  2. This device is not yet fully compatible with the mainline Linux kernel. Realtek USB 2.5GbE adapters, in particular, are known to have issues when used over USB 3 on these devices. The vendor-provided kernel reportedly offers better tuning for these adapters, though it is still not entirely flawless.
  3. Making progress, but it seems there a number of problems to work through... Here's my current state, comments/suggestions welcome It does seem to eventually be happy(ish) with the BAR setup wth minor DTB changei, but it doesn't seem to even try to load the firmware.... :- [ 950.592779] amdgpu 0000:01:00.0: amdgpu: initializing kernel modesetting (POLARIS12 0x1002:0x699F 0x1458:0x22F2 0xC7). [ 950.592800] amdgpu 0000:01:00.0: amdgpu: register mmio base: 0xF0200000 [ 950.592802] amdgpu 0000:01:00.0: amdgpu: register mmio size: 262144 [ 950.592956] amdgpu 0000:01:00.0: amdgpu: detected ip block number 0 <common_v1_0_0> (vi_common) [ 950.592960] amdgpu 0000:01:00.0: amdgpu: detected ip block number 1 <gmc_v8_1_0> (gmc_v8_0) [ 950.592962] amdgpu 0000:01:00.0: amdgpu: detected ip block number 2 <ih_v3_0_0> (tonga_ih) [ 950.592965] amdgpu 0000:01:00.0: amdgpu: detected ip block number 3 <gfx_v8_0_0> (gfx_v8_0) [ 950.592967] amdgpu 0000:01:00.0: amdgpu: detected ip block number 4 <sdma_v3_1_0> (sdma_v3_0) [ 950.592970] amdgpu 0000:01:00.0: amdgpu: detected ip block number 5 <smu_v1_0_0> (powerplay) [ 950.592972] amdgpu 0000:01:00.0: amdgpu: detected ip block number 6 <dce_v1_0_0> (dm) [ 950.592975] amdgpu 0000:01:00.0: amdgpu: detected ip block number 7 <uvd_v6_3_0> (uvd_v6_0) [ 950.592977] amdgpu 0000:01:00.0: amdgpu: detected ip block number 8 <vce_v3_4_0> (vce_v3_0) [ 950.920388] amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR [ 950.920394] amdgpu: ATOM BIOS: xxx-xxx-xxx [ 950.920492] [drm] UVD is enabled in VM mode [ 950.920494] [drm] UVD ENC is enabled in VM mode [ 950.920497] [drm] VCE enabled in VM mode [ 950.920500] amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported [ 950.920504] amdgpu 0000:01:00.0: amdgpu: PCIE atomic ops is not supported [ 950.920510] amdgpu 0000:01:00.0: amdgpu: PCI CONFIG reset [ 950.920627] amdgpu 0000:01:00.0: amdgpu: GPU posting now... [ 951.046148] amdgpu 0000:01:00.0: amdgpu: vm size is 128 GB, 2 levels, block size is 10-bit, fragment size is 9-bit [ 951.046277] amdgpu 0000:01:00.0: BAR 2 [mem 0x910000000-0x9101fffff 64bit pref]: releasing [ 951.046282] amdgpu 0000:01:00.0: BAR 0 [mem 0x900000000-0x90fffffff 64bit pref]: releasing [ 951.046315] pcieport 0000:00:00.0: bridge window [mem 0x900000000-0x9101fffff 64bit pref]: releasing [ 951.046323] pcieport 0000:00:00.0: bridge window [mem size 0x80200000 64bit pref]: can't assign; no space [ 951.046325] pcieport 0000:00:00.0: bridge window [mem size 0x80200000 64bit pref]: failed to assign [ 951.046330] pcieport 0000:00:00.0: bridge window [mem size 0x80200000 64bit pref]: can't assign; no space [ 951.046332] pcieport 0000:00:00.0: bridge window [mem size 0x80200000 64bit pref]: failed to assign [ 951.046335] amdgpu 0000:01:00.0: BAR 0 [mem size 0x80000000 64bit pref]: can't assign; no space [ 951.046337] amdgpu 0000:01:00.0: BAR 0 [mem size 0x80000000 64bit pref]: failed to assign [ 951.046339] amdgpu 0000:01:00.0: BAR 2 [mem size 0x00200000 64bit pref]: can't assign; no space [ 951.046341] amdgpu 0000:01:00.0: BAR 2 [mem size 0x00200000 64bit pref]: failed to assign [ 951.046344] amdgpu 0000:01:00.0: BAR 0 [mem size 0x80000000 64bit pref]: can't assign; no space [ 951.046345] amdgpu 0000:01:00.0: BAR 0 [mem size 0x80000000 64bit pref]: failed to assign [ 951.046347] amdgpu 0000:01:00.0: BAR 2 [mem size 0x00200000 64bit pref]: can't assign; no space [ 951.046349] amdgpu 0000:01:00.0: BAR 2 [mem size 0x00200000 64bit pref]: failed to assign [ 951.046352] pcieport 0000:00:00.0: PCI bridge to [bus 01-ff] [ 951.046354] pcieport 0000:00:00.0: bridge window [io 0x300000-0x300fff] [ 951.046357] pcieport 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff] [ 951.046360] pcieport 0000:00:00.0: PCI bridge to [bus 01-ff] [ 951.046362] pcieport 0000:00:00.0: bridge window [io 0x300000-0x300fff] [ 951.046364] pcieport 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff] [ 951.046367] pcieport 0000:00:00.0: bridge window [mem 0x900000000-0x9101fffff 64bit pref] [ 951.046380] amdgpu 0000:01:00.0: amdgpu: Not enough PCI address space for a large BAR. [ 951.046383] amdgpu 0000:01:00.0: BAR 0 [mem 0x900000000-0x90fffffff 64bit pref]: assigned [ 951.046405] amdgpu 0000:01:00.0: BAR 2 [mem 0x910000000-0x9101fffff 64bit pref]: assigned [ 951.046430] amdgpu 0000:01:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used) [ 951.046433] amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF [ 951.046438] [drm] Detected VRAM RAM=2048M, BAR=256M [ 951.046440] [drm] RAM width 128bits GDDR5 [ 951.046690] amdgpu 0000:01:00.0: amdgpu: amdgpu: 2048M of VRAM memory ready [ 951.046695] amdgpu 0000:01:00.0: amdgpu: amdgpu: 15812M of GTT memory ready. [ 951.046733] [drm] GART: num cpu pages 65536, num gpu pages 65536 [ 951.048243] [drm] PCIE GART of 256M enabled (table at 0x000000F400000000). [ 951.048855] [drm] Chained IB support enabled! [ 951.050102] amdgpu: hwmgr_sw_init smu backed is polaris10_smu [ 951.050568] [drm] Found UVD firmware Version: 1.130 Family ID: 16 [ 951.054854] [drm] Found VCE firmware Version: 53.26 Binary ID: 3 [ 951.264633] amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110) [ 951.266003] amdgpu 0000:01:00.0: amdgpu: hw_init of IP block <gfx_v8_0> failed -110 [ 951.266667] amdgpu 0000:01:00.0: amdgpu: amdgpu_device_ip_init failed [ 951.267227] amdgpu 0000:01:00.0: amdgpu: Fatal error during GPU init [ 951.267780] amdgpu 0000:01:00.0: amdgpu: amdgpu: finishing device.
  4. As amazingfate (the Armbian dev for this device) clearly stated on the forum: cellular and camera are not working, only display, touch, wifi, and bluetooth are functional—so it won't replace your phone OS for calls and texts
  5. Yesterday
  6. Can confirm. S905X5M is a different beast than the S905X. If there's interest, I can start another thread with an image and status, once this is somewhat more stable. Currently booting, but not without some debug console interaction on power up. In the meantime, code's up at https://github.com/tparys/build/tree/odroidc5 if anyone wants to go poking
  7. Hello, I hope you don't have any problem. Maybe me and my brother have defective or more unstable helios64 than you. Only thing I can say that Prahal share here the specifics files rk3399-kobol-helios64.dtb-6.XX.xx-L2-hs400-opp in this forum since two years ago my helios64 and my brother's helios64 work stable only with it. I back to 6.12.58 Kernel with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp file and freeze firmware/kernel with armbian-config.
  8. I am having issues with eMMC detection… The kernel does not detect the eMMC, but apparently U-Boot does. Attached are images.
  9. I'm kinda new here, and lets first say thank you for Armbian, it has kinda saved me from having to do a lot more work than I have had to, to get my Orange Pi 5 Plus to a state where it's really a pretty cool little test/experimental system... BUT, I wondered... since many of these devices have accessible PCIe in one form or another, and the Mali GPU is a bit of a blocker... Perhaps it would be good to build the kernel with the modules for open source GPUs for Mesa... AMDGPU, XE, and i915.. Currently I'm in this position... I know I could clone the project from GIT, and build my own kernel, but this seems like an obvious next step and I wonder how many other people would try this if the modules were available. root@mouse:/home/james# lscpu | head -5 Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 root@mouse:/home/james# free -h total used free shared buff/cache available Mem: 30Gi 4.1Gi 18Gi 723Mi 9.2Gi 26Gi Swap: 15Gi 0B 15Gi root@mouse:/home/james# df -h . Filesystem Size Used Avail Use% Mounted on /dev/sda1 800G 322G 475G 41% /home root@mouse:/home/james# lspci 0000:00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0000:01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7) 0000:01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] 0002:20:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0002:21:00.0 Network controller: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] (rev 1a) 0003:30:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0003:31:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05) 0004:40:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0004:41:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05) root@mouse:/home/james# modprobe amdgpu modprobe: FATAL: Module amdgpu not found in directory /lib/modules/6.18.16-current-rockchip64 root@mouse:/home/james#
  10. Hi, I am trying out Armbian 26.2.0-trunk.592 nightly (trixie) on a Radxa Rock PI 4b+ The community supported image boots fine and it is no problem to install Armbian on the on-board eMMC flash, but the installed NVMe SSD on PCIi is no recognised. It looks like the whole PCIe bus is not initialised properly during boot. in the kernel log I see: [ 0.062396] /pcie@f8000000: Fixed dependency cycle(s) with /pcie@f8000000/interrupt-controller [ 2.160749] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 2.160771] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 2.160779] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 2.869988] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 2.870032] rockchip-pcie f8000000.pcie: probe with driver rockchip-pcie failed with error -110 I have searched for quite a while now but could not really find a solution for this. It seems there have been similar problems reported regarding other SOCs using the same chip and I even see patches being proposed (not sure whether the PR has been merged) though at this moment I cannot really see any solution available to this yet. Did anyone else encounter this and is there any fix or workaround for this? I installed the Homeassistant OS image for this board (maintained here: https://github.com/citruz/haos-rockpi), which does not have this issue and allowed me to install and boot from the NVMe drive without any problem. Is anyone aware of the differences in the upstream linux kernel and the one that Armbian ships w.r.t. patches that could make a difference here? regards, Frederik
  11. Hi @Edmilson Santos, what about Ethernet?
  12. While waiting for new info, first poke in the dark. rk3399-fix-pci-phy.patch disabled https://testing.armbian.de/r4s/ feel free to test
  13. Perhaps a hardware defect? At least that would be my guess from what it sounds.
  14. Please provide logs. armbianmonitor -u Otherwise its just poking around in the dark
  15. it only show 0xc8 if i have the wrong baudrate, otherwise nothing is shown on picocom's output. when i plug the poe hat, which has a fan (loaded by an overlay) it turns on, which would mean that it was loaded, right? but, i get no serial/hdmi output, no network uplink and only the green led is on. the same setup on another board works
  16. I'm getting the exact same error after upgrading from kernel 6.12.58-current-rockchip64 to 6.18.10-current-rockchip64 on one of my NanoPi R4S. After a reboot, the network interface enp1s0 is missing. After shutting down and restarting, it reappears. If I revert to kernel 6.12.58-current-rockchip64 using armbian-config, the enp1s0 interface is also present after a reboot. Are there any suggestions on how I can resolve this issue without remaining on kernel 6.12.58-current-rockchip64?
  17. elaborate. If there is only garbage output your usb uart adapter may not be able to handle this speed. Example would be CP2102 which outputs garbage instead of gracefully failing when "overclocked".
  18. Hello @Lamerjack! I tested both images and no one give me video on HDMI sorry!
  19. Hi Does anyone have any advice on how to get Armbian running on this device. I am comeplety new to Armbian. Is there a generic Allwinner H6 image that I need to modify? Any advice pls? Thanks
  20. Hello, this is my first message here: I want to thank the community for the work done so far, and for allowing to keep functional old devices which would otherwise become (nasty) garbage. Now, I tried to install Armbian on a Wetek Play 2 (Amlogic S905), buit now the box is not booting. I would be grateful if I could get some help, or at least clarification about what happened. Here is what I did so far: Download the image `Armbian_community_26.2.0-trunk.493_Aml-s9xx-box_trixie_current_6.18.13_minimal.img.xz`, and write it on a SD card. Boot from the SD card, by holding the power button when inserting the power cable. The box booted fine. Log in via SSH, and configure the installation. Back-up the full emmc with `dd if=/dev/mmcblk1 of=/mnt/backup/wetek_play2_android_emmc.img bs=4M`. The emmc had the original Android system (with more stuff installed, but I guess the most important part are the first 4 MB...) Run the `/root/install-aml` script. Power-off When powering on again, the box did not boot. I tried to boot from SD by holding the power button, but it did not work. So at this point my questions are: What can I do to recover the situation? What did I made wrong? As additional context, in the past I had also successfully booted LibreELEC from SD, although the last boot before switching to Armbian was to Android. Thanks for your help UPDATE: OK, I think I found the culprit: I overseen the quite important statement "Note: It is not possible to install into emmc on boxes with the s905 cpu". Great.
  21. Hello, I have experimented with a Realtek USB 2.5Gbe USB Ethernet dongle and find that it works fine with the vendor kernel but not with kernels 6.12.x or 6.18.y. I have included an iperf3 example below, you can see that the dongle manages a few runs at high speed before it quietly fails and seizes up. I use a number of these dongles and they tend to work fine on other set-ups. Any thoughts about a resolution? dmesg output: [Tue Mar 17 11:37:00 2026] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [Tue Mar 17 11:37:00 2026] usb 2-1: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=31.00 [Tue Mar 17 11:37:00 2026] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [Tue Mar 17 11:37:00 2026] usb 2-1: Product: USB 10/100/1G/2.5G LAN [Tue Mar 17 11:37:00 2026] usb 2-1: Manufacturer: Realtek [Tue Mar 17 11:37:00 2026] usb 2-1: SerialNumber: 0013000001 [Tue Mar 17 11:37:00 2026] usbcore: registered new device driver r8152-cfgselector [Tue Mar 17 11:37:00 2026] r8152-cfgselector 2-1: reset SuperSpeed USB device number 2 using xhci-hcd [Tue Mar 17 11:37:01 2026] r8152 2-1:1.0 eth0: v1.12.13 [Tue Mar 17 11:37:01 2026] usbcore: registered new interface driver r8152 [Tue Mar 17 11:37:01 2026] usbcore: registered new interface driver cdc_ether [Tue Mar 17 11:37:01 2026] usbcore: registered new interface driver cdc_ncm [Tue Mar 17 11:37:01 2026] usbcore: registered new interface driver cdc_wdm [Tue Mar 17 11:37:01 2026] usbcore: registered new interface driver cdc_mbim [Tue Mar 17 11:37:01 2026] r8152 2-1:1.0 enx00e04c680142: renamed from eth0 [Tue Mar 17 11:37:02 2026] xhci-hcd xhci-hcd.3.auto: WARN: HC couldn't access mem fast enough for slot 1 ep 6 [Tue Mar 17 11:37:02 2026] r8152 2-1:1.0 enx00e04c680142: intr status -63 [Tue Mar 17 11:37:07 2026] xhci-hcd xhci-hcd.3.auto: WARN: HC couldn't access mem fast enough for slot 1 ep 6 [Tue Mar 17 11:37:07 2026] r8152 2-1:1.0 enx00e04c680142: intr status -63 [Tue Mar 17 11:37:35 2026] xhci-hcd xhci-hcd.3.auto: WARN: HC couldn't access mem fast enough for slot 1 ep 6 [Tue Mar 17 11:37:35 2026] r8152 2-1:1.0 enx00e04c680142: intr status -63 Subsequent iperf3 example: iperf3 -c nx1 Connecting to host nx1, port 5201 [ 5] local 192.168.1.191 port 58598 connected to 192.168.1.14 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 221 MBytes 1.85 Gbits/sec 0 5.35 MBytes [ 5] 1.00-2.00 sec 280 MBytes 2.35 Gbits/sec 0 5.35 MBytes [ 5] 2.00-3.00 sec 280 MBytes 2.35 Gbits/sec 0 5.35 MBytes [ 5] 3.00-4.00 sec 18.1 MBytes 152 Mbits/sec 1 1.41 KBytes [ 5] 4.00-5.00 sec 0.00 Bytes 0.00 bits/sec 0 1.41 KBytes [ 5] 5.00-6.00 sec 0.00 Bytes 0.00 bits/sec 0 1.41 KBytes [ 5] 6.00-7.00 sec 0.00 Bytes 0.00 bits/sec 0 1.41 KBytes [ 5] 7.00-8.00 sec 0.00 Bytes 0.00 bits/sec 0 1.41 KBytes [ 5] 8.00-9.00 sec 0.00 Bytes 0.00 bits/sec 0 1.41 KBytes [ 5] 9.00-10.00 sec 0.00 Bytes 0.00 bits/sec 0 1.41 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 800 MBytes 670 Mbits/sec 1 sender [ 5] 0.00-10.86 sec 796 MBytes 615 Mbits/sec receiver
  22. You may be experiencing the same issue that other people are encountering: https://github.com/tauri-apps/tauri/issues/12787 @Giunti Can you confirm that this is the same issue as the one reported above? Thank you.
  23. We made several test install on Windows 11 and it always worked ... bugs are possible. Best here: https://github.com/armbian/imager/issues And add perhaps more information about the OS, hardware, any special settings that might play a role here. I don't think there is. As far as I can recall, we haven't see this problem yet. Let's ping main developer - if he has any ideas. @SuperKali But as this is a complex software with possible bugs deep down in some libraries, or even Windows itself - I assume you run with all updates?
  24. I have a ROCK 3A that reaches Maskrom/recovery but will not boot any Radxa or Armbian SD image and produces no useful UART output. UART is configured per Radxa docs at 1500000 8N1 on the debug header, and the exact same adapter/host/settings work on another ROCK 3A. There is no eMMC and no NVMe installed. I also tried resetting/loading SPI via Maskrom using rkdeveloptool db rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin, then loading Radxa’s rock-3a-spi-image-gef9f6b1caad.img. Radxa’s ROCK 3A loader directory contains the matching SPI artifacts, including rock-3a-spi-image-gef9f6b1caad.img, rock-3a-idbloader-gef9f6b1caad.img, and rock-3a-u-boot-gef9f6b1caad.itb, along with RK356x SPL loader binaries. Looking for guidance on whether this points to SPI/SPL/DDR init or a board hardware fault.
  25. This week in Armbian development saw significant progress across board support and kernel updates. New boards such as the Cainiao CNIOT Core, EByte ECB41-PGE, DG SVR 865 Tiny, and NORCO EMB-3531 received initial support, expanding hardware compatibility. Kernel patches were rewritten for the meson64 and rockchip64 platforms, aligning with version 6.18.18, while edge releases were bumped to 7.0-rc3 and rc4. Improvements included enhanced SD card and audio support for SpacemiT and Youyeetoo YY3588 boards, as well as refined configuration checks and display fixes. Several upstream patches were dropped or disabled, and the Dependabot schedule was updated for daily maintenance. Additional fixes addressed USB modes, Docker host-gateway resolution, and Xorg display issues, rounding out a productive week for the Armbian project. ChangesAdd cainiao-cniot-core board and cainiao vendor image. by @retro98boy in armbian/armbian.github.io#251Add EByte Vendor // ECB41-PGE board. by @vidplace7 in armbian/armbian.github.io#250add recomputer rk3576-devkit dts. by @ackPeng in armbian/linux-rockchip#451Add support for the Radxa Display 10 FHD to the Rock 5B Plus. by @FlorianKohn in armbian/linux-rockchip#453add: initial support for DG SVR 865 Tiny board (SM8250/QCS8250). by @Lemon1151 in armbian/build#9423arch: arm: dts: add EByte ECB41-PGE (RK3506g2). by @vidplace7 in armbian/linux-rockchip#454armbian-zram-config: refine check for existing /tmp mount. by @vidplace7 in armbian/build#9514cainiao cniot core improve. by @retro98boy in armbian/build#9526chore: update Dependabot schedule to daily updates. by @igorpecovnik in armbian/build#9537csc board: Add NORCO EMB-3531 initial support. by @retro98boy in armbian/build#9456Drop patches that landed upstream and fix two. by @igorpecovnik in armbian/build#9544edge: bump 7.0 to rc4. by @EvilOlaf in armbian/build#9543extension: ccache-remote: fix Docker host-gateway for hostnames resolving to loopback. by @iav in armbian/build#9505fix(orangepi5max): change usbdrd_dwc3_0 mode from otg to host. by @Echoflare in armbian/linux-rockchip#449fix: correct repository dispatch event type name. by @igorpecovnik in armbian/armbian.github.io#254framework run_host_x86_binary_logged - support 32-bit x86. by @tabrisnet in armbian/build#9466Gateway AM-GZ80x: Update $board and meson-axg family conf. by @pyavitz in armbian/build#9533maint: meson64-current: rewrite patches against 6.18.18. by @EvilOlaf in armbian/build#9528maint: rockchip64-current: rewrite kernel patches against 6.18.18. by @EvilOlaf in armbian/build#9527meson64: a311d: Fix Xorg display when etnaviv enabled. by @retro98boy in armbian/build#9524Odroid-M2: Support for weather board zero. by @mlegenovic in armbian/build#9523odroidn2: u-boot: bump to v2026.04-rc3; make fancy, incl LWIP. by @rpardini in armbian/build#9507OrangePi 3 LTS: Update $board.conf file. by @pyavitz in armbian/build#9495OrangePi-RV2/R2S: add sdcard and emmc for Linux-7.x. by @sven-ola in armbian/build#9539Reword BTF memory check. by @x13-me in armbian/build#9502RK3506: Add spidev overlays for RK3506 family. by @vidplace7 in armbian/linux-rockchip#450rockchip64: bump edge to 7.0-rc3. by @EvilOlaf in armbian/build#9445rockchip64: cleanup old patchsets. by @EvilOlaf in armbian/build#9498rockchip: Add CSC board EByte ECB41-PGE (RK3506G). by @vidplace7 in armbian/build#9513rockchip: refresh LibreELEC patch import for edge 6.19 kernel. by @paolosabatino in armbian/build#9506rockchip: restore proper LE patches for rockchip armhf. by @paolosabatino in armbian/build#9530rpi4b: bump edge to 7.0. by @EvilOlaf in armbian/build#9529Spacemit rv2 rename dtb. by @sven-ola in armbian/build#9531SpacemiT: Add SD card support, CPU freq scaling and other fixups. by @pyavitz in armbian/build#9518SpacemiT: Disable patches that made it upstream (7.0-rc4). by @pyavitz in armbian/build#9540spacemit: enable powervr drm driver for current 6.18 kernels. by @sven-ola in armbian/build#9515sunxi: bump edge to 6.19.y, current to 6.18.y and legacy to 6.12.y. by @EvilOlaf in armbian/build#9381Youyeetoo YY3588: Enable ES8388 audio support + RK3588 I2S MCLK gate fix . by @SuperKali in armbian/build#9534View the full article
  26. Last week
  27. After some experimentation, I realized that the full xfce images are working fine, likely because NetworkManager is built in. The minimal CLI images, even after switching to NetworkManager per the instructions here, never worked for me to retain Wifi after a reboot. I'm going through the process of removing the XFCE desktop from my install as CPU utilization in Klipper is very high otherwise.
  28. FWIW, I am running -edge kernel from armbian with respective dtb (linux-dtb-edge-rockchip64 package), and it's quite stable. vmlinuz-6.18.0-rc6-edge-rockchip64 dtb-6.18.0-rc6-edge-rockchip64 🤞
