Just an information about the `edge` kernel (6.18) when used on the cm3588-nas system. The rtc driver is not initialized on a `poweron`. After a poweron, you will see the following in the log. Nov 11 01:17:10 uhutest kernel: rtc-hym8563 6-0051: could not init device, -6 Nov 11 01:17:10 uhutest systemd[1]: System time advanced to built-in epoch: Tue 2025-11-11 01:17:09 CET If you have `fake-hwclock` running, you will see the following a moment later. fake-hwclock restores the time, but the service will not properly start, because of the rtc device error. Nov 11 01:17:12 uhutest fake-hwclock.sh[461]: Restoring saved system time Nov 20 13:22:43 uhutest fake-hwclock.sh[466]: Thu Nov 20 01:22:43 PM CET 2025 Nov 20 13:22:43 uhutest fake-hwclock.sh[468]: hwclock: Cannot access the Hardware Clock via any known method. Nov 20 13:22:43 uhutest fake-hwclock.sh[468]: hwclock: Use the --verbose option to see the details of our search for an access method. Nov 20 13:22:43 uhutest systemd[1]: fake-hwclock.service: Main process exited, code=exited, status=1/FAILURE Nov 20 13:22:43 uhutest systemd[1]: fake-hwclock.service: Failed with result 'exit-code'. Nov 20 13:22:43 uhutest systemd[1]: Failed to start Restore system time on boot and save it on shutdown. You would need to restart the fake-hwclock service, if you want that it saves time before the next restart. If you do a `restart` of the system, the rtc device will get properly initialized and time is good. Following is seen in the logs. Nov 20 13:26:14 uhutest kernel: rtc-hym8563 6-0051: registered as rtc0 Nov 20 13:26:14 uhutest kernel: rtc-hym8563 6-0051: setting system clock to 2025-11-20T12:26:11 UTC (1763641571) Nov 20 13:26:16 uhutest fake-hwclock.sh[455]: Not restoring old system time I have seen the issue right now only with the 6-18-RC kernel. The following patch mentioned here works as a pure workaround. https://patchwork.kernel.org/project/linux-rockchip/patch/20220608161150.58919-2-linux@fw-web.de/ Lets see how the development of kernel 6.18 goes and if the final version will not have this issue.
QwertyChouskie replied to jock's topic in Rockchip CPU Boxes
Is there any chance of this image running on a device using the RKPX30 chip? From some research, it seems to be a variant of the RK3326, and I'm not sure how similar the 3328 and 3326 are or are not. Or is there another Armbian image for the RKPX30/RK3326? Specifically looking to run Armbian on this: https://docs.revrobotics.com/duo-control/control-system-overview/driver-hub-specifications - Yesterday
Hello SteeMan, Thanks for your answer Its running now And I will browse the getting started pages To get this system running well It seems faster So i hope i can learn a lot at this forum Greetings Herman
https://docs.armbian.com/User-Guide_Getting-Started/#first-boot
Hello everybody, I am new at linux have ubuntu running on n old windows laptop now I found a new use for my old TVBOX i have lying around I need some help logging in to my tv box it is a T95ZPlus with a 912 soc I am booting Armbian_community_25.11.0-trunk.519_Aml-s9xx-box_plucky_edge_6.18.0-rc6_xfce_desktop.img.xz I copy u-boot-s905x2-s912 to u-boot.ext My extlinux.conf looks like this label Armbian_community kernel /Image initrd /uInitrd fdt /dtb/amlogic/meson-gxm-t95z-plus.dtb append root=UUID=8ba6ae05-2bb2-4d2c-bba6-ce6cd91ed2cb rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 The system runs but after booting Armbian_community 25.11.0-trunk.519 plucky tty1 it gives me this prompt aml-s9xx-box loging the tutorial tells Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user But my system asked for a login so i am stuck I hope someone have had this problem and can give a solution Greetings Ducdreamer
Quick update, having sorted this out I went on to install a CanBus device only to have to enable it again, so I'm back to the same delay
current isn't a good option for rk3588/s devices. At this point of time barely any support for this SoC was mainlined. And it seems like later revisions introduced a regression causing a crash. Since 6.18 may become next LTS kernel it will replace current current kernel at some point. So better go for an edge based image instead.
ok same error. The maxio module works with this snippet though : mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0xee>; ethernet-phy@0 { compatible = "ethernet-phy-id7b74.4411", "ethernet-phy-ieee802.3-c22" reg = <0x00>; status = "okay"; phandle = <0x51>; }; }; -
maka replied to Hqnicolas's topic in Rockchip CPU Boxes
yes. Things that can be tried: - DTS phy-mode = "rgmii-id"; or phy-mode = "rgmii-rxid"; - UBOOT CONFIG_PHY_REALTEK=y CONFIG_DWC_ETH_QOS=y CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -
OK do you mean boot with ethernet working using the maxio module then change DTB and reboot? -
Can you boot in a working ethernet and then reboot to this trial? -
bunducafe replied to Peter Quiring's topic in Libre Sweet Potato
I have a very similar if not the same issue on my Odroid M1. When doing a reboot it won't detect the SATA hdd. The NVME is working fine and I am booting the device via a sdcard anyway. Aparantly it has something to do with the kernel. Once I shut down the odroid and power it on again (cold reboot) the SATA device is just working fine again. I did not find a solution for this so far but I keep on digging... -
@makaOK I corrected my error and tried your suggestion but i get in dmesg : [ 47.378829] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 47.380072] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19) -
Hello comunity members, I've installed and run Armbian_community_25.11.0-trunk.437_Tanix-tx6_trixie_current_6.12.47_minimal Since my Tanix TX 6 is running pretty hot in my opinion I want to reduce the operating frequency. Please help me with some instructions how to do so, since I couldn't find any. Thank you in advance.
I know that told you the ID of your chip but also told you to switch to phy1 but you didn't. I think It is possible to use the generic driver but don't know if It will work. Changes in dtb must be accurate. -
Thank you! I'm still in the middle of a long build (chromium). I'll be able to check the flash-image-DDR4-1g_1cs_5-1200_750 image with the specific device I own with frequency scaling enabled and report if it is stable or not. It will crash pretty reliably if the firmware doesn't have the change I submitted here: https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell/commit/622677674cf34ef8fdf75b0c580d27efc8628ae8
Apologies, I somehow missed this comment until after I'd posted mine Would have saved me a fair bit of searching had I read it
@maka Thanks for this suggestion. I'll look further into this. The reason I made that change was because you suggested it here : It works well to auto load the maxio module on startup without resorting to manual modprobe commands. Is it really possible to use a generic driver for this maxio NIC chip? - Last week
I would always go RPi, as I have been burned going with a different board in the past. This may not be a fair reflection on the Orange Pi, as I can only speak for having purchased an Odroid C1+ many years ago. The C1+ was a very capable board, and definitely more capable than the RPi offering at the time. However, there just is no substitute for the support and community around the RPi. I now have 3, and even my original RPi 1 Model B+ is still supported by the RPi foundation, and still gets modern kernel and OS updates. This is a board running off just 512MB RAM, A 700 MHz single-core 32-bit processer and released over 11 years ago. No one could complain if they had dropped support long ago, but they didn't, and they still show no signs of dropping support any time soon. Hardkernel, on the other hand, pretty much dumped support for the Odroid C1+ as soon as it released, so it is stuck on a 3.x kernel and a uBoot from 2011. If it wasn't for the Armbian project this board just would not be useable, and even then, we are still stuck on a 15 year old uBoot solution. None of this may be important to you, and like I say, my experience is not likely a like-for-like comparison with the Orange Pi, but the long term support you get from the RPi foundation and the wider community around it is not even close to being matched by any other vendor, and (personally) I don't like supporting vendors who effectively manufacture e-waste.
@Shubham Singh To check if KVM is compiled into the kernel, use the following command: grep CONFIG_KVM /boot/config-$(uname -r) CONFIG_KVM=y CONFIG_KVM_MMIO=y CONFIG_KVM_VFIO=y CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y CONFIG_KVM_XFER_TO_GUEST_WORK=y You also need to ensure your CPU supports virtualization. Check with: egrep -c '(vmx|svm)' /proc/cpuinfo 0 A return value greater than 0 indicates virtualization support is present. CPU doesn't support virtualization. Check the official Radxa image. Using these commands. I doubt it works. I'm using the same kernel config and Board support package.
HI, I'm trying Mint forum. I am receiving this notification on every system startup. 19/11/2025,16:18:34 Problems during Cinnamon initialization Cinnamon started successfully, but it was not possible to load one or more applets, desklets or extensions. Check the system logs and the LookingGlass log for any issues in Cinnamon. You can disable all extension(s) in Cinnamon Settings to prevent this message from appearing repeatedly. Please contact the developer. and Looking Glass log error t=2025-11-19T03:20:50Z [menu@cinnamon.org]: Util.latinise is not a function [menu@cinnamon.org]: Failed to evaluate 'main' function on applet: menu@cinnamon.org/0 error t=2025-11-19T03:20:50Z [menu@cinnamon.org]: Applet menu@cinnamon.org: Could not create applet object.[menu@cinnamon.org]: Error importing applet.js from menu@cinnamon.org error t=2025-11-19T03:20:51Z [menu@cinnamon.org]: Util.latinise is not a function [menu@cinnamon.org]: Failed to evaluate 'main' function on applet: menu@cinnamon.org/0 error t=2025-11-19T03:20:51Z [menu@cinnamon.org]: Applet menu@cinnamon.org: Could not create applet object. [menu@cinnamon.org]: Error importing applet.js from menu@cinnamon.org info t=2025-11-19T03:20:51Z AppletManager started in 15564 ms info t=2025-11-19T03:20:51Z Cinnamon took 15834 ms to start info t=2025-11-19T03:20:51Z Adding systray: blueman-tray (1x1px) info t=2025-11-19T03:20:51Z Adding systray: solaar (1x1px) info t=2025-11-19T03:20:51Z Adding systray: indicator-solaar (1x1px) info t=2025-11-19T03:20:51Z GPU offload supported: false Captured from my system: cury@orangepi5-plus:~$ inxi -Fxxxz System: Kernel: 6.1.115-vendor-rk35xx arch: aarch64 bits: 64 compiler: gcc v: 11.4.0 clocksource: arch_sys_counter Desktop: Cinnamon v: 6.4.10 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Armbian GNU/Linux 13 (trixie) Machine: Type: ARM System: Orange Pi 5 Plus details: N/A CPU: Info: 8-core model: N/A variant-1: cortex-a76 variant-2: cortex-a55 bits: 64 type: MCP smt: <unsupported> arch: ARMv8 rev: 0 cache: L1: 768 KiB L2: 2.5 MiB L3: 3 MiB Speed (MHz): avg: 1800 min/max: 408/1800:2256 cores: 1: 1800 2: 1800 3: 1800 4: 1800 5: 1800 6: 1800 7: 1800 8: 1800 bogomips: N/A Features: Use -f option to see features Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A bus-ID: N/A chip-ID: rockchip:display-subsystem class-ID: display-subsystem Device-2: rk3588-dw-hdmi driver: dwhdmi_rockchip v: N/A bus-ID: N/A chip-ID: rockchip:fde80000 class-ID: hdmi Device-3: rk3588-dw-hdmi driver: dwhdmi_rockchip v: N/A bus-ID: N/A chip-ID: rockchip:fdea0000 class-ID: hdmi Display: x11 server: X.Org v: 21.1.16 driver: X: loaded: modesetting unloaded: fbdev dri: rockchip gpu: rockchip_drm,dwhdmi_rockchip, dwhdmi_rockchip display-ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93") Monitor-1: HDMI-A-1 mapped: HDMI-1 model: LG (GoldStar) FHD serial: <filter> res: mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 82 size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 1920x1080 min: 640x480 API: EGL v: 1.5 platforms: device: 0 drv: panthor device: 1 drv: rknpu device: 2 drv: rockchip device: 3 drv: swrast gbm: drv: panthor surfaceless: drv: panthor x11: drv: rockchip inactive: wayland API: OpenGL v: 4.5 compat-v: 3.1 vendor: mesa v: 25.0.7-2 glx-v: 1.4 direct-render: yes renderer: Mali-G610 (Panfrost) device-ID: ffffffff:ffffffff Info: Tools: api: eglinfo,glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr Audio: Device-1: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:dp0-sound class-ID: dp0-sound Device-2: rk3588-dw-hdmi driver: dwhdmi_rockchip bus-ID: N/A chip-ID: rockchip:fde80000 class-ID: hdmi Device-3: rk3588-dw-hdmi driver: dwhdmi_rockchip bus-ID: N/A chip-ID: rockchip:fdea0000 class-ID: hdmi Device-4: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:hdmi0-sound class-ID: hdmi0-sound Device-5: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:hdmi1-sound class-ID: hdmi1-sound API: ALSA v: k6.1.115-vendor-rk35xx status: kernel-api Server-1: PulseAudio v: 17.0 status: active Network: Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: 1000 bus-ID: 0003:31:00.0 chip-ID: 10ec:8125 class-ID: 0200 IF: enP3p49s0 state: down mac: <filter> Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: 100000 bus-ID: 0004:41:00.0 chip-ID: 10ec:8125 class-ID: 0200 IF: enP3p49s0 state: down mac: <filter> Device-3: wlan-platdata driver: wlan_platdata v: N/A bus-ID: N/A chip-ID: wlan-platdata:wireless-wlan class-ID: wireless-wlan IF-ID-1: dummy0 state: down mac: <filter> IF-ID-2: enP4p65s0 state: down mac: <filter> IF-ID-3: wlx90de807f1947 state: up mac: <filter> Bluetooth: Device-1: Realtek 802.11ac NIC driver: btusb,rtw_8822bu type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 bus-ID: 1-1.4:3 chip-ID: 0bda:b82c class-ID: e001 serial: <filter> Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes address: <filter> Drives: Local Storage: total: 1.04 TiB used: 107.07 GiB (10.0%) ID-1: /dev/nvme0n1 vendor: Reletech model: P600 M.2 PCIE3.0 1TB size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SN10660 temp: 39.9 C scheme: GPT ID-2: /dev/sda vendor: Kingston model: DataTraveler 3.0 size: 115.47 GiB type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 tech: N/A serial: <filter> fw-rev: 0000 scheme: MBR Partition: ID-1: / size: 576.47 GiB used: 12.63 GiB (2.2%) fs: ext4 dev: /dev/nvme0n1p1 ID-2: /var/log size: 46.8 MiB used: 7.4 MiB (15.9%) fs: ext4 dev: /dev/zram1 Swap: ID-1: swap-1 type: partition size: 19.14 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2 ID-2: swap-2 type: zram size: 7.79 GiB used: 0 KiB (0.0%) priority: 5 dev: /dev/zram0 Sensors: System Temperatures: cpu: 49.0 C mobo: N/A Fan Speeds (rpm): N/A Info: Memory: total: N/A available: 15.58 GiB used: 4.38 GiB (28.1%) Processes: 313 Power: uptime: 1h 17m states: freeze,mem suspend: deep wakeups: 0 Init: systemd v: 257 default: graphical Packages: pm: dpkg pkgs: 1548 Compilers: clang: 19.1.7 gcc: 14.2.0 Shell: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.38 cury@orangepi5-plus:~$
Yes, I removed that as well quite quickly. Now the printer is ready in 30s after power-on.
@djoness you need to Disable Armbian kernel/firmware upgrades using the armbian-config tool. System -> Updates -> UPD002 - Disable Armbian firmware upgrades -> Disable Armbian kernel/firmware upgrades X96Q has many different variations of the same box. Read the bottom of this thread. https://github.com/warpme/miniarch/issues/102 If you want a well supported box get a Transpeed 8K618-t.
