ 17.385611] input: bt-powerkey as /devices/platform/wireless-bluetooth/input/input8 [ 17.386104] Key type dns_resolver registered [ 17.386157] Key type ceph registered [ 17.386863] libceph: loaded (mon/osd proto 15/24) [ 17.389637] registered taskstats version 1 [ 17.389705] Loading compiled-in X.509 certificates [ 17.394797] zswap: loaded using pool zstd/zbud [ 17.395342] Key type .fscrypt registered [ 17.395370] Key type fscrypt-provisioning registered [ 17.396740] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no [ 17.397270] pstore: Using crash dump compression: deflate [ 17.397684] Key type encrypted registered [ 17.398082] AppArmor: AppArmor sha1 policy hashing enabled [ 17.409984] rga3 fdb60000.rga: Adding to iommu group 2 [ 17.410299] rga3 fdb60000.rga: probe successfully, irq = 50, hw_version:3.0.76831 [ 17.410378] rga3 fdb70000.rga: Adding to iommu group 3 [ 17.410591] rga3 fdb70000.rga: probe successfully, irq = 51, hw_version:3.0.76831 [ 17.411096] rga2 fdb80000.rga: probe successfully, irq = 157, hw_version:3.2.63318 [ 17.411197] rga: IOMMU binding successfully, default mapping core[0x1] [ 17.411307] rga: Module initialized. v1.3.7 [ 17.428976] mpp_vdpu1 fdb51000.avsd-plus: Adding to iommu group 1 [ 17.429491] mpp_vdpu1 fdb51000.avsd-plus: probe device [ 17.429863] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.429904] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.430015] mpp_vdpu1 fdb51000.avsd-plus: probing finish [ 17.430384] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 17.430491] mpp_vdpu2 fdb50400.vdpu: probe device [ 17.430735] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.430765] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.430805] mpp_vdpu2 fdb50400.vdpu: probing finish [ 17.431113] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 17.431216] mpp_vepu2 fdb50000.vepu: probing start [ 17.431487] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.431517] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.431585] mpp_vepu2 fdb50000.vepu: probing finish [ 17.431923] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 17.432140] mpp_vepu2 fdba0000.jpege-core: probing start [ 17.432468] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 17.432541] mpp_vepu2 fdba0000.jpege-core: probing finish [ 17.432853] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 17.433029] mpp_vepu2 fdba4000.jpege-core: probing start [ 17.433332] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 17.433403] mpp_vepu2 fdba4000.jpege-core: probing finish [ 17.433738] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 17.433922] mpp_vepu2 fdba8000.jpege-core: probing start [ 17.434221] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 17.434292] mpp_vepu2 fdba8000.jpege-core: probing finish [ 17.434629] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 17.434806] mpp_vepu2 fdbac000.jpege-core: probing start [ 17.435111] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 17.435182] mpp_vepu2 fdbac000.jpege-core: probing finish [ 17.435611] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 17.435804] mpp-iep2 fdbb0000.iep: probe device [ 17.436396] mpp-iep2 fdbb0000.iep: probing finish [ 17.436518] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 17.436635] mpp_jpgdec fdb90000.jpegd: probe device [ 17.436723] mpp_jpgdec fdb90000.jpegd: probing finish [ 17.436812] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 17.436973] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 17.437048] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 17.437054] rkvdec2_init:1198: No niu aclk reset resource define [ 17.437059] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 17.437063] rkvdec2_init:1201: No niu hclk reset resource define [ 17.437098] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 17.437135] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 17.437141] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 17.437256] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 17.437262] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 17.437267] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 17.437271] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 17.437277] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 17.437282] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 17.437286] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 17.437291] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 17.437295] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 17.437300] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 17.437304] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 17.437309] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 17.437313] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 17.437318] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 17.437322] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 17.437326] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 17.437345] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 17.437433] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 17.437563] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 17.437635] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 17.437641] rkvdec2_init:1198: No niu aclk reset resource define [ 17.437645] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 17.437650] rkvdec2_init:1201: No niu hclk reset resource define [ 17.437671] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 17.437699] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 17.437715] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 17.437823] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 17.437828] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 17.437833] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 17.437838] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 17.437843] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 17.437848] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 17.437852] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 17.437857] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 17.437861] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 17.437866] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 17.437870] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 17.437875] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 17.437879] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 17.437884] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 17.437888] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 17.437893] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 17.437913] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 17.437998] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 17.438091] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 17.438188] mpp_rkvenc2 fdbd0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.438195] mpp_rkvenc2 fdbd0000.rkvenc-core: bin=0 [ 17.438380] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage=11 [ 17.438386] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage-volt-sel=0 [ 17.438418] mpp_rkvenc2 fdbd0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.438436] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to set opp config [ 17.438441] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init opp info [ 17.438445] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init_opp_table [ 17.438449] rkvenc_init:2147: failed to add venc devfreq [ 17.438469] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 17.438487] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 17.438567] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 17.438667] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 17.438753] mpp_rkvenc2 fdbe0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.438759] mpp_rkvenc2 fdbe0000.rkvenc-core: bin=0 [ 17.438929] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage=11 [ 17.438934] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage-volt-sel=0 [ 17.438958] mpp_rkvenc2 fdbe0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.438970] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to set opp config [ 17.438975] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init opp info [ 17.438979] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init_opp_table [ 17.438983] rkvenc_init:2147: failed to add venc devfreq [ 17.439020] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 17.439036] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 17.439120] mpp_av1dec fdc70000.av1d: Adding to iommu group 14 [ 17.439256] mpp_av1dec fdc70000.av1d: probing start [ 17.439352] mpp_av1dec fdc70000.av1d: probing finish [ 17.439820] rockchip-dmc dmc: bin=0 [ 17.439992] rockchip-dmc dmc: leakage=35 [ 17.439999] rockchip-dmc dmc: leakage-volt-sel=1 [ 17.440006] rockchip-dmc dmc: soc version=0, speed=1 [ 17.440182] mali fb000000.gpu: Kernel DDK version g25p0-00eac0 [ 17.440238] mali fb000000.gpu: GPU metrics tracepoint support enabled [ 17.444985] mali fb000000.gpu: bin=0 [ 17.445158] mali fb000000.gpu: leakage=14 [ 17.445178] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.445636] rockchip-dmc dmc: avs=0 [ 17.445651] rockchip-dmc dmc: current ATF version 0x100 [ 17.445812] rockchip-dmc dmc: normal_rate = 1560000000 [ 17.445819] rockchip-dmc dmc: reboot_rate = 2112000000 [ 17.445825] rockchip-dmc dmc: suspend_rate = 528000000 [ 17.445830] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 17.445836] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 17.445841] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 17.445847] rockchip-dmc dmc: boost_rate = 2112000000 [ 17.445852] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 17.445858] rockchip-dmc dmc: performance_rate = 2112000000 [ 17.445864] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 17.445870] rockchip-dmc dmc: deep_suspend_rate = 2112000000 [ 17.445877] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 17.445883] rockchip-dmc dmc: failed to get vop pn to msch rl [ 17.446111] rockchip-dmc dmc: l=15000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 17.446164] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 235 [ 17.446197] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 17.446645] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 17.450278] mali fb000000.gpu: pvtm=816 [ 17.452503] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 17.452589] GPT:3235839 != 31116287 [ 17.452602] GPT:Alternate GPT header not at the end of the disk. [ 17.452616] GPT:3235839 != 31116287 [ 17.452627] GPT: Use GNU Parted to correct GPT errors. [ 17.452653] mmcblk1: p1 [ 17.456624] mali fb000000.gpu: pvtm-volt-sel=1 [ 17.456736] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.458413] mali fb000000.gpu: avs=0 [ 17.458521] mali fb000000.gpu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=5 voltsel (-1) [ 17.458566] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 144; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 17.459429] WCN: marlin_init entry! [ 17.459488] mali fb000000.gpu: Register LUT 000a0800 initialized for GPU arch 0x000a0806 [ 17.459541] mali fb000000.gpu: r0p0 status 5 not found in HW issues table; [ 17.459562] mali fb000000.gpu: falling back to closest match: r0p0 status 0 [ 17.459580] mali fb000000.gpu: Execution proceeding normally with fallback match [ 17.459599] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 17.459714] mali fb000000.gpu: CSF_GPU_RESET_TIMEOUT is capped from 20666ms to 4500ms [ 17.459739] mali fb000000.gpu: KBASE_PRFCNT_ACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.459760] mali fb000000.gpu: KBASE_AS_INACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.459780] mali fb000000.gpu: CSF_FIRMWARE_STOP_TIMEOUT is capped from 40000ms to 4500ms [ 17.459854] mali fb000000.gpu: No priority control manager is configured [ 17.459873] mali fb000000.gpu: Large page allocation set to false after hardware feature check [ 17.460184] mali fb000000.gpu: No memory group manager is configured [ 17.460228] mali fb000000.gpu: Protected memory allocator not available [ 17.460761] RKNPU fdab0000.npu: Adding to iommu group 0 [ 17.460982] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 17.462436] mali fb000000.gpu: EM: created perf domain [ 17.462637] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 17.462672] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 17.462696] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 17.462789] mali fb000000.gpu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.463410] [drm] Initialized rknpu 0.9.8 20240828 for fdab0000.npu on minor 1 [ 17.464159] mali fb000000.gpu: * MALI kbase_mmap_min_addr compiled to CONFIG_DEFAULT_MMAP_MIN_ADDR, no runtime update possible! * [ 17.464179] mali fb000000.gpu: Probed as mali0 [ 17.464915] hwmon hwmon8: temp1_input not attached to any thermal zone [ 17.465049] hwmon hwmon8: temp2_input not attached to any thermal zone [ 17.466216] RKNPU fdab0000.npu: RKNPU: bin=0 [ 17.466426] RKNPU fdab0000.npu: leakage=8 [ 17.466468] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.474051] RKNPU fdab0000.npu: pvtm=814 [ 17.475374] nvme nvme0: allocated 64 MiB host memory buffer. [ 17.479475] RKNPU fdab0000.npu: pvtm-volt-sel=0 [ 17.479591] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.482014] RKNPU fdab0000.npu: avs=0 [ 17.482107] RKNPU fdab0000.npu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=6 voltsel (-1) [ 17.482283] RKNPU fdab0000.npu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.489359] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91 [ 17.489411] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.489441] usb 1-1: Product: USB2.1 Hub [ 17.489465] usb 1-1: Manufacturer: GenesysLogic [ 17.496617] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 17.518220] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 17.519182] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 17.520164] clk: Disabling unused clocks [ 17.521790] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 17.522587] rockchip-suspend not set sleep-mode-config for mem-lite [ 17.522615] rockchip-suspend not set wakeup-config for mem-lite [ 17.522644] rockchip-suspend not set sleep-mode-config for mem-ultra [ 17.522668] rockchip-suspend not set wakeup-config for mem-ultra [ 17.525353] ALSA device list: [ 17.525379] #0: rockchip-dp0 [ 17.525400] #1: rockchip-hdmi0 [ 17.525419] #2: rockchip-hdmi1 [ 17.525438] #3: rockchip-es8388 [ 17.534502] hub 1-1:1.0: USB hub found [ 17.534766] hub 1-1:1.0: 4 ports detected [ 17.596619] nvme nvme0: 8/0/0 default/read/poll queues [ 17.609378] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 17.631903] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91 [ 17.631965] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.632029] usb 2-1: Product: USB3.2 Hub [ 17.632054] usb 2-1: Manufacturer: GenesysLogic [ 17.660964] Freeing unused kernel memory: 8320K [ 17.661384] Run /init as init process [ 17.663401] hub 2-1:1.0: USB hub found [ 17.664091] hub 2-1:1.0: 4 ports detected [ 17.993319] input: adc-keys as /devices/platform/adc-keys/input/input9 [ 18.004482] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 18.004516] rockchip-cpuinfo cpuinfo: Serial : 9f77ef415554aece DDR V1.13 25cee80c4f cym 23/08/11-09:31:58 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB Manufacturer ID:0xff CH0 RX Vref:28.9%, TX Vref:22.8%,21.8% CH1 RX Vref:26.7%, TX Vref:21.8%,20.8% CH2 RX Vref:28.9%, TX Vref:20.8%,20.8% CH3 RX Vref:28.5%, TX Vref:20.8%,20.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Nov 15 2023 - 16:53:25) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(d41c62e80b...) + OK ## Checking fdt 0x00355940 ... sha256(7146109403...) + OK ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 741.283 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 usb dr_mode not found usb dr_mode not found U-Boot 2017.09_armbian-2017.09-S3f41-Pdfdd-H6539-Ve691-Bbf55-R448a (Nov 19 2025 - 17:07:00 +0000) Model: Orange Pi 5 Plus MPIDR: 0x0 PreSerial: 2, raw, 0xfeb50000 DRAM: 31.7 GiB Sysmem: init Relocation Offset: eda09000 Relocation fdt: eb9f7610 - eb9fecd0 CR: M/C/I usb dr_mode not found usb dr_mode not found Using default environment DM: v2 RESC: No bootdev Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Orange Pi 5 Plus [Vendor ERROR]:Invalid boot device type(0) ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 [Vendor ERROR]:Invalid boot device type(0) rockchip_set_ethaddr: vendor_storage_write failed -19 [Vendor ERROR]:Invalid boot device type(0) mmc@fe2c0000: 1, mmc@fe2e0000: 0 Card did not respond to voltage select! mmc_init: -95, time 13 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 No bootdev dev_desc is NULL! boot mode: None No bootdev CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz MMC1: Legacy, 52Mhz PartType: EFI No bootdev dev_desc is NULL! No bootdev Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 Bus usb@fc400000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc800000 for devices... 1 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning bus usb@fc400000 for devices... cannot reset port 1!? 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ............. and so on
