BananaPi M1 failed boot after armbian-upgrade
eselarm replied to Chris007's topic in Allwinner sunxi
Somehow the SD-card contents and SSD contents could be mixed-up or partly double. I do not know what armbian-update does, but what is your plan or what do you want? Should Armbian run from SD-card or SSD? -
Nasko replied to Shakai2's topic in Allwinner sunxi
Same Here. I am using Armbian on top of cubietruk as cups print server for years without issue. Now I have decided to see if I can use scanning function of my Samsung SCX-4600 3 in 1 machine. So, I logged in via ssh to my cubietruk running Armbian 23.02.0-trunk Lunar and I just did sudo apt-get update (And got some errors of missing repos), Despite that I have decided to give a try with sudo apt-get install sane Result was 5-6 missing packages Next obvious step was to start armbian-config and I went directly with "Update firmware and packages" Update was success and armbian-config asked for a reboot, which I did. Unfortunately the system was not able to boot. Luckily I have 23" HP Z-series monitor next to my trusty SBC and saw that on the console was lots of errors related to ETHERNET. Second and third reboot was pointles, so I have decided that It is time for fresh install for my cusps print- server. I have downloaded "Debian 12 (Bookworm)Minimal / IOT" from https://www.armbian.com/cubietruck/ and I have flashed it using dd. Next obvious step was to start the system. I saw U-Boot Logo and "Starting Kernel" Then the screen went BLACK. NOTHING. Now there is no way to configure this fresh install. Is there any workarounds? - Today
Ach, OK. On Banana Pi M4 Zero (H618), the Ethernet PHY is integrated into the SoC, specifically within the AC200 block. There is no external Ethernet PHY chip like RTL8211F — the EMAC1 interface uses RMII and talks directly to the internal PHY. The issue I’m facing is likely due to incompatibility with kernel 6.x.x. I haven’t been able to get any overlay to work properly. However, with a kernel from the 5.4.x series, Ethernet works out-of-the-box on the same hardware. Any insights on proper overlay structure or required patches for AC200 support in newer kernels would be highly appreciated. Thanks for your help!
Werner replied to Nguyễn Tất Hùng's topic in Amlogic CPU Boxes
Okay, then you have to adjust the source to mitigate the issue. Also log excerpts are often useless. My random guess is that uboot is some old outdated version depending on python2 which has been deprecated years ago. -
Hi, yesterday i see a "armbian-update" message after login per ssh. I run this command and than my banana pi M1 won't boot. How can i repair it without formatting the SSD? Regards Christian
Ask where you got the source code from. -
@StanleyLIM I see it should run a variant of OpenWrt, see https://www.friendlyelec.com/index.php?route=product/product&path=69&product_id=290 My NanoPi-R6C got delivered with that FriendlyWrt pre-installed on eMMC. I bought the R6C as alternative for RPi5, nice metal passive cooling and M.2 M-key as well. FriendlyWrt uses a bunch of partitions to store various objects related to the boot stage and although it would be nice for a router, I wanted generic Linux as base. But R6C is using RK3588S as SoC, yours RK3568B2. Based on experience with my ROCK3A (RK3568), you could first check if both NICs are available on PCI-E, 'sudo lspci' should show. If available, 'sudo ip link' should also show the 2 NICs as network ports. Then it is a matter of high-level networking, not really specific to Armbian.
Odroid C4 is using HC4 dtb and odroidhc4 packages
spleeth replied to spleeth's topic in Amlogic meson
To anyone this may help, removing hc4 related packages and replacing them with c4 packages did the job. Only to discover that, for whatever reason, I actually had an HC4 board and convince myself that it was a C4 ... Anyway, the reverse process also worked as expected and my board is now running 25.051.1 happily, except for the samsung SSD not recognized at boot, and requires to be hot plugged just after the linux kernel starts in order to be seen by the system, as it is described in other threads. -
To be more precise - parameters that are provided to that driver. If driver would be the problem, both NICs would be down. You need to find / create correct settings (device tree), based on schematics. This forum (search) can provide plenty of resources and hints how to do this. Someone from community (with the device so testing can be done) has to sacrifice afternoon or more to get this in operation.
why I self build Armbian and get this error when build armbian [🐳|🔨] /armbian/cache/sources/u-boot-worktree/u-boot-ugoos-sk1/khoahung_dev/drivers/misc/swap_case.c:56:(.text+0x3eb4): undefined reference to `ofnode_get_property' [🐳|🔨] collect2: error: ld returned 1 exit status [🐳|🔨] make: *** [Makefile:1824: u-boot] Error 1 [🐳|💥] Error 2 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:223 run_host_command_logged_raw() --> lib/functions/logging/runners.sh:223 run_host_command_logged_long_running() --> lib/functions/logging/runners.sh:200 do_with_ccache_statistics() --> lib/functions/compilation/ccache.sh:39 compile_uboot_target() --> lib/functions/compilation/uboot.sh:245 loop_over_uboot_targets_and_do() --> lib/functions/compilation/uboot.sh:336 compile_uboot() --> lib/functions/compilation/uboot.sh:444 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_uboot_build_from_sources() --> lib/functions/artifacts/artifact-uboot.sh:177 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:102 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [🐳|💥] Cleaning up [ please wait for cleanups to finish ] [🐳|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-no-uuidgen-yet-29800-91055.log.ans ] [🐳|🌱] Share log manu
I'm brought the NanoPi-R5C to setup Internet-in-a-Box on for an Orphan school. I would like both the network port to work so that 1 part can be connected to the internet and the second can be connected to their local router. Base on the documentation, the 2 LAN port uses the same RTL8125BG. I assume driver shouldn't be the issue..
Mechano replied to Mechano's topic in Allwinner sunxi
They have a repository on Mega and Baidu. https://wiki.sipeed.com/hardware/en/longan/h618/lpi3h/3_images.html - Yesterday
As far as I know openvfd needs to be re-worked to support 6.12.y and up. EDIT: I stand corrected. I found a working patch at unifreq. It needs to be patched against the source-tree. 0001-drv-auxdisplay-Add-openvfd-driver.patch
With logs, we could see if this is NIC not recognized or network stack problem. Community supported target are often not having anyone behind https://docs.armbian.com/User-Guide_Board-Support-Rules/
@KrzyPacu Can you look at your full dmesg output (no filter on tm16xx)? I guess there are some other error messages prior to there filtered output. I don't think that you have a different controller. Maybe rather the pinout: which pins of the SoC of your TV box are wired to the controller and how they are declared in the device tree. Was your display working properly with the OpenVFD driver and the hk1-x3.conf VFD configuration file you posted? If so, the controller is good and it's probably the pin numbers described in the device tree that needs to be adjusted. My hk1-x3.dtso was converted from the OpenVFD configuration file, but the device hasn't been tested yet to my knowledge. So it might need some corrections. -
@junji. Can you explain me how you proceed to boot this OS image Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_xfce_desktop.img.xz ?
For a few weeks I've been using the latest official release from May 26, 2025, running just fine from my NVME drive. But then I turned it on and at the screen where you get the Amrbian grey/red logo in the middle of the screen and the spinning circle, it went no further. The spinning circle would either stop rotating or disappear after a minute or so. I can SSH into the device. But when I use remote desktop from a Windows PC, the full and functioning desktop is there. It's just not on my TV screen any more. I've done the usual HDMI cable testing and powering off the TV completely, but no change. The fact that the desktop is accessible remotely does indicate that it must be loading in some fashion. Took a log here: https://paste.next.armbian.com/qococumoga
# make -j 4 make -C /lib/modules/6.12.33-current-meson64/build M=/home/INSTALKI/linux_openvfd/driver modules make[1]: Enter the directory '/usr/src/linux-headers-6.12.33-current-meson64' CC [M] /home/INSTALKI/linux_openvfd/driver/protocols/i2c_sw.o CC [M] /home/INSTALKI/linux_openvfd/driver/protocols/i2c_hw.o CC [M] /home/INSTALKI/linux_openvfd/driver/protocols/spi_sw.o CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/dummy.o CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/seg7_ctrl.o /home/INSTALKI/linux_openvfd/driver/controllers/seg7_ctrl.c:11:6: warning: no previous prototype for ‘transpose8rS64’ [-Wmissing-prototypes] 11 | void transpose8rS64(unsigned char* A, unsigned char* B) { | ^~~~~~~~~~~~~~ /home/INSTALKI/linux_openvfd/driver/controllers/seg7_ctrl.c:40:8: warning: no previous prototype for ‘seg7_write_display_data’ [-Wmissing-prototypes] 40 | size_t seg7_write_display_data(const struct vfd_display_data *data, unsigned short *raw_wdata, size_t sz) | ^~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/fd628.o CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/fd650.o CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/hd44780.o CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/gfx_mono_ctrl.o CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/ssd1306.o CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/pcd8544.o /home/INSTALKI/linux_openvfd/driver/controllers/gfx_mono_ctrl.c:239:6: warning: no previous prototype for ‘transpose_buffer’ [-Wmissing-prototypes] 239 | void transpose_buffer(unsigned char *buffer, const struct rect *rect) | ^~~~~~~~~~~~~~~~ CC [M] /home/INSTALKI/linux_openvfd/driver/controllers/il3829.o CC [M] /home/INSTALKI/linux_openvfd/driver/openvfd_drv.o /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:44:7: warning: "CONFIG_AMLOGIC_LEGACY_EARLY_SUSPEND" is not defined, evaluates to 0 [-Wundef] 44 | #elif CONFIG_AMLOGIC_LEGACY_EARLY_SUSPEND | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c: In function ‘register_openvfd_driver’: /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:400:75: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body] 400 | pr_dbg("%s: Succeeded to add openvfd module \n", __func__); | ^ /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c: At top level: /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:622:19: warning: no previous prototype for ‘gpiochip_find’ [-Wmissing-prototypes] 622 | struct gpio_chip *gpiochip_find(void *data, | ^~~~~~~~~~~~~ /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:669:5: warning: no previous prototype for ‘evaluate_pin’ [-Wmissing-prototypes] 669 | int evaluate_pin(const char *name, const unsigned int *vfd_arg, struct vfd_pin *pin, unsigned char enable_skip_evaluation) | ^~~~~~~~~~~~ /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:752:6: warning: no previous prototype for ‘get_pin_from_dt’ [-Wmissing-prototypes] 752 | void get_pin_from_dt(const char *name, const struct platform_device *pdev, struct vfd_pin *pin) | ^~~~~~~~~~~~~~~ /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:763:5: warning: no previous prototype for ‘request_pin’ [-Wmissing-prototypes] 763 | int request_pin(const char *name, struct vfd_pin *pin, unsigned char enable_skip) | ^~~~~~~~~~~ /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:1034:19: error: initialization of ‘void (*)(struct platform_device *)’ from incompatible pointer type ‘int (*)(struct platform_device *)’ [-Werror=incompatible-pointer-types] 1034 | .remove = openvfd_driver_remove, | ^~~~~~~~~~~~~~~~~~~~~ /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:1034:19: note: (near initialization for ‘openvfd_driver.<anonymous>.remove’) /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c: In function ‘print_param_debug’: /home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:611:1: warning: the frame size of 1040 bytes is larger than 1024 bytes [-Wframe-larger-than=] 611 | } | ^ cc1: some warnings being treated as errors make[3]: *** [scripts/Makefile.build:229: /home/INSTALKI/linux_openvfd/driver/openvfd_drv.o] Error 1 make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1945: /home/INSTALKI/linux_openvfd/driver] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:5: modules] Error 2 I'm trying to compile the "openvfd" driver but the compilation ends with an error. I'm a complete noob at these things and I really want this driver so I'd be very grateful for any help.
Kernel 6.12.20 Banana Pi M2 zero USB doesn't work
laibsch replied to Bernd's topic in Allwinner sunxi
Thank you for letting us know, much appreciated. Have you tried to reach out to Michael Hawkins, the maintainer? -
Hello all Is anybody having success with spidev with orange pi zero 3 and Linux 6.12? I want to test my LCD panel's touch, but I need spidev working first
