I finally got wifi working on a fresh install of 24.5.1. Video acceleration is working perfectly in Chromium but I am not having any luck playing h264 mp4 videos with hardware acceleration in vlc or mpv. Is this possible or am I missing something? CPU is around ~30% with chromium playing 4k youtube but if I play one of my mp4 files it's a solid 130%
> Back in March I ran into problems with the community builds for the NanoPi Neo, for Debian Bookworm. It would boot up initially, > but within 30 minutes or so, it would crash. So I did a fresh install from the last official build I had saved from June 2023: > Armbian_23.5.2_Nanopineo_bookworm_current_6.1.30 Dear @dave3 I had the same problem with my three NanoPi Neo2 (the H5 version of the Neo) I went for the (latest) 6.1.36 image and did also the freeze kernel/firmware (now they are running cool/stabe:
Maybe. However nothing we could do anything about.
ARMBIAN 5.34 for Orange Pi One
Werner replied to Hyun Choi's topic in Software, Applications, Userspace
https://archive.armbian.com If it is not there its gone. -
Can I get orange pi one ARMBIAN 5.34 version? We developed a product based on orange pi one ARMBIAN 5.34 and need to modify it but I can not find this version. Kindly let me know.
The sound patches have now been implemented in Armbian current and edge. The community images for orangepizero3 are only updated once a week. So either wait for a new image or build one yourself from Armbian build on github.
- 25 replies
- Banana Pi M4 Zero
- Orange Pi Zero 2
(and 1 more)
Tagged with:
I don't think I've ever tried to connect the NanoPi to the PC to access the SD card. I didn't know there was such a thing. I just use a usb SD card adapater.
it is alone in 6.8 dir :) View the full article
Hi, it is strange, I'm in Czech republic on Vodafone network. It really doesn't work. So I have tried to connect over my mobile phone and now it work fine. Can be some problem with routing on my provider? apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://security.debian.org bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Err:5 http://imola.armbian.com/apt bookworm InRelease Could not connect to imola.armbian.com:80 (93.103.15.56), connection timed out Reading package lists... Done Building dependency tree... Done Reading state information... Done 11 packages can be upgraded. Run 'apt list --upgradable' to see them. W: Failed to fetch http://apt.armbian.com/dists/bookworm/InRelease Could not connect to imola.armbian.com:80 (93.103.15.56), connection timed out W: Some index files failed to download. They have been ignored, or old ones used instead.
guys anyone willing to help with tv-out drivers for $? many thanks in advance!
I have a "G96 mini" box that is bricked, I don't know its history but wrong firmware is a likely candidate- It contains a RK3228A and 08emcp08-el3cv100 ram & flash in a single chip. After some investigation I found how to boot from SD, boot in maskrom mode and access it with AndroidTool and capture the serial messages. I found very little info about this specific box, only that looks similar to the H20 mentioned in this thread: I tried all the bootloaders I could find including multitool-1.11 and the armbian indicated in that thread and this is what happens: DDR Version V1.11 20200910_dbg In ID:0xFFF unknow device ERR Another older bootloader I found around there seems to go a step further: DDR Version V1.06 20171130_1_xintu_en_rd_odt In 300MHz LPDDR3 Bus Width=32 Col=11 Bank=8 Row=14 CS=1 Die Bus-Width=32 Size=1024MB mach:4 rd addr 0x60000004 = 0xE0808004 ERR Do you think it requires some special customized bootloader or is it that the RAM is not working properly? Thanks in advance,
NanoPi Neo2 login stuck past entering user/password after Update
guidol replied to guidol's topic in Allwinner sunxi
I dont know was it was - with updated armbian (with Kernel 6.7.12-edge-sunxi64 or 6.6.31-current-sunci64) I do get a high cpu load and couldnt login anymore. Because of the CPU load the temperature gets high as 73-89 degree celsius Because I could login or find a error (maybe the installation is too old or too mich times updated) I didi go the way of fresh install, but had to avoid to much kernel/firmware to kernel 6.6.31-current-sunxi64.... So I ended in reinstalling all my 3 Neo2 as base-system with Armbian_23.11.1_Nanopineo2_bookworm_current_6.1.63 (latest full cli-image for bookworm for download) After initial setup (user/passwd/timezone) I did freeze kernel/firmware in armbian-config. Then updated via apt update/upgrade to Welcome to Armbian 24.5.1 Bookworm with Linux 6.1.63-current-sunxi64 With that my 3 Neo2 do work stable at 43 degree Celsius (when my room is at around 29 degree celsius) - like it was before the critical update. because they are mostly samba-servers (in theit siler aluminum-case) it should'nt be a problem to use only this kernel. When it works - it works - never change a running system login as: root root@192.168.6.22's password: _ _ ____ _ _ _ ____ | \ | | _ \(_) | \ | | ___ ___ |___ \ | \| | |_) | | | \| |/ _ \/ _ \ __) | | |\ | __/| | | |\ | __/ (_) | / __/ |_| \_|_| |_| |_| \_|\___|\___/ |_____| Welcome to Armbian 24.5.1 Bookworm with Linux 6.1.63-current-sunxi64 No end-user support: community creations System load: 6% Up time: 1 min Memory usage: 22% of 482M IP: 192.168.6.22 CPU temp: 43°C Usage of /: 14% of 15G storage/: 2% of 229G storage temp: 40°C RX today: 158.1 MiB [ Kernel and firmware upgrades disabled: armbian-config ] Last check: 2024-06-05 22:23 [ General system configuration (beta): armbian-config ] Last login: Wed Jun 5 22:06:23 2024 from 192.168.6.17 root@npineo2-22:~# -
All Armbians with Kernel 6.8.x woun't start on Radaxa Rock 5b
Igor replied to Tomogo's topic in Radxa Rock 5B
Kernel 6.8.y is hit and miss. We need to separate download links somehow ... for now it was added "Kernel 6.8.y is at experimental support level! Not all features work but it runs fairy stable." to warn you. Its good to be there, as they are usable - where they work. I run several github runners on Rock5 without any troubles for months. -
This is probably some (temporally) network issue. Infrastructure shows no signs of troubles.
status of armbian-configng?
Igor replied to jimg's topic in Framework and userspace feature requests
This. I think the shell / concept is done and adding this should already be possible, but from scratch. We try to get rid of that old spaghetti code that is in old armbian-config. I am not very up 2 date on what is going on there. @Tearran and @schwar3kat are trying hard to push it further and perhaps they can give you some hints how to add this section. Yes. That the idea. -
apt.armbian.com is published at point releases, from this branch https://github.com/armbian/build/tree/v24.05 If you check it out, you will get identical what is on stable repository. If you want to go manual way, here https://github.com/armbian/build/blob/v24.05/config/sources/git_sources.json are information about sources. beta.armbian.com is published every x hours from trunk https://github.com/armbian/build If you want to see how this is done, peek into this code. Kernel 6.8 and 6.1 are very very different. Don't expect 6.8 to work better or that all functions will work. Some are not even developed - it is being developed from scratch for around two years now. Code is changing fast, so there is not possible to provide any support. Its too expensive and useless. If you want dig in, but expect troubles and very little response as not many people deal with. 6.1 is different. All 3588 share same problems ... more or less and there is a lot of support in forums.
Tomogo replied to Tomogo's topic in Radxa Rock 5B
Hi, I hate you (sorry just joke) 🙂 I have no UART to USB cable so I found old Teensy 3.2 board. Made program for Serial to USB bridge. Updated SPI flash with new firmware with debug mode. And.... It works now! Dam or huray... 😉 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB Manufacturer ID:0x6 CH0 RX Vref:27.5%, TX Vref:25.8%,25.8% CH1 RX Vref:25.8%, TX Vref:25.8%,25.8% CH2 RX Vref:27.9%, TX Vref:24.8%,24.8% CH3 RX Vref:27.1%, TX Vref:24.8%,24.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28) Trying to boot from MMC2 MMC: no card present mmc_init: -123, time 0 spl: mmc init failed with error: -123 Trying to boot from MTD2 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK ## Checking uboot 0x00200000 ... sha256(25a398ffe0...) + OK ## Checking fdt 0x0031e9f8 ... sha256(5bee414074...) + OK ## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK ## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 489.724/719.766 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45 NOTICE: BL31: Built : 10:11:21, Dec 27 2023 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28 +0800) Model: Radxa ROCK 5B MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 16 GiB Sysmem: init Relocation Offset: eda3f000 Relocation fdt: eb9f96c0 - eb9fecc8 CR: M/C/I Using default environment DM: v2 mmc@fe2c0000: 1, mmc@fe2e0000: 0 Bootdev(assign): mmc 0 MMC0: HS400 Enhanced Strobe, 200Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Radxa ROCK 5B MPIDR: 0x81000000 CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... No working controllers found USB is stopped. Please issue 'usb start' first. MMC: no card present mmc_init: -123, time 0 pcie@fe150000: PCIe Linking... LTSSM is 0x0 pcie@fe150000: PCIe Linking... LTSSM is 0x0 pcie@fe150000: PCIe Linking... LTSSM is 0x6 pcie@fe150000: PCIe Linking... LTSSM is 0x210023 pcie@fe150000: PCIe Link up, LTSSM is 0x230011 pcie@fe150000: PCIE-0: Link up (Gen3-x2, Bus0) pcie@fe150000: invalid flags type! Device 0: unknown device Device 1: unknown device switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3920 bytes read in 8 ms (478.5 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0:1 172 bytes read in 8 ms (20.5 KiB/s) 26373283 bytes read in 112 ms (224.6 MiB/s) 32436736 bytes read in 142 ms (217.8 MiB/s) 163397 bytes read in 28 ms (5.6 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 26373219 Bytes = 25.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=8e000 Using Device Tree in place at 0000000008300000, end 0000000008390fff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory WARNING: could not set reg FDT_ERR_BADOFFSET. Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000) Total: 2321.467/3095.859 ms Starting kernel ... -
u-boot-radxa-rk3588/legacy: use 000.patching_config; fix boot from SD when combined with from-factory eMMC blobs (TEE mismatch) u-boot-radxa-rk3588/legacy: rewrite u-boot patches, no changes u-boot-radxa-rk3588/legacy: add 0000.patching_config.yaml and move all null-patches into dt and defconfig dirs as bare files DTs and defconfigs should be identical to their null-patch equivalents u-boot-radxa-rk3588/legacy: rewrite nanopc_t6_defconfig -- no changes CONFIG_REGULATOR_RK806=y seems a leftover that's not really used? u-boot-radxa-rk3588/legacy: rewrite nanopc_cm3588_defconfig -- no changes CONFIG_REGULATOR_RK806=y seems a leftover that's not really used? u-boot-radxa-rk3588/legacy: nanopc_cm3588_defconfig: disable OPTEE (for OOB working boot with from-factory blobs in eMMC) makes it compatible with vendor out-of-box blobs (which include TEE) in the from-factory eMMC Armbian itself doesn't ship TEE blobs when combining from-factory eMMC blobs with an Armbian SD card, TEE blobs are in practice found by u-boot but then proceeds to fail with optee api revision is too low disable OPTEE in defconfig fixes it, TEE isn't used in any way by Armbian u-boot-radxa-rk3588/legacy: nanopc_t6_defconfig: disable OPTEE (for OOB working boot with from-factory blobs in eMMC) makes it compatible with vendor out-of-box blobs (which include TEE) in the from-factory eMMC Armbian itself doesn't ship TEE blobs when combining from-factory eMMC blobs with an Armbian SD card, TEE blobs are in practice found by u-boot but then proceeds to fail with optee api revision is too low disable OPTEE in defconfig fixes it, TEE isn't used in any way by Armbian View the full article
Last week I attended the GStreamer spring hackfest in Thessaloniki to work on the PipeWire GStreamer elements and connect with the community. View the full article
@usual user@Efe Çetin it seem to work with i burned an sd card with the new compiled Armbian-unofficial_24.8.0-trunk_Orangepi5-plus_bookworm_legacy.5.10.160 image . I boot from the sdcard It seems to work as i have no crash copying a 250GB file between a usb ssd and the mvne. I'm trying now memtester 31G. ... ... trying mlock ...Killed BUT not crash trying memtester 30G is working ... ... and it does not crash. @Efe Çetin Is it possible to make the official release working for the 32Gb version ?
Since a board with 16G RAM practically has a little less than 16 GiB RAM, probably mem=16G limits it a little too less to prevent the crash 100% reliably, while mem=15G would do. I don't know how exactly those limits are applied, and at which point exactly the power usage of the RAM raises above the critical point (in case really this is the reason for the crashes), so this is just a guess which can be tested.
