https://debug.armbian.de
FYI latest image for rock 5B+ in downloads section is broken (Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop) Wont boot at all, previous 25.2.2 images works fine.
FYI this release has some sort of bootloader bug for Radaxa 5B+ boards. Wont boot at all from fresh image in downloads section (Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop)
Ok Tks, very hard work with nand. But, ok work for me with sd card. Could you tell me if the Wifi would work?
Can someone share a ready .dtb file with this patch. I am trying to run SPDIF in Tv-Box Vontar X3 with Amlogic S905x3 processor but I can't compile with this patch.
Good morning: I've got a ROCK64 and it does't boot from few days. White; Red and Green led stand with light. nothing change even after minutes. I've tried rock64-debian-mrfixit-190531.img.xz, , freedombox-bookworm_all-arm64.img.xz, debian-12.11.0-arm64-netinst.iso, But never go further. Do you have an idea ? I've got a 5A power so should not be a problem.
i think there is not even useable nand support in the mainline allwinner kernel, so chances are close to zero to get this working currently
Update maintainers and board status synced status from the database rename to .csc where we don't have anyone If you want to become a board maintainer, adjust data here. Ref: Board Maintainers Procedures and Guidelines Contribute View the full article
Description Attempt to work towards one U-Boot bootscript for (at least) mvebu, sunxi and rockchip64. This adds: (Aligned) load address calculations This will remove the need to update any kernel_load_addr_r or ramdisk_addr_r in case kernel image increases. Calculation is based on either Flat kernel image image_size + text_offset as specified in the vmlinux(/Image) header info Compressed kernel image filesize (vmlinuz/zImage) Clear warnings to user in case files are not found, not able to load or application failed. Merge of armbianEnv.txt kernel options was attempted for sunxi, mvebu and rockchip64. DT folder determination based on sunxi approach. DT file determination based on sunxi approach. Compat with /boot/dtb/fdtfile.dtb and /boot/dtb/vendor/fdtfile.dtb. Simplified some constructs by assuming U-Boot has successfully sourced us with a set of pre-set variables, like ${prefix} ${devtype} etc. Actively set the ${kernel_comp_*} parameters based on calculations of load addresses. Ability to select different kernel/initrd by setting kver in armbianEnv.txt Also: Any warning or error includes a 10 second delay to make sure the user is able to see and read them. Any "informative" message added by the bootscript can be silenced by setting verbosity to 0 Attempted to make the bootscript 'reentrant' in away: all variables required for proper (re)execution are set, which should allow for the entire bootscript to be re-run on a next boot_target. All variables used in for-loops are actively cleared from the environment to ensure for loops work as expected. Any pre-set variable that might be used in next boot_target will be reset whenever necessary. Documentation summary for feature / change [ ] short description (copy / paste of PR title) [x] summary (description relevant for end users) Load address calculation can be disabled by adding load_addr_calc=off to armbianEnv.txt Load address calculation OBOE avoidance can be disabled by adding align_overlap_oboe_avoidance=off to armbianEnv.txt User can set custom fdtdir and fdtfile in armbianEnv.txt, but make sure to only specify DT filename in fdtfile. fdtdir will be used to both load DT, DT overlays and fixup scripts [ ] example of usage (how to see this in function) How Has This Been Tested? [x] Orangepi Zero (first gen):[12:39:52] U-Boot SPL 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000) [12:39:52] DRAM: 512 MiB [12:39:52] Trying to boot from MMC1 [12:39:53] ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 [12:39:53] U-Boot 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000) Allwinner Technology [12:39:53] CPU: Allwinner H3 (SUN8I 1680) [12:39:53] Model: Xunlong Orange Pi Zero [12:39:53] DRAM: 512 MiB [12:39:53] Core: 70 devices, 19 uclasses, devicetree: separate [12:39:53] WDT: Not starting watchdog@1c20ca0 [12:39:53] MMC: mmc@1c0f000: 0, mmc@1c10000: 1 [12:39:53] Loading Environment from FAT... Unable to use mmc 0:1... [12:39:53] In: serial,usbkbd [12:39:53] Out: serial [12:39:53] Err: serial [12:39:53] Starting SCP... [12:39:53] Net: SCP/INF: Crust v0.6.10000 [12:39:53] eth0: ethernet@1c30000 [12:39:53] starting USB... [12:39:53] Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus [12:39:53] USB EHCI 1.00 [12:39:53] Bus usb@1c1a400: USB OHCI 1.0 [12:39:53] Bus usb@1c1b000: USB EHCI 1.00 [12:39:53] Bus usb@1c1b400: USB OHCI 1.0 [12:39:53] Bus usb@1c1c000: USB EHCI 1.00 [12:39:53] Bus usb@1c1c400: USB OHCI 1.0 [12:39:53] scanning bus usb@1c1a000 for devices... 1 USB Device(s) found [12:39:54] scanning bus usb@1c1a400 for devices... 1 USB Device(s) found [12:39:55] scanning bus usb@1c1b000 for devices... 1 USB Device(s) found [12:39:56] scanning bus usb@1c1b400 for devices... 1 USB Device(s) found [12:39:57] scanning bus usb@1c1c000 for devices... 1 USB Device(s) found [12:39:59] scanning bus usb@1c1c400 for devices... 1 USB Device(s) found [12:40:00] scanning usb for storage devices... 0 Storage Device(s) found [12:40:00] Autoboot in 1 seconds, press <Space> to stop [12:40:01] switch to partitions #0, OK [12:40:01] mmc0 is current device [12:40:01] Scanning mmc 0:1... [12:40:01] Found U-Boot script /boot/boot.scr [12:40:01] 18117 bytes read in 4 ms (4.3 MiB/s) [12:40:01] ## Executing script at 43100000 [12:40:01] Boot script loaded from mmc 0:1. [12:40:01] 687 bytes read in 3 ms (223.6 KiB/s) [12:40:01] Loaded/imported environment /boot/armbianEnv.txt to/from 0x45000000. [12:40:01] Found mainline kernel configuration. [12:40:01] 35473 bytes read in 11 ms (3.1 MiB/s) [12:40:01] Loaded DT /boot/dtb/sun8i-h2-plus-orangepi-zero.dtb to 0x43000000. [12:40:01] Working FDT set to 43000000 [12:40:01] Loading kernel provided DT overlay(s) from /boot/dtb/overlay to 0x45000000 .. [12:40:01] 504 bytes read in 10 ms (48.8 KiB/s) [12:40:01] Applied DT overlay usbhost2 (/boot/dtb/overlay/sun8i-h3-usbhost2.dtbo). [12:40:01] 504 bytes read in 10 ms (48.8 KiB/s) [12:40:01] Applied DT overlay usbhost3 (/boot/dtb/overlay/sun8i-h3-usbhost3.dtbo). [12:40:01] 617 bytes read in 10 ms (59.6 KiB/s) [12:40:01] Applied DT overlay tve (/boot/dtb/overlay/sun8i-h3-tve.dtbo). [12:40:01] 374 bytes read in 9 ms (40 KiB/s) [12:40:01] Applied DT overlay i2c0 (/boot/dtb/overlay/sun8i-h3-i2c0.dtbo). [12:40:01] Loading user provided DT overlay(s) from /boot/overlay-user to 0x45000000 .. [12:40:01] 835 bytes read in 3 ms (271.5 KiB/s) [12:40:01] Applied user DT overlay rtc0-i2c-ds3231-rtc1-soc (/boot/overlay-user/rtc0-i2c-ds3231-rtc1-soc.dtbo). [12:40:01] 4185 bytes read in 10 ms (408.2 KiB/s) [12:40:01] ## Executing script at 45000000 [12:40:01] Loaded/sourced fixup script /boot/dtb/overlay/sun8i-h3-fixup.scr to/at 0x45000000. [12:40:02] 10554192 bytes read in 441 ms (22.8 MiB/s) [12:40:02] Loaded compressed kernel image /boot/zImage to 4300a000. [12:40:02] Using compressed kernel image filesize 0xa10b50 bytes to calculate initial ramdisk load address. [12:40:02] 11621101 bytes read in 484 ms (22.9 MiB/s) [12:40:02] Loaded initial ramdisk /boot/uInitrd to 43a1b000. [12:40:02] Unknown command 'kaslrseed' - try 'help' [12:40:02] Not able to prepare for KASLR. [12:40:02] Kernel commandline arguments: [12:40:02] root=/dev/nfs [12:40:02] rootfstype=nfs [12:40:02] rootwait [12:40:02] splash=verbose [12:40:02] earlycon [12:40:02] console=ttyS0,115200 [12:40:02] consoleblank=0 [12:40:02] loglevel=8 [12:40:02] ubootpart=81f6566a-01 [12:40:02] usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x174c:0x55aa:u [12:40:02] dwc_otg.fiq_enable=0 [12:40:02] net.ifnames=0 [12:40:02] ipv6.disable=1 [12:40:02] rw [12:40:02] nfsroot=192.168.2.34:/export/rootfs/blippi [12:40:02] ip=dhcp [12:40:02] nfsrootdebug [12:40:02] nfs.enable_ino64=0 [12:40:02] cgroup_enable=cpuset [12:40:02] cgroup_memory=1 [12:40:02] cgroup_enable=memory [12:40:02] Kernel image @ 0x4300a000 [ 0x000000 - 0xa10b50 ] [12:40:02] ## Loading init Ramdisk from Legacy Image at 43a1b000 ... [12:40:02] Image Name: uInitrd [12:40:02] Image Type: ARM Linux RAMDisk Image (gzip compressed) [12:40:02] Data Size: 11621037 Bytes = 11.1 MiB [12:40:02] Load Address: 00000000 [12:40:02] Entry Point: 00000000 [12:40:02] Verifying Checksum ... OK [12:40:02] ## Flattened Device Tree blob at 43000000 [12:40:02] Booting using the fdt blob at 0x43000000 [12:40:02] Working FDT set to 43000000 [12:40:02] Loading Ramdisk to 494ea000, end 49fff2ad ... OK [12:40:02] Loading Device Tree to 494de000, end 494e9fff ... OK [12:40:02] Working FDT set to 494de000 [12:40:02] Starting kernel ... [12:40:03] [ 0.000000] Booting Linux on physical CPU 0x0 [x] Orangepi zero (first gen): OKU-Boot SPL 2024.01-armbian (Feb 23 2024 - 10:47:39 +0000) DRAM: 256 MiB Trying to boot from MMC1 ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian (Feb 23 2024 - 10:47:39 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB Core: 70 devices, 19 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial,usbkbd Out: serial Err: serial Starting SCP... Net: SCP/INF: Crust v0.6.10000 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 18202 bytes read in 5 ms (3.5 MiB/s) ## Executing script at 43100000 Boot script loaded from mmc 0:1. 265 bytes read in 4 ms (64.5 KiB/s) Loaded/imported environment /boot/armbianEnv.txt to/from 0x45000000. Found mainline kernel configuration. 35473 bytes read in 9 ms (3.8 MiB/s) Loaded DT /boot/dtb/sun8i-h2-plus-orangepi-zero.dtb to 0x43000000. Working FDT set to 43000000 Loading kernel provided DT overlay(s) from /boot/dtb/overlay to 0x45000000 .. 504 bytes read in 11 ms (43.9 KiB/s) Applied DT overlay usbhost2 (/boot/dtb/overlay/sun8i-h3-usbhost2.dtbo). 504 bytes read in 12 ms (41 KiB/s) Applied DT overlay usbhost3 (/boot/dtb/overlay/sun8i-h3-usbhost3.dtbo). 4185 bytes read in 11 ms (371.1 KiB/s) ## Executing script at 45000000 Loaded/sourced fixup script /boot/dtb/overlay/sun8i-h3-fixup.scr to/at 0x45000000. 10554192 bytes read in 442 ms (22.8 MiB/s) Loaded compressed kernel image /boot/zImage to 4300a000. Using compressed kernel image filesize 0xa10b50 bytes to calculate initial ramdisk load address. 11867098 bytes read in 497 ms (22.8 MiB/s) Loaded initial ramdisk /boot/uInitrd to 43a1b000. Unknown command 'kaslrseed' - try 'help' Not able to prepare for KASLR. Kernel commandline arguments: root=PARTUUID=1c01f668-02 rootfstype=f2fs rootwait splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=8 ubootpart=1c01f668-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x174c:0x55aa:u net.ifnames=0 ipv6.disable=1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory Kernel image @ 0x4300a000 [ 0x000000 - 0xa10b50 ] ## Loading init Ramdisk from Legacy Image at 43a1b000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11867034 Bytes = 11.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Working FDT set to 43000000 Loading Ramdisk to 494ae000, end 49fff39a ... OK Loading Device Tree to 494a2000, end 494adfff ... OK Working FDT set to 494a2000 Starting kernel ... Checklist: [ ] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings New warnings introduced: Environment load failed Environment import failed DT load/application failed DT (user) overlay load/application failed Initial ramdisk load failed Kernel image load failed Boot failed [x] Any dependent changes have been merged and published in downstream modules Prequisite U-Boot setexpr command already merged via https://github.com/armbian/build/pull/8260. View the full article
I understand, but would I be able to do it officially?
We don't support 3rd party forks
Good afternoon. I need a little help here. I managed to compile a working version for this board. However, it does not recognize the internal disk, which in this case is a nand. I used this repo: https://github.com/sicXnull/armbian-build.git Branch: X96Q-5.1-DDR3 Could someone help me?
In one post here I saw a "please buy hardware we recommend" quote, and I appreciate that, but I wasn't able to find a recommended boards list - is there even one? Or should I just use the standard/platinum support filtering on the main page? Anyway, I could also use some help / recommendation for a general purpose SBC as I ... didn't by one for years. I'm looking for a more recent SBC to run a small, low power server (think pihole, homeassistant, zigbee, etc). I don't have specific requirements, but I'd like the board to have some kind of "long term support" and I'd also like to choose something that the armbian team would recommend, maybe from a manufacturer that supports armbian directly, or at least provides good documentation. Headless install, may use GPIO, at least 3 USB ports, built-in ethernet + wifi + BT (not sure if there's an SBC that would support zigbee natively?). And also, avoid using an SD card. Ability to use eMMC or SSD would be important. Where I'm coming from: I still run two first-gen Raspberry Pis as webcams + dataloggers (the 26 pin GPIO ones with 256 and 512 MB RAM respectively) and I used OrangePi One and Lite as two surprisingly stable servers for years (one a small postfix mailserver + datalogger, the other even running 4 docker containers). I like using low-level hardware to its limits🙂 I have recently upgraded to an already outdated OrangePi PC+ that I found in the drawer - at least it has 1 GB of RAM and I was starting running into limits with the 512 MB ones. So yeah - I don't need the top of the range SBC but something ... reasonably priced (think ~40 €) that will run well for years to come. I heard good stuff about the Radxa boards with Rockchip SoCs but I have no experience as I haven't bought new SBCs in ... years. Thanks in advance 🙂
In this final article of a three-part series, I look at locking with C++ and Matt Godbolt's notion of CADR. View the full article
arbeiter replied to Hqnicolas's topic in Rockchip CPU Boxes
Hi, I got new H96 Max M9S and would like to ask some questions before flashing armbian on the device. 1. In this thread reset button is mentioned and I cannot find one on the case and neither on the board. Is there o photo of it or is it another name for maskrom switch? 2. I intend to flash from Linux, is the following method correct: - put device in maskrom mode - connect it to a computer by a USB A-A cable (to USB 2.0 port) - on a computer: rkdeveloptool ld (to list recognized devices) - on a computer: rkdeveloptool db RK3576_MiniLoaderAll.bin - on a computer: rkdeveloptool wl 0 h96_max_m9s_rk3576_20240930_1033.img - restart H96 Max M9S I also have a question regarding building Armbian image: which dtb file should I use to put in directory build/packages/blobs/h96-m9/ (is it H96-RK3576-BOX.dtb)? Best Regards and keep up the good work. -
OrangePi 3 lts / i2C / overlay / armbian-config ?
Lars Christian Nygård replied to kris777's topic in Allwinner sunxi
Having trouble with my klipper accelerometer every time the dtb is upgraded during a update/upgrade. I made this patch to fix the spi@5011000 { ...} section: 831c831 < status = "disabled"; --- > status = "okay"; 834a835,840 > spidev@0 { > compatible = "armbian,spi-dev"; > reg = <0x00>; > spi-max-frequency = <0xf4240>; > }; > And then dtc -I dtb -O dts -o sun50i-h6-orangepi-3-lts.dts /boot/dtb/allwinner/sun50i-h6-orangepi-3-lts.dtb patch -b sun50i-h6-orangepi-3-lts.dtso opi3lts-dtb.patch dtc -I dts -O dtb -o /boot/dtb/allwinner/sun50i-h6-orangepi-3-lts.dtb sun50i-h6-orangepi-3-lts.dts Not sure if this is a sane and safe way to do it, but it works for me at least. Hope it can find it's way in a sane form into a future release. Maybe it's better to do it in an overlay, rather than directly? opi3lts-dtb.patch -
Helios64 - SATA issues with Armbian 25.5.1/Kernel 6.12.32
djurny replied to Alexander Eiblinger's topic in Rockchip
Hi, Not an expert here, but some educated guesses would be related to either timing, blocksizes towards the devices. Anything that might change or increase the amount of ATA commands towards the disks would be my bet to look at. You could experiment with enabling/disabling NCQ, reducing read-ahead, increasing chunksizes in case you use [software] RAID, increasing caching by tweaking vm options. Perhaps even the IO schedulers, there might have been some new IO schedulers introduced on the new kernel that show different behavior compared to the older kernel, etc. Groetjes, -
I found an incredibly roundabout way of doing this. ./compile.sh \ kernel \ BOARD=$OPT_ARMBIAN_BOARD \ BRANCH=$OPT_ARMBIAN_KERNEL \ CLEAN_LEVEL=make,alldebs,images,cache \ EXPERT=yes \ PREFER_DOCKER=yes \ KERNEL_GIT=shallow KERNEL_CONFIG=$(find $KERNEL_DIR/cache/sources/linux-kernel-worktree -name .config) if [ ! -f $KERNEL_CONFIG ] then echo "Failed to find .config" exit 1 fi FULL_KERNEL_VERSION=$(cat $KERNEL_CONFIG | grep "Kernel Configuration" | grep -oE '[0-9]+\.[0-9]+\.[0-9]+') if [ "$FULL_KERNEL_VERSION" == "" ] then echo "Failed to get full kernel version." exit 1 fi
Offeacy61 replied to Pita Bread's topic in TV Boxes running Armbian
Thanks for the detailed description! Very useful post, especially for those who are just starting to tinker with Armbian on TV boxes. I had a similar situation with another S905X3 box - neither Wi-Fi nor Bluetooth worked, and there was trouble with HDMI audio. Special thanks for the advice on disabling unattended-upgrades and systemd-networkd-wait-online, I just encountered problems with long loading, now I understand where the legs are growing from. Regarding USB audio - an excellent solution, I didn't even know that it was so easy to bypass the lack of built-in sound. I will try with a similar adapter. If you have a chance, tell me later whether you managed to set up Wi-Fi via a USB adapter or in another way. And I wonder if you tried other window environments besides XFCE? LXQt, for example? In any case - a great guide, thanks for your work! -
Description Currently, PocketBeagle 2 edge images cannot build (without patch 1) and fails to boot (without patch 3). The patch one just defines the missing variable for OPTEE. Patch 3 specifies root using path instead of UUID. For some reason, UUID does not work with PocketBeagle 2 U-boot. How Has This Been Tested? Tested on PocketBeagle 2 rev A0 Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
Look at your board config file: config/boards/orangepi5b.csc In there you will find the board family, which in your case is: BOARDFAMILY="rockchip-rk3588" Then look at the corresponding board family config file: config/sources/families/rockchip-rk3588.conf There you will find a section for each branch (i.e vendor, current, edge) that will specify which kernel source is used: For BRANCH=vendor that would currently be: KERNELSOURCE='https://github.com/armbian/linux-rockchip.git' KERNELBRANCH='branch:rk-6.1-rkr5.1' KERNELPATCHDIR='rk35xx-vendor-6.1'
i.e. git clone -b main --depth 1 https://github.com/armbian/build.git cd build # I want to find out what kernel my board is building befor here. ./compile.sh kernel BOARD=orangepi5b BRANCH=vendor EXPERT=yes PREFER_DOCKER=yes KERNEL_GIT=shallow I need to do this so I can apply patches based on the selected kernel verison (e.g. 5.10, 6.1, 6.12) as they are all different patches due to Makefile changes. I don't see a clean way to do this with the builder unless I build the kernel first, search the kernel sources and then determine the kernel that way.
