  2. I have verified that Wi-Fi is working, and I have also figured out how to install to eMMC. However, after running armbian-install, the system only boots if I put MiniLoaderAll.bin into the firmware field of the “Upgrade Firmware” session in Rockchip-AndroidTool while the device is in Maskrom mode, and then press the Upgrade button. MiniLoaderAll.bin It appears to be an SPI-related issue, but at the moment I don’t see any way to resolve it. I am also having difficulty getting Bluetooth to work. If you have any information on this, your assistance would be appreciated.
  3. I see. Ok so Armbian sees only one IRL i2c buss, and stuffs any 'inconvenient' other devices into a useless buss. IOW Armbian is busted, at least for the ODroid N2+. Why use it then?
  4. Probably more experienced users will not have similar issues, but I'll provide my solution just for for the record: Power off devide. Insert SD card into the slot. Hold 'boot' button on the mainboard. Plug in device. Release 'boot' after 5 seconds. Power off and power on. in my case it took up to 60 seconds before my device boot from SD card. I checked the same with USB and it also work (*it ust be plugged into one of USB2.0 ports). Thank you for your suggestion. I'll close the thread.
  5. Yesterday
  6. Some updates... After rebooting (power off and power on) the device.... this appears and Armbian won't boot anymore...
  7. Someone was able to run Armbian on the Arduino Uno Q. So, maybe Armbian will support the board in some future, hopefully. But due to no available test image or further information beside this tweet, I don't expect that currently, at least in a near future.
  8. So I made a second test with your image. I changed to a 32GB SD card because the other one's capacity was an old 4gb one and run out of space when installing some stuff. I run your image as is in my device. I don't change the DTB to the extracted one from Android partition, because if I do so, I get black screen. I managed to install kodi and xfce4 desktop (xinit and lightdm are required to make it work, as I understand) sudo apt update && sudo apt upgrade sudo apt install xfce4 xinit lightdm I realized I could run Kodi without xfce desktop... just typiing "kodi" command. Before doing so I plugged my pendrive in the USB3.0 port and checked it was mounted. I did some file exploration with ls commands, mount, lsblk etc... but at the end when opened Kodi it was detected as "New_volume" which is the drive's name. For my surprise: When moving through Kodi's menu, the "tic" sound came out from my TV. So: HDMI sound was working Added the movie's folder to the Kodi library and it searched all the stuff that Kodi does (movie posters, tittle, information, etc.) Hit play on one of them and movie played fluid ! movie spec: 1080p and H264 codec I looked for another movie encoded with H265 (HEVC) file... and it played but with some "stuttering". I don't know the cause, if USB is not working at 3.0 speed, or GPU is running slower than expected (or other reason) --> The same file in the same pendrive in the same port, when running the device's Android and Kodi, plays perfectly smooth. Also: In ANdroid Kodi es v21 and the one in Armbian is v20.5 ; maybe some HW acceleration issue there? In conclusion, at the moment, with the original @johlnx image (v0.3, the latest at the moment of testing), for this board (pics in first post of this thread) I have: USB2.0 port: Working: used for wireless keyboard+mouse receiver USB3.0 port: Working, used for a 64G Pendrive (I don't know if it was recognized as USB 3.0 or 2.0, I don't know hoy to check that, yet) HDMI-Video: Working HDMI-Audio: Working (played few movies with 2ch audio content) HDMI-CEC: Not tested, don't know how to do it, yet. SD card reader: Working, as device boots from SD card. LAN: Working WiFi: Not fully tested, (I could only "See" networks , but did'nt connect to them as I was using the device wired.) So it is supposed to be working. Will fully test it in another moment. IR and LCD: Not tested, I don't know where to start with those (will appreciate some help) Analog A/V output: Not tested yet. I can do more tests if some of you consider it, just ask me. The more specific information (and how-to's...) the better. Thanks
  9. I have a Radxa Zero 3E and was facing the same issue. Since RK3566 is a stripped down version of RK3588. I figured the quirks on RK3588 might be able to apply to RK3566 as well. The issue seems to be fixed now after I implemented these quirks taken from rk3588-base.dtsi on top of rk356x-base.dtsi. tested on Linux 6.17.9 and 6.18.0-rc7(Armbian linux-edge-rockchip64) usb_host1_xhci: usb@fd000000 { compatible = "rockchip,rk3568-dwc3", "snps,dwc3"; reg = <0x0 0xfd000000 0x0 0x400000>; interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru CLK_USB3OTG1_REF>, <&cru CLK_USB3OTG1_SUSPEND>, <&cru ACLK_USB3OTG1>; clock-names = "ref_clk", "suspend_clk", "bus_clk"; dr_mode = "host"; phys = <&usb2phy0_host>, <&combphy1 PHY_TYPE_USB3>; phy-names = "usb2-phy", "usb3-phy"; phy_type = "utmi_wide"; power-domains = <&power RK3568_PD_PIPE>; resets = <&cru SRST_USB3OTG1>; snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + snps,dis-u2-freeclk-exists-quirk; + snps,dis-del-phy-power-chg-quirk; + snps,dis-tx-ipgap-linecheck-quirk; status = "disabled"; }; If anyone else has other RK356x devices please try it out and I think it would be nice if someone could submit a patch to mainline kernel dts.
  10. @Gavin Munday Did you compile a desktop or server image? Did you write the image onto a reliable sdcard? Remember there’s no framebuffer support. Server images need a usb to serial device attached to the UART. Having a usb serial device attached to the UART helps with these types of problems. https://docs.radxa.com/en/cubie/a7a/system-config/uart_debug Also, first boot might take awhile to boot. For desktop images wait at least 5 minutes for a display manager login screen.
  11. sadly my a7a doesnt doesnt boot with the image that outputs from the build
  12. I don't understand then, what is the problem?
  13. You don’t actually need a static route on PC1. Since PC1 already has a default gateway (192.168.100.254), anything outside 192.168.100.0/24 is automatically sent there. So PC1 isn’t the source of the routing problem. The real issue is on the 10.10.10.x side: Device1 has no gateway. Without a gateway, it can receive packets coming from the Linux box, but it has no way to send replies back to a different subnet. That’s why the communication fails. The fix is simply to give Device1 a valid gateway pointing to the Linux box. Device1: IP: 10.10.10.2 Mask: 255.255.255.0 Gateway: 10.10.10.1 On the Linux box: sudo sysctl -w net.ipv4.ip_forward=1 This is enough to route between NIC1 and NIC2. If Device1 cannot be configured manually, the Linux box can offer a small DHCP service on NIC2. A minimal dnsmasq example: interface=enp4s0 dhcp-range=10.10.10.50,10.10.10.150,255.255.255.0,12h dhcp-option=3,10.10.10.1 This simply ensures Device1 learns “send everything through 10.10.10.1”. Once Device1 has a gateway, the Linux box will forward traffic correctly and PC1 will reach it without needing any static route at all. Useful resources: https://wiki.archlinux.org/title/Router https://askubuntu.com/questions/205017/how-to-define-the-range-of-ips-using-dhcp https://pingmynetwork.com/network/ccna-200-301/dhcp-dynamic-host-configuration-protocol
  14. I don't think so, then my Virtual Machine run would fail the same way as you describe, but it doesn't, it works fine. Of course it is the meson64 kernel running on top of KVM/virt machine, the RTC for example is emulated, while for your real N2+ is a specific Amlogic SoC kernel driver I assume, so there something could be wrong. Or what about clocking tree, there are many failures possible. I know for rockchip64 there were 2 RTC modules, at some point in time 1 was chosen over the other, so a change, could also introduce issues. You could browse kernel changes/patches And also what about an unknown bad/corrupted diskblock or so. I normally use Btrfs for rootfs, so easy to check for and detect corruption. So maybe re-image again. I am still not sure if I used the same image as you, but up to you to track that. You can do the same thing as I did to see if it is maybe a specific Amlogic driver issue; Run that image as VM on the same N2+, you need a network bridge with main eth port or else use NAT. Or you make it first efi bootable, then it can run easier in virt-manager GUI. N2+ is fast enough to run VMs, I even do that on ROCK3A (2GB RAM, 4x Cortex-A55). Or use standard Debian Trixie kernel on real N2+, not sure if that works good enough. Or remove/disable RTC kernel module. Or also remove fake-hwclock stuff if you haven't already done that. I did not do it for this VM run, but when real RTC+battery, I would remove or disable it.
  15. @Gavin Mundayhttps://github.com/NickAlilovic/build/blob/Radxa-A7A/config/boards/radxa-cubie-a7z.csc
  16. found it wasnt using correct tree..;p
  17. i have, board not there unless it using some other name?
  18. Try to select CSC/EOS/TVB or use EXPERT=yes
  19. esalarm: personally, I tear out systemd-resolved and netplan, and just use /etc/resolv.conf. (and chattr +i) In my LAN the gateway is designated DNS resolver running Unbound, so my situation is more normal. But that's not the reason systemd-timesyncd and chrony are not working. Neither one can set the time properly, even as properly configured. Using tcpdump I see the 123/udp request going out to the proper machine, and the response coming back... but it has no effect on Armbian. No firewall blocks. Time stays on whatever I set it to, and counts from there, always a few minutes behind or ahead. There is something fundamentally wrong with current Armbian.
  20. when i do ./compile.sh i cant see the board in the list???
  21. Something wrong with xorg or x11 session on cinnamon desktop for my boxes, i can get into desktop when i choose experimental wayland session but that is not a good way to start. So, i switch to Mate and i like it
  22. Cinnamon desktop environment is bugged for me, both my a95x r2 (amlogic s905w) and a95x f3 slim (amlogic s905x3) showing no display, blank screen like no input after loging in. My suggestion for desktop ubuntu based varian, better change it to Mate desktop. The armbian desktop cinnamon varian based on ubuntu is now work for me after switching to mate desktop
  23. can this SoC boot from a USB drive? i've tried it multiple times and it didnt work.
  24. Orange Pi 5 pro,whith Armbian_community_26.2.0-trunk.7_Orangepi5pro_noble_vendor_6.1.115_gnome_desktop 。 when I try to start Eclipse/idea/vscode or other JavaApp , java processes crash and gets core dump every time, tested on Jdk 17,21 25 ,both openjdk and oracleJDK。 It seems there is a compatibility issue between the kernel and the JDK. How can I fix it? Or I have to wait kenel update? some error like Current thread (0x0000ffffa802b9b0): JavaThread "main" [_thread_in_vm, id=6202, stack(0x0000ffffaeb62000,0x0000ffffaed60000) (2040K)] Stack: [0x0000ffffaeb62000,0x0000ffffaed60000], sp=0x0000ffffaed5ce40, free space=2027k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) V [libjvm.so+0xddc444] Symbol::as_C_string() const+0x14 V [libjvm.so+0xbef608] Method::print_external_name(outputStream*, Klass*, Symbol*, Symbol*)+0x40 V [libjvm.so+0xb07e7c] LinkResolver::resolve_method(LinkInfo const&, Bytecodes::Code, JavaThread*)+0x154 V [libjvm.so+0xb0a85c] LinkResolver::linktime_resolve_virtual_method(LinkInfo const&, JavaThread*)+0x3c V [libjvm.so+0xb0b204] LinkResolver::resolve_virtual_call(CallInfo&, Handle, Klass*, LinkInfo const&, bool, JavaThread*)+0x3c V [libjvm.so+0xb0b3a0] LinkResolver::resolve_invokevirtual(CallInfo&, Handle, constantPoolHandle const&, int, JavaThread*)+0xd4 V [libjvm.so+0x887cd4] InterpreterRuntime::resolve_invoke(JavaThread*, Bytecodes::Code)+0x250 V [libjvm.so+0x887f80] InterpreterRuntime::resolve_from_cache(JavaThread*, Bytecodes::Code)+0x3c j java.util.AbstractSet.removeAll(Ljava/util/Collection;)Z+8 java.base@25.0.1 j org.eclipse.osgi.container.ModuleResolver$ResolveProcess.resolveRevisions(Ljava/util/List;ZLorg/eclipse/osgi/container/ModuleResolver$ResolveProcess$ResolveLogger;Ljava/util/Map;)V+424 j org.eclipse.osgi.container.ModuleResolver$ResolveProcess.resolveRevisionsInBatch(Ljava/util/Collection;ZLorg/eclipse/osgi/container/ModuleResolver$ResolveProcess$ResolveLogger;Ljava/util/Map;)V+253 j org.eclipse.osgi.container.ModuleResolver$ResolveProcess.resolve()Lorg/eclipse/osgi/container/ModuleResolutionReport;+307 j org.eclipse.osgi.container.ModuleResolver.resolveDelta(Ljava/util/Collection;ZLjava/util/Collection;Ljava/util/Map;Lorg/eclipse/osgi/container/ModuleDatabase;)Lorg/eclipse/osgi/container/ModuleResolutionReport;+19 j org.eclipse.osgi.container.ModuleContainer.resolveAndApply(Ljava/util/Collection;ZZLorg/eclipse/osgi/container/ModuleContainer$ResolutionLock$Permits;)Lorg/eclipse/osgi/report/resolution/ResolutionReport;+256 j org.eclipse.osgi.container.ModuleContainer.resolve(Ljava/util/Collection;ZZ)Lorg/eclipse/osgi/report/resolution/ResolutionReport;+63 j org.eclipse.osgi.container.ModuleContainer.refresh(Ljava/util/Collection;)Lorg/eclipse/osgi/report/resolution/ResolutionReport;+34 j org.eclipse.osgi.storage.Storage.checkSystemBundle([Ljava/lang/String;)V+242 j org.eclipse.osgi.storage.Storage.createStorage(Lorg/eclipse/osgi/internal/framework/EquinoxContainer;)Lorg/eclipse/osgi/storage/Storage;+17 j org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(Ljava/util/Map;Lorg/osgi/framework/connect/ModuleConnector;)V+146 j org.eclipse.osgi.launch.Equinox.<init>(Ljava/util/Map;Lorg/osgi/framework/connect/ModuleConnector;)V+10 j org.eclipse.osgi.launch.Equinox.<init>(Ljava/util/Map;)V+3
  25. Good day, @jock the link of the Multitool is not valid anymore. Please help where I can download from? Thank you for your efford.
  26. I also tried the latest image (https://github.com/armbian/community/releases/download/26.2.0-trunk.22/Armbian_community_26.2.0-trunk.22_Rock-3c_trixie_current_6.12.59_minimal.img.xz) and it works fine (with mainline u-boot). I think I may have experienced problems using radxa's software to erase the spi flash memory, but writing an image fine would always work. So you may be better off writing Radxa's u-boot image to the spi flash memory, as per their instructions (and to get rid of the Android image). You can subsequently manage the spi flash memory either directly from u-boot (by interrupting start-up) or from the linux terminal. See comments by @amazingfate in this post for instruction on how to write Armbian u-boot image to mtdblock0 from a linux terminal.
