  2. HOST /dts-v1/; /plugin/; / { fragment@0 { target = <&usbotg>; __overlay__ { dr_mode = "host"; }; }; }; OTG /dts-v1/; /plugin/; / { fragment@0 { target = <&usbotg>; __overlay__ { dr_mode = "otg"; }; }; }; By default it is set to peripheral.
  3. Thank you for the information I have completed the build dependencies step, for mesa 25.2, in Debian Trixie. However, when I build it, my orange pi zero 3 with 1 GB or RAM, it runs out of memory... even when I make a swap file of 2GB. I keep rebooting the opiz3, and continue the compilation job. Is this normal? In the raspberry forum, they told me that my LCD driver panel-mipi-dbi.ko doesn't work with X11... so I give up on this, and continue my development with labwc/wayland (easily installed in Trixie)
  4. Device tree it is. I will follow up if i have any success. Thanks !
  5. I set the dram speed to 648, no difference. Gotta be the axp or another option.
  6. Maybe the mirror isn't good at this time. You can work around by choosing any mirror from this list and add it to your armbian source list: https://docs.armbian.com/Mirrors/
  7. Ah, I misunderstood. I thought does not appear at all anymore but the question was about manual call. Has been answered properly already.
  8. If there is no overlay available you may need to write one by yourself. I'd start by modifying the device tree itself and set the port in question to host and see if this actually works. I think armbian-config comes with a device tree editor. Make sure to make a backup beforehand.
  9. Thank you @laibsch I unfortunately don't understand @Werner's response, but yours is very helpful, thank you very much! I will look at trying to add that to my .bashrc or .zshrc I suppose! cheers
  10. hello experts, any fix for the redirection issue. i am still getting below error while doing sudo apt update Err:7 https://mirror.albony.in/armbian bookworm Release Redirection from https to 'http://mirror.nag.albony.in/armbian/dists/bookworm/Release' is forbidden [IP: 82.180.XXX.XXX 443]
  11. Hmm, in boot log I see AXP1530 mentioned in theandroid boot (booted off the sd card, not emmc). I attached the log. bootinfo.txt
  12. Hi, Board: BPI‑M4 Zero OS: Armbian (Bookworm), kernel 6.12.35 (current) This board has two USB‑C ports: one fixed HOST and one OTG. I’d like the OTG port (USB0) to operate as a host as well. I can’t find any Armbian overlay in armbian-config or on the forums that flips USB0 to host. If anyone has this working, it would be cool to let me know . Thanks!
  13. According to Android uboot, DRAM_VCC= 1200mv DRAM CLK =648 MHZ DRAM TYPE=7 (lpddr3) DRAM SIZE =1536 MBytes, para1 = 30fa, para2 = 6001000, dram_tpr13 = 26061 gonna try some of this in the x96q image, see what happens
  14. Hmm, according to the config, the X96q lpddr3 uses the AXP313 already. Maybe ram is wrong? Pretty sure it's lpddr3, if there is any way to check that, I can. Gonna do a little digging in android.
  15. Cool, good to know. I'll try one with the same AXP and go from there.
  16. I cannot provide the answer, but have you had a chance to check https://www.armbian.com/tinkerboard/ ? I am not sure if the maintainer Paolo is active in the forum. Edit: found him. ping @jock
  17. moved to off-topic we dont support 3rd party os.
  18. The answer to your question is "sudo run-parts /etc/update-motd.d/", @snow To have that information displayed every time you login, you might want to check ~/.profile or ~/.bash* files if you use bash as your shell. I am not sure what problem you might run into since as you can see above the run-parts command needs root. Do some testing, with and without root.
  19. I have followed this guide for Firefly SDK Buildroot and I am unable to get the shell on uart2(ttyS2) or fiq-debugger port. I have checked multiple blogs, tickets, and forums, and edited .dts and .dtsi to: Disable fiq-debugger and use uart2 as shell Disable uart2 and enable fiq-debugger (default file mode) Route fiq-debugger to uart 0x00 by editing serial ID and other configs to use uart2 (ttyS2) …but I am unable to get shell access on console. I am a beginner in this, so I apologize in advance as I feel there might be a small issue I am unable to identify. Here are the relevant files/content: rk3568-linux.dtsi / { aliases { mmc0 = &sdhci; mmc1 = &sdmmc0; mmc2 = &sdmmc1; mmc3 = &sdmmc2; }; chosen: chosen { bootargs = "earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 rw rootwait rootdelay=5 debug"; /*bootargs = "earlycon=uart8250,mmio32,0xfe660000 console=ttyS2,1500000n8 rw root=PARTUUID=614e0000-0000 rootwait";*/ }; fiq-debugger { label = "fiq-debugger-uart2"; compatible = "rockchip,fiq-debugger"; rockchip,serial-id = <2>; rockchip,wake-irq = <0>; /* If enable uart uses irq instead of fiq */ rockchip,irq-mode-enable = <1>; rockchip,baudrate = <1500000>; /* Only 115200 and 1500000 */ interrupts = <GIC_SPI 252 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; pinctrl-0 = <&uart2m0_xfer>; status = "okay"; }; One problem I can think of is that it's unable to mount root. Here are the logs: DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21 ln LP4/4x derate en, other dram:1x trefi ddrconfig:0 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB tdqss: cs0 dqs0: -24ps, dqs1: -72ps, dqs2: -72ps, dqs3: -120ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x62 rx vref: 32.4% tx vref: 34.0% change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 32.4% tx vref: 38.0% change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 15.6% tx vref: 40.0% change to: 1560MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x2b rx vref: 17.6% tx vref: 21.8% cs 0: the read training result: DQS0:0x31, DQS1:0x35, DQS2:0x31, DQS3:0x31, min : 0x3 0x5 0x3 0x2 0x4 0x1 0x2 0x5 , 0x2 0x8 0x8 0x8 0x3 0x7 0x6 0x6 , 0x4 0x2 0x4 0x3 0x3 0x6 0x5 0x8 , 0x4 0x3 0x3 0x2 0x2 0x6 0x5 0x4 , mid :0x1d 0x1f 0x1c 0x1c 0x1f 0x1c 0x1d 0x1e ,0x1a 0x1e 0x1e 0x1e 0x1a 0x20 0x20 0x21 , 0x1e 0x1d 0x1e 0x1f 0x1c 0x1f 0x1e 0x1f ,0x1c 0x1a 0x1a 0x1b 0x19 0x1d 0x21 0x1a , max :0x38 0x39 0x36 0x36 0x3a 0x38 0x39 0x38 ,0x32 0x34 0x34 0x35 0x32 0x39 0x3a 0x3c , 0x38 0x38 0x38 0x3b 0x36 0x38 0x37 0x37 ,0x34 0x32 0x32 0x34 0x31 0x34 0x3d 0x30 , range:0x35 0x34 0x33 0x34 0x36 0x37 0x37 0x33 ,0x30 0x2c 0x2c 0x2d 0x2f 0x32 0x34 0x36 , 0x34 0x36 0x34 0x38 0x33 0x32 0x32 0x2f ,0x30 0x2f 0x2f 0x32 0x2f 0x2e 0x38 0x2c , the write training result: DQS0:0x27, DQS1:0x1d, DQS2:0x1d, DQS3:0x14, min :0x5f 0x60 0x5f 0x5e 0x5e 0x5d 0x5f 0x60 0x5e ,0x4e 0x52 0x50 0x51 0x50 0x53 0x53 0x52 0x4e , 0x57 0x54 0x55 0x56 0x53 0x55 0x53 0x55 0x55 ,0x4b 0x4c 0x4b 0x4a 0x49 0x4a 0x4c 0x4c 0x4a , mid :0x77 0x79 0x78 0x76 0x78 0x76 0x77 0x79 0x76 ,0x67 0x69 0x69 0x6a 0x68 0x6c 0x6c 0x6c 0x68 , 0x70 0x6e 0x6f 0x70 0x6d 0x6e 0x6d 0x6e 0x6f ,0x61 0x61 0x60 0x61 0x5f 0x60 0x66 0x61 0x62 , max :0x90 0x93 0x91 0x8f 0x92 0x90 0x8f 0x93 0x8f ,0x80 0x81 0x82 0x83 0x81 0x86 0x86 0x86 0x83 , 0x89 0x89 0x89 0x8a 0x87 0x87 0x88 0x87 0x89 ,0x78 0x77 0x76 0x78 0x76 0x77 0x81 0x76 0x7a , range:0x31 0x33 0x32 0x31 0x34 0x33 0x30 0x33 0x31 ,0x32 0x2f 0x32 0x32 0x31 0x33 0x33 0x34 0x35 , 0x32 0x35 0x34 0x34 0x34 0x32 0x35 0x32 0x34 ,0x2d 0x2b 0x2b 0x2e 0x2d 0x2d 0x35 0x2a 0x30 , CA Training result: cs:0 min :0x57 0x4e 0x57 0x45 0x56 0x44 0x4c ,0x50 0x45 0x4b 0x47 0x51 0x40 0x4f , cs:0 mid :0x8f 0x91 0x8e 0x89 0x8c 0x87 0x76 ,0x88 0x87 0x87 0x87 0x88 0x81 0x77 , cs:0 max :0xc7 0xd4 0xc5 0xcd 0xc3 0xcb 0xa1 ,0xc1 0xca 0xc3 0xc8 0xbf 0xc3 0xa0 , cs:0 range:0x70 0x86 0x6e 0x88 0x6d 0x87 0x55 ,0x71 0x85 0x78 0x81 0x6e 0x83 0x51 , out U-Boot SPL board init U-Boot SPL 2017.09-g606f72bd97a-240527 #lxh (May 30 2024 - 16:08:15), fwver: v1.14 unknown raw ID 0 0 0 unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 MMC: no card present mmc_init: -123, time 0 spl: mmc init failed with error: -123 Trying to boot from MMC1 SPL: A/B-slot: _a, successful: 0, tries-remain: 7 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(b5946ac63d...) + OK ## Checking uboot 0x00a00000 ... sha256(c843395069...) + OK ## Checking fdt 0x00b47be0 ... sha256(b3854af6ad...) + OK ## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK ## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK ## Checking atf-4 0xfdcce000 ... sha256(86ef885748...) + OK ## Checking atf-5 0xfdcd0000 ... sha256(0b2b146c60...) + OK ## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK ## Checking optee 0x08400000 ... sha256(28fba8b7d7...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 122.975/222.356 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44 NOTICE: BL31: Built : 16:36:43, Sep 19 2023 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid 220114 INFO: l3 cache partition cfg-0 INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 I/TC: I/TC: OP-TEE version: 3.13.0-791-g185dc3c92 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Tue Apr 16 10:47:32 CST 2024 aarch64, fwver: v2.12 I/TC: OP-TEE memory: TEEOS 0x200000 TA 0xc00000 SHM 0x200000 I/TC: Primary CPU initializing I/TC: CRYPTO_CRYPTO_VERSION_NEW no support. Skip all algo mode check. I/TC: Primary CPU switching to normal world boot INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09(u-boot commit id: 30d6e6f55d2b943c0910c3f69ccf4d302272ee71)(sdk version: rk356x_linux5.10_release_20241220_v1.4.0c.xml)-g30d6e6f55d-231220 #rk3566 (Jul 25 2025 - 04:23:32 -0700) Model: Rockchip RK3568 Evaluation Board MPIDR: 0x81000000 PreSerial: 2, raw, 0xfe660000 DRAM: 2 GiB Sysmem: init Relocation Offset: 7d217000 Relocation fdt: 7b9f88c8 - 7b9fece8 CR: M/C/I Using default environment optee api revision: 2.0 dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Card did not respond to voltage select! mmc_init: -95, time 9 switch to partitions #0, OK mmc0(part 0) is current device Bootdev(scan): mmc 0 MMC0: HS200, 200Mhz PartType: EFI TEEC: Waring: Could not find security partition DM: v1 ** Unrecognized filesystem type ** boot mode: recovery (misc) RESC: 'recovery', blk@0x0005ec45 resource: sha256+ FIT: no signed, no conf required DTB: rk-kernel.dtb HASH(c): OK I2c0 speed: 100000Hz PMIC: RK8090 (on=0x10, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK INFO: ddr dmc_fsp already initialized in loader. Could not find baseparameter partition Model: Rockchip RK3568 EVB1 DDR4 V10 Board MPIDR: 0x81000000 Rockchip UBOOT DRM driver version: v1.0.1 VOP have 3 active VP vp0 have layer nr:2[1 5 ], primary plane: 5 vp1 have layer nr:3[0 2 4 ], primary plane: 4 vp2 have layer nr:1[3 ], primary plane: 3 Using display timing dts dsi@fe060000: detailed mode clock 132000 kHz, flags[a] H: 1080 1095 1097 1127 V: 1920 1935 1937 1952 bus_format: 100e VOP update mode to: 1080x1920p60, type: MIPI0 for VP1 VP1 set crtc_clock to 132000KHz VOP VP1 enable Smart0[500x501->500x501@290x709] fmt[1] addr[0x7dfb8000] final DSI-Link bandwidth: 876 Mbps x 4 edp@fe0c0000 disconnected xfer: num: 2, addr: 0x50 xfer: num: 2, addr: 0x50 Monitor has basic audio support Could not find baseparameter partition hdmi@fe0a0000: detailed mode clock 148500 kHz, flags[5] H: 1920 2008 2052 2200 V: 1080 1084 1089 1125 bus_format: 2025 VOP update mode to: 1920x1080p60, type: HDMI0 for VP0 VP0 set crtc_clock to 148500KHz VOP VP0 enable Smart1[500x501->500x501@710x289] fmt[1] addr[0x7dfb8000] CEA mode used vic=16 final pixclk = 148500000 tmdsclk = 148500000 PHY powered down in 0 iterations PHY PLL locked 1 iterations PHY powered down in 0 iterations PHY PLL locked 1 iterations sink has audio support hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500 No FDT memory address configured. Default at 0x08300000 CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 1104000 KHz dpll 780000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 792000 KHz hpll 148500 KHz ppll 200000 KHz armclk 1104000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 500000 KHz aclk_top_low 400000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000 Hit key to stop autoboot('CTRL+C'): 0 ANDROID: reboot reason: "recovery" Not AVB images, AVB skip No valid android hdr Android image load failed Android boot failed, error -1. ## Booting FIT Image at 0x78e6ee80 with size 0x02988a00 Fdt Ramdisk skip relocation ## Loading kernel from FIT Image at 78e6ee80 ... Using 'conf' configuration ## Verified-boot: 0 Trying 'kernel' kernel subimage Description: unavailable Type: Kernel Image Compression: uncompressed Data Start: 0x78e9c880 Data Size: 36663808 Bytes = 35 MiB Architecture: AArch64 OS: Linux Load Address: 0x00280000 Entry Point: 0x00280000 Hash algo: sha256 Hash value: 52e85544b6ef286735dcfc1c2e290d1c3cf36129bedb96035f3fee232d62fc8c Verifying Hash Integrity ... sha256+ OK ## Loading ramdisk from FIT Image at 78e6ee80 ... Using 'conf' configuration Trying 'ramdisk' ramdisk subimage Description: unavailable Type: RAMDisk Image Compression: uncompressed Data Start: 0x7b193a80 Data Size: 6700451 Bytes = 6.4 MiB Architecture: AArch64 OS: Linux Load Address: 0x0a200000 Entry Point: unavailable Hash algo: sha256 Hash value: 91e0d1694a981ddb0df34381f9b38c931919c54a282185df61d8d34824ba44e5 Verifying Hash Integrity ... sha256+ OK Loading ramdisk from 0x7b193a80 to 0x0a200000 ## Loading fdt from FIT Image at 78e6ee80 ... Using 'conf' configuration Trying 'fdt' fdt subimage Description: unavailable Type: Flat Device Tree Compression: uncompressed Data Start: 0x78e6f680 Data Size: 184435 Bytes = 180.1 KiB Architecture: AArch64 Load Address: 0x08300000 Hash algo: sha256 Hash value: ef1cdb3ec5d9ac9d9333fe87220ea8fcea1a482226a77e48aebd9565e5840a0b Verifying Hash Integrity ... sha256+ OK Loading fdt from 0x08300000 to 0x08300000 Booting using the fdt blob at 0x08300000 Loading Kernel Image from 0x78e9c880 to 0x00280000 ... OK kernel loaded at 0x00280000, end = 0x02577200 Using Device Tree in place at 0000000008300000, end 0000000008330072 vp1 adjust cursor plane from 0 to 1 vp0, plane_mask:0x22, primary-id:5, curser-id:1 vp1 adjust cursor plane from 1 to 0 vp1, plane_mask:0x15, primary-id:4, curser-id:0 vp2, plane_mask:0x8, primary-id:3, curser-id:-1 WARNING: could not set reg FDT_ERR_BADOFFSET. ## reserved-memory: drm-logo@00000000: addr=7df00000 size=2e0000 drm-cubic-lut@00000000: addr=7ff00000 size=8000 ramoops@110000: addr=110000 size=f0000 Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x09400000 - 0x80000000 (size: 0x76c00000) == DO RELOCATE == Kernel from 0x00280000 to 0x00200000 Total: 1428.11/1473.545 ms Starting kernel ... [ 1.478776] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.478800] Linux version 5.10.198 (rk3566@ubuntu) (firefly: 34d433bc5e75/2507250416) (sdk version: rk356x_linux5.10_release_20241220_v1.4.0c.xml) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #2 SMP Fri Jul 25 04:16:45 PDT 2025 [ 1.480827] random: crng init done [ 1.485246] Machine model: Rockchip RK3568 EVB1 DDR4 V10 Board [ 1.520346] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '') [ 1.525703] printk: bootconsole [uart8250] enabled [ 1.527450] efi: UEFI not found. [ 1.565235] Zone ranges: [ 1.565489] DMA [mem 0x0000000000200000-0x000000007fffffff] [ 1.566077] DMA32 empty [ 1.566352] Normal empty [ 1.566625] Movable zone start for each node [ 1.567028] Early memory node ranges [ 1.567367] node 0: [mem 0x0000000000200000-0x00000000083fffff] [ 1.567958] node 0: [mem 0x0000000009400000-0x000000007fffffff] [ 1.568552] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff] [ 1.583943] cma: Reserved 16 MiB at 0x000000007e800000 [ 1.584513] psci: probing for conduit method from DT. [ 1.585000] psci: PSCIv1.1 detected in firmware. [ 1.585437] psci: Using standard PSCI v0.2 function IDs [ 1.585934] psci: Trusted OS migration not required [ 1.586397] psci: SMC Calling Convention v1.2 [ 1.587184] percpu: Embedded 30 pages/cpu s83800 r8192 d30888 u122880 [ 1.587906] Detected VIPT I-cache on CPU0 [ 1.588324] CPU features: detected: GIC system register CPU interface [ 1.588932] CPU features: detected: Virtualization Host Extensions [ 1.589521] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.590195] alternatives: patching kernel code [ 1.592350] Built 1 zonelists, mobility grouping on. Total pages: 511496 [ 1.592999] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.verifiedbootstate=orange rw rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 comm-07/25/2025 androidboot.fwver=ddr-v1.21-2d653b3476,spl-v1.14,bl31-v1.44,bl32-v2.12,uboot--boot [ 1.596658] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 1.597645] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 1.598377] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.623130] Memory: 1974968K/2078720K available (18688K kernel code, 3484K rwdata, 6848K rodata, 6656K init, 592K bss, 87368K reserved, 16384K cma-reserved) [ 1.624565] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 1.625216] ftrace: allocating 57076 entries in 223 pages [ 1.699063] ftrace: allocated 223 pages with 7 groups [ 1.699857] rcu: Hierarchical RCU implementation. [ 1.700308] rcu: RCU event tracing is enabled. [ 1.700736] rcu: RCU dyntick-idle grace-period acceleration is enabled. [ 1.701368] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 1.701984] Rude variant of Tasks RCU enabled. [ 1.702413] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 1.703125] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 1.707979] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 1.710120] GICv3: GIC: Using split EOI/Deactivate mode [ 1.710623] GICv3: 320 SPIs implemented [ 1.710986] GICv3: 0 Extended SPIs implemented [ 1.711438] GICv3: Distributor has no Range Selector support [ 1.711979] GICv3: 16 PPIs implemented [ 1.712370] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 1.713125] ITS [mem 0xfd440000-0xfd45ffff] [ 1.713583] ITS@0x00000000fd440000: allocated 8192 Devices @29d0000 (indirect, esz 8, psz 64K, shr 0) [ 1.714482] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @29e0000 (flat, esz 2, psz 64K, shr 0) [ 1.715448] ITS: using cache flushing for cmd queue [ 1.716282] GICv3: using LPI property table @0x00000000029f0000 [ 1.716952] GIC: using cache flushing for LPI property table [ 1.717490] GICv3: CPU0: using allocated LPI pending table @0x0000000002a00000 [ 1.718229] rcu: Offload RCU callbacks from CPUs: (none). [ 1.747595] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 1.748186] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 1.749207] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 1.751046] Console: colour dummy device 80x25 [ 1.751507] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 1.752480] pid_max: default: 32768 minimum: 301 [ 1.753027] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 1.753733] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 1.755737] rcu: Hierarchical SRCU implementation. [ 1.756841] Platform MSI: interrupt-controller@fd440000 domain created [ 1.757947] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created [ 1.759121] EFI services will not be available. [ 1.759831] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot [ 1.761484] Detected VIPT I-cache on CPU1 [ 1.761517] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 1.761535] GICv3: CPU1: using allocated LPI pending table @0x0000000002a10000 [ 1.761585] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 1.762848] Detected VIPT I-cache on CPU2 [ 1.762872] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 1.762886] GICv3: CPU2: using allocated LPI pending table @0x0000000002a20000 [ 1.762924] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 1.764135] Detected VIPT I-cache on CPU3 [ 1.764158] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 1.764172] GICv3: CPU3: using allocated LPI pending table @0x0000000002a30000 [ 1.764207] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 1.764296] smp: Brought up 1 node, 4 CPUs [ 1.771711] SMP: Total of 4 processors activated. [ 1.772165] CPU features: detected: Privileged Access Never [ 1.772691] CPU features: detected: LSE atomic instructions [ 1.773216] CPU features: detected: User Access Override [ 1.773718] CPU features: detected: 32-bit EL0 Support [ 1.774202] CPU features: detected: Common not Private translations [ 1.774792] CPU features: detected: RAS Extension Support [ 1.775300] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 1.776119] CPU features: detected: CRC32 instructions [ 1.776605] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 1.777260] CPU features: detected: RCpc load-acquire (LDAPR) [ 1.804632] CPU: All CPU(s) started at EL2 [ 1.806383] devtmpfs: initialized [ 1.828377] Registered cp15_barrier emulation handler [ 1.828873] Registered setend emulation handler [ 1.829471] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 1.830425] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 1.831550] pinctrl core: initialized pinctrl subsystem [ 1.832560] DMI not present or invalid. [ 1.833174] NET: Registered protocol family 16 [ 1.835190] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 1.836001] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 1.838940] Registered FIQ tty driver [ 1.839643] thermal_sys: Registered thermal governor 'fair_share' [ 1.839648] thermal_sys: Registered thermal governor 'step_wise' [ 1.840224] thermal_sys: Registered thermal governor 'user_space' [ 1.840790] thermal_sys: Registered thermal governor 'power_allocator' [ 1.841634] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 1.843073] cpuidle: using governor menu [ 1.843716] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 1.844477] ASID allocator initialised with 65536 entries [ 1.847188] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 1.848564] ramoops: console 0x80000@0x0000000000130000 [ 1.849073] ramoops: pmsg 0x50000@0x00000000001b0000 [ 1.849909] printk: console [ramoops-1] enabled [ 1.850340] pstore: Registered ramoops as persistent store backend [ 1.850924] ramoops: using 0xf0000@0x110000, ecc: 0 [ 1.890274] rockchip-gpio fdd60000.gpio0: probed /pinctrl/gpio0@fdd60000 [ 1.891365] rockchip-gpio fe740000.gpio1: probed /pinctrl/gpio1@fe740000 [ 1.892557] rockchip-gpio fe750000.gpio2: probed /pinctrl/gpio2@fe750000 [ 1.893722] rockchip-gpio fe760000.gpio3: probed /pinctrl/gpio3@fe760000 [ 1.894834] rockchip-gpio fe770000.gpio4: probed /pinctrl/gpio4@fe770000 [ 1.895577] rockchip-pinctrl pinctrl: probed pinctrl [ 1.919656] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 1.920212] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 1.920764] fiq_debugger_probe: could not install nmi irq handler [[ 1.921420] printk: console [ttyFIQ0] enabled 1.921420] printk: console [ttyFIQ0] enabled [ 1.922221] printk: bootconsole [uart8250] disabled [ 1.922221] printk: bootconsole [uart8250] disabled [ 1.922910] Registered fiq debugger ttyFIQ0 [ 1.923596] vcc3v3_sys: supplied by dc_12v [ 1.923857] vcc5v0_sys: supplied by dc_12v [ 1.924095] vcc5v0_usb: supplied by dc_12v [ 1.924519] vcc5v0_host: supplied by vcc5v0_usb [ 1.924970] vcc5v0_otg: supplied by vcc5v0_usb [ 1.925567] vcc2v5-sys: supplied by vcc3v3_sys [ 1.925819] vcc3v3_vga: supplied by vcc3v3_sys [ 1.926073] pcie30_avdd0v9: supplied by vcc3v3_sys [ 1.926316] pcie30_avdd1v8: supplied by vcc3v3_sys [ 1.926671] vcc3v3_pcie: supplied by dc_12v [ 1.926837] vcc3v3_bu: supplied by vcc5v0_sys [ 1.928112] iommu: Default domain type: Translated [ 1.931420] SCSI subsystem initialized [ 1.931637] usbcore: registered new interface driver usbfs [ 1.931679] usbcore: registered new interface driver hub [ 1.931717] usbcore: registered new device driver usb [ 1.931810] mc: Linux media interface: v0.10 [ 1.931839] videodev: Linux video capture interface: v2.00 [ 1.931915] pps_core: LinuxPPS API ver. 1 registered [ 1.931923] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.931940] PTP clock support registered [ 1.931978] EDAC MC: Ver: 3.0.0 [ 1.932856] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 1.932919] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 1.934767] Advanced Linux Sound Architecture Driver Initialized. [ 1.935160] Bluetooth: Core ver 2.22 [ 1.935198] NET: Registered protocol family 31 [ 1.935206] Bluetooth: HCI device and connection manager initialized [ 1.935220] Bluetooth: HCI socket layer initialized [ 1.935229] Bluetooth: L2CAP socket layer initialized [ 1.935247] Bluetooth: SCO socket layer initialized [ 1.935670] rockchip-cpuinfo cpuinfo: SoC : 35662000 [ 1.935682] rockchip-cpuinfo cpuinfo: Serial : efdfa4c53e24272c [ 1.936394] clocksource: Switched to clocksource arch_sys_counter [ 2.364285] NET: Registered protocol family 2 [ 2.364457] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 2.365532] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 2.365574] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.365661] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear) [ 2.365856] TCP: Hash tables configured (established 16384 bind 16384) [ 2.365968] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 2.366002] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 2.366141] NET: Registered protocol family 1 [ 2.366581] RPC: Registered named UNIX socket transport module. [ 2.366592] RPC: Registered udp transport module. [ 2.366598] RPC: Registered tcp transport module. [ 2.366604] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.367546] PCI: CLS 0 bytes, default 64 [ 2.368202] Trying to unpack rootfs image as initramfs... [ 2.577996] Freeing initrd memory: 6540K [ 2.580226] rockchip-thermal fe710000.tsadc: tsadc is probed successfully! [ 2.581235] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [ 2.585203] Initialise system trusted keyrings [ 2.585344] workingset: timestamp_bits=62 max_order=19 bucket_order=0 [ 2.589409] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.589939] NFS: Registering the id_resolver key type [ 2.589975] Key type id_resolver registered [ 2.589984] Key type id_legacy registered [ 2.590020] ntfs: driver 2.1.32 [Flags: R/O]. [ 2.590214] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 2.590482] fuse: init (API version 7.32) [ 2.590758] SGI XFS with security attributes, no debug enabled [ 2.621789] NET: Registered protocol family 38 [ 2.621822] Key type asymmetric registered [ 2.621832] Asymmetric key parser 'x509' registered [ 2.621873] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 2.621883] io scheduler mq-deadline registered [ 2.621891] io scheduler kyber registered [ 2.622565] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully! [ 2.623415] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully! [ 2.631873] rockchip-snps-pcie3-phy fe8c0000.phy: failed to find rockchip,pipe_grf regmap [ 2.635139] rk-pcie 3c0800000.pcie: invalid prsnt-gpios property in node [ 2.635528] pwm-backlight backlight: supply power not found, using dummy regulator [ 2.635974] pwm-backlight backlight1: supply power not found, using dummy regulator [ 2.636615] iep: Module initialized. [ 2.636687] mpp_service mpp-srv: ea89a0945141 author: Yandong Lin 2023-12-20 video: rockchip: mpp: fix watch dog interrupt storm issue [ 2.636698] mpp_service mpp-srv: probe start [ 2.638637] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 1 [ 2.638821] mpp_vdpu2 fdea0400.vdpu: probe device [ 2.639266] mpp_vdpu2 fdea0400.vdpu: probing finish [ 2.639808] mpp_vepu2 fdee0000.vepu: Adding to iommu group 3 [ 2.639983] mpp_vepu2 fdee0000.vepu: probing start [ 2.640369] mpp_vepu2 fdee0000.vepu: probing finish [ 2.641016] mpp-iep2 fdef0000.iep: Adding to iommu group 4 [ 2.641182] rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply [ 2.641197] mpp-iep2 fdef0000.iep: probe device [ 2.641200] phy phy-fe8c0000.phy.9: phy init failed --> -110 [ 2.641206] rk-pcie 3c0800000.pcie: fail to init phy, err -110 [ 2.641219] rk-pcie 3c0800000.pcie: phy init failed [ 2.641488] mpp-iep2 fdef0000.iep: allocate roi buffer failed [ 2.641708] mpp-iep2 fdef0000.iep: probing finish [ 2.642217] mpp_jpgdec fded0000.jpegd: Adding to iommu group 2 [ 2.642398] mpp_jpgdec fded0000.jpegd: probe device [ 2.642855] mpp_jpgdec fded0000.jpegd: probing finish [ 2.644380] mpp_service mpp-srv: probe success [ 2.648948] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330 [ 2.648987] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.650760] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330 [ 2.650784] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.651545] rockchip-pvtm fde00000.pvtm: pvtm@0 probed [ 2.651675] rockchip-pvtm fde80000.pvtm: pvtm@1 probed [ 2.651779] rockchip-pvtm fde90000.pvtm: pvtm@2 probed [ 2.652375] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 2.653014] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active. [ 2.653342] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 2.654375] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 78, base_baud = 1500000) is a 16550A [ 2.656749] rockchip-vop2 fe040000.vop: Adding to iommu group 8 [ 2.666107] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x22, primary plane phy id: 5 [ 2.666152] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, primary plane phy id: 4 [ 2.666164] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3 [ 2.666287] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster1-win0 as cursor plane for vp0 [ 2.666454] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster0-win0 as cursor plane for vp1 [ 2.666577] [drm] failed to init overlay plane Cluster0-win1 [ 2.666586] [drm] failed to init overlay plane Cluster1-win1 [ 2.666757] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffffc00934e2e8) [ 2.667385] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffffc00935b9f0) [ 2.667656] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.668168] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.668420] dwhdmi-rockchip fe0a0000.hdmi: IRQ index 1 not found [ 2.668778] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffffc00935ce78) [ 2.668863] dw-mipi-dsi-rockchip fe060000.dsi: failed to find panel or bridge: -517 [ 2.675548] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 2.676181] brd: module loaded [ 2.680772] loop: module loaded [ 2.681156] zram: Added device: zram0 [ 2.681384] lkdtm: No crash points registered, enable through debugfs [ 2.683977] ahci fc800000.sata: supply ahci not found, using dummy regulator [ 2.684124] ahci fc800000.sata: supply phy not found, using dummy regulator [ 2.684352] ahci fc800000.sata: supply target not found, using dummy regulator [ 2.684474] ahci fc800000.sata: forcing port_map 0x0 -> 0x1 [ 2.684516] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode [ 2.684530] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst [ 2.684547] ahci fc800000.sata: port 0 is not capable of FBS [ 2.685599] scsi host0: ahci [ 2.685863] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 19 [ 2.688258] spi-nand spi4.0: unknown raw ID 00000000 [ 2.688292] spi-nand: probe of spi4.0 failed with error -524 [ 2.690563] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 2.690827] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator [ 2.690970] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output). [ 2.690982] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f). [ 2.690992] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26). [ 2.691007] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 2.691271] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 2.691503] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 2.691518] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 2.691529] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 2.691538] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 2.691545] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 2.691552] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 2.691614] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 2.691624] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 2.691633] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 2.691641] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width [ 2.827890] rk_gmac-dwmac fe2a0000.ethernet: IRQ eth_lpi not found [ 2.828216] rk_gmac-dwmac fe2a0000.ethernet: supply phy not found, using dummy regulator [ 2.828348] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (output). [ 2.828361] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c). [ 2.828371] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f). [ 2.828385] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no). [ 2.828645] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII [ 2.828837] rk_gmac-dwmac fe2a0000.ethernet: Version ID not available [ 2.828854] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5 [ 2.828865] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported [ 2.828874] rk_gmac-dwmac fe2a0000.ethernet: Ring mode enabled [ 2.828884] rk_gmac-dwmac fe2a0000.ethernet: Using 32 bits DMA width [ 2.963581] usbcore: registered new interface driver rtl8150 [ 2.963658] usbcore: registered new interface driver r8152 [ 2.975181] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.975225] ehci-pci: EHCI PCI platform driver [ 2.975300] ehci-platform: EHCI generic platform driver [ 2.975579] phy phy-fe8b0000.usb2-phy.4: illegal mode [ 2.977627] ehci-platform fd800000.usb: EHCI Host Controller [ 2.977823] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1 [ 2.977933] ehci-platform fd800000.usb: irq 20, io mem 0xfd800000 [ 2.989803] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [ 2.989971] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 2.989982] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.989991] usb usb1: Product: EHCI Host Controller [ 2.989999] usb usb1: Manufacturer: Linux 5.10.198 ehci_hcd [ 2.990006] usb usb1: SerialNumber: fd800000.usb [ 2.990403] hub 1-0:1.0: USB hub found [ 2.990439] hub 1-0:1.0: 1 port detected [ 2.993109] ehci-platform fd880000.usb: EHCI Host Controller [ 2.993267] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2 [ 2.993380] ehci-platform fd880000.usb: irq 22, io mem 0xfd880000 [ 2.999446] ata1: SATA link down (SStatus 0 SControl 300) [ 3.006412] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [ 3.006579] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 3.006591] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.006600] usb usb2: Product: EHCI Host Controller [ 3.006607] usb usb2: Manufacturer: Linux 5.10.198 ehci_hcd [ 3.006614] usb usb2: SerialNumber: fd880000.usb [ 3.007047] hub 2-0:1.0: USB hub found [ 3.007082] hub 2-0:1.0: 1 port detected [ 3.007767] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.007807] ohci-platform: OHCI generic platform driver [ 3.008112] phy phy-fe8b0000.usb2-phy.4: illegal mode [ 3.008132] ohci-platform fd840000.usb: Generic Platform OHCI controller [ 3.008292] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3 [ 3.008414] ohci-platform fd840000.usb: irq 21, io mem 0xfd840000 [ 3.067205] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 3.067224] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.067234] usb usb3: Product: Generic Platform OHCI controller [ 3.067242] usb usb3: Manufacturer: Linux 5.10.198 ohci_hcd [ 3.067250] usb usb3: SerialNumber: fd840000.usb [ 3.067637] hub 3-0:1.0: USB hub found [ 3.067673] hub 3-0:1.0: 1 port detected [ 3.068165] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [ 3.068316] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4 [ 3.068410] ohci-platform fd8c0000.usb: irq 23, io mem 0xfd8c0000 [ 3.127197] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 3.127217] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.127226] usb usb4: Product: Generic Platform OHCI controller [ 3.127234] usb usb4: Manufacturer: Linux 5.10.198 ohci_hcd [ 3.127241] usb usb4: SerialNumber: fd8c0000.usb [ 3.127630] hub 4-0:1.0: USB hub found [ 3.127665] hub 4-0:1.0: 1 port detected [ 3.128918] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.129110] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5 [ 3.129236] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000800002010010 [ 3.129294] xhci-hcd xhci-hcd.0.auto: irq 94, io mem 0xfd000000 [ 3.129415] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.129550] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6 [ 3.129569] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 3.129706] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 3.129750] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.129760] usb usb5: Product: xHCI Host Controller [ 3.129768] usb usb5: Manufacturer: Linux 5.10.198 xhci-hcd [ 3.129775] usb usb5: SerialNumber: xhci-hcd.0.auto [ 3.130183] hub 5-0:1.0: USB hub found [ 3.130220] hub 5-0:1.0: 1 port detected [ 3.130547] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.130644] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 3.130656] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.130665] usb usb6: Product: xHCI Host Controller [ 3.130673] usb usb6: Manufacturer: Linux 5.10.198 xhci-hcd [ 3.130680] usb usb6: SerialNumber: xhci-hcd.0.auto [ 3.131025] hub 6-0:1.0: USB hub found [ 3.131058] hub 6-0:1.0: 1 port detected [ 3.131456] usbcore: registered new interface driver cdc_acm [ 3.131466] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.131668] usbcore: registered new interface driver uas [ 3.131752] usbcore: registered new interface driver usb-storage [ 3.131837] usbcore: registered new interface driver usbserial_generic [ 3.131861] usbserial: USB Serial support registered for generic [ 3.131922] usbcore: registered new interface driver cp210x [ 3.131945] usbserial: USB Serial support registered for cp210x [ 3.132004] usbcore: registered new interface driver ftdi_sio [ 3.132027] usbserial: USB Serial support registered for FTDI USB Serial Device [ 3.132142] usbcore: registered new interface driver keyspan [ 3.132170] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 3.132193] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 3.132214] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 3.132233] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 3.132281] usbcore: registered new interface driver option [ 3.132305] usbserial: USB Serial support registered for GSM modem (1-port) [ 3.132460] usbcore: registered new interface driver oti6858 [ 3.132483] usbserial: USB Serial support registered for oti6858 [ 3.132524] usbcore: registered new interface driver pl2303 [ 3.132547] usbserial: USB Serial support registered for pl2303 [ 3.132594] usbcore: registered new interface driver qcserial [ 3.132617] usbserial: USB Serial support registered for Qualcomm USB modem [ 3.132672] usbcore: registered new interface driver sierra [ 3.132695] usbserial: USB Serial support registered for Sierra USB modem [ 3.133895] usbcore: registered new interface driver usbtouchscreen [ 3.134321] .. rk pwm remotectl v2.0 init [ 3.134556] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0 [ 3.134906] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000 [ 3.134957] remotectl-pwm fe6e0030.pwm: Controller support pwrkey capture [ 3.135510] i2c /dev entries driver [ 3.136758] fan53555-regulator 0-001c: Failed to get chip ID! [ 3.139285] rk808 0-0020: chip id: 0x8090 [ 3.139345] rk808 0-0020: No cache defaults, reading back from HW [ 3.163032] rk808 0-0020: source: on=0x10, off=0x00 [ 3.163075] rk808 0-0020: support dcdc3 fb mode:-22, 1 [ 3.163087] rk808 0-0020: support pmic reset mode:0,0 [ 3.168518] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 3.168563] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 3.168979] vdd_logic: supplied by vcc3v3_sys [ 3.170003] vdd_gpu: supplied by vcc3v3_sys [ 3.170592] vcc_ddr: supplied by vcc3v3_sys [ 3.171182] vdd_npu: supplied by vcc3v3_sys [ 3.172111] vcc_1v8: supplied by vcc3v3_sys [ 3.172676] vdda0v9_image: supplied by vcc3v3_sys [ 3.174112] vdda_0v9: supplied by vcc3v3_sys [ 3.175208] vdda0v9_pmu: supplied by vcc3v3_sys [ 3.176287] vccio_acodec: supplied by vcc3v3_sys [ 3.177714] vccio_sd: supplied by vcc3v3_sys [ 3.178799] vcc3v3_pmu: supplied by vcc3v3_sys [ 3.180253] vcca_1v8: supplied by vcc3v3_sys [ 3.181361] vcca1v8_pmu: supplied by vcc3v3_sys [ 3.182441] vcca1v8_image: supplied by vcc3v3_sys [ 3.183889] vcc_3v3: supplied by vcc3v3_sys [ 3.184798] vcc3v3_sd: supplied by vcc3v3_sys [ 3.185354] rk817-battery: Failed to locate of_node [id: -1] [ 3.185507] rk817-battery rk817-battery: Failed to find matching dt id [ 3.185647] rk817-charger: Failed to locate of_node [id: -1] [ 3.185742] rk817-charger rk817-charger: Failed to find matching dt id [ 3.188764] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1 [ 3.194888] rk808-rtc rk808-rtc: registered as rtc0 [ 3.196613] rk808-rtc rk808-rtc: setting system clock to 2022-08-07T16:54:13 UTC (1659891253) [ 3.200010] <<GTP-INF>>[gt1x_ts_probe:560] GTP Driver Version: V1.4<2015/07/10> [ 3.200049] <<GTP-INF>>[gt1x_ts_probe:561] GTP I2C Address: 0x14 [ 3.200117] <<GTP-ERR>>[gt1x_parse_dt:341] vdd_ana not specified, fallback to power-supply [ 3.200253] <<GTP-INF>>[gt1x_parse_dt:348] Power Invert,no [ 3.200333] <<GTP-INF>>[gt1x_reset_guitar:788] GTP RESET! [ 3.201636] i2c i2c-4: 1 i2c clients have been registered at 0x36 [ 3.205139] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe! [ 3.205319] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw! [ 3.206470] rkisp_hw fdff0000.rkisp: Adding to iommu group 7 [ 3.206676] rkisp_hw fdff0000.rkisp: is_thunderboot: 0 [ 3.206709] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff] [ 3.206738] rkisp_hw fdff0000.rkisp: max input:0x0@0fps [ 3.206889] rkisp_hw fdff0000.rkisp: no find phandle sram [ 3.207393] rkisp rkisp-vir0: rkisp driver version: v02.04.00 [ 3.207545] rkisp rkisp-vir0: No memory-region-thunderboot specified [ 3.207746] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized! [ 3.207767] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized! [ 3.210389] usbcore: registered new interface driver uvcvideo [ 3.210407] USB Video Class driver (1.1.1) [ 3.212050] Bluetooth: HCI UART driver ver 2.3 [ 3.212068] Bluetooth: HCI UART protocol H4 registered [ 3.212075] Bluetooth: HCI UART protocol ATH3K registered [ 3.212143] usbcore: registered new interface driver bfusb [ 3.212191] usbcore: registered new interface driver btusb [ 3.213087] cpu cpu0: bin=0 [ 3.213152] cpu cpu0: leakage=29 [ 3.213196] cpu cpu0: pvtm = 87290, from nvmem [ 3.213212] cpu cpu0: pvtm-volt-sel=2 [ 3.213263] cpu cpu0: soc version=0, speed=2 [ 3.215246] sdhci: Secure Digital Host Controller Interface driver [ 3.215266] sdhci: Copyright(c) Pierre Ossman [ 3.215273] Synopsys Designware Multimedia Card Interface Driver [ 3.216053] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.216557] dwmmc_rockchip fe000000.dwmmc: No normal pinctrl state [ 3.216577] dwmmc_rockchip fe000000.dwmmc: No idle pinctrl state [ 3.216695] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode. [ 3.216728] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller. [ 3.216741] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a [ 3.216788] dwmmc_rockchip fe2b0000.dwmmc: No normal pinctrl state [ 3.216797] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 54,32 bit host data width,256 deep fifo [ 3.216807] dwmmc_rockchip fe2b0000.dwmmc: No idle pinctrl state [ 3.216919] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode. [ 3.216943] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller. [ 3.216955] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a [ 3.216997] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo [ 3.217190] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq [ 3.217205] mmc_host mmc3: card is non-removable. [ 3.218407] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 3.218507] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 3.219465] cryptodev: driver 1.12 loaded. [ 3.219527] hid: raw HID events driver (C) Jiri Kosina [ 3.219865] usbcore: registered new interface driver usbhid [ 3.219874] usbhid: USB HID core driver [ 3.225081] usbcore: registered new interface driver snd-usb-audio [ 3.227275] rk817-codec rk817-codec: DMA mask not set [ 3.227812] rk817_codec_parse_dt_property: rk809 have no io-channels defined [ 3.227832] invalid rk817->hp_det_gpio: -2 [ 3.227844] invalid gpio: -2 [ 3.230073] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 3.234880] rk-multicodecs rk809-sound: Failed to get ADC channel [ 3.235080] rk-multicodecs rk809-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even [ 3.236246] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94 [ 3.243494] input: rockchip-rk809 Headset as /devices/platform/rk809-sound/sound/card0/input2 [ 3.244686] Initializing XFRM netlink socket [ 3.245108] NET: Registered protocol family 10 [ 3.245847] Segment Routing with IPv6 [ 3.245913] NET: Registered protocol family 17 [ 3.245936] NET: Registered protocol family 15 [ 3.246066] Bluetooth: RFCOMM socket layer initialized [ 3.246102] Bluetooth: RFCOMM ver 1.11 [ 3.246116] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.246128] Bluetooth: HIDP socket layer initialized [ 3.246173] [BT_RFKILL]: Enter rfkill_rk_init [ 3.246182] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.246855] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.246908] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s [ 3.246917] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.246924] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.246947] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 125 flags = 0. [ 3.246968] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0. [ 3.246980] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 3.246987] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.246994] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [ 3.247002] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 3.247783] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73. [ 3.247812] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96. [ 3.247826] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 98. [ 3.247839] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 97. [ 3.247901] [BT_RFKILL]: Request irq for bt wakeup host [ 3.247997] [BT_RFKILL]: ** disable irq [ 3.248090] [BT_RFKILL]: bt_default device registered. [ 3.248218] Key type dns_resolver registered [ 3.249163] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA [ 3.249365] os04a10 4-0036: driver version: 00.01.05 [ 3.249384] os04a10 4-0036: Get hdr mode failed! no hdr default [ 3.249404] os04a10 4-0036: detect os04a10 lane 4 [ 3.249551] os04a10 4-0036: could not get default pinstate [ 3.249561] os04a10 4-0036: could not get sleep pinstate [ 3.249606] os04a10 4-0036: supply avdd not found, using dummy regulator [ 3.249805] os04a10 4-0036: supply dovdd not found, using dummy regulator [ 3.249857] os04a10 4-0036: supply dvdd not found, using dummy regulator [ 3.286006] mmc0: Host Software Queue enabled [ 3.286040] mmc0: new HS200 MMC card at address 0001 [ 3.286766] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB [ 3.287004] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB [ 3.287266] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB [ 3.287524] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB, chardev (236:0) [ 3.289751] os04a10 4-0036: Unexpected sensor id(000000), ret(-5) [ 3.290682] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 [ 3.293529] <<GTP-ERR>>[_do_i2c_write:432] I2c transfer error! (-6) [ 3.293570] <<GTP-ERR>>[gt1x_init:2319] Reset guitar failed! [ 3.293578] <<GTP-INF>>[gt1x_reset_guitar:788] GTP RESET! [ 3.321735] ov5695 4-0036-1: driver version: 00.01.04 [ 3.321868] ov5695 4-0036-1: supply avdd not found, using dummy regulator [ 3.322011] ov5695 4-0036-1: supply dovdd not found, using dummy regulator [ 3.322081] ov5695 4-0036-1: supply dvdd not found, using dummy regulator [ 3.323161] ov5695 4-0036-1: Unexpected sensor id(000000), ret(-5) [ 3.323841] gc8034 4-0037: driver version: 00.01.09 [ 3.323880] gc8034 4-0037: Failed to get power-gpios, maybe no use [ 3.323951] gc8034 4-0037: supply dovdd not found, using dummy regulator [ 3.324064] gc8034 4-0037: supply dvdd not found, using dummy regulator [ 3.324114] gc8034 4-0037: supply avdd not found, using dummy regulator [ 3.324157] gc8034 4-0037: lane_num(4) pixel_rate(319887360) [ 3.324173] gc8034 4-0037: could not get default pinstate [ 3.324181] gc8034 4-0037: could not get sleep pinstate [ 3.336627] gc8034 4-0037: gc8034 read reg:0xf0 failed ! [ 3.336852] gc8034 4-0037: gc8034 read reg:0xf1 failed ! [ 3.336865] gc8034 4-0037: Unexpected sensor id(000000), ret(-6) [ 3.337750] Loading compiled-in X.509 certificates [ 3.339194] pstore: Using crash dump compression: deflate [ 3.340423] rga: rga2, irq = 31, match scheduler [ 3.340933] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 3.340965] rga: rga2 probe successfully [ 3.341300] rga_iommu: IOMMU binding successfully, default mapping core[0x4] [ 3.341557] rga: Module initialized. v1.3.1 [ 3.355356] vendor storage:20190527 ret = 0 [ 3.386801] <<GTP-ERR>>[_do_i2c_write:432] I2c transfer error! (-6) [ 3.386835] <<GTP-ERR>>[gt1x_init:2319] Reset guitar failed! [ 3.386844] <<GTP-INF>>[gt1x_reset_guitar:788] GTP RESET! [ 3.433465] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 3.447118] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5 [ 3.447352] mpp_rkvenc fdf40000.rkvenc: probing start [ 3.447823] mpp_rkvenc fdf40000.rkvenc: bin=0 [ 3.447852] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage [ 3.447904] mpp_rkvenc fdf40000.rkvenc: pvtm = 87290, from nvmem [ 3.447919] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1 [ 3.448100] mpp_rkvenc fdf40000.rkvenc: avs=0 [ 3.448219] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node [ 3.448231] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model [ 3.448239] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient [ 3.448975] mpp_rkvenc fdf40000.rkvenc: probing finish [ 3.449368] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6 [ 3.449586] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start [ 3.449981] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found! [ 3.449994] rkvdec2_init:1022: No niu aclk reset resource define [ 3.450004] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found! [ 3.450010] rkvdec2_init:1025: No niu hclk reset resource define [ 3.450221] mpp_rkvdec2 fdf80200.rkvdec: bin=0 [ 3.450329] mpp_rkvdec2 fdf80200.rkvdec: leakage=54 [ 3.450344] mpp_rkvdec2 fdf80200.rkvdec: leakage-volt-sel=0 [ 3.450383] mpp_rkvdec2 fdf80200.rkvdec: pvtm = 87290, from nvmem [ 3.450395] mpp_rkvdec2 fdf80200.rkvdec: pvtm-volt-sel=1 [ 3.450560] mpp_rkvdec2 fdf80200.rkvdec: avs=0 [ 3.450685] mpp_rkvdec2 fdf80200.rkvdec: failed to find power_model node [ 3.450697] mpp_rkvdec2 fdf80200.rkvdec: failed to initialize power model [ 3.450706] mpp_rkvdec2 fdf80200.rkvdec: failed to get dynamic-coefficient [ 3.450829] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000 [ 3.450840] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000 [ 3.450848] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056 [ 3.450855] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536 [ 3.450864] mpp_rkvdec2 fdf80200.rkvdec: min_width 512 [ 3.450916] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish [ 3.450986] mpp_rkvdec2 fdf80200.rkvdec: probing finish [ 3.452318] mali fde60000.gpu: Kernel DDK version g18p0-01eac0 [ 3.452744] rockchip-dmc dmc: bin=0 [ 3.452848] rockchip-dmc dmc: leakage=54 [ 3.452865] rockchip-dmc dmc: leakage-volt-sel=0 [ 3.452900] mali fde60000.gpu: bin=0 [ 3.452921] rockchip-dmc dmc: pvtm = 87290, from nvmem [ 3.452937] rockchip-dmc dmc: pvtm-volt-sel=1 [ 3.452953] mali fde60000.gpu: leakage=8 [ 3.452956] rockchip-dmc dmc: soc version=0, speed=1 [ 3.453000] mali fde60000.gpu: pvtm = 87290, from nvmem [ 3.453017] mali fde60000.gpu: pvtm-volt-sel=2 [ 3.453031] mali fde60000.gpu: soc version=0, speed=2 [ 3.453160] rockchip-dmc dmc: avs=0 [ 3.453181] rockchip-dmc dmc: current ATF version 0x102 [ 3.453578] mali fde60000.gpu: avs=0 [ 3.453601] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 3.453956] rockchip-dmc dmc: normal_rate = 780000000 [ 3.453970] rockchip-dmc dmc: reboot_rate = 1560000000 [ 3.453979] rockchip-dmc dmc: suspend_rate = 324000000 [ 3.453987] rockchip-dmc dmc: video_4k_rate = 780000000 [ 3.453996] rockchip-dmc dmc: video_4k_10b_rate = 780000000 [ 3.454004] rockchip-dmc dmc: boost_rate = 1560000000 [ 3.454012] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000 [ 3.454020] rockchip-dmc dmc: performance_rate = 1560000000 [ 3.454043] rockchip-dmc dmc: failed to get vop pn to msch rl [ 3.454056] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0 [ 3.454144] mali fde60000.gpu: No priority control manager is configured [ 3.454222] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 3.454421] mali fde60000.gpu: No memory group manager is configured [ 3.454831] rockchip-dmc dmc: could not find power_model node [ 3.456356] mali fde60000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 3.457010] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu [ 3.457218] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3000000 uV) supplied by vccio_acodec [ 3.457453] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd [ 3.457634] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(3300000 uV) supplied by vcc_3v3 [ 3.457739] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3 [ 3.457806] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(3300000 uV) supplied by vcc_3v3 [ 3.457871] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3 [ 3.458044] mali fde60000.gpu: Probed as mali0 [ 3.462994] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x22, primary plane phy id: 5 [ 3.463021] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, primary plane phy id: 4 [ 3.463033] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3 [ 3.463264] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster1-win0 as cursor plane for vp0 [ 3.463396] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster0-win0 as cursor plane for vp1 [ 3.463546] [drm] failed to init overlay plane Cluster0-win1 [ 3.463556] [drm] failed to init overlay plane Cluster1-win1 [ 3.463738] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffffc00934e2e8) [ 3.464900] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffffc00935b9f0) [ 3.465181] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.466067] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 3.466729] dwhdmi-rockchip fe0a0000.hdmi: IRQ index 1 not found [ 3.467866] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.5.auto/input/input3 [ 3.468868] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffffc00935ce78) [ 3.469037] rockchip-drm display-subsystem: bound fe060000.dsi (ops 0xffffffc00935e7d0) [ 3.471713] rockchip-drm display-subsystem: route-edp: failed to get logo,offset [ 3.507154] rockchip-vop2 fe040000.vop: [drm:vop2_isr] *ERROR* POST_BUF_EMPTY irq err at vp1 [ 3.518113] <<GTP-ERR>>[_do_i2c_write:432] I2c transfer error! (-6) [ 3.518149] <<GTP-ERR>>[gt1x_init:2319] Reset guitar failed! [ 3.518158] <<GTP-INF>>[gt1x_reset_guitar:788] GTP RESET! [ 3.543128] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 3.559594] rockchip-dp fe0c0000.edp: failed to get hpd plug in status [ 3.651673] <<GTP-ERR>>[_do_i2c_write:432] I2c transfer error! (-6) [ 3.651694] <<GTP-ERR>>[gt1x_init:2319] Reset guitar failed! [ 3.651701] <<GTP-INF>>[gt1x_reset_guitar:788] GTP RESET! [ 3.676482] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) [ 3.736884] rockchip-dp fe0c0000.edp: failed to get hpd plug in status [ 3.742027] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 3.743068] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 3.743657] input: adc-keys as /devices/platform/adc-keys/input/input4 [ 3.752546] RKNPU fde40000.npu: Adding to iommu group 0 [ 3.753045] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 3.753395] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff] [ 3.753998] [drm] Initialized rknpu 0.9.3 20231121 for fde40000.npu on minor 1 [ 3.754604] RKNPU fde40000.npu: bin=0 [ 3.754660] RKNPU fde40000.npu: leakage=4 [ 3.754700] RKNPU fde40000.npu: pvtm = 87290, from nvmem [ 3.754718] RKNPU fde40000.npu: pvtm-volt-sel=2 [ 3.754734] RKNPU fde40000.npu: soc version=0, speed=2 [ 3.755313] RKNPU fde40000.npu: avs=0 [ 3.755486] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 3.756011] RKNPU fde40000.npu: failed to find power_model node [ 3.756025] RKNPU fde40000.npu: RKNPU: failed to initialize power model [ 3.756033] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient [ 3.757133] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 3.763131] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 3.765086] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '00:56:26', on 'Jul 25 2025'. [ 3.765548] Mali: [ 3.765551] Mali device driver loaded [ 3.765579] rkisp rkisp-vir0: clear unready subdev num: 3 [ 3.765794] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 3.765808] cfg80211: failed to load regulatory.db [ 3.766203] rkisp-vir0: update sensor failed [ 3.768214] vÏ [ 3.774529] usb 3-1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01 [ 3.774550] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.774560] usb 3-1: Product: USB Receiver [ 3.774568] usb 3-1: Manufacturer: Logitech [ 3.783435] input: Logitech USB Receiver as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.0/0003:046D:C534.0001/input/input5 [ 3.785369] <<GTP-ERR>>[_do_i2c_write:432] I2c transfer error! (-6) [ 3.785392] <<GTP-ERR>>[gt1x_init:2319] Reset guitar failed! [ 3.785400] <<GTP-ERR>>[gt1x_init:2345] Init failed, use default setting [ 3.840514] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fd840000.usb-1/input0 [ 3.845995] input: Logitech USB Receiver Mouse as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.1/0003:046D:C534.0002/input/input6 [ 3.870375] <<GTP-ERR>>[_do_i2c_read:390] I2c Transfer error! (-6) [ 3.870400] <<GTP-ERR>>[gt1x_get_chip_type:895] I2c communication error. [ 3.870409] <<GTP-ERR>>[gt1x_init:2355] Get chip type failed!
  20. I'm willing to help guide @Error1429 a bit on how to get this done.
  21. @JuanEsf in case you need testing - I own both OrangePi 4A and Radxa Cubie A5E. So far I tried to build the image from your repo (https://github.com/juanesf/build) - neither board boots for me.
  22. The problem is still occurring with the Armbian Bookworm images using the XFCE interface. I closed the topic last year because all the Le Potato Bookworm images had been archived. However, it is now part of the current desktop images listed on the Le Potato page with Armbian Linux v6.12. I tested the Debian 12 (Bookworm) distribution with the XFCE variant, and the issue seen in the archived images—specifically, the missing firefox.conf file—is still present.
  23. For the sake of future people running across this thread, I switched to Orangepi debian and there the issue was at least partly that I was following the wrong cmake command, and should have used the one for the Rpi 4 64 bit, as well as not having installed libc6-dev-armhf-cross.
  24. To 1.) it is only displayed if the first boot assistant is not cancelled before user creation. To 2.) You should find some clues here: https://github.com/armbian/build/tree/main/packages/bsp/common/etc/update-motd.d
  25. Have you tried to start and shut down the service multiple times? How do you implement your hostapd.service? I haven't tried bridging, but the configuration for system services seems to be wrong. It happened multiple times. I tried countless times with the 5.4 kernel and it never failed, even by terminating the process.
  26. Yesterday
  27. Finally got around to working on this again. A friend lent me a Windows machine with a USB-A port and it worked immediately as it should. I was able to see the helios64 machines boot. Machine A (in use so far): Disconnected after starting the kernel. Machine B (my backup unit): worked flawlessly. I took machine B home with me and I'm setting it up as I want it. It's running bookworm with OMV7 now as desired. Next time at the offsite location, I am going to take the HDDs from machine A and insert them into machine B. It's a software RAID that I set up via OMV at the time. I believe I should be able to just mount it in machine B and then set up all the services as they were before (more or less). Then I'll take machine A back with me and see if I can figure out what was wrong with it. I think a new thread will be in order then because the solution was to use a machine with a USB-A port. The use of adapters seems to have been the reason why 'screen' kept malfunctioning. Whether or not it could also be an issue with the OS (i.e. macOS not working well with it), I don't know but I doubt.
