Install openVFD for LCD display on recent (6.12) kernels - Tutorial
going replied to torz77's topic in Reviews / Tutorials
I'm not sure what this adds? I saw a user struggling to get it working, I managed to get it working, so thought I would give my steps that they may help other people. I apologize. I have not read what you wrote earlier. Please write whatever you see fit your work can be very useful. Success to you in your endeavor. -
dmesg | grep -E 'hdmi|gpu|drm' ?
torz77 replied to torz77's topic in Reviews / Tutorials
I'm not sure what this adds? I saw a user struggling to get it working, I managed to get it working, so thought I would give my steps that they may help other people. I am happy to improve my instructions based on feedback from users like @SteeMan above, but I was not specifically looking for help. If my tutorial and responses are in anyway not wanted here, then feel free to delete them. -
Ok, this I was not aware of. When I get a second I will try it out. I'm not sure how long editing remains open on my post, but if it works, and if I can, I will go back and edit -
What can be said about this (help)? Answer: nothing. Please show the output of the UART download, show the source code of the overlay you are using. By reading specific data, users will be able to give you advice. -
SteeMan replied to torz77's topic in Reviews / Tutorials
Yeah that won't work as that code has no support for extlinux. The extlinux way would be to add a line FDTOVERLAYS /path/overlayfilename.dtbo to your extlinux.conf file. Again, I haven't tested this, (I've had no overlays that I've needed to use for anything), but theoretically this is supposed to work. - Today
I mean that creating the dts and executing: sudo armbian-add-overlay openvfd.dts Results in: grep: /boot/boot.cmd: No such file or directory Overlays are not supported on Meson64 based boards. I started to investigate, but realised it was a massive rabbit hole, and what with the note in the documentation saying: I decided that directly applying the overlay to the DTB and running an /etc/kernel/postinst.d/ script following a kernel update would be my path of least resistance. If I have overlooked something, I would happily update the instructions as, clearly, using an overlay would be far more preferential. EDIT: I should add, that I also tried compiling and adding the overlay manually, and adding an armbianEnv.txt for boot, but the overlay was not loaded. -
I'm curious what you mean by this. I thought they were working via the extlinux.conf way of specifying them (although I will admit I've never tested this). -
Werner replied to torz77's topic in Reviews / Tutorials
I tested the upstream Debian and I only got 4GB as well, I don't know if that was stable or not. Actually some upstream Debian images I tried didn't work at all at first. Then I upgraded the firmwares on my board, following these instructions: https://forum.rvspace.org/t/visionfive-2-debian-image-released/994/75 Bu I was more precise than that, first I used the sdcard image and fimware files from 2.6.0 (said to work in that page): https://github.com/starfive-tech/VisionFive2/releases/tag/VF2_v2.6.0 Note: I had no display, I ran the firmware update commands over SSH. Then I rebooted, using the sdcard image from 2.11.5 (arbitrary chosen): https://github.com/starfive-tech/VisionFive2/releases/tag/VF2_v2.11.5 But I used the latest (5.11.3) firmware files to update the firmware: https://github.com/starfive-tech/VisionFive2/releases/tag/JH7110_VF2_515_v5.11.3 After that, I flased the latest image (202409), for sdcard: starfive-jh7110-202409-SD-minimal-desktop-wayland.img The whole 8GB is displayed and everything looks stable, the board is running since 9 hours without problem. But one problem is that this Debian image is based on an now-old Debian Trixie/Sid snapshot, which is painful to deal whit. I'll try again the Armbian image later to see if the firmware update fixed the memory size problem and the stability.
<off topic: If someone wants to tell me how to "reply" to a post on these forums, that would be appreciated!> Sadly, Meson64 does not have DTB Overlays enabled. That would, of course, be my preference. I have, however, updated my instructions to create an overlay and apply it directly to the DTB (rather than manually editing the DTB) and pointed users in the direction of postint.d if they wish to automate this (out of scope to provide specific instructions here). It should now be easier to create an overlay rather than directly apply to DTB if the user's box supports this. Unfortunately, I did not see this until I was well underway getting OpenVFD working. The box is now in production, so it is not straightforward taking it out and experimenting with it. However, having more than one way to achieve an end goal is no bad thing imho. -
Also, did you experiment with this alternative to openvfd? -
Did you try doing this with a device tree overlay file instead of editing the device tree? That way on kernel upgrades you shouldn't need to redo the device tree edits each time. -
HW: OrangePi5 Plus 32 32 GB RAM 512 GB NVME 5K Monitor Image: Armbian_25.8.1_Orangepi5-plus_trixie_vendor_6.1.115_xfce_desktop.img prepare system before each case dd if=u-boot-V2024.04-orangepi5-plus-spi.img of=/dev/mtdblock0 flash_erase /dev/mtd0 0 0 case 1: 1. copy image to 64GB uSD 2. booting 3. system comes up with xfce 4. sudo apt-get -y update; apt-get -y upgrade 5. reboot 6. system comes up, without desktop. system is reachable with ssh case 2: 1. copy image to 64GB uSD 2. booting 3. system comes up with xfce 4. armbian-install 5. choose boot from mtd flash 6. choose nvme0n1p1 6. update mtdblock0 7. reboot 8. system comes up, without desktop. system is reachable with ssh any idea whats going wrong?
Is it possible to use /dev/ttyS0 to connect a zigbee coordinator?
Yurannich replied to Yurannich's topic in Amlogic CPU Boxes
S905W2 I didn't find a solution to my problem on the forum. -
Werner replied to pochopsp's topic in Amlogic CPU Boxes
moved -
Armbian 25.8.1 Noble XFCE (mainline Kernel: 6.16.6-edge-rockchip64) + PanVk - mesa 23.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.7 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~30fps@720p Dark Souls 2 - SotFS -
I've just been through this process myself. Those instructions are not close to working, and I'm not sure they ever worked. I have documented how I got the LCD display working on the T3-Mini here:
This was originally meant as a reply to a user having problems enabling openVFD on a Tannix T3-Mini, a device I happen to own. I have recently been through this journey myself, and having searched the forums, I cannot find a recent topic on how to build this for Armbian, so have decided to make a new post that may be of use to some. Hold on to your hat, because this is going to be long. Caveats These instructions are, specifically, for the Tannix TX3-Mini. However, with a bit of fiddling, the general approach should work for any supported TV Box. I have added notes where you will need to look to edit a different file for your specific device There are many, many variants of the TX3-Mini out there. What works for me, may not work for you. Do not expect any help or support from me, I am just posting this as a courtesy for how I got this working... your mileage may vary. I am not going to troubleshoot anyone's issues These instructions are quite verbose, as they may also help users of other TV Boxes to get their displays working. It also may not. Like I say, I am not here to be tech support, but we can all agree not having a display stuck on "boot" is a nice thing to have As this is a kernel module it will most likely stop working after each kernel update. You will probably want to create a DKMS to rebuild the module whenever you download a new kernel. This is outside of scope here. Use Google. At the end of this, if all goes well, you will have a display showing the current time. If you want to do more with the display then this is outside of scope and you will need to look elsewhere. However, this link is useful for how to trigger the icons: https://github.com/arthur-liberman/linux_openvfd/blob/master/led_control.txt (note: only items 1 to 6 are valid for the tx3-mini) A lot of this can be done in a chroot, but the actual building of the kernel module itself must be done on the target device. To simplify things all of these instructions are to be executed on the device itself. If you want to do this in a chroot, then knock yourself out, but you are on your own. My setup At the time of writing, these instructions are confirmed working for the 7 Segment display and all icons on: Tannix T3-Mini S905w with 2GB RAM Armbian 25.11 Kernel 6.12.48-current-meson64 Debian stable (trixie) (13) Instructions Note: Every code block here is meant to be pasted and executed in one go, even the multi-line blocks We will work from the home folder to keep things simple. Don't worry, there will be no clutter as we will remove files we no longer require as we go cd ~ Device Tree Blob The first thing we are going to want to do is enable kernel support for openvfd in our DTB. Normally I'd do this with an overlay, but this does not appear to be enabled on the aml-s9xx-box image, so we will apply an overlay to the DTB directly: Install the device tree compiler: sudo apt install -y device-tree-compiler --no-install-recommends Back up the existing DTB (if anything goes wrong you can always just restore the backed up DTB) : Note: If your device is not a Tanix T3-Mini, then you will want to amend the following to point to the actual DTB you are using (you can find this in '/boot/extlinux/extlinux.conf') sudo cp /boot/dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb /boot/dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb.orig Create the overlay source code: cat << EOF > ~/openvfd.dts /dts-v1/; /plugin/; / { fragment@0 { target-path = "/"; __overlay__ { openvfd { compatible = "open,vfd"; dev_name = "openvfd"; status = "okay"; }; }; }; }; EOF Compile the overlay: dtc -@ -I dts -O dtb -o ~/openvfd.dtbo ~/openvfd.dts Merge the overlay into your DTB: Note: If your device is not a Tanix T3-Mini, then you will want to amend the following to point to the actual DTB you are using sudo fdtoverlay -i /boot/dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb -o /boot/dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb ~/openvfd.dtbo Delete the overlay source: rm ~/openvfd.dts [Optional] Delete the compiled overlay: If your build is static (that is, you will never pull an updated DTB through apt) then you can also delete the compiled .dtbo overlay file. I prefer to keep this around, as you can just re-patch the new DTB with the "sudo fdtoverlay ..." command above. It is also possible to automate the update of a newly installed DTB file by creating a postinst.d script, but that is outside of the scope of this document. Google is your friend. rm ~/openvfd.dtbo Reboot so when we load the module later, our device knows what to do with it sudo reboot now Once your device has been rebooted, you can confirm that your change has been applied correctly with the following command: dtc -I fs -O dts /proc/device-tree | grep -A3 openvfd Again, this will generate a lot of warnings! This is normal. At the end of the warnings you should see the openvfd entry that you added to your DTS in the earlier step. If you do not, then you have not edited the file correctly, and you should go back and try again. OpenVFD Config file We need to create a configuration file which tells the OpenVFD module which GPIO pins are connected to the LCD display. We put this in the /etc folder as this is where we should be storing system configuration files for *deb based systems The contents of this file were extracted from https://github.com/arthur-liberman/vfd-configurations so if you are using a different device, you must replace the following config with the relevant one from the link. If you are having issues with your config not working, direct them to the repo owner, not me. I do not know your device or what may be wrong. Note: I remove the final functions='usb colon eth wifi' line as whilst the driver works fine with it included, it generates errors/warnings, which I would rather not see, and it appears to serve no purpose for Armbian Execute the following to generate the config for the TX3-Mini Note: If your device is not a Tanix T3-Mini do not execute the following. Instead, find your config at https://github.com/arthur-liberman/vfd-configurations and save it as /etc/openvfd.conf sudo bash -c "cat << 'EOF' > /etc/openvfd.conf vfd_gpio_clk='0,76,0' vfd_gpio_dat='0,75,0' vfd_gpio_stb='1,4,0' vfd_chars='4,3,2,1,0' vfd_dot_bits='0,1,3,2,4,5,6' vfd_display_type='0x01,0x00,0x00,0x00' EOF" Build the Kernel Module Now for the nitty gritty, we need to build the kernel module. The first thing we need is the kernel headers. Note: the headers version must match your installed kernel version exactly. Do not try installing the headers for a different kernel version. You will run into issues If you are on a standard image, or your kernel has been upgraded since you built your image, this is straightforward: sudo apt install linux-headers-$(uname -r) However, if you have built the image yourself, and you have not upgraded your kernel, then most likely the version available from the apt repository will not be compatible and your build may fail or the driver may not work at all. In these instances, you will need to go back to your build system and add the following switch to your ./compile.sh command: INSTALL_HEADERS=yes Install the required build tools sudo apt install -y git build-essential --no-install-recommends Clone the openvfd repo. At the time of writing the openvfd repo is not compatible with later Linux kernels. I have raised a PR against the repo to enable support, however it has not yet been accepted. If/when it is accepted I will be deleting my fork of the repo, but in the meantime, you can clone my fork with: git clone https://github.com/torzdf/linux_openvfd.git ~/linux_openvfd If the above does not work, it is because I have deleted my fork as the changes have been merged, and I am unable to come back and edit this post. If this is the case then run the following: Note: DO NOT run the next line, if the above git clone worked git clone https://github.com/arthur-liberman/linux_openvfd.git ~/linux_openvfd Enter the driver folder of the cloned repo cd ~/linux_openvfd/driver Create a Makefile. The provided Makefile will not work, so we need to replace it with our own: cat << 'EOF' > ./Makefile ifeq ($(KERNELRELEASE),) PWD = $(shell pwd) KERNELDIR = /lib/modules/`uname -r`/build modules: $(MAKE) -C $(KERNELDIR) M=$(PWD) modules modules_install: $(MAKE) -C $(KERNELDIR) M=$(PWD) modules_install clean: rm -rf *.o *.ko .tmp_versions *.mod.c modules.order Module.symvers ssd253x-ts.* else obj-m := openvfd.o openvfd-objs += protocols/i2c_sw.o openvfd-objs += protocols/i2c_hw.o openvfd-objs += protocols/spi_sw.o openvfd-objs += controllers/dummy.o openvfd-objs += controllers/seg7_ctrl.o openvfd-objs += controllers/fd628.o openvfd-objs += controllers/fd650.o openvfd-objs += controllers/hd44780.o openvfd-objs += controllers/gfx_mono_ctrl.o openvfd-objs += controllers/ssd1306.o openvfd-objs += controllers/pcd8544.o openvfd-objs += controllers/il3829.o openvfd-objs += openvfd_drv.o endif EOF Compile the kernel module: make -j$(nproc) Install the kernel module: sudo make modules_install Update the kernel modules: sudo depmod -a Create the helper service Next we need to compile and install the helper service Enter the folder that contains the source code for the helper service: cd ~/linux_openvfd Build the helper service: make OpenVFDService Make the helper service executable: chmod +x OpenVFDService Install the helper service: sudo cp OpenVFDService /usr/bin/ Clean up We have built everything we need from the OpenVFD repo, so we can get rid of the source code Go back to our home folder and delete the source code cd ~ && sudo rm -r linux_openvfd systemd Service file The final step. We need to create a service file that will load the kernel module, and launch the helper service, and enable it on boot Create the systemd service file: note: If you prefer a 12 hour clock rather than a 24 hour clock, edit the 'Environment="OPTS=-24h"' line to 'Environment="OPTS=-12h"' sudo bash -c 'cat << '\''EOF'\'' > /etc/systemd/system/openvfd.service [Unit] Description=openvfd Wants=network-online.target [Service] Type=simple Environment="OPTS=-24h" ExecStartPre=/usr/bin/sh -c ". /etc/openvfd.conf; /usr/sbin/modprobe openvfd vfd_gpio_clk=$vfd_gpio_clk vfd_gpio_dat=$vfd_gpio_dat vfd_gpio_stb=$vfd_gpio_stb vfd_chars=$vfd_chars vfd_dot_bits=$vfd_dot_bits vfd_display_type=$vfd_display_type;" ExecStart=/usr/bin/OpenVFDService $OPTS & ExecStop=/usr/bin/killall OpenVFDService ExecStopPost=-/usr/sbin/rmmod openvfd [Install] WantedBy=multi-user.target EOF' Reload the systemd daemon: sudo systemctl daemon-reload Start the openvfd service: sudo systemctl start openvfd.service At this point your LCD should now be showing the time. If it is not, you can check for errors with: sudo systemctl status openvfd.service Enable the service at boot: sudo systemctl enable openvfd.service And that's it. If all has gone well, you now have a working LCD Display for your TV Box running a recent Armbian build
I face the same problem, Armbian only reports 4GB on my VisionFive2 board with 8GB of RAM. I also noticed that the system is very unstable and constantly hanging after some minutes of usage, especially when I install Debian packages with Apt. I haven't tested the official Debian image yet. I hope it fixes both the reported RAM and that instability. Here is the page for the official VisionFive2 Debian: https://rvspace.org/en/project/VisionFive2_Debian_Wiki_202409_Release Links can be found there: https://debian.starfivetech.com/
My brief experience in trying out a USB-C display wasn't great. I was never able to get any video at all until / unless I was fully booted into an OS, and even then it was shotty. Both USB-C connectors on the Orange PI 5 Plus (on mine anyway) are poorly made and intermittently lose connection if moved around at all. I recently read that's a real problem with SBCs in general that get their power over USB-C... clearly a very poor design. I also read somewhere that a similar board required proprietary drivers for USB-C display output to function. My experience indicates at least something like that likely applies here as well. Dysfunctional hardware design.
SteeMan replied to pochopsp's topic in Amlogic CPU Boxes
The issue is that your u-boot can't read the emmc. The linux kernel can since when it was run from your sd card you can access the emmc. But after you have copied the install to emmc and then boot, the uboot is reporting it can't read the emmc. There are instruction in /boot/build-u-boot for building the various uboots. I would suggest you try building with a newer version of uboot. What is currently shipped (the u-boot-s905x-s912 was built from uboot 2020-07 sources) so trying with newer uboot 2025-xx might provide better support for your specific emmc. -
Hello everyone, I own this android box and I followed this tutorial https://ragone.dev/post/install-linux-on-android-tv-box which is based on tutorials on armbian website, I tried to install Armbian 25.8 server with Debian. Everything went fine until the step "5. Flash Armbian to the internal eMMC", despite me running the install-aml.sh script and getting a complete message in the end (see following images for script execution output), when I reboot it just always starts from the sd (see the following screenshot showing that the mounted storage is 16 GB, but my box internal storage is 8 GB). fdisk -l output to also show the internal mmc (in the screen /dev/mmcblk1) If I remove the sd and then turn it on, it is just stuck in a loop, having the following errors: Can you please help me in solving this problem? I already tried looking on the web and found these two topics: https://github.com/ophub/amlogic-s9xxx-armbian/issues/3032 But they didn't help me. Kind regards
Getting error installing Octoprint via armbian-config on Orange Pi Zero
seamoce replied to seamoce's topic in Allwinner sunxi
@Werner https://paste.armbian.com/izobaqaguk here the link So do you think docker cannot run well on this device?
