  2. I got my Orange Pi 5 out of the drawer today and discovered that it would not boot from NVMe after armbian-install if I used btrfs, but it boots fine with ext4. I tried both the Minimal/IOT Ubuntu 24.04 and 25.11.1 Trixie Minimal/IOT images with 6.1.x kernels. (I updated each to 25.11.2 before doing the armbian-install of both the system and the mtd image.) P.S. A minor quibble, but it was annoying that the numbering of the continents/countries during setup and the ordering of the SPI bootloader options during armbian-install were different between the Trixie and Noble images. I had to actually read. 🙈
  3. @Octavio Cuatrochio, you need root privileges to modify any partition at runtime. If you want to modify firmware, get update.zip to your PC, modify it, and flash using android's Settings->About->Local update.
  4. Hello. Im trying to configurate and adapt OrangePI Zero 2W board to a custom extension board with multiple RS485 drivers. For now, im trying to configurate a single secondary UART (UART2) to initialize with muxed Rx\Tx pins and in RS485 (with software driven RTS pin). My current DT overlay is: And it is partially works. Works as UART. Able to send and receive data with muxed Rx\Tx. For RTS... its complicated. Seems RTS(PH4 GPIO) are initialized and acquired by UART2 software, and stay low during initial idling. After im trying to send any data (echo 123 >> /dev/ttyS2), RTS goes HIGH and stuck in this state before reboot. Im have tried to send big blob at 9600 and check the RTS with statserial. But as i see, RTS is 1 (active???) from inital to complete and after, and never changes.
  5. Never heard of that spelling "ip_tables". Anyway should be built in: https://github.com/armbian/build/blob/4e027a40d6d38d5e9072577a7e47b110914a843d/config/kernel/linux-qcs6490-edge.config#L421
  6. When attempting to install microk8s, I noticed that the `ip_tables` module is missing from the provided image (Ubuntu 24.04 (Noble) Minimal / IOT image) on this page: https://www.armbian.com/radxa-dragon-q6a/ Easy way to replicate: ``` sudo modprobe ip_tables modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.18.0-rc6-edge-qcs6490 ``` Is there another image that has this module are part of the kernel or do I need to build the kernel myself? This seems like a module that should be included for an image that is labeled as `IOT`.
  7. Today
  8. Thanks for the suggestion, but it didn't work for me. Both /var/log/postgresql and /var/log.hdd/postgresql reverted to their pre-intervention ownership and permissions when I rebooted.
  9. I am glad you made the LCD work with a DRM driver Three clarifications: the driver panel-mipi-dbi is provided in the OS image you write in the microSD. The DTS is something you get from this thread, and install it with armbian-add-overlay. Kungfupancake provides a txt or a bin file that defines the configuration sent to the LCD, when the kernel driver starts, and instructions on how to install it. The panel-mipi-dbi driver (the recent versions I tried) does not support X11, and you need 100% Wayland, and 0% X11 See my thread to install rpi-greeter (one of the 2 login managers that work with Wayland), and Labwc:
  10. Yesterday
  11. Those are super cheap maybe a dollar if shipped from Asia and an absolute essential tool for debugging. Get yourself one. http://debug.armbian.de
  12. Hello and thank you for the problem report. What solution did orangepi.org provide for you? As you can see, nobody in the Armbian community was interested to step up and support this board and from what I have heard through the grapevine this is because of the poor support that orangepi.org gives to FOSS projects and communities such as armbian.com. Armbian has already pushed another update for Sunxi64. Maybe you are in luck and the problem is already fixed. If not, we are happy to accept a PR once orangepi.org has published a solution.
  13. @Mohammad Adel here are some links that will help you. Find your Dram settings https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-218660 Find boot.bin and extract dts. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-187672
  14. I find the lack of GRUB via HDMI too problematic, so I put EDK2-UEFI v1.1 in eMMC again. I needed to wipe it completely, just writing the part without partition table normally done for U-Boot kept using the 2025.10 U-boot that was written there. I do not know how that comes. I know EDK2-UEFI v1.1 will divert to SD-card, so I though I use that to test U-Boot again. - blkdiscard SD-card - write U-Boot SPL 2026.01-rc2_armbian-2026.01-rc2-S365a-Pb445-He3cc-V062a-Bbf55-R448a (Dec 03 2025 - 04:31:42 +0000) to it - type reboot After restart and desktop login no HDMI audio. Kernel log showed long series of audio driver related errors - shutdown and pull USB-C powerplug - plug it in again and let it boot - then no audio error and also hear a 'plop' in the monitor that means the audio is enabled/working So it seems something does not reset correctly, so powercycle needed, while HDMI monitor is kept powered and HDMI cable stays connected all the time. What is different now: - kernel 6.18.0-edge-rockchip64 - eMMC contains EDK2-UEFI v1.1 and passes control/boot to SD-card U-Boot But I think it is the powercycle that is the key thing. An interesting new feature of the 2026.01-rc2 U-Boot is that the CPU clock go down to 480 MHz when mainline kernel, was 1GHz. Is not lowering idle power though, is 3 W, is 1.5 W with vendor kernel. Not clear why that is.
  15. Yes, One/some/all of those kernel configs may be needed for analog audio. Start with the activating configs that correlate with the missing kernel modules * snd_soc_sunxi_machine * snd_soc_sunxi_ahub * snd_soc_sunxi_ahub_dam If it still doesn't work, activate all the 2 other linux kernel configs: internalcodec and aaudio
  16. That's good news You are using lightdm with the default greeter GUI, right? That means that your LCD driver can support X11. Are you still using adafruit,yx240qv29? Maybe the lightdm service is getting confused about which display to use. What do you get with: $ ls /dev/fb* ? Make sure that you don't connect an HDMI LCD at the same time. Which desktop(s) do you use? XFCE and Gnome?
  17. @Malay Your board isn't a board supported by Armbian. It is status "Community Support" which means there is no maintainer for the board and it is people like you from the user community submitting PRs that keep it active.
  18. For anyone experiencing similar issues with the Luckfox Lyra Ultra W and installing the Armbian firmware, I compiled Ubuntu 24.04.3 from this repository - https://github.com/markbirss/rk3506-ubuntu Initially, it lacked kernel-level support for many programs. I rebuilt the kernel with this support, and now Docker works perfectly. The firmware is good, and I think it will help many at this stage. For now, I really hope the Armbian firmware developer fixes the broken firmware (although I'm not sure, as they're unfortunately almost unresponsive to my messages). Download Ubuntu 24.04.3 with Docker support for the Luckfox Lyra Ultra W - https://disk.yandex.ru/d/PlIW_k9Ma3i5aA Username: root Password: root sudo apt update passwd sudo adduser ++++ sudo usermod -aG sudo ++++ sudo apt install apt-utils iptables bluez cifs-utils wget curl dbus mc git curl curl -fsSL get.docker.com | sh Setting up WiFi via USB connection of the board to the computer and launching the adb server - https://wiki.luckfox.com/Luckfox-Lyra/Login adb shell "cd /home/lyra/aic800/ && make install; reboot" #test adb shell nmcli dev wifi list #connect nmtui Good luck!
  19. @MMorales@mmie4jbcu i have the same x88 pro 20 clone like you guys, on the pcb is written "x88pro-rk3566-4d32-v1.0", which should state for 4gb ddr and 32gb rom i guess? I installed latest armbian for station m2 with image-included demo-box.dtb, everything is working so far, despite bluetooth (CDtech-208821C=RTL8821CS). installed armbian-firmware-full but bt still doesn't work. Maybe usefull for just Linux-Users (i don't have a windows pc): original loader didn't allow me to boot from sd-card, rkdeveloptool (or xrock or rdeveltool-gui) didn't work for me, so i used proprietary upgrade_tool for linux from rockchip: https://docs.radxa.com/en/zero/zero3/low-level-dev/upgrade-tool I downloaded this loader from radxa https://dl.radxa.com/rock3/images/loader/rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin and flashed it with: sudo ./upgrade_tool wl 0x0 rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin After that i put in the sdcard and it bootet straight (wait for min. 5 seconds) to armbian!
  20. Made some progress today. For debugging, I built my own image with the Edge kernel (6.18). However, this time, the board did not even boot up and there was also no signal on HDMI. The last idea I had was to downgrade the kernel using armbian-config. But since the Ethernet is not working, I was trying to setup WiFi because armbian-config was trying to load apt cache but without internet, I cannot load anything. After multiple reboots, I slowly cached the apt. Then the armbian-config loaded. I downgraded the kernel from 6.12.60 to 6.6.63 and then the Ethernet started working fine! ☺️ Current version: $ uname -a Linux rockpi.dev.com 6.6.63-current-rockchip64 #2 SMP PREEMPT Fri Nov 22 14:38:37 UTC 2024 aarch64 GNU/Linux $ lsb_release -a Distributor ID: Debian Description: Armbian_community 26.2.0-trunk.44 trixie Release: 13 Codename: trixie I am now confident that somewhere after Kernel 6.6, the Ethernet is broken in Rockpi 4B.
  21. That's not really possible either. The only thing that is possible is using my kernel build in Armbian environment to see how it is performing for you. With my jumpstart image, this is actually quite easy to implement. For this, both root filesystems just need to be mounted and extlinux/prepare-jump-start ${target-rootfs-mount-point} needs to be executed in the jumpstart rootfs. If the target system is now being booted with firmware that uses mainline U-Boot as the payload, nothing stands in the way of booting with my kernel. And don't worry, prepare-jump-start only adds files to the target rootfs. Nothing will be overwritten or deleted. If you want to give it a whirl, speak up and I will upload a current image. But you will be disappointed, because the stock kernel only provides the functionalities available with the officially released kernel. Both Armbian and my kernel build have already applied patches that may appear in a future official release. I doubt that you will succeed, because even the fedora organization only does a full rebuild once per release cycle. There is no advantage in rebuilding a component unmodified that leads to the same result as the package already provided. It only makes sense to do this when branching off the release version in order to create a synchronized basis for further development. Only modified packages will be replaced or upgraded. My weekly upgrade gives me several gigabytes of new packages each time because I'm on Rawhide. Somehow, I can no longer manage to stick to any official release versions.
  22. Maybe a handful, I have most SBC's equipped with one permanently. And needed for Arduinos etc, you can even power tiny old things like RPI0/1 with it (if you connect red wire to 5V pin as well). In the meantime, you might think about some previous U-Boot and previous kernel. For quite some SBCs, there is trouble when U-Boot is new/mainline/releasecandidate and kernel vendor. I am currently also doing some tests on my NanoPi-R6C (RK3588s) because HDMI is not initialized fast enough (by U-Boot). And with 6.1.115 vendor kernel really choppy mouse updates and green tint, not complete flat green luckily, I can still see icons and mouse.
  23. Hey @Sergey Lepeshkin, thanks for the fast reply. I will check what you mentioned. I was thinking, could i modify the recovery.zip from the recovery partition so when it reflashes it gives the box "su" rights? that would be via software and no need to connect wires. If my idea is not possible, i will keep trying with the UART. Thanks for the advice.
  24. Nothing is working and the device did not boot sun50i-h313-tanix-tx1.dtb sun50i-h313-x96q.dtb sun50i-h313-x96-q.dtb sun50i-h313-x96-q-lpddr3.dtb sun50i-h313-x96-q-v5.1.dtb
  25. I managed to run Armbian, everything seems to work except the WiFi, which is module KM3306005. Any idea how to fix it?
  26. I'll have to order a USB serial cable based on CH340. Give me a few days and I'll have those logs for you.
  27. Thank you for the kind words.
  28. I find this forum very interesting. There's a lot of useful information here.
