  2. First of all thanks to the people maintaining armbian for helios64. I recently upgraded (well I reinstalled) to trixie and everything mostly runs stable for me. However I have a problem with the 2.5GB adapter. It is connected to a 2.5GB switch and when for example running iperf3 I get proper results close to 2.5 GBit. So in general it seems to be running ok. I have a DLNA server (minidlna) running on that machine and when I stream from my TV (streaming via VLC from my laptop triggers the same problems) the network connection drops for a moment and works again after a few seconds (which you can guess is super annoying when watching something). I am not sure what exactly is triggering this. most of the time the network is super stable but during streaming I get hickups. This is what my kernel log spits out when this is happending: ``` Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f10 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f20 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f30 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f40 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f50 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f60 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f70 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f80 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f90 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8fa0 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:59 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: NETDEV WATCHDOG: CPU: 0: transmit queue 0 timed out 5152 ms Apr 09 17:45:59 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx timeout Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:02 hermann-walter kernel: r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd ``` the usb related messages are not always there but the r8152 related messages are always there. I found a similar problem here: https://github.com/openwrt/openwrt/issues/22130 I tried replacing the firmware but that didn't help and I later found out that the helios64 uses a different firmware so that explains why it didn't help: ``` Apr 10 05:48:30 hermann-walter kernel: r8152 2-1.4:1.0: Loaded FW: rtl_nic/rtl8156a-2.fw, sha256: 7b50f4a307bde7b3f384935537c4d9705457fa42613eb0003ffbc4e19461a1e0 Apr 10 05:48:30 hermann-walter kernel: r8152 2-1.4:1.0: Loaded FW: rtl_nic/rtl8156a-2.fw, sha256: 7b50f4a307bde7b3f384935537c4d9705457fa42613eb0003ffbc4e19461a1e0 ``` does anybody know what is going on? I am quite sure that the problem wasn't there before the upgrade (but I might be mistaken because I only started observing the helios64 again after the upgrade. also it seems to be related to the amount of network traffic going on. i.e. lower bitrate streams seem to not trigger the problem). Streaming via the 1GBit NIC is working fine.
  4. I think I may have found the Wi-Fi info from the board label. It is an Allwinner H313 board, and the sticker says **1+8 (SV625 6P)**, so I believe the Wi-Fi chip/module is **SV6256P**. I still can't read the marking directly on the IC itself, but the board label strongly suggests that this is the Wi-Fi chip being used.
  5. Yesterday
  6. 3D Graphics Acceleration on T95N (A98X Jackbox) - RK3229 with 2GB RAM / 16GB eMMC - Educational Project for Schools Hi, I’m working on a project using a specific TV Box model (A98X Jackbox) to repurpose these boxes as low-cost computers for schools. The goal is to provide students with a platform to use AI tools and basic productivity, but I need better browser rendering. Hardware Specs (Confirmed via board teardown and logs): Board ID: T95N-RK3229_512X4_V1.5 CPU: Rockchip RK3229 RAM: 2GB (Confirmed via free -m) Storage: 16GB eMMC (SanDisk SDIN9DS2-16G) OS: Armbian 21.08.8 Bullseye (Legacy Kernel 4.4.194-rk322x) What I have done so far: Installed the Minimal image and set up LXDE with LightDM. Optimized the system (Governor set to performance, swappiness set to 10). Ran glxinfo -B which confirms it's currently using llvmpipe (Accelerated: no). Tried searching for Mali drivers via apt, but armbian-config is not available in the repositories for this specific build/architecture. Verified Wi-Fi functionality (working fine with LED config 2 via rk322x-config). The system is stable and surprisingly fast thanks to the 2GB RAM, but the CPU is struggling with 100% spikes during browser rendering (Epiphany WebKit) because it lacks GPU acceleration. Question: Is there a way to enable Mali-400 MP2 drivers for X11 on this Legacy 4.4 kernel? Are there any specific packages, blobs, or workarounds to get hardware acceleration working and replace llvmpipe? I’m available to run any tests or provide further logs if needed. Thanks for this amazing project!
  7. @Sergioclr you can also try a newer branch https://github.com/NickAlilovic/build/tree/v20251014 https://github.com/NickAlilovic/build/tree/v20251014?tab=readme-ov-file#build-host-requirements
  8. @Sergioclr Requirements for self hosted x86_64 / aarch64 machine at least 2GB of memory and ~35GB of disk space for VM, container or bare metal installation Armbian / Ubuntu Jammy 22.04.x for native building or any Docker capable Linux for containerised Windows 10/11 with WSL2 subsystem running Ubuntu Jammy 22.04.x Superuser rights (configured sudo or root access). Make sure your system is up-to-date! Outdated Docker binaries, for example, can cause trouble.
  9. $ cat /etc/os-release PRETTY_NAME="Debian GNU/Linux 13 (trixie)" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.4 Compile phase failed due to missing package (ntpdate) Short log: [🌱] Configuration prepared for BOARD build [ x98h.csc ] [✨] Repeat Build Options (early) [ ./compile.sh build BOARD=x98h BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=trixie ] [🌱] Checked directory OK for mount options [ /home/*****/build/.tmp ('main temporary dir') ] [🌱] Preparing [ host ] [🌱] Python2 not available on host release 'trixie' [ ancient u-boot versions might/will fail to build ] [🌱] Updating apt host-side for installing host-side packages [ 50 packages ] [🌱] Installing host-side packages [ binfmt-support bison libc6-dev make dpkg-dev gcc ccache device-tree-compiler dwarves flex imagemagick jq libbison-dev libelf-dev libfdt-dev libfile-fcntllock-perl libmpc-dev libfl-dev lz4 libncurses-dev libssl-dev libusb-1.0-0-dev ntpdate patchutils pkg-config pv qemu-user-static arch-test swig u-boot-tools uuid-dev zlib1g-dev expect colorized-logs zip pigz pbzip2 lzop gdisk aria2 axel parallel rdfind libpython3-dev libffi-dev libgnutls28-dev gcc-aarch64-linux-gnu libc6-amd64-cross gcc-arm-linux-gnueabi gcc-or1k-elf ] [πŸ”¨] E: Package 'ntpdate' has no installation candidate [πŸ’₯] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [πŸ’₯] Cleaning up [ please wait for cleanups to finish ] [🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-dd186c47-e7eb-49f8-8d38-836915cf0aec.log.ans ] [🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] Note ntpdate has a more recent version: ntpsec-ntpdate Should I try to compile in a Debian 12 computer? I am afraid of messing with 'sources.list'. Thanks in advance.
  10. Wayland 1.25 refreshes its documentation with three new chapters covering Wayland XML specification, content model updates, and color management design. View the full article
  11. Hi @sven-ola , I'm having an issue where my portrait-oriented monitor isn't displaying anything properly. I have a portrait-oriented monitor, and when I try to connect it via HDMI, it doesn't display anythingβ€”the screen remains blank. I found this in dmesg: [drm] spacemit_hdmi_connector_detect() hdmi status connected [drm] Initialized spacemit 1.0.0 for c0440000.display-subsystem-hdmi on minor 1 [drm] spacemit_hdmi_connector_detect() hdmi status connected [drm] spacemit_hdmi_get_edid_block() len 128 [drm] spacemit_hdmi_get_edid_block() len 128 spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes I added `video=1080x1920@60` to the kernel parameters. Now it outputs: [ 4.162834] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] User-defined mode not supported: "1080x1920": 60 137020 1080 1152 1160 1176 1920 1934 1936 1942 0x68 0x5 [ 4.162871] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes I think this is because the driver only supports a resolution of 1920x1080, but not 1080x1920. dmesg.txt
  12. I have seen some kernel errors w.r.t. trim on Silicon Power 16GB SD-card, was in ROCK3A. But no other errors. Kernel is unspecified, although I might be able to figure out which/what, you can even search this forum, then you know yourself. This errors do not occur on a RPi4 v1.1 (with RPL OS and kernel). So if you want to know, dig more into logs, doe specialistic blocklevel error checking. In general: welcome to SD-card magic!. See also this:
  13. I flashed a home built nanpim4v2 image to two brand new Silicon Power 32GB sdcards and they wont boot whereas SanDisk 32GB boot OK can anyone explain why ?
  14. Why repair the filesystem first while you anyway overwrite the whole storage device then? /dev/sdb1 suggests an USB SD-card adaptor is used. Both the adaptor, which translates USB protocol into MMC commands, and the SD-card itself, which also does internal block managing, can mess up the filesystem. Not as long as this is plugged into the computer where the imager (or dd) is running, but once removed and put into the SBC, power is lost and re-applied. The USB + SD-card hardware (and also OS driver in the computer) might have flaws in its implementation. It could easily be that SD-card signals 'ready' to OS, so you then take out USB + SD-card, but that actually not all is committed to the actual flash and still some is in buffers or the SD-card is still doing wear-leveling and doesn't do that in a correct way. And worse, if fake sized counterfeit, the firmware might be busy doing its 'magic tricks' to fake hundreds of GB size while only 8 or 32 GB is actual flash chip. So unfortunately, even if using a verify step in writing an image, the actual content on the SD-card might be different from the image file once the SD-card is put in the SBC. I remember such a case on this forum where someone did manual block-level compare of storage device and image. I also have had such issue at least once. It is the situation where you just re-do / re-write again without knowing what is wrong. And/or use other SD-card, other USB-adaptor, other computer, etc. To prevent such issues, I tend to use (the) SBC itself to write SD-cards. My RPI4 runs from USB-SSD, so SD-card slot is free. I trust RPL HW more than various USB SD-card adaptors. Earlier test I mentioned using the the Armbian-imager was on NanoPi-R6C running from eMMC+NVME, so same story, free SD-card slot. It ran Armbian Trixie KDE6 and 7.0-rc rockchip64 kernel. I was also forced to more or less, because on my Tumbleweed N100 box the Armbian Imager only stayed white (some EGL error). That was with x86-64 AppImage. I thought it would be better to install from a .deb hence walked to my powered-on ARM64 running Debian. Anyway I do normally not use images. I would rather use ddrescue (enable mapfile option) to check and make sure image is same as on storage device. That helped also in the past for 4TB HDD's (when risk of bit-rot). It is CLI based and allows to re-do check after power-cycle.
  15. Could you please send me the DTB file that your motherboard displays and only receives internet signals? I have a motherboard that's similar to that one.
  16. Last week
  17. It is not working with this patch because offcially AIC8800 is not supported in kernel > 7.0-rc6 plus in my image Wifi was initially disabled With new image it is better: I made a small fix to make it running with some commands as root: ``` # unzip AIC_FIX.zip # mkdir -p /lib/modules/$(uname -r)/kernel/drivers/net/wireless/aic8800 # cp aic_btusb.ko aic_load_fw.ko aic8800_fdrv.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/aic8800/ # depmod -a # cat /etc/modules-load.d/aic8800.conf aic_load_fw aic8800_fdrv aic_btusb # cp -r aic8800_fw /lib/firmware/ # cp -pr aic8800_fw/USB/aic8800D80/ /lib/firmware/ # modprobe aic_load_fw # modprobe aic8800_fdrv # modprobe aic_btusb # lsmod |grep -i aic aic_btusb 57344 0 aic8800_fdrv 626688 0 cfg80211 1200128 1 aic8800_fdrv aic_load_fw 86016 1 aic8800_fdrv ``` Please also remember as it is experimental and all you do it is on your own risk HDMI is not working and we need some code first, I guess for this part: CONFIG_PHY_ROCKCHIP_INNO_HDMI_QP
  18. Ok, maybe I am not able to boot because this image is not for the stock PocketCHIP but for one which requires a custom breakout board: https://github.com/armbian/build/pull/7647 Maybe I could have found that out sooner if there was a device page for this custom PocketCHIP in the community supported devices page at ttps://www.armbian.com/community/. Who/how is supposed to create it? The board maintainer? How is one supposed to do that? There is no mention in the Board Maintainers Procedures and Guidelines. I haven't anything on the armbian github repositories about the boards information on this page. It would be important to have the device page, especially when the image was created for custom developed PCBs. Only after some digging and finding the PR where the device was added, I was able to figure out why I may not be able to boot the pocketchip-sd armbian image.
  19. @Sergioclr the H313, H616, H618, and IK316 are essentially the same SoC family. To successfully boot an image, you must match the correct AXP chip (the Power Management IC) and the specific DRAM version used on your board. Essentially, any thread discussing the H616/H618 (excluding older H3/H5/H6 chips) will contain relevant information for these SoCs. PMIC Information: http://linux-sunxi.org/AXP_PMICs DRAM Types: 3: DDR3 4: DDR4 7: LPDDR3 8: LPDDR4 You can try flashing various boot images until one successfully initializes your hardware. (If your box is secure-boot enabled, you will need to add the secure-boot modifications posted above.) https://github.com/NickAlilovic/build/releases/tag/20250306 Alternatively, for a more precise approach: Extract your Device Tree (DTS). Identify the specific AXP chip located on your board. Connect a USB-to-UART TTL device to the RX, TX, and GND pins on your board to monitor the boot sequence. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-232411 https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/4/#findComment-187672 https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/23/#findComment-218660 https://linux-sunxi.org/UART Decompile your Device Tree Blob (DTB😞 dtc -I dtb -O dts -o source.dts source.dtb For a visual reference of a board using these specific chips, check out this hardware breakdown. http://nskhuman.ru/allwinner/krugh618.php?np=3
  20. On a first analysis, I noticed that the git already has a very similar option that I need (H313): ~/build/patch/u-boot/u-boot-sunxi/board_x96q$ arm64-sun50i-h313-add-x96q-lpddr3-defconfig.patch sunsi-add-h616-internal-eth-phy-support.patch so I am stuck on how to proceed because the example has H616 parameters. Help will be appreciated.
  21. TL;DR: fsck /dev/sdb1 Looks like something corrupted the drive filesystem. I was able fsck repair the drive, and re-apply the image via armbian-imager. The fact that armbian-imager 'validated' the flashed contents multiple times is where things went sideways. Once i tried to manually delete the contents of the drive, and that failed, it became apparent that the drive had been corrupted. I'm not sure what the 'validation' that armbian-imager does is, though.
  22. @Ducdanh Nguyen probably a real H313 SOC. You know this! You were on the other thread.
  23. Have you mounted the image to verify that the problem isn't with the image? (You assume that the issue is with imager but you should first verify that the issue isn't with the image that imager is copying to the storage media.
  24. Armbian-imager is just.. not doing anything useful... I manually deleted the 'kernel' on the device... which was really an apt packages list somehow... rebuilt & 'flashed'... 14:03:51 ● custom_image: Board detection completed successfully 14:03:51 ● frontend::app: Detected board from filename: Espressobin (espressobin) 14:03:52 ● board_queries: Device(s) added: ["/dev/sda", "/dev/sdb", "/dev/nvme0n1"] 14:03:55 ● operations: Requesting write authorization for device: /dev/sdb 14:03:55 ● flash::linux::privileges: Authorization will be requested via polkit when accessing: /dev/sdb 14:03:55 ● operations: Authorization granted for /dev/sdb 14:03:55 ● custom_image: Check decompression for /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img: false 14:03:55 ● operations: Starting flash: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img -> /dev/sdb (verify: true) 14:03:55 ● flash::linux::writer: Starting flash: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img -> /dev/sdb 14:03:55 ● flash::linux::writer: Image size: 2139095040 bytes (1.99 GB) 14:03:55 ● flash::linux::writer: Unmounting device partitions... 14:03:55 ● flash::linux::writer: Writing image... 14:04:01 ● flash::linux::writer: Write complete: 2040.0 MB in 5.5s (avg 373.2 MB/s) 14:04:01 ● flash::linux::writer: Starting verification... 14:04:01 ● flash::verify: Starting verification of 2139095040 bytes (1.99 GB) 14:04:05 ● flash::verify: Verify complete: 2040.0 MB in 4.6s (avg 441.9 MB/s) 14:04:05 ● flash::linux::writer: Flash complete! 14:04:05 ● operations: Flash completed successfully 14:04:05 ● custom_image: Deleting decompressed custom image: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img 14:04:05 ● custom_image: Attempted to delete file outside custom-decompress cache: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img > sudo mount /dev/sdb1 /mnt/ > ls /mnt bin boot/ dev/ etc/ home/ initrd.img initrd.img.old lib lost+found/ media/ mnt/ opt/ proc/ root/ run/ sbin selinux/ srv/ sys/ tmp/ usr/ var/ vmlinuz vmlinuz.old > ls -ltr /mnt/ total 80 drwxr-xr-x 2 root root 4096 Mar 2 16:50 sys/ lrwxrwxrwx 1 root root 8 Mar 2 16:50 sbin -> usr/sbin/ drwxr-xr-x 2 root root 4096 Mar 2 16:50 proc/ lrwxrwxrwx 1 root root 7 Mar 2 16:50 lib -> usr/lib/ drwxr-xr-x 2 root root 4096 Mar 2 16:50 home/ drwxr-xr-x 2 root root 4096 Mar 2 16:50 dev/ lrwxrwxrwx 1 root root 7 Mar 2 16:50 bin -> usr/bin/ drwxr-xr-x 2 root root 4096 Mar 31 22:57 mnt/ drwxr-xr-x 2 root root 4096 Mar 31 22:57 srv/ drwxr-xr-x 2 root root 4096 Mar 31 22:57 opt/ drwxr-xr-x 2 root root 4096 Mar 31 22:57 media/ drwxr-xr-x 11 root root 4096 Mar 31 22:57 usr/ drwxrwxrwt 2 root root 4096 Mar 31 22:57 tmp/ drwxr-xr-x 12 root root 4096 Apr 7 16:47 var/ drwxrwxr-x 2 root root 4096 Apr 7 16:47 selinux/ lrwxrwxrwx 1 root root 33 Apr 7 16:48 vmlinuz.old -> boot/vmlinux-6.18.21-edge-mvebu64 lrwxrwxrwx 1 root root 33 Apr 7 16:48 vmlinuz -> boot/vmlinux-6.18.21-edge-mvebu64 lrwxrwxrwx 1 root root 36 Apr 7 16:48 initrd.img.old -> boot/initrd.img-6.18.21-edge-mvebu64 lrwxrwxrwx 1 root root 36 Apr 7 16:48 initrd.img -> boot/initrd.img-6.18.21-edge-mvebu64 drwx------ 3 root root 4096 Apr 7 16:48 root/ drwx------ 2 root root 16384 Apr 7 16:49 lost+found/ drwxr-xr-x 91 root root 4096 Apr 7 16:49 etc/ drwxr-xr-x 3 root root 4096 Apr 7 16:49 run/ drwxr-xr-x 3 root root 4096 Apr 8 13:35 boot/ > ls -ltr /mnt/boot/ total 59328 -rw-rw-r-- 1 root root 1592 Apr 3 18:14 boot.cmd -rw-r--r-- 1 root root 5318624 Apr 3 18:36 System.map-6.18.21-edge-mvebu64 -rw-r--r-- 1 root root 224205 Apr 3 18:36 config-6.18.21-edge-mvebu64 lrwxrwxrwx 1 root root 28 Apr 7 16:48 Image -> vmlinux-6.18.21-edge-mvebu64 drwxr-xr-x 3 root root 4096 Apr 7 16:48 dtb-6.18.21-edge-mvebu64/ lrwxrwxrwx 1 root root 24 Apr 7 16:48 dtb -> dtb-6.18.21-edge-mvebu64/ -rw-rw-r-- 1 root root 38518 Apr 7 16:48 boot.bmp -rw-rw-r-- 1 root root 95 Apr 7 16:49 armbianEnv.txt -rw-rw-r-- 1 root root 1664 Apr 7 16:49 boot.scr -rw-r--r-- 1 root root 18372350 Apr 7 16:49 initrd.img-6.18.21-edge-mvebu64 -rw-r--r-- 1 root root 18372414 Apr 7 16:49 uInitrd-6.18.21-edge-mvebu64 lrwxrwxrwx 1 root root 28 Apr 7 16:49 uInitrd -> uInitrd-6.18.21-edge-mvebu64 -rw-r--r-- 1 root root 18398788 Apr 7 16:49 espressobin.itb > ls -ltr /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img -rw-rw-r-- 1 root root 2139095040 Apr 8 14:02 /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img > > ls -ltr /mnt/boot/Image lrwxrwxrwx 1 root root 28 Apr 7 16:48 /mnt/boot/Image -> vmlinux-6.18.21-edge-mvebu64 > ls -ltr /mnt/boot/vmlinux-6.18.21-edge-mvebu64 ls: cannot access '/mnt/boot/vmlinux-6.18.21-edge-mvebu64': No such file or directory > so... why is armbian-imager not pushing the kernel files from a custom image?
  25. Hey everyone, I’ve cross-flashed a MXQ 4K 5G (Allwinner sun8iw7p1 / H3) firmware onto a different H3-based TV box. Everything works surprisingly well, except for the IR Power-On/Wakeup. Since the hardware is different, my box's IR receiver is sending a scancode that the MXQ firmware doesn't recognize as the "Wakeup" key. Because this is an Allwinner (sunxi) build and not Rockchip, I know I can't just edit a remote.conf file in the system partition to fix the cold-boot power button. My questions: Where exactly is the Hardcoded IR Wakeup/Power-on scancode stored in these Phoenix-style Allwinner images? Is it buried in the Device Tree Blob (DTB) under a specific IR controller node, or is it hardcoded in the U-Boot/SPL? If I unpack the boot.img or kernel, what hex patterns should I search for to find the Power-key scancode table? If anyone has experience patching the primary boot scancode for sun8i chips, I’d love some guidance on which partition/file to hex-edit. Thanks!
  26. I have a 512 MB RAM, 4GB Toshiba NAND PocketCHIP with a custome u-boot supporting USB Booting and decided to test the latest armbian community image for the PocketCHIP (https://github.com/armbian/community/releases/download/26.2.0-trunk.668/Armbian_community_26.2.0-trunk.668_Pocketchip-sd_trixie_current_6.18.20_minimal.img.xz) Boot seems to start fine with all kernel files load confirmed by u-boot output (vmlinuz, ramdisk dtb, etc) but then it goes mute while starting the kernel @TheSnowfield, you are listed as the pocketchip board maintainer (thanks a lot for your contribution! πŸ™), any ideas of what am I missing? Do you have a suggestion for a working build? Thanks! Serial UART output: U-Boot SPL 2016.01-00115-g5f814bb (Dec 09 2016 - 23:00:24) Fuel Gauge: 77% Battery Voltage: 3776mV DRAM: 512 MiB CPU: 1008000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from NAND U-Boot 2021.10-rc5+ (Oct 21 2021 - 14:43:51 -0500) Allwinner Technology CPU: Allwinner A13 (SUN5I) Model: NextThing C.H.I.P. I2C: ready DRAM: sunxi SPL version mismatch: expected 3, got 1 512 MiB NAND: 4096 MiB Loading Environment from nowhere... OK Setting up a 480x272 lcd console (overscan 0x0) In: serial Out: vidconsole Err: vidconsole sunxi SPL version mismatch: expected 2, got 1 starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 5 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Hit any key to stop autoboot: 0 DIP: PocketCHIP (0x1) from Next Thing Co. (0x9d011a) Found 1 extension board(s). Device 0: Vendor: Mass Rev: 1.00 Prod: Storage Device Type: Removable Hard Disk Capacity: 14832.0 MB = 14.4 GB (30375936 x 512) ... is now current device Scanning usb 0:1... Found U-Boot script /boot/boot.scr 5475 bytes read in 4 ms (1.3 MiB/s) ## Executing script at 43100000 U-boot loaded from NAND 154 bytes read in 4 ms (37.1 KiB/s) sun5i-r8-chip.dtb: No match Load fdt: /boot/dtb/sun5i-r8-chip.dtb 14474151 bytes read in 780 ms (17.7 MiB/s) 10539688 bytes read in 557 ms (18 MiB/s) Found mainline kernel configuration 25215 bytes read in 9 ms (2.7 MiB/s) 2146 bytes read in 7 ms (298.8 KiB/s) Applying kernel provided DT fixup script (sun5i-a13-fixup.scr) ## Executing script at 45000000 Kernel image @ 0x42000000 [ 0x000000 - 0xa0d2a8 ] ## Loading init Ramdisk from Legacy Image at 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 14474087 Bytes = 13.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 49232000, end 49fffb67 ... OK Loading Device Tree to 491c3000, end 49231fff ... OK Starting kernel ...
Γ—
Γ—
