  2. Customizing image and customizing kernel are different tasks. For latter use the code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } kernel-config command and then copy over the created config file from output to userpatches. The framework will look for custom kernel configuration files and uses them if they're detected. More details here: https://zuckerbude.org/armbian-using-kernel-config/
  4. @Nick A success build log : https://paste.armbian.eu/simirepihe
  5. Thanks. I'll have to look into that. I expect that's for customizing the packages installed?
  6. Armbian uses Netplan by default to manage network settings. But when it uses NetworkManager as renderer, it silently changes iptables rulesโ€”without asking, without telling. *Neither Netplan nor NetworkManager are supposed to manage firewall settings.* But they do it anyway, behind the scenes. That kind of behaviorโ€”making security changes without user consentโ€”feels a lot like what malware does.
  7. @Nick A full log (failed): [๐Ÿ’ฒ|๐ŸŒฑ] Starting main configuration [๐Ÿ’ฒ|๐ŸŒฑ] Using REVISION from [ main VERSION file: '25.05.0-trunk' ] [๐Ÿ’ฒ|๐ŸŒฟ] Enabling extension [ armbian-config ] [๐Ÿ’ฒ|๐ŸŒฑ] Sourcing family configuration [ /home/nguye/build/config/sources/families/sun50iw9.conf ] [๐Ÿ’ฒ|๐ŸŒฟ] Enabling extension [ sunxi-tools ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ KERNELBRANCH='tag:v6.12.11' ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ LINUXFAMILY='sunxi64' # (was: 'sun50iw9') ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ KERNELPATCHDIR='archive/warpme-6.12' ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ BOOTBRANCH='tag:v2025.01' ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ BOOTPATCHDIR='u-boot-h616' ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ ATFBRANCH='tag:lts-v2.10.14' ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ] [๐Ÿ’ฒ|๐ŸŒฑ] Sourcing arch configuration [ arm64.conf ] [๐Ÿ’ฒ|โœ…] change-tracking: after sourcing arm64 arch [ ATFDIR='arm-trusted-firmware' ] [๐Ÿ’ฒ|๐ŸŒฑ] Using NETWORKING_STACK [ NETWORKING_STACK: network-manager ] [๐Ÿ’ฒ|๐ŸŒฑ] Adding networking extensions [ net-network-manager, net-chrony ] [๐Ÿ’ฒ|๐ŸŒฟ] Enabling extension [ net-network-manager ] [๐Ÿ’ฒ|๐ŸŒฟ] Enabling extension [ net-chrony ] [๐Ÿ’ฒ|๐ŸŒฑ] Extension manager [ processed 17 Extension Methods calls and 27 Extension Method implementations ] [๐Ÿ’ฒ|๐ŸŒฑ] x96q-lpddr3 [ Using allwinner/sun50i-h313-x96-q-lpddr3.dtb for edge ] [๐Ÿ’ฒ|๐Ÿ’ฅ] Error 1 occurred in SUBSHELL [ SUBSHELL at /home/nguye/build/lib/functions/configuration/config-desktop.sh:48 ] [๐Ÿ’ฒ|๐Ÿ’ฅ] Cleaning up [ please wait for cleanups to finish ] [๐Ÿ’ฒ|๐ŸŒฟ] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans ] [๐Ÿ’ฒ|๐ŸŒฑ] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] [๐Ÿ’ฒ|๐ŸŒฟ] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.com/log ] [๐Ÿ’ฒ|๐ŸŒฟ] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.de/log ] [๐Ÿ’ฒ|๐ŸŒฟ] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.next.armbian.com/log ] [๐Ÿ’ฒ|๐ŸŒฟ] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.eu/log ] nguye@DESKTOP-IFEAUMD:~/build$ EDIT: it continued while i tried Debian 12 Next i choosed xfce config_base (onlyone) internet
  8. @Nick A i choosed x96q-lpddr3 (csc) Allwinner H313 TVB with 2gigs of ram and emmc (my box uses emmc) debian 11 image with desktop enviroment
  9. by the way i don't see any options with allwinner h313 and 1gb ram, can i just choose the 2gb x96q?
  10. @Ducdanh Nguyen on the other side of the board it has two capacitors. I donโ€™t think thatโ€™s it.
  11. hey @Nick A, i think i found the serial port look at the yellow mark on the image
  12. Could this be a power supply issue? Unfortunately, there is no official maintainer for your board. None of the core devs will be able to verify your issue.
  13. Yesterday
  14. Hi, thanks for the tip, here's the link of the amrbianmonitor results: https://paste.armbian.de/okeqakeval
  15. Thanks, I am aware of that. But that's an Ubuntu that's using the barebones vendor kernel. I need a fuller kernel than that, and Debian. As it turns out, in looking at recent updates here, it looks like the audio issue has been addressed within the past few days, and that it's an easy fix (as I thought it would be): https://patchwork.kernel.org/project/linux-rockchip/list/ I have yet to try that out, but it looks like I can either wait for the update in the bleeding edge kernel (if it's not already present) or modify the devicetree myself with the fix they discovered.
  16. That seems to have gone away. ? SNILMERG... Now using very small but 1920x1080 screen, xfce terminal text is about 7 microns tall, way too small for my ancient eyes, Simplified keyboard. ctrl&shift&+ magnify's text but when big enough to read, bottom of xfce4 terminal is offscreen below bottom of screen, so cannot see command line. Is there a keycode combo that expands text independently from terminal window size? Thank you.
  17. The most interesting thing is that everything works fine for joshua-riek Ubuntu 24.04 with the 6.1 kernel https://joshua-riek.github.io/ubuntu-rockchip-download/boards/orangepi-5-plus.html
  18. Armbian kernel and BSP Debian/Ubuntu userland
  19. With the armbian build system, you can build either Bookworm or Trixie You will always get the latest Bookworm or the latest Trixie packages in a freshly built armbian OS. This is what's meant by "always rolling release"... not to be understood as "always sid or Trixie". Independently, the armbian build system will let you choose a stable Linux version, or the latest available from Armbian (edge).
  20. You are still using an old Linux. You need Linux 6.13 or newer. You need to build your own Armbian OS. Also, don't forget the cma=256M kernel argument
  21. Ho ! That's a new thing isn't it ? And IMHO, a strange choice. Is there a way to disable that rolling release during the image building process?
  22. Stable images can only be built by Armbian. All user built images are essentially rolling releases. But once booted into an image, you can use armbian-config to switch to the stable apt repositories, which means you won't get bug fixes or security updates to the kernel, but instead you get a stable kernel build released once every three months.
  23. Hi there! Made some further research. It seems I was wrong assuming hw GPU/VPU is used. The reduced CPU load is more likely a result of the lower fps when using -hwaccel drm (aka v4l2request) and the v4l2 layer falls back to soft decoding. I also tried now mpv but just with null output (as it can't fbdev) and captured the debug trace like so mpv Big_Buck_Bunny_720_10s_10MB.mp4 -vo=null --msg-level=all=trace [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] Opening decoder h264 [vd] Looking at hwdec h264-drm... [vd] Could not create device. [vd] No hardware decoding available for this codec. [vd] Using software decoding. no hw accel used! I also captured a ffmpeg trace. ffmpeg -v trace -re -hwaccel drm -i Big_Buck_Bunny_720_10s_10MB.mp4 -f null - Maybe its in fact a duo2 only device tree related? Could someone try the same on any other H3 and provide thr results? If it really works with hwaccel and the org. 30fps I would like to have the trace logs, ideally the ffmpg* or both. lsmod | grep ced sunxi_cedrus 40960 0 v4l2_mem2mem 16384 1 sunxi_cedrus videobuf2_dma_contig 16384 1 sunxi_cedrus videobuf2_v4l2 16384 2 sunxi_cedrus,v4l2_mem2mem videobuf2_common 45056 5 sunxi_cedrus,videobuf2_dma_contig,videobuf2_memops,v4l2_mem2mem,videobuf2_v4l2 videodev 188416 3 sunxi_cedrus,v4l2_mem2mem,videobuf2_v4l2 mc 36864 5 sunxi_cedrus,videobuf2_common,videodev,v4l2_mem2mem,videobuf2_v4l2 *ffmpeg has been installed from below as the compiled 8x throws errors with -hwaccel. # Install the precompiled # ffmpeg version 5.1.6-0+deb12u1 Copyright (c) 2000-2024 the FFmpeg developers # built with gcc 12 (Debian 12.2.0-14) # https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/ # As root, no sudo # APT REPOSITORY SETUP wget http://apt.undo.it:7242/apt.undo.it.asc -O /etc/apt/trusted.gpg.d/apt.undo.it.asc . /etc/os-release && echo "deb http://apt.undo.it:7242 $VERSION_CODENAME main" | sudo tee /etc/apt/sources.list.d/apt.undo.it.list echo -e "Package: *\nPin: release o=apt.undo.it\nPin-Priority: 600" | sudo tee /etc/apt/preferences.d/apt-undo-it # We only install ffmpeg. mpv doesn't work anyway with framebuffer # INSTALL FFMPEG AND MPV PACKAGES apt install ffmpeg
  24. I was just wondering if there would be an issue because of different U-Boot and kernel combination in the 2 tests, but that does not seem to be the case. I think there might be some issue with the controller in the eMMC module that is starting to reveal when wear-level is or is getting higher. What fsck commands are done? So how is it fixed and is it fixed or is only metadata corrected and might there be corrupted data-blocks still without knowing. I don't use Ext4, I use Btrfs for rootfs and all other storage devices. In doubt, I use DUP profile for meta data, that is more for HDDs. As said Btrfs allows adhoc or regular scrubs, you will be able to detect where corrupt blocks are if that is the issue. It also might be that there is an issue in the 6.6 kernel that reveals itself when higher write delays or so, maybe update the OS. Maybe mmc-utils can show some issue (I have no experience with it).
  25. reopening after moving to "Software / Applications / Userspace"
  26. You realized the wrong thing: the topic is actual but this is not a forum where to discuss about Android or stock firmwares
  27. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
ร—
ร—
