Using apt, sudo is needed, but you having to use sudo in your USERSPACE sounds like something has gone horribly wrong. AFAIK if you write an armbian image, then boot, log in with root and follow the installation script that should start (I think) it will ASK you to create your username etc and set up everything for you. It sounds like you did not do that, so your userspace (your ~/) never got created correctly with correct credentials. Or maybe you did not reboot and login as your user after the script created your user, but instead kept running as root and setting everything up on your system, witch then means it is all owned by root (sudo is needed). If this is the case, yes, you can take ownership easily by using a few commands, but that might not solve everything. I would recommend you restart from scratch, making sure everything is set up correctly.
@OttawaHacker This is a minimal build, probably it has no HDMI output. As @ag123 said, you need a serial cable to see output. Or you could access via SSH, looking at your router for DHCP address. Other option would be to use a build with desktop like this one, and apply patch the same way. Any way, pull request was already merged, so you can wait for next community release in a few days.
Hi @compent you're right, I'll try to write what I did to solve the problem. After these commands run sudo armbian-install - option 7 to flash mtdblock0 (bootloader install) - option 4 (to install system and boot from mtdblock0) choose nvme0n1p2 partition to install system After checking that when I rebooted it didn't start from nvme I did this I deleted the nvme ssd partitions with fdisk I copied the armbian image with SCP from another PC into a currently working installation folder on Microsd Finally with the DD command I copied the image to nvme Rebooted without micro sd and started from nvme with the fresh armbian image. At this point for future installations on nvme with the new armbian images I will only delete with fdisk and copy with the dd command using an image on microsd. I hope I was helpful. I'm sorry to say but the installation part of armbian-config is very confusing to me
@OttawaHacker connect to the board using a usb-uart (debug) serial dongle. the boot messages would normally show up there, or that if it booted to the prompt, you could login as root and run dmesg to see what goes wrong try also the other u-boot https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/ to see if that helps. there is a sequence of patches that needs to be applied and I've done that with my implementation. Unfortunately, in my case I hardcoded the 1.5GB memory as I found that for 1.5GB boards, the mainline u-boot incorrectly detected memory as 2GB or 4GB inconsistently. For once it says 2GB, then 4GB, then 2GB, and the algorithm would probe into the wrong memory size. so 'hardcoding' it ensures that it is 1.5GB no more / no less. you can use the distributed Armbian images https://www.armbian.com/orange-pi-zero-3/ and subsequently apply the u-boot patch from my repository. If you don't use dd , you can try using the python script that I've provided in my respository to patch u-boot into the image. Checkout instructions in my repository.
I found another example dtoverlay support for 1-wire subsystem on H616 devices https://github.com/orangepi-xunlong/linux-orangepi/pull/21 /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&pio>; __overlay__ { w1_pins: w1_pins { pins = "PC10"; function = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { onewire@0 { compatible = "w1-gpio"; pinctrl-names = "default"; pinctrl-0 = <&w1_pins>; gpios = <&pio 2 10 0>; /* PC10 */ status = "okay"; }; }; }; }; I will try used
May this tell you something? Edit: In my case, on the SD card the /boot folder is empty. So I don't know how to use DTS files. Also, a flash drive was plugged: sda1 device. I can see Armbian sees the internal memory of my device (mmcblk1p1...p2...) lsblk: NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 1 57,7G 0 disk └─sda1 8:1 1 57,7G 0 part /media/chad/New Volume mmcblk1 179:0 0 14,7G 0 disk ├─mmcblk1p1 179:1 0 4M 0 part ├─mmcblk1p2 179:2 0 4M 0 part ├─mmcblk1p3 179:3 0 4M 0 part ├─mmcblk1p4 179:4 0 4M 0 part ├─mmcblk1p5 179:5 0 4M 0 part ├─mmcblk1p6 179:6 0 1M 0 part ├─mmcblk1p7 179:7 0 64M 0 part ├─mmcblk1p8 179:8 0 96M 0 part ├─mmcblk1p9 179:9 0 384M 0 part ├─mmcblk1p10 179:10 0 384M 0 part ├─mmcblk1p11 179:11 0 16M 0 part ├─mmcblk1p12 179:12 0 1M 0 part ├─mmcblk1p13 179:13 0 4G 0 part └─mmcblk1p14 179:14 0 9,7G 0 part mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk mmcblk0 179:96 0 29G 0 disk ├─mmcblk0p1 179:97 0 256M 0 part /boot └─mmcblk0p2 179:98 0 28,4G 0 part /var/log.hdd / zram0 254:0 0 989,3M 0 disk [SWAP] zram1 254:1 0 50M 0 disk /var/log df -h Filesystem Size Used Avail Use% Mounted on tmpfs 198M 6,3M 192M 4% /run /dev/mmcblk0p2 28G 4,7G 23G 17% / tmpfs 990M 0 990M 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 990M 12K 990M 1% /tmp /dev/mmcblk0p1 224M 122M 92M 58% /boot /dev/zram1 47M 1,6M 42M 4% /var/log tmpfs 198M 104K 198M 1% /run/user/1000 /dev/sda1 58G 28G 31G 48% /media/chad/New Volume blkid /dev/mmcblk0p1: LABEL="armbi_boot" UUID="b7da92dc-e8d6-4f98-bc78-2c2d26cb0e58" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="bootfs" PARTUUID="5ebaa50c-e6a2-ef4b-bdc0-42959c284dac" /dev/mmcblk0p2: LABEL="armbi_root" UUID="15ad00eb-944a-4829-8ff0-a0d0b211226c" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="a6783103-918f-fc44-b9ba-b8c9fc8915e4" /dev/mmcblk1p11: UUID="c6ed55dd-55ba-4fb3-81ed-e341a836e379" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="metadata" PARTUUID="015f0000-0000-4131-8000-2af900001415" /dev/mmcblk1p14: UUID="4548798e-a22e-48de-8b75-9fcbd508481a" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="userdata" PARTUUID="216e0000-0000-471b-8000-1139000006f0" /dev/mmcblk1p10: UUID="d90fb683-12be-438a-a851-85bb4899d594" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="cache" PARTUUID="a1470000-0000-4b4a-8000-335e00002f47" /dev/zram0: UUID="f4ddf41e-a476-410c-927e-7d1ad4814472" TYPE="swap" /dev/zram1: LABEL="log2ram" UUID="e37fe586-baaf-498e-980e-cdd667b954c2" BLOCK_SIZE="4096" TYPE="ext4" /dev/mmcblk1p3: PARTLABEL="trust" PARTUUID="d1630000-0000-4261-8000-78e300006a8d" /dev/mmcblk1p13: PARTLABEL="super" PARTUUID="78170000-0000-462e-8000-351f00003b21" /dev/mmcblk1p1: PARTLABEL="security" PARTUUID="72340000-0000-4939-8000-1a3d00005715" /dev/mmcblk1p8: PARTLABEL="recovery" PARTUUID="b2460000-0000-455b-8000-592d000036b6" /dev/mmcblk1p6: PARTLABEL="vbmeta" PARTUUID="4e6c0000-0000-4d7e-8000-1fcf000040fc" /dev/mmcblk1p4: PARTLABEL="misc" PARTUUID="357e0000-0000-4575-8000-0005000045d9" /dev/mmcblk1p2: PARTLABEL="uboot" PARTUUID="28010000-0000-4b3f-8000-3b8d00007f0e" /dev/mmcblk1p12: PARTLABEL="baseparameter" PARTUUID="5b6c0000-0000-424a-8000-6fa2000072f0" /dev/mmcblk1p9: PARTLABEL="backup" PARTUUID="74600000-0000-4a1e-8000-3b0700007340" /dev/mmcblk1p7: PARTLABEL="boot" PARTUUID="927d0000-0000-4354-8000-060700007162" /dev/mmcblk1p5: PARTLABEL="dtbo" PARTUUID="1c5d0000-0000-4b75-8000-66bb0000653c" /dev/sda1: LABEL="New Volume" BLOCK_SIZE="512" UUID="2070DF2870DF0406" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="17cffda1-bd82-44b9-8fc4-6e7175882b3a"
Description Please include a summary of the change and which issue is fixed. Please also include relevant motivation and context. List any dependencies that are required for this change. Jira reference number [AR-9999] Documentation summary for feature / change Please delete this section if entry to main documentation is not needed. If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer: [ ] short description (copy / paste of PR title) [ ] summary (description relevant for end users) [ ] example of usage (how to see this in function) How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [ ] Test A [ ] Test B Checklist: Please delete options that are not relevant. [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
I'm trying to do this but my /boot folder is empty. I used the exact same version you mentioned: Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop Was it moved to another folder?
So I managed to extract .dtb files from uboot.img using this extract-dtb tool. Later on, on a PC running Ubuntu 22.04 LTS I used "device tree compile" to decompile thos dtb files into dts files. I followed this article trying to use those DTS files to get the correct hardware informatin and/or drivers, but the /boot folder in the flashed SD card is empty. Probably, as the article says, dtb overlay is not activated in this image. -
I tried the uboot with the same image you mentioned. Something is definitely happening, I see red and green lights flashing however there is nothing on my hdmi output, no shell or nothing else. Am I missing something?
@OttawaHacker you could try the images from here: https://www.armbian.com/orange-pi-zero-3/ and to patch the u-boot into the image from here https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/tree/main
I have this Rupa X88 13 TV BOX with also uses RK3528, I dumped many parts of firmware using a tool called rkdumper and managed to extract .dtb files using a tool called dtb-extract Maybe this can help you. I don't know how to use those files yet, but reading your post I think I have a hint now
@ag123 @OttawaHacker I submitted a pull request in order to add DRAM patch to community builds. Let's see how it goes...
Crashed.
https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first https://forum.armbian.com/topic/33676-installation-instructions-for-tv-boxes-with-amlogic-cpus
Hi, I'm doing some tests on my BTVe10 Box TV. I tried the image "Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11.img" with the dtb "meson-g12a-sei510.dtb" and it booted but the wifi didn't work. I used the command iwconfig and got the error "no wireless extensions". How can I make the wifi work?
Each code change represent danger that some feature out of tens of thousands will stop working. One bug is fixed, something else can and do break down ... Nobody knows when this happens as nobody can't test all features. Testing is expensive and we run this - for public good service - mainly with our private money. Since information does not exists, we will not be keeping list of working / not working features for you. Especially not if this require additional expensive manual work. I told you to verify with latest image from development as this might just work. You didn't and there is little we can do from here. If you didn't know, we provide users results of automated testing, which is sadly primitive and can't test complex functions as in this case, but it will stay that way as we have not enough support/interest from anyone (but everyone would like to have this info) If you need better info that this https://github.com/armbian/os?tab=readme-ov-file#latest-smoke-tests-results apply here: and start working for us as a full time volunteer. I know you will not, but this request is on same level as yours. So far, in one year, we didn't get anyone.
I am not your personal assistance. Orangepi (mainly as they are chepest) customers are demanding thousands of fixes, changes and improvements. Personally I can't answer to this and other thousands of issues that are found in code / text. I would love to but its impossible even as a team and I have to run the project and sometimes I chat on forums. Mainly for fun and providing hints. I can't be your partner in resolving your (clearly business) problem. I would love to, but Orangepi treat as not good and we treat their clients accordingly. Use other board and you will get help. Isn't that stupid? Yes, but this is one of ways we fight abuse that is targeted toward open source developers. In this segment of open source, there are things you might never experienced with your work in open source. Isn't it better to be open for other perspectives? I believe in yours. Perhaps this will give you a picture on resources you are addressing? You are not the only one that is requesting support. Our resources are 1/1000 of needed. We are developers, we maintain serious and complex system and we don't have much time for individual problems. Regardless if you think we should be more attractive. We can be, but then we have to kill R&D. Which is source of sorrow, frustration and costs. Why do you even try to be accepted over the line? And why you think this problem is important enough to be even discussed? Why don't you resolve a problem you find? And on and on. I told you already that we only loose if we fix a bug. We have competitors, that invest nothing, while they can provide the same. In order to catch them, we have to invest less and less. And be more attractive at the same time, agree with that. This means we should invest into sales a lot more, where again you know what has to suffer. Absolutely. We love that, me included. But I have to run this development on totally different level. If you would set our priorities, we would already be long dead. Imagine users, who in big majority have no clue about how much time some problem is needed, they don't care how many problems are already been worked on, what is team capacity, and on and on. Remember also that, at the end, support goes under "best effort" principle. If serious and life important problems are not done, your will wait. A week, month, year ... never. This is how it goes and this won't be changed. Not sure what you mean by that, but open source is like freedom.
Writing one sentence “our image is intended only for installation from SD” is not “more and more”. This doesn't require a second or third job, or month or years. Besides, being an open-source developer is your conscious choice, so why have you already repeated a hundred times that you have nothing to gain from it? If human impact is so important to you, do something that will bring it, instead of blaming me for something. Open source is a calling, not an excuse.
If you care so much about people not wasting time, documentation is open source, invest your time https://github.com/armbian/documentation and stop wasting my time. Our project is saving all of you years, not just months. And you still don't get it and want more and more. Remember that not you, not the one that generates problem contributes virtually nothing. Buy a PC, which works well with our product.
Владимир Владимиров replied to alienxz77b's topic in Allwinner CPU Boxes
My set-top box has an FX-618-D4_V10 board. The WI-FI chip is HK6334Q. WIFI started working when using the brcmfmac4334-sdio.bin driver and file brcmfmac4334-sdio.txt from the website https://github.com/LibreELEC/brcmfmac_sdio-firmware/blob/master/brcmfmac4334-sdio.bin . -
You don't understand what I'm talking about. I understand perfectly well what open source is, I have been dealing with it for 14 years. Including, sometimes I do something of my own. But if my product is not intended to be used according to the instructions for what it is based on, I write about it in big red letters so that people do not waste time on actions that are not designed for results. Is Orange Pi shamelessly stealing from Armbian? Apparently, they still came up with the phrase “the flashing manual is intended only for our images”, which helps save time without making unnecessary mistakes. And they have (not so fancy but) manual, by the way. What I am asking from you is not some kind of feat, or a "fancy manual", or something for which you need to involve PR. We are talking about the basic required minimum: if you want to attract people to your project, it must be attractive. At a minimum, attract by accessibility of use. It should at least run. If it not designed to be run using certain methods, (RkDevTool for example) just write one sentence about it right above the download link. If you suddenly have some kind of documentation, attach a link to it there. There's nothing complicated about it, no one forces you to write archwiki for each image. You can’t just do it "somehow", post it without the simplest explanation and justify it by saying that it’s open source. All Linux is open-source, and 99% of them either just work, or without a forum it’s clear how to make them work. Because it's just minimum.
