  2. moved
  4. I will try but I have this line working on exactly the same box with a older build that was upgraded
  5. If you remove the "rk3588-" from each it should work as that is included in the overlay_prefix
  6. Thanks - I'm worried my main issue was with the overlay loading issue I mentioned. I did try 6.15 but prob need to retry with the hack with overlay-user. But man... it is SO incredibly simple to switch the kernels.
  7. @KrzyPac I suspect you just need the DTB correct? Git clone the armbian/build, place the patch in patch/kernel/archive/meson64-6.12/ and build any meson64 board. ./compile.sh KERNEL_GIT=shallow BRANCH=current EXPERT=yes KERNEL_BTF=no kernel BOARD=bananapicm4io The DTS files are one of the first things to be compiled, so once you see them finish, hit CTRL+C to cancel the build and then grab the DTB file from the source dir: cache/sources/linux-kernel-worktree/6.12__meson64__arm64/arch/arm64/boot/dts/amlogic/ That is the easiest way I can think of doing what you want to achieve. Here is an updated PATCH and pr-ecompiled DTB. NOTE: There are different variants of the X96-AIR. I have two. One that uses Qualcomm for wireless and another that is Realtek. Each variant requires a different DTS for it to function properly. This patch is for the Realtek variant. x96-air-gbit-spdif-jack-i2c1-openvfd-jl2xx1-bt-support.patch meson-sm1-x96-air-gbit.dtb
  8. See for more details but without using the overlay-user folder - I was not able to get the pwm to work on a fresh download.
  9. OMG - I can confirm this issue is also happening on orange pi 5 with latest armbian v25.5.1 + Linux 6.1.*-vendor-rk35xx This is my armbianEnv.txt The pwm only loads when I copy it into overlay-user. The really strange thing is that I have two of these boxes and the one that went through upgrades is working just fine but I'm trying a fresh install on another and no way to get the overlay to work except this hack
  10. I have the file .../dts/amlogic/meson-sm1-x96-air-gbit.dts and the patch 004-arch-arm64-dts-amlogic-meson-sm1-ac2xx-tv-boxes.patch. How to patch a dts file and generate a dtb file from it. I am asking for help.
  11. https://paste.armbian.com/cawuyeyice
  12. Selling a fully working Helios64 NAS from Kobol. It has been running continuously since purchase without any issues. Includes 4x Western Digital Red 4TB HDDs (16TB total), all in good health and used only in this setup. All original parts are included: case, power supply, cables, and accessories. Note: the 1GbE Ethernet fix has not been applied. Selling because I recently upgraded to a new NAS. Located in the Netherlands. Pickup possible or shipping within the EU. Contact me for pricing or questions.
  13. Thanks. Etcher worked. Now my device can boot successfully. I will use Etcher instead of USBImager for armbian in future.
  14. 6.12.y current is far from being feature-complete and won't get any new ones but bug fixes only. Try 6.1.y vendor or 6.15 edge.
  15. Been trying to enable multiple overlays on kernel 6.12 (orange pi 5) but I am not able to get any pwm device in /sys/class/pwm/ The i2c also seems to be missing. Is going back to 6.1 the safest option? Thanks
  16. Armbian 24.5 works normally, but this issue occurs in versions 24.8, 25.5 and 25.8 [ 0.872698] dwhdmi-rockchip ff940000.hdmi: supply avdd-0v9 not found, using dummy regulator [ 0.872852] dwhdmi-rockchip ff940000.hdmi: supply avdd-1v8 not found, using dummy regulator [ 2.361552] dwhdmi-rockchip ff940000.hdmi: supply avdd-0v9 not found, using dummy regulator [ 2.361723] dwhdmi-rockchip ff940000.hdmi: supply avdd-1v8 not found, using dummy regulator [ 2.361912] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.363007] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffff80008120fe60) [ 22.444508] hdmi-audio-codec hdmi-audio-codec.8.auto: Only one simultaneous stream supported! [ 22.444524] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 0.871390] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffff80008120b5e8) [ 0.872604] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffff80008120b5e8) [ 2.360057] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffff80008120b5e8) [ 2.361397] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffff80008120b5e8) [ 2.363007] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffff80008120fe60) [ 2.364674] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [ 2.510919] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
  17. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  18. I just did some new experiments, trying to get touch working in ili9488 LCD v2.1 Increasing or decreasing the SPI MHz in both the LCD and touch section of the DTS DONT WORK... I couldn't get touch working Next is to use a software defined SPI with spi-gpio (based on my experience in my ili9341 thread)
  19. Hello all, I am trying to host the rtsp server using gstreamer on armbian. everything is latest and updated. I found, bare rtsp server is taking 3-4% of cpu usage. when I add timestamp and text overlay, cpu goes 23-25%. I was checking if I can enable GPU support, here is output. My system is on NVME, and its working so not sure why error popped. I am connected to wifi, so again not sure why wifi drivers are having issues. however my board never shows it has gpu. can some one guide me ? I have 2 mp camera, not a huge load. again memory is 8GB but never used beyond 1GB, but CPU is most of the time on above 70% dmesg | grep -i error [ 10.423927] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found [ 10.423965] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found [ 11.550508] dw-pcie: probe of 3c0000000.pcie failed with error -22 [ 11.611235] rockchip-vop2 fe040000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found [ 11.613533] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found [ 11.616990] rockchip-drm display-subsystem: [drm] run display error_event monitor [ 12.251529] mali fde60000.gpu: error -ENXIO: IRQ JOB not found [ 12.251654] mali fde60000.gpu: error -ENXIO: IRQ MMU not found [ 12.251725] mali fde60000.gpu: error -ENXIO: IRQ GPU not found [ 12.251821] mali fde60000.gpu: Register map failed error = -5 [ 12.251912] mali: probe of fde60000.gpu failed with error -5 [ 12.257912] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found [ 19.231558] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.rockchip,rk3566-orangepi-3b.bin failed with error -2 Regards-
  20. Yesterday
  21. And could you tell me how to add a patch to my .dtb or .dts file. I installed linux-headers but I don't know what to do next with the patch posted above by c0rnelius.
  22. I was having some trouble with newer ili9488 LCD v2.1, and I didn't have ili9488 LCD v1.1, so I decided to experiment again with ili9341 LCD v1.2. I found that this DTS https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-204672 Doesn't work with the touch chip. By accident, I ran the ili9488 driver on this ili9341, and I saw garbled graphics... but the good news: touch was working. Something in the ili9488 DTS which doesn't work for the ili9488 LCD, works for ili9341. I found the difference was not in the ads7846 section, but in the spi speed for the ili9xxx part. I switched back to the ili9341 DTS (with adafruit driver), but changed the SPI speed from 24MHZ to 40MHz.... then the ili9341 DTS was working with graphics and touch again ALTHOUGH the graphics have some flashing pseudo-colors in some places. Maybe the 40MHZ is too much, but I re-gained touch in ili9341 LCD v1.1. I will keep doing experiments. Playing with the SPI Mhz didn't help with the ili9488
  23. Images were tested. Do you perhaps use Etcher for flashing? And try minimal image. That might even work with Etcher.
  24. So I was able to reproduce the issue when trying to boot via NVMe after using armbian-config to switch from emmc. Using rkdeveloptool to flash the SPI with https://dl.radxa.com/rock5/sw/images/loader/rock-5b+/release/rock-5b+-spi-image-8ea7ee4-20240730.img (short guide in the spoiler) I was able to boot into the NVMe. Looking into fixing the broken SPI installation
  25. Hello, I try to use armbian image on SD card for my nanopi r6c, it is without emmc, can only boot with SD card. However, armbian can't boot correctly. It stop at pre-mount while booting up, please refer to attached screenshot. I tried the images that can download from armbian web site and build armbians image with my PC, none of them can work, all are same issue, but Dietpi image for r6c can boot successfully. Images tried, but not work: #download from armbian site Armbian_25.5.1_Nanopi-r6s_noble_vendor_6.1.115_gnome_desktop.img Armbian_25.5.1_Nanopi-r6s_bookworm_current_6.12.30_cinnamon-backported-mesa_desktop.img Armbian_25.5.1_Nanopi-r6s_noble_current_6.12.30_gnome_desktop.img Armbian_25.5.1_Nanopi-r6s_noble_current_6.12.30_kde-neon_desktop.img #build by compile.sh Armbian-unofficial_25.08.0-trunk_Nanopi-r6c_noble_current_6.12.33_gnome_desktop.img Armbian-unofficial_25.08.0-trunk_Nanopi-r6c_noble_edge_6.15.2_gnome_desktop.img Armbian-unofficial_25.08.0-trunk_Nanopi-r6c_bookworm_edge_6.15.2_cinnamon-backported-mesa_desktop.img Image can work: DietPi_NanoPiR6C-ARMv8-Bookworm.img Please help on this issue. Thanks.
  26. Check here https://github.com/armbian/community/releases/tag/25.5.0-trunk.256 or on a mirror with archive https://docs.armbian.com/Mirrors/#current-mirrors for what you are looking for. We're aware that some links are broken for yet to be determined reason.
