  2. See build log https://paste.armbian.de/lesoquheja The kernel works, but installing the .deb failed because my extlinux script could not copy: /usr/lib/linux-image-6.18.1-edge-sunxi/overlay/sun8i-h3-analog-codec.dtbo The whole overlay folder does not exist. It does exist for 6.12.58-current-sunxi and last time I compiled kernel for the nanopineo was 6.16.8, the overlays were created. I remember it was also once the case with edge kernel for other SBC ( .deb package from the Armbian beta repo). That time own local build did create overlays. I am not sure where to look or what could be wrong.
  3. Alright Did you ever make this LCD work with your H618 motherboard, with another kernel driver?
  5. I just registered here to say thanks to @bAL, your solution works on my Odroid HC4. I was bashing my head against the wall because I couldn't find what was constantly changing the fan PWM value even after disabling the fancontrol service. Now I finally have full control over the fan PWM (and thus the noise levels). Thanks again! So yeah, this issue is still relevant in 2025. `lsb_release -a` output for the interested: Distributor ID: Debian Description: Armbian 25.11.2 trixie Release: 13 Codename: trixie
  6. Odd. Should more look like this. Also the first time I hear there is an issue like this. Perhaps retry now since your group is no longer validation but members. https://x.na4.eu/KOTu3/PACoFIsE81.jpg
  7. Try the X11 windowing manager or the Wayland compositor without lightdm (or another display manager).
  8. Thanks @Werner for the button-descriptions, but I simply don't see anything you're describing. Tried in 2 different browsers (LibreFox, Chromium). It still says "P3ter: Validating" next to my "P"-Icon. Maybe I don't have the rights yet? LibreFox has NoScript on, but allowing from armbian.com - and chromium as test-browser has all scripts enabled: So it shouldn't be a script-blocker issue.
  9. @Jerry Falken I am pretty sure you jumped in this 3ad without reading all of it, and this is unfair . You are right, it is huge, but such question you ask have been already answered in the past many times , and I will answer just as a form of courtesy , but will not go back in the future on the same question again If you look at your board you can spot 3 pads : tx rx gnd . That is all is needed, no 5 volts just tx rx gnd Those pads are the "uart" , in other words there you will see ALL that happens when the board starts, if is a rk 322x or other fake print, if it is ddr3 or ddr2 manyyyyy manyyy infos to debug the whole process. For me it is a 3229 with ddr3 memory but uart will tell you Go find in the 1st post the speed of uart to use with putty or minicom ( spoiler :1500000 🙃 ) just for sake of coriousity, this si the setting I have in my lab: ALWAYS and I repeat ALWAYS a uart connected to debug what is going so if you need answer.. post the right questions and not generic ones g on
  10. Output of the USB TTL converter or of another chip? the one's I've seen online have 5 pins, but you only mentioned three places for the pins to go to, that is unless the 5v and 3.3v lines aren't needed for this specific use case. For curiosity's sake, what should i expect to see from something like that? I'll need to purchase that, so while it arrives, is there any chance that the CPU simply had an incorrect print, and i need another version of Multitool? Sorry for asking so many questions, just that i have little experience doing this.
  11. I've read your DXVK-stripped code on github. Looks like your code is far behind the original one. Is your code can match the release "stripped 2.7.1" libs you provide? Thanks you so much!
  12. @JuanEsf sunxi-edge is now on 6.18. You can add your patches for t527 there.
  13. I noticed that some games are using DXVK while some are using wined3d, what is the reason? It that a way that force every game using DXVK?
  14. Sure. However, I am in PRC, Google is blocked. I cannot login in on my SBC since I am using Google account to login. I have to use my laptop which has vpn. I will find a way this weekend.
  15. Do you mind sharing some screenshots + your settings ?
  16. Sorry I missed the "dxvk-stripped", Now it works fine! thank you so much!
  17. You should try other Kron4ek's Wine-Builds wine/proton versions. It's easier to set up!
  18. I am trying to use umu-launcher, using this cmd : umu-run "./VampireSuvivors.exe", the steamrt & wine did start up. However, it stucked in "g_proton.winserver_bin" and nothing happened.
  19. @Jerry Falken Never seen such board, you need usb-ttl converter , connect to tx-rx-gnd and grab the output
  20. You have to use umu-launcher https://github.com/Open-Wine-Components/umu-launcher
  21. How do you use GE-proton? I see no wine dir in the released tar.gz but a bunch of python script. When I try to run the "proton", comes out "Proton: No compat data path?"
  22. Hello, i have a screen thats bigger than what I could see (frame). on a raspberry, i change the config with overlay adjustment. But i dont know how to do this for the banana pi.. Someone Here could redirect me the rijgt pad where to fix it?
  23. HI, this setting isn't in your account settings but embedded in your profile. https://forum.armbian.com/profile/218842-p3ter There is a button at the bottom left of the "P" what is now your avatar. Also at the bottom right you should have buttons like "Edit Profile" or "Cover Photo".
  24. I have once again returned to this post in need of assistance. I have recently acquired from my tech wizard father a MXQ Pro 5G 4K TV box, which not even he managed to get working. According to him, its eMMC. Attached are photos of the motherboard, i did some looking at previous recent pages, so i have my suspicions, if someone though knows if this is a false print, or a just a freak motherboard please do tell. The problem itself is that it wont boot to the SD card, sometimes it will boot in sometimes not, but every time it boots if i try to access the files or sd card the Android freezes up. CPU: According to the print, RK3228A If any questions about any other components arise, please circle them in a photo because my knowledge on hardware electronics is limited.
  25. Yesterday
  26. @PH Ph You need to find the correct GPIO# for your emmc. Extract the boot.bin from your original Android to get the device tree (DTS). Follow the steps in this link. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-187672
  27. Hi everyone! I'm obviously new here, and I simply wanted to give my profile a picture, but failed to find that option in the "profile > account settings". I assume it's easy, and to be honest I like to take the time to ask a real person here. Is there an option to upload an avatar image? Thank you!
  28. I will definitely look into that. "mplayer -vo fbdev2:/dev/fb0 videofile.mp4" with desktop disabled worked perfectly by the way, no issues. I've used both X11 and wayland though and also there is nothing in the logs which I find extremely weird. However I will look into it further the upcoming week, I am most definitely missing something.
