Orange Pi Lite. problem with latest firmware.
AlexTransit replied to AlexTransit's topic in Allwinner sunxi
Did not work out sudo dtc -@ -I dts -O dtb -o /boot/overlay-user/st7789.dtbo st7789.dts added user_overlays=st7789 to /boot/armbianEnv.txt after a reboot the log constantly writes May 10 08:18:48 vm00 kernel: fb_st7789v spi0.1: fbtft_update_display: write_vmem failed to update display buffer May 10 08:18:48 vm00 kernel: fb_st7789v spi0.1: write() failed and returned -22 May 10 08:18:48 vm00 kernel: fb_st7789v spi0.1: write() failed and returned -22 Probably dts running on the previous firmware is not suitable for this one. my knowledge is not enough i use one spi for external device and for display spi-dev uses cs=0 display uses cs=1 -
@Joko Christian For the archive, go to the image download page for the orangepione and look at the line just below the image icons. It would be very useful to know how your system is failing. Could you describe what is running on the machine at the time it fails? Please provide output of: sudo armbianmonitor -u
I can confirm that new armbian-firmware make instabilities. (orange pi one board, Linux 6.6.16-current-sunxi) can someone point out the location of repository (3rd party is ok) of previous armbian-firmware releases ? I need to downgrade it from version 24.2.1 to version 21
russians destroyed my town, Bachmut, I lost my home and all the boards I had and I can't afford buying one for now. I have an OSDev project - an NT-like (inspired) OS, that I'm writing for x64 and arm64. Now, the arm64 work happens only in the qemu virt machine. Having an rk3588 would be, of course, an awesome addition, not just because, it's a very powerful arm minicomputer, but also because there is an EDK2 port for it and I need especially such an arm machine! because ACPI and UEFI are requirements for the project. Also, I could use it for freelance work on arm tasks. I would be happy to get even a humbler board, like something with rk3566 on it, this SoC has also an EDK2 port. And this is a screenshot of the Loader for the OS. It's from qemu virt. just tested the font drawing this is without using GOP.Blt(), because, as said, it's for the kernel itself. First, to check the jump into kernel was successful, then for further development purposes and some "early" console.
After messing around with Android TV boxes, and trying to get them to run OMV, VPN, AltServer and Syncthing with unpredictable stability and poor performance has made me give up on having a perfect setup. This would completely change that and allow me to focus on testing and developing FOSS tools for Armbian
This is what I've been trying to say the whole time... I know many distros are small projects with no full time developers. I saw in this thread that it looked like you guys could use some help and given how new this board is I wasn't expecting anyone to just solve something for me. I wanted to jump in and help if and where I could. What did you expect? Truth or fake happiness and prompt resolving of your problem? The opposite literally. I figured that if I have the ability to help and hardware in hand that I should help (or at least offer to be a guinea pig) - I wasn't and haven't been looking for someone to solve this thing for me but literally offering my assistance as I happen to have the hardware and wanted to give back if I could. This whole conversation has felt like I've been gaslit by people who assume everyone posting for the first time on this forum must be demanding fixes for everything right now. That may be many (or even most) folks but it's not a great feeling when all you're doing is trying to offer help.
@sasa I tested with your patch and it gets rid of the error but also creates a new sound device. ahubdam, that has no input or output. I then just took the device creation out of the dtb and then there is no error even without the patch. Analog and HDMI audio still work. This is the piece removed from the dtb. ahub_dam_mach { compatible = "allwinner,sunxi-snd-mach"; soundcard-mach,name = "ahubdam"; status = "okay"; phandle = <0x3f>; soundcard-mach,cpu { sound-dai = <0x0e>; }; soundcard-mach,codec { }; };
- 14 replies
- Banana Pi M4 Zero
- Orange Pi Zero 2
(and 1 more)
Tagged with:
Thank youuu, this was helpful! However I still need some help (I'm beginner within linux) I mounted the boot partition but I have not permission to write on it. I booted Ubuntu 22.04 LTS on a x86 system (I permantly installed this version for Armbian compilnig ) Inserted SD card and opened up a Terminal and run the following: sudo mount -t auto -v /dev/sdd1 /mnt/Armbian_boot Where "/dev/sdd1" points to the SD card boot partition. (had to run lsblk with the inserted SD card to odentify it) Now I can open the mounted folder with "Files" app and navigate it. I can see the dtb/rockchip folder, and the ArmbianEnv.txt file. There is also a dtb-5.10.160-legacy-rk35xx/rockchip folder. When I try to put the 4 .dtb files I have into dtb folder (or 5.10.160-legacy-rk35xx folder), or inside Rockchip folder (in each case), I am not allowed. It says "Permissions do not allow pasting files in this directory" I can't either edit and save ArmbianEnv.txt file! I did some internet search and tried with this command: (chad is my user and Armbian_boot the mouted folder) chown -R chad /mnt/Armbian_boot or chown -R 775 /mnt/Armbian_boot And it says "Operation not permited" I checked the SD card is not physically write-protected (I'm using MicroSD to SD adaptor). What I'm missing?
Welcome! Remember that this is forum, not a professional technical support service that waits on problems. We are on the same side. Problems takes years to be resolved as there is nobody behind. They don't invest, you don't invest, we can't invest into support service you might with or expect. We didn't produce this hardware and manufacturer doesn't work with us. They almost literally throw hardware like bone to a dog. Armbian ultra small team have to deal with other things then this hardware / 3rd party (copy of) OS clients problems. Now you know. You came from a project that has bad reputation, you are using hardware from manufacturer that does not support open source software. They are not alone. More makers are abusing community to generate software, support and sales. But some genuine help and there our focus goes. Sometimes we made wrong judgements ... If you mentioned RPi. They are far from being modest example, but they are returning about 2M USD annually back to community. Here small dealers, who have no affection and understanding how non profit community works, are competing how well they will abuse this community. The more the more they will profit - that is why there is so much bad vibes here. Some are doing everything to optimise this abuse. Not talking just about Armbian, but developers community at large. No need to mention, that Dietpi is not a part of this game. They don't suffer as nobody never took anything from them in past 10 years. What did you expect? Truth or fake happiness and prompt resolving of your problem? With our private money and in private time? "Case number 125323". Perhaps weeks of research is needed. Not just trolling on forums? I believe you didn't know nothing about this and it feels me bad that I have to tell you this. But this is your problem too and I hope now you see why. If open source developers are not happy, you will not move them with anything. Just trying to draw you a bigger picture. Raspbian / RaspberryPi has IMO 20-30 full time engineers for supporting clients and they have classes easier job then we do. We have not a single one.
Ok well this has gone poorly with you guys... I really dont care about what OS I'm playing with - DietPi can apparently go **** themselves - cool, I'm not them - I'm just a dude who happened to be using it this morning but now I'm not... This seemed to be a discussion about kernel panics happening on the OPi5+ 32GB which I have and am experiencing no matter which OS I install and run a memtest on. They happen on Armbian too and you guys have a forum post that relates to my problem. Thus I am here. In terms of your beef with DietPi - would it make y'all feel better if I edit my posts and I started with Armbian all along? For the purposes of this discussion the originating reason why I came here really shouldn't matter if the result is the same on either OS. I honestly have no clue about your beef with DietPi (most of my experience comes from either raspbian or with non arm OSes - and OS politics is not my jam) and you've given me a negative vibe about them so I'll probably leave but at the moment I dont have a good vibe from Armbian either by how I'm being treated here. I came in with a good attitude offering up what I can in terms of help (and trying to follow the previous steps outlined in this thread). Can we get back on track talking about the issue at hand or am I just not going to get anywhere with you guys?
You might insult many people if you compare Armbian with Dietpi. They download Armbian (firmware is binary copy), run BASH script to re-brand, add their script junk and sell as "supported". When bug is found they say "oh, this trash Armbian", when someone say compliment, they take it. This is how piracy works in open source. Compliment and recognition of work is everything. They contribute nothing to Armbian, nor its possible to take anything. Where we would, as community, progress, if we would just steal and pretend? Board manufacturer is responsible to fix this problem. They know how and where change is needed. But ... they compete with OS we made with us. Are you sure, you are long enough around to see it all?
Nope - been around long enough to know each distro has it's own crap to figure out. I do eventually hope to see fixes applied downstream in DietPi whenever someone figures out what's going on but right now I'm just a person trying to help the community of OPi5+ folks with no agenda towards DietPi. If the 32GB model only works with Armbian so be it but right now it seems to have this issue (or related issues) across all of the OSes that I've tried/read. FWIW same issue on Armbian_24.2.3_Orangepi5-plus_bookworm_legacy_5.10.160_minimal But I think this was already known
Hi, In a bid to solve an issue with my NAS (which I now think was a dying HDD) I foolishly decided to upgrade from buster to bullseye and now most, if not all, of the services are failing to start - including network-manager, sshd and fancontrol so I only have access via the USB serial console. By setting a static IP I have been able to get it network access at least. When I try to start any of the dead services it hangs for a minute or so, then kicks me back to the login and the terminal is corrupted so I need to reboot before I'm able to do anything meaningful. (I am able to start fancontrol by just running `fancontrol` at which point the fans stop going at 100%, so I don't think there's a config issue there at least.) Please help! The upgrade was done with sudo sed -i 's#/debian-security bullseye/updates# bullseye-security#g' /etc/apt/sources.list sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*.list sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d.save/*.list apt full-upgrade root@helios2:~# cat /etc/apt/sources.list deb http://deb.debian.org/debian bullseye main contrib non-free # deb-src http://deb.debian.org/debian bullseye main contrib non-free deb http://deb.debian.org/debian bullseye-updates main contrib non-free # deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free deb http://deb.debian.org/debian bullseye-backports main contrib non-free # deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free # deb http://security.debian.org/ bullseye/updates main contrib non-free deb http://security.debian.org/debian-security bullseye-security main contrib non-free # deb-src http://security.debian.org/ bullseye/updates main contrib non-free root@helios2:~# cat /etc/apt/sources.list.d/* deb http://apt.armbian.com bullseye main bullseye-utils bullseye-desktop deb [signed-by=/etc/apt/trusted.gpg.d/gluster.gpg] https://download.gluster.org/pub/gluster/glusterfs/LATEST/Debian/10/arm64/apt buster main deb [signed-by=/etc/apt/trusted.gpg.d/gluster.gpg] https://download.gluster.org/pub/gluster/glusterfs/LATEST/Debian/10/arm64/apt bullseye main deb http://ppa.launchpad.net/gluster/glusterfs-7/ubuntu oracular main # deb-src http://ppa.launchpad.net/gluster/glusterfs-7/ubuntu oracular main It looks like ix.io is down right now so I can't share `armbianmonitor -u` root@helios2:~# uname -a Linux helios2 5.15.93-rockchip64 #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 aarch64 GNU/Linux root@helios2:~# systemctl status --all | grep dead -C 3 │ ├─1435 /sbin/sulogin │ ├─1436 bash │ ├─5144 systemctl status --all │ └─5145 grep dead -C 3 ├─dev-hugepages.mount └─system-getty.slice -- ● dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device - /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80 Loaded: loaded Active: inactive (dead) ● dev-disk-by\x2duuid-9b0108f1\x2d5a11\x2d4f24\x2dabd0\x2daebb458ebbd7.device - ST4000DM004-2CV104 1 Follow: unit currently follows state of sys-devices-platform-f8000000.pcie-pci0000:00-0000:00:00.0-0000:01:00.0-ata2-host1-target1:0:0-1:0:0:0-block-sda-sda1.device -- ● data-glusterfs-sda1.mount - /data/glusterfs/sda1 Loaded: loaded (/etc/fstab; generated) Active: inactive (dead) Where: /data/glusterfs/sda1 What: /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80 Docs: man:fstab(5) -- ● proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System Loaded: loaded (/lib/systemd/system/proc-sys-fs-binfmt_misc.mount; static; vendor preset: enabled) Active: inactive (dead) Where: /proc/sys/fs/binfmt_misc What: binfmt_misc Docs: https://www.kernel.org/doc/html/latest/admin-guide/binfmt-misc.html -- ● bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active Loaded: loaded (/lib/systemd/system/bootsplash-ask-password-console.path; enabled; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:45 BST; 23min ago └─ ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled was not met Unit apparmor.service could not be found. ● systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch Loaded: loaded (/lib/systemd/system/systemd-ask-password-console.path; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-ask-password-console.service(8) ● systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch Loaded: loaded (/lib/systemd/system/systemd-ask-password-wall.path; static; vendor preset: enabled) Active: inactive (dead) since Thu 2024-05-09 20:44:16 BST; 22min ago Docs: man:systemd-ask-password-console.service(8) Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable. -- ● apt-daily-upgrade.service - Daily apt upgrade and clean activities Loaded: loaded (/lib/systemd/system/apt-daily-upgrade.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:apt(8) ● apt-daily.service - Daily apt download activities Loaded: loaded (/lib/systemd/system/apt-daily.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:apt(8) ● armbian-firstrun-config.service - Armbian first run optional user configuration Loaded: loaded (/lib/systemd/system/armbian-firstrun-config.service; enabled; vendor preset: enabled) Active: inactive (dead) ● armbian-hardware-monitor.service - Armbian hardware monitoring Loaded: loaded (/lib/systemd/system/armbian-hardware-monitor.service; enabled; vendor preset: enabled) Unit auditd.service could not be found. Unit connman.service could not be found. Unit console-screen.service could not be found. -- ● bootsplash-ask-password-console.service - Dispatch Password Requests to Console when bootsplash is active Loaded: loaded (/lib/systemd/system/bootsplash-ask-password-console.service; static; vendor preset: enabled) Active: inactive (dead) ● bootsplash-hide-when-booted.service - Hide bootsplash after starting the system Loaded: loaded (/lib/systemd/system/bootsplash-hide-when-booted.service; enabled; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:44:16 BST; 22min ago └─ ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled was not met ● chrony.service - chrony, an NTP client/server Loaded: loaded (/lib/systemd/system/chrony.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:chronyd(8) man:chronyc(1) man:chrony.conf(5) -- ● cpufrequtils.service - LSB: set CPUFreq kernel parameters Loaded: loaded (/etc/init.d/cpufrequtils; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● cron.service - Regular background program processing daemon Unit display-manager.service could not be found. Loaded: loaded (/lib/systemd/system/cron.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:cron(8) ● dbus.service - D-Bus System Message Bus Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:dbus-daemon(1) ● e2scrub_all.service - Online ext4 Metadata Check for All Filesystems Loaded: loaded (/lib/systemd/system/e2scrub_all.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:e2scrub_all(8) ● e2scrub_reap.service - Remove Stale Online ext4 Metadata Check Snapshots Loaded: loaded (/lib/systemd/system/e2scrub_reap.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:e2scrub_all(8) ● emergency.service - Emergency Shell -- ├─1435 /sbin/sulogin ├─1436 bash ├─5144 systemctl status --all └─5145 grep dead -C 3 May 09 20:44:21 helios2 systemd[579]: emergency.service: Executable /bin/plymouth missing, skipping: No such file or directory May 09 20:48:11 helios2 sudo[1764]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/bin/apt info armbian-bsp-cli-helios64 -- ● fake-hwclock.service Loaded: masked (Reason: Unit fake-hwclock.service is masked.) Active: inactive (dead) ● fancontrol.service - fan speed regulator Loaded: loaded (/lib/systemd/system/fancontrol.service; enabled; vendor preset: enabled) Drop-In: /etc/systemd/system/fancontrol.service.d └─pid.conf Active: inactive (dead) Docs: man:fancontrol(8) man:pwmconfig(8) ● getty-static.service - getty on tty2-tty6 if dbus and logind are not available Loaded: loaded (/lib/systemd/system/getty-static.service; static; vendor preset: enabled) Active: inactive (dead) ● getty@tty1.service - Getty on tty1 Loaded: loaded (/lib/systemd/system/getty@.service; enabled; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/getty@tty1.service.d └─10-noclear.conf Active: inactive (dead) Docs: man:agetty(8) man:systemd-getty-generator(8) http://0pointer.de/blog/projects/serial-console.html ● glusterd.service - GlusterFS, a clustered file-system server Loaded: loaded (/lib/systemd/system/glusterd.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:glusterd(8) ● haveged.service - Entropy Daemon based on the HAVEGE algorithm Unit kbd.service could not be found. Unit lm-sensors.service could not be found. -- ● helios64-heartbeat-led.service - Enable heartbeat & network activity led on Helios64 Loaded: loaded (/etc/systemd/system/helios64-heartbeat-led.service; enabled; vendor preset: enabled) Active: inactive (dead) ● hostapd.service - LSB: Advanced IEEE 802.11 management daemon Loaded: loaded (/etc/init.d/hostapd; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● ifup@eth0.service - ifup for eth0 -- ● loadcpufreq.service - LSB: Load kernel modules needed to enable cpufreq scaling Loaded: loaded (/etc/init.d/loadcpufreq; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● logrotate.service - Rotate log files Loaded: loaded (/etc/systemd/system/logrotate.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:logrotate(8) man:logrotate.conf(5) ● man-db.service - Daily man-db regeneration Loaded: loaded (/lib/systemd/system/man-db.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:mandb(8) ● mountkernfs.service Unit ntp.service could not be found. Unit ntpsec.service could not be found. Unit openntpd.service could not be found. Unit plymouth-quit-wait.service could not be found. Unit plymouth-start.service could not be found. Loaded: masked (Reason: Unit mountkernfs.service is masked.) Active: inactive (dead) ● networkd-dispatcher.service - Dispatcher daemon for systemd-networkd Loaded: loaded (/lib/systemd/system/networkd-dispatcher.service; enabled; vendor preset: enabled) Active: inactive (dead) ● networking.service - Raise network interfaces Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled) -- ● NetworkManager.service - Network Manager Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:NetworkManager(8) ● rc-local.service - /etc/rc.local Compatibility Loaded: loaded (/lib/systemd/system/rc-local.service; enabled-runtime; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/rc-local.service.d └─debian.conf Active: inactive (dead) Docs: man:systemd-rc-local-generator(8) ● rescue.service - Rescue Shell Loaded: loaded (/lib/systemd/system/rescue.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:sulogin(8) ● resolvconf.service - Nameserver information manager -- ● rng-tools-debian.service - LSB: rng-tools (Debian variant) Loaded: loaded (/etc/init.d/rng-tools-debian; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● rpcbind.service - RPC bind portmap service -- ● rsync.service - fast remote file copy program daemon Loaded: loaded (/lib/systemd/system/rsync.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:rsync(1) man:rsyncd.conf(5) ● rsyslog.service - System Logging Service Loaded: loaded (/lib/systemd/system/rsyslog.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:rsyslogd(8) https://www.rsyslog.com/doc/ ● selinux-autorelabel-mark.service - Mark the need to relabel after reboot Loaded: loaded (/lib/systemd/system/selinux-autorelabel-mark.service; static; vendor preset: enabled) Active: inactive (dead) ● serial-getty@ttyS2.service - Serial Getty on ttyS2 Loaded: loaded (/lib/systemd/system/serial-getty@ttyS2.service; enabled; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/serial-getty@.service.d └─10-term.conf Active: inactive (dead) Docs: man:agetty(8) man:systemd-getty-generator(8) http://0pointer.de/blog/projects/serial-console.html ● ssh.service - OpenBSD Secure Shell server Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:sshd(8) man:sshd_config(5) ● sysfsutils.service - LSB: Set sysfs variables from /etc/sysfs.conf Loaded: loaded (/etc/init.d/sysfsutils; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● systemd-ask-password-console.service - Dispatch Password Requests to Console Loaded: loaded (/lib/systemd/system/systemd-ask-password-console.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-ask-password-console.service(8) ● systemd-ask-password-wall.service - Forward Password Requests to Wall Loaded: loaded (/lib/systemd/system/systemd-ask-password-wall.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-ask-password-console.service(8) ● systemd-binfmt.service - Set Up Additional Binary Formats Loaded: loaded (/lib/systemd/system/systemd-binfmt.service; static; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:46 BST; 23min ago ├─ ConditionDirectoryNotEmpty=|/lib/binfmt.d was not met ├─ ConditionDirectoryNotEmpty=|/usr/lib/binfmt.d was not met -- ● systemd-fsck-root.service - File System Check on Root Device Loaded: loaded (/lib/systemd/system/systemd-fsck-root.service; enabled-runtime; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:46 BST; 23min ago └─ ConditionPathExists=!/run/initramfs/fsck-root was not met Docs: man:systemd-fsck-root.service(8) ● systemd-fsckd.service - File System Check Daemon to report status Loaded: loaded (/lib/systemd/system/systemd-fsckd.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-fsckd.service(8) ● systemd-hwdb-update.service - Rebuild Hardware Database Loaded: loaded (/lib/systemd/system/systemd-hwdb-update.service; static; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:46 BST; 23min ago ├─ ConditionPathExists=|!/lib/udev/hwdb.bin was not met ├─ ConditionPathExists=|/etc/udev/hwdb.bin was not met -- ● systemd-initctl.service - initctl Compatibility Daemon Loaded: loaded (/lib/systemd/system/systemd-initctl.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-initctl.service(8) ● systemd-journal-flush.service - Flush Journal to Persistent Storage -- ● systemd-logind.service - Login Service Loaded: loaded (/lib/systemd/system/systemd-logind.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-logind.service(8) man:logind.conf(5) https://www.freedesktop.org/wiki/Software/systemd/logind -- ● systemd-machine-id-commit.service - Commit a transient machine-id on disk Loaded: loaded (/lib/systemd/system/systemd-machine-id-commit.service; static; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:44:16 BST; 22min ago └─ ConditionPathIsMountPoint=/etc/machine-id was not met Docs: man:systemd-machine-id-commit.service(8) -- ● systemd-networkd.service - Network Service Loaded: loaded (/lib/systemd/system/systemd-networkd.service; disabled; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-networkd.service(8) ● systemd-random-seed.service - Load/Save Random Seed Unit systemd-update-done.service could not be found. -- Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/systemd-timesyncd.service.d └─disable-with-time-daemon.conf Active: inactive (dead) Docs: man:systemd-timesyncd.service(8) ● systemd-tmpfiles-clean.service - Cleanup of Temporary Directories Loaded: loaded (/lib/systemd/system/systemd-tmpfiles-clean.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:tmpfiles.d(5) man:systemd-tmpfiles(8) -- ● systemd-update-utmp-runlevel.service - Update UTMP about System Runlevel Changes Loaded: loaded (/lib/systemd/system/systemd-update-utmp-runlevel.service; static; vendor preset: enabled) Active: inactive (dead) since Thu 2024-05-09 20:44:19 BST; 22min ago Docs: man:systemd-update-utmp.service(8) man:utmp(5) Process: 1357 ExecStart=/lib/systemd/systemd-update-utmp runlevel (code=exited, status=0/SUCCESS) Unit systemd-vconsole-setup.service could not be found. -- ● systemd-user-sessions.service - Permit User Sessions Loaded: loaded (/lib/systemd/system/systemd-user-sessions.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-user-sessions.service(8) ● unattended-upgrades.service - Unattended Upgrades Shutdown Loaded: loaded (/lib/systemd/system/unattended-upgrades.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:unattended-upgrade(8) ● wpa_supplicant.service - WPA supplicant Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; enabled; vendor preset: enabled) Active: inactive (dead) ● -.slice - Root Slice Loaded: loaded -- │ ├─1435 /sbin/sulogin │ ├─1436 bash │ ├─5144 systemctl status --all │ └─5145 grep dead -C 3 ├─haveged.service │ └─1354 /usr/sbin/haveged --Foreground --verbose=1 ├─rpcbind.service -- │ ├─1435 /sbin/sulogin │ ├─1436 bash │ ├─5144 systemctl status --all │ └─5145 grep dead -C 3 ├─haveged.service │ └─1354 /usr/sbin/haveged --Foreground --verbose=1 ├─rpcbind.service -- ● dbus.socket - D-Bus System Message Bus Socket Loaded: loaded (/lib/systemd/system/dbus.socket; static; vendor preset: enabled) Active: inactive (dead) Listen: /run/dbus/system_bus_socket (Stream) ● rpcbind.socket - RPCbind Server Activation Socket -- ● syslog.socket - Syslog Socket Loaded: loaded (/lib/systemd/system/syslog.socket; static; vendor preset: disabled) Active: inactive (dead) since Thu 2024-05-09 20:44:16 BST; 22min ago Docs: man:systemd.special(7) https://www.freedesktop.org/wiki/Software/systemd/syslog Listen: /run/systemd/journal/syslog (Datagram) Unit armbian-hardware-monitor.target could not be found. Unit armbian-ramlog.target could not be found. -- ● basic.target - Basic System Loaded: loaded (/lib/systemd/system/basic.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● cryptsetup.target - Local Encrypted Volumes -- ● getty-pre.target - Login Prompts (Pre) Loaded: loaded (/lib/systemd/system/getty-pre.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) man:systemd-getty-generator(8) http://0pointer.de/blog/projects/serial-console.html -- ● graphical.target - Graphical Interface Loaded: loaded (/lib/systemd/system/graphical.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● local-fs-pre.target - Local File Systems (Pre) -- ● local-fs.target - Local File Systems Loaded: loaded (/lib/systemd/system/local-fs.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● multi-user.target - Multi-User System Loaded: loaded (/lib/systemd/system/multi-user.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● network-online.target - Network is Online -- ● nss-user-lookup.target - User and Group Name Lookups Loaded: loaded (/lib/systemd/system/nss-user-lookup.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● paths.target - Paths -- ● rescue.target - Rescue Mode Loaded: loaded (/lib/systemd/system/rescue.target; static; vendor preset: disabled) Active: inactive (dead) Docs: man:systemd.special(7) ● rpcbind.target - RPC Port Mapper -- ● shutdown.target - Shutdown Loaded: loaded (/lib/systemd/system/shutdown.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) Unit syslog.target could not be found. ● slices.target - Slices -- ● sysinit.target - System Initialization Loaded: loaded (/lib/systemd/system/sysinit.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● time-sync.target - System Time Synchronized -- ● umount.target - Unmount All Filesystems Loaded: loaded (/lib/systemd/system/umount.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● apt-daily-upgrade.timer - Daily apt upgrade and clean activities Loaded: loaded (/lib/systemd/system/apt-daily-upgrade.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a ● apt-daily.timer - Daily apt download activities Loaded: loaded (/lib/systemd/system/apt-daily.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a ● e2scrub_all.timer - Periodic ext4 Online Metadata Check for All Filesystems Loaded: loaded (/lib/systemd/system/e2scrub_all.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a ● logrotate.timer - Daily rotation of log files Loaded: loaded (/lib/systemd/system/logrotate.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a Docs: man:logrotate(8) man:logrotate.conf(5) ● man-db.timer - Daily man-db regeneration Loaded: loaded (/lib/systemd/system/man-db.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a Docs: man:mandb(8) ● systemd-tmpfiles-clean.timer - Daily Cleanup of Temporary Directories Loaded: loaded (/lib/systemd/system/systemd-tmpfiles-clean.timer; static; vendor preset: enabled) Active: inactive (dead) Trigger: n/a Docs: man:tmpfiles.d(5) man:systemd-tmpfiles(8) root@helios2:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.15.93-rockchip64 (root@cf2b4ed83279) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 [ 0.000000] Machine model: Helios64 [ 0.000000] efi: UEFI not found. [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] NUMA: NODE_DATA [mem 0xf77cc100-0xf77cdfff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x00000000e9000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 29 pages/cpu s80984 r8192 d29608 u118784 [ 0.000000] pcpu-alloc: s80984 r8192 d29608 u118784 alloc=29*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 999432 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: root=UUID=d82ec6f7-ac67-4a80-a092-295ebfdbbd1d rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=306d94a6-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] Unknown kernel command line parameters "ubootpart=306d94a6-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] Memory: 3807704K/4061184K available (16000K kernel code, 2692K rwdata, 6712K rodata, 4352K init, 593K bss, 122408K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] trace event string verifier disabled [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] ITS [mem 0xfee20000-0xfee3ffff] [ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @500000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000000004d0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000004e0000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.002149] Console: colour dummy device 80x25 [ 0.002217] printk: console [tty1] enabled [ 0.002334] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.002357] pid_max: default: 32768 minimum: 301 [ 0.002492] LSM: Security Framework initializing [ 0.002532] Yama: becoming mindful. [ 0.002673] AppArmor: AppArmor initialized [ 0.002821] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002859] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.006959] rcu: Hierarchical SRCU implementation. [ 0.008549] Platform MSI: interrupt-controller@fee20000 domain created [ 0.009124] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.011444] EFI services will not be available. [ 0.012340] smp: Bringing up secondary CPUs ... [ 0.013479] Detected VIPT I-cache on CPU1 [ 0.013547] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.013571] GICv3: CPU1: using allocated LPI pending table @0x00000000004f0000 [ 0.013645] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.015135] Detected VIPT I-cache on CPU2 [ 0.015203] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.015226] GICv3: CPU2: using allocated LPI pending table @0x0000000000580000 [ 0.015297] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.016845] Detected VIPT I-cache on CPU3 [ 0.016912] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.016935] GICv3: CPU3: using allocated LPI pending table @0x0000000000590000 [ 0.017005] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.018500] CPU features: detected: Spectre-v2 [ 0.018513] CPU features: detected: Spectre-v3a [ 0.018520] CPU features: detected: Spectre-v4 [ 0.018525] CPU features: detected: Spectre-BHB [ 0.018534] CPU features: detected: ARM erratum 1742098 [ 0.018540] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.018546] Detected PIPT I-cache on CPU4 [ 0.018583] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.018601] GICv3: CPU4: using allocated LPI pending table @0x00000000005a0000 [ 0.018648] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [ 0.020015] Detected PIPT I-cache on CPU5 [ 0.020061] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.020081] GICv3: CPU5: using allocated LPI pending table @0x00000000005b0000 [ 0.020127] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [ 0.020300] smp: Brought up 1 node, 6 CPUs [ 0.020338] SMP: Total of 6 processors activated. [ 0.020348] CPU features: detected: 32-bit EL0 Support [ 0.020355] CPU features: detected: 32-bit EL1 Support [ 0.020365] CPU features: detected: CRC32 instructions [ 0.047134] CPU: All CPU(s) started at EL2 [ 0.047234] alternatives: patching kernel code [ 0.050385] devtmpfs: initialized [ 0.066010] Registered cp15_barrier emulation handler [ 0.066036] Registered setend emulation handler [ 0.066050] KASLR disabled due to lack of seed [ 0.066262] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.066340] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.069355] pinctrl core: initialized pinctrl subsystem [ 0.070018] DMI not present or invalid. [ 0.070887] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.075546] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.077236] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.080044] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.080138] audit: initializing netlink subsys (disabled) [ 0.080417] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1 [ 0.081677] thermal_sys: Registered thermal governor 'fair_share' [ 0.081686] thermal_sys: Registered thermal governor 'bang_bang' [ 0.081693] thermal_sys: Registered thermal governor 'step_wise' [ 0.081699] thermal_sys: Registered thermal governor 'user_space' [ 0.082180] cpuidle: using governor menu [ 0.082456] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.082689] ASID allocator initialised with 65536 entries [ 0.084016] Serial: AMBA PL011 UART driver [ 0.114072] platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc [ 0.117339] platform ff8f0000.vop: Fixing up cyclic dependency with fec00000.dp [ 0.118666] platform ff900000.vop: Fixing up cyclic dependency with fec00000.dp [ 0.131544] rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000 [ 0.132340] rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000 [ 0.133048] rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000 [ 0.133824] rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000 [ 0.134539] rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000 [ 0.159716] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.159732] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.159741] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.159750] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.165441] cryptd: max_cpu_qlen set to 1000 [ 0.244392] raid6: neonx8 gen() 1666 MB/s [ 0.312551] raid6: neonx8 xor() 1222 MB/s [ 0.380726] raid6: neonx4 gen() 1727 MB/s [ 0.448881] raid6: neonx4 xor() 1269 MB/s [ 0.517055] raid6: neonx2 gen() 1541 MB/s [ 0.585216] raid6: neonx2 xor() 1177 MB/s [ 0.653386] raid6: neonx1 gen() 1200 MB/s [ 0.721555] raid6: neonx1 xor() 932 MB/s [ 0.789715] raid6: int64x8 gen() 1001 MB/s [ 0.857912] raid6: int64x8 xor() 577 MB/s [ 0.926047] raid6: int64x4 gen() 1001 MB/s [ 0.994213] raid6: int64x4 xor() 591 MB/s [ 1.062378] raid6: int64x2 gen() 943 MB/s [ 1.130532] raid6: int64x2 xor() 524 MB/s [ 1.198710] raid6: int64x1 gen() 724 MB/s [ 1.266853] raid6: int64x1 xor() 391 MB/s [ 1.266861] raid6: using algorithm neonx4 gen() 1727 MB/s [ 1.266867] raid6: .... xor() 1269 MB/s, rmw enabled [ 1.266874] raid6: using neon recovery algorithm [ 1.268516] vcc12v_dcin_bkup: supplied by vcc12v_dcin [ 1.268899] vcc12v_hdd: supplied by vcc12v_dcin_bkup [ 1.269401] vcc5v0_perdev: supplied by vcc12v_dcin_bkup [ 1.269764] vcc5v0_hdd: supplied by vcc12v_dcin_bkup [ 1.270104] vcc5v0_sys: supplied by vcc12v_dcin_bkup [ 1.271505] iommu: Default domain type: Translated [ 1.271515] iommu: DMA domain TLB invalidation policy: strict mode [ 1.274682] vgaarb: loaded [ 1.275149] SCSI subsystem initialized [ 1.275658] libata version 3.00 loaded. [ 1.275919] usbcore: registered new interface driver usbfs [ 1.275965] usbcore: registered new interface driver hub [ 1.276009] usbcore: registered new device driver usb [ 1.276809] pps_core: LinuxPPS API ver. 1 registered [ 1.276817] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.276845] PTP clock support registered [ 1.277168] EDAC MC: Ver: 3.0.0 [ 1.278511] NetLabel: Initializing [ 1.278519] NetLabel: domain hash size = 128 [ 1.278526] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.278599] NetLabel: unlabeled traffic allowed by default [ 1.279111] clocksource: Switched to clocksource arch_sys_counter [ 1.329969] VFS: Disk quotas dquot_6.6.0 [ 1.330055] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.330890] AppArmor: AppArmor Filesystem Enabled [ 1.341530] NET: Registered PF_INET protocol family [ 1.341876] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 1.344975] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 1.345230] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 1.345353] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.345891] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 1.346560] TCP: Hash tables configured (established 32768 bind 32768) [ 1.346754] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.346924] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.347312] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 1.347347] NET: Registered PF_XDP protocol family [ 1.347361] PCI: CLS 0 bytes, default 64 [ 1.347999] Trying to unpack rootfs image as initramfs... [ 1.348651] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 1.349157] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 1.349963] kvm [1]: IPA Size Limit: 40 bits [ 1.351307] kvm [1]: vgic-v2@fff20000 [ 1.351343] kvm [1]: GIC system register CPU interface enabled [ 1.351639] kvm [1]: vgic interrupt IRQ18 [ 1.351971] kvm [1]: Hyp mode initialized successfully [ 1.364047] Initialise system trusted keyrings [ 1.364119] Key type blacklist registered [ 1.364436] workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 1.371163] zbud: loaded [ 1.372948] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.373856] fuse: init (API version 7.34) [ 1.376680] integrity: Platform Keyring initialized [ 1.441692] xor: measuring software checksum speed [ 1.445597] 8regs : 2541 MB/sec [ 1.448978] 32regs : 2933 MB/sec [ 1.453182] arm64_neon : 2353 MB/sec [ 1.453191] xor: using function: 32regs (2933 MB/sec) [ 1.453205] Key type asymmetric registered [ 1.453212] Asymmetric key parser 'x509' registered [ 1.453344] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.453571] io scheduler mq-deadline registered [ 1.453581] io scheduler kyber registered [ 1.453796] io scheduler bfq registered [ 1.480430] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.480452] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 1.481898] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.481911] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.487343] vdd_log: supplied by regulator-dummy [ 1.489024] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 1.492484] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 40, base_baud = 1500000) is a 16550A [ 1.493559] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 41, base_baud = 1500000) is a 16550A [ 1.493834] printk: console [ttyS2] enabled [ 1.495351] Serial: AMBA driver [ 1.497517] rockchip-vop ff8f0000.vop: Adding to iommu group 2 [ 1.498545] rockchip-vop ff900000.vop: Adding to iommu group 3 [ 1.505356] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 1.515416] loop: module loaded [ 1.524749] tun: Universal TUN/TAP device driver, 1.6 [ 1.525997] thunder_xcv, ver 1.0 [ 1.526042] thunder_bgx, ver 1.0 [ 1.526085] nicpf, ver 1.0 [ 1.527352] e1000e: Intel(R) PRO/1000 Network Driver [ 1.527359] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 1.527415] igb: Intel(R) Gigabit Ethernet Network Driver [ 1.527422] igb: Copyright (c) 2007-2014 Intel Corporation. [ 1.527464] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 1.527470] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 1.527784] sky2: driver version 1.30 [ 1.528567] VFIO - User Level meta-driver version: 0.3 [ 1.540242] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.540272] ehci-pci: EHCI PCI platform driver [ 1.540319] ehci-platform: EHCI generic platform driver [ 1.540691] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.540710] ohci-pci: OHCI PCI platform driver [ 1.540750] ohci-platform: OHCI generic platform driver [ 1.541974] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.542004] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.542210] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 [ 1.542286] xhci-hcd xhci-hcd.0.auto: irq 75, io mem 0xfe900000 [ 1.542507] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.542523] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 1.542539] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 1.542758] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 1.542775] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.542786] usb usb1: Product: xHCI Host Controller [ 1.542795] usb usb1: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 1.542804] usb usb1: SerialNumber: xhci-hcd.0.auto [ 1.543424] hub 1-0:1.0: USB hub found [ 1.543466] hub 1-0:1.0: 1 port detected [ 1.543910] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.544070] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 1.544085] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.544096] usb usb2: Product: xHCI Host Controller [ 1.544105] usb usb2: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 1.544114] usb usb2: SerialNumber: xhci-hcd.0.auto [ 1.544633] hub 2-0:1.0: USB hub found [ 1.544687] hub 2-0:1.0: 1 port detected [ 1.545171] usbcore: registered new interface driver usb-storage [ 1.548123] mousedev: PS/2 mouse device common for all mice [ 1.549661] i2c_dev: i2c /dev entries driver [ 1.556095] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 1.556601] vdd_cpu_b: supplied by vcc5v0_sys [ 1.559325] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 1.559818] vdd_gpu: supplied by vcc5v0_sys [ 1.568997] dw_wdt ff848000.watchdog: No valid TOPs array specified [ 1.571319] sdhci: Secure Digital Host Controller Interface driver [ 1.571330] sdhci: Copyright(c) Pierre Ossman [ 1.571358] Synopsys Designware Multimedia Card Interface Driver [ 1.572746] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.577292] ledtrig-cpu: registered to indicate activity on CPUs [ 1.578834] hid: raw HID events driver (C) Jiri Kosina [ 1.578965] usbcore: registered new interface driver usbhid [ 1.578974] usbhid: USB HID core driver [ 1.584210] drop_monitor: Initializing network drop monitor service [ 1.584982] NET: Registered PF_INET6 protocol family [ 1.803152] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 1.947662] Freeing initrd memory: 13060K [ 1.953250] usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04 [ 1.953270] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1.953282] usb 1-1: Product: USB2.0 Hub [ 1.953292] usb 1-1: Manufacturer: VIA Labs, Inc. [ 1.991056] hub 1-1:1.0: USB hub found [ 1.991312] hub 1-1:1.0: 4 ports detected [ 2.005042] Segment Routing with IPv6 [ 2.005165] In-situ OAM (IOAM) with IPv6 [ 2.005310] NET: Registered PF_PACKET protocol family [ 2.005542] 8021q: 802.1Q VLAN Support v1.8 [ 2.005630] Key type dns_resolver registered [ 2.008334] registered taskstats version 1 [ 2.008361] Loading compiled-in X.509 certificates [ 2.014287] Loaded X.509 cert 'Build time autogenerated kernel key: 1fb701576c47097ebe5805564f004ecdeffa983a' [ 2.021345] zswap: loaded using pool zstd/z3fold [ 2.022740] Key type .fscrypt registered [ 2.022754] Key type fscrypt-provisioning registered [ 2.025971] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes [ 2.053304] Key type encrypted registered [ 2.053339] AppArmor: AppArmor sha1 policy hashing enabled [ 2.085691] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 2.117051] pcie_power: supplied by vcc5v0_perdev [ 2.128044] vcc3v3_sys_s3: supplied by vcc5v0_sys [ 2.128666] vcc3v0_sd: supplied by vcc3v3_sys_s3 [ 2.129612] vcc5v0_usb: supplied by vcc5v0_perdev [ 2.130592] vcc5v0_typec: supplied by vcc5v0_usb [ 2.131168] usblan_power: supplied by vcc5v0_usb [ 2.135297] pca953x 2-0020: using no AI [ 2.138195] rk808 0-001b: chip id: 0x0 [ 2.143667] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 2.143725] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 2.143741] rk808-regulator rk808-regulator: max buck steps per change: 4 [ 2.144508] vdd_center: supplied by vcc5v0_sys [ 2.145467] vdd_cpu_l: supplied by vcc5v0_sys [ 2.145951] vcc_ddr_s3: supplied by vcc5v0_sys [ 2.146703] vcc1v8_sys_s3: supplied by vcc5v0_sys [ 2.147763] vcc1v8_dvp: supplied by vcc5v0_sys [ 2.148360] vcc3v0_touch: supplied by vcc5v0_sys [ 2.149048] vcc1v8_s3: supplied by vcc5v0_sys [ 2.150234] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV [ 2.150676] vcc_sdio_s0: supplied by vcc5v0_sys [ 2.152048] vcca3v0_codec: supplied by vcc5v0_sys [ 2.152588] vcc1v5_s3: supplied by vcc5v0_sys [ 2.154043] vcca1v8_codec: supplied by vcc5v0_sys [ 2.154591] vcc3v0_s3: supplied by vcc5v0_sys [ 2.155600] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER [ 2.155638] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3 [ 2.156340] vcc3v3_s0: supplied by vcc3v3_sys_s3 [ 2.160655] rk808-rtc rk808-rtc: registered as rtc0 [ 2.161254] rk808-rtc rk808-rtc: setting system clock to 2024-05-09T19:41:41 UTC (1715283701) [ 2.164638] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode. [ 2.164678] dwmmc_rockchip fe320000.mmc: Using internal DMA controller. [ 2.164695] dwmmc_rockchip fe320000.mmc: Version ID is 270a [ 2.164761] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo [ 2.165413] dwmmc_rockchip fe320000.mmc: Got CD GPIO [ 2.166716] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3 [ 2.167466] vcc0v9_s3: supplied by vcc3v3_sys_s3 [ 2.168097] avdd_0v9_s0: supplied by vcc1v8_sys_s3 [ 2.168709] avdd_1v8_s0: supplied by vcc3v3_sys_s3 [ 2.169896] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 2.169964] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 2.170000] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 2.170879] rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms [ 2.178315] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.200296] rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan [ 2.200782] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 2.200802] pci_bus 0000:00: root bus resource [bus 00-1f] [ 2.200818] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 2.200837] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 2.200908] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 [ 2.201094] pci 0000:00:00.0: supports D1 [ 2.201108] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.209023] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.209468] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601 [ 2.209554] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 2.209568] pci 0000:01:00.0: reg 0x10: [io size 0x0080] [ 2.209641] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid [ 2.209656] pci 0000:01:00.0: reg 0x14: [io size 0x0080] [ 2.209698] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid [ 2.209711] pci 0000:01:00.0: reg 0x18: [io size 0x0080] [ 2.209753] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [ 2.209766] pci 0000:01:00.0: reg 0x1c: [io size 0x0080] [ 2.209835] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid [ 2.209839] usb 2-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04 [ 2.209850] pci 0000:01:00.0: reg 0x20: [io size 0x0080] [ 2.209859] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.209871] usb 2-1: Product: USB3.0 Hub [ 2.209881] usb 2-1: Manufacturer: VIA Labs, Inc. [ 2.209894] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff] [ 2.209939] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref] [ 2.209987] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512) [ 2.210366] pci 0000:01:00.0: PME# supported from D3hot [ 2.210638] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link) [ 2.218200] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01 [ 2.218258] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff] [ 2.218286] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] [ 2.218306] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff] [ 2.218334] pci 0000:01:00.0: BAR 0: no space for [io size 0x0080] [ 2.218349] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0080] [ 2.218362] pci 0000:01:00.0: BAR 1: no space for [io size 0x0080] [ 2.218376] pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0080] [ 2.218390] pci 0000:01:00.0: BAR 2: no space for [io size 0x0080] [ 2.218403] pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0080] [ 2.218418] pci 0000:01:00.0: BAR 3: no space for [io size 0x0080] [ 2.218431] pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0080] [ 2.218445] pci 0000:01:00.0: BAR 4: no space for [io size 0x0080] [ 2.218458] pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0080] [ 2.218476] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.218495] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] [ 2.218829] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 2.219338] pcieport 0000:00:00.0: PME: Signaling with IRQ 89 [ 2.219959] pcieport 0000:00:00.0: AER: enabled with IRQ 89 [ 2.220410] ahci 0000:01:00.0: version 3.0 [ 2.220453] ahci 0000:01:00.0: enabling device (0000 -> 0002) [ 2.221275] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled [ 2.221392] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode [ 2.221415] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh [ 2.229604] scsi host0: ahci [ 2.230577] scsi host1: ahci [ 2.230929] hub 2-1:1.0: USB hub found [ 2.231059] hub 2-1:1.0: 4 ports detected [ 2.231566] scsi host2: ahci [ 2.232443] scsi host3: ahci [ 2.233267] scsi host4: ahci [ 2.233587] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 90 [ 2.233604] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 91 [ 2.233618] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 92 [ 2.233631] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 93 [ 2.233643] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 94 [ 2.242754] mmc1: CQHCI version 5.10 [ 2.243204] WCN: marlin_init entry! [ 2.244730] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.245360] of_cfs_init [ 2.245407] of_cfs_init: OK [ 2.268943] mmc1: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA [ 2.340044] mmc1: Command Queue Engine enabled [ 2.340077] mmc1: new HS200 MMC card at address 0001 [ 2.341189] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB [ 2.344236] mmcblk1: p1 [ 2.344942] mmcblk1boot0: mmc1:0001 AJTD4R 4.00 MiB [ 2.347428] mmcblk1boot1: mmc1:0001 AJTD4R 4.00 MiB [ 2.349698] mmcblk1rpmb: mmc1:0001 AJTD4R 4.00 MiB, chardev (241:0) [ 2.871217] usb 2-1.4: new SuperSpeed USB device number 3 using xhci-hcd [ 2.892193] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00 [ 2.892210] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 2.892222] usb 2-1.4: Product: USB 10/100/1G/2.5G LAN [ 2.892232] usb 2-1.4: Manufacturer: Realtek [ 2.892240] usb 2-1.4: SerialNumber: 000000001 [ 12.231936] ata1: softreset failed (1st FIS failed) [ 22.232089] ata1: softreset failed (1st FIS failed) [ 33.759210] vcc3v0_sd: disabling [ 57.231598] ata1: softreset failed (1st FIS failed) [ 57.231616] ata1: limiting SATA link speed to 3.0 Gbps [ 62.443153] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320) [ 62.443174] ata1: link online but 1 devices misclassified, device detection might fail [ 62.919153] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 62.947839] ata2.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 [ 62.956929] ata2.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 63.017151] ata2.00: configured for UDMA/133 [ 63.017799] scsi 1:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 [ 63.019201] sd 1:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [ 63.019223] sd 1:0:0:0: [sda] 4096-byte physical blocks [ 63.019318] sd 1:0:0:0: [sda] Write Protect is off [ 63.019339] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 63.019507] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 63.110763] sda: sda1 [ 63.127476] sd 1:0:0:0: [sda] Attached SCSI disk [ 63.495157] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 63.497569] ata3.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 [ 63.497814] ata3.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 63.500666] ata3.00: configured for UDMA/133 [ 63.501214] scsi 2:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 [ 63.502517] sd 2:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [ 63.502533] sd 2:0:0:0: [sdb] 4096-byte physical blocks [ 63.502585] sd 2:0:0:0: [sdb] Write Protect is off [ 63.502597] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 63.502682] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 63.588633] sdb: sdb1 [ 63.603350] sd 2:0:0:0: [sdb] Attached SCSI disk [ 63.817781] ata4: SATA link down (SStatus 0 SControl 300) [ 64.129791] ata5: SATA link down (SStatus 0 SControl 300) [ 64.132579] Freeing unused kernel memory: 4352K [ 64.132703] Run /init as init process [ 64.132711] with arguments: [ 64.132719] /init [ 64.132726] with environment: [ 64.132732] HOME=/ [ 64.132739] TERM=linux [ 64.132745] ubootpart=306d94a6-01 [ 64.132751] cgroup_enable=memory [ 64.132757] cgroup_memory=1 [ 64.786426] input: adc-keys as /devices/platform/adc-keys/input/input1 [ 65.003675] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found [ 65.003698] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found [ 65.003856] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock [ 65.004323] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 65.004340] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 65.004353] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20). [ 65.004371] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 65.004456] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ 65.004465] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 65.011874] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 65.015423] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 65.015447] rk_gmac-dwmac fe300000.ethernet: DWMAC1000 [ 65.015458] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported [ 65.015467] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported [ 65.015475] rk_gmac-dwmac fe300000.ethernet: COE Type 2 [ 65.015484] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported [ 65.015492] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported [ 65.015602] rk_gmac-dwmac fe300000.ethernet: Normal descriptors [ 65.015612] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled [ 65.015619] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 65.146278] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [ 65.146305] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL) [ 65.350024] async_tx: api initialized (async) [ 65.668181] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [ 66.088777] systemd[1]: Inserted module 'autofs4' [ 66.142611] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 66.143545] systemd[1]: Detected architecture arm64. [ 66.204214] systemd[1]: Set hostname to <helios2>. [ 66.310253] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console [ 66.625803] random: systemd: uninitialized urandom read (16 bytes read) [ 66.629970] systemd[1]: /lib/systemd/system/haveged.service:19: Unknown lvalue 'ProtectHostname' in section 'Service', ignoring [ 66.630017] systemd[1]: /lib/systemd/system/haveged.service:20: Unknown lvalue 'ProtectKernelLogs' in section 'Service', ignoring [ 66.636333] random: systemd: uninitialized urandom read (16 bytes read) [ 66.637122] systemd[1]: Listening on udev Control Socket. [ 66.637656] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 66.637714] random: systemd: uninitialized urandom read (16 bytes read) [ 66.638215] systemd[1]: Listening on fsck to fsckd communication Socket. [ 66.638739] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 66.639021] systemd[1]: Reached target Swap. [ 66.753097] lm75 2-004c: supply vs not found, using dummy regulator [ 66.753894] hwmon hwmon2: temp1_input not attached to any thermal zone [ 66.753913] lm75 2-004c: hwmon2: sensor 'lm75' [ 66.759941] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [ 67.683595] mc: Linux media interface: v0.10 [ 67.720321] random: systemd: uninitialized urandom read (16 bytes read) [ 67.720429] random: systemd: uninitialized urandom read (16 bytes read) [ 67.720469] random: systemd: uninitialized urandom read (16 bytes read) [ 67.732347] videodev: Linux video capture interface: v2.00 [ 67.750408] input: beeper as /devices/platform/beeper/input/input2 [ 67.804206] sd 1:0:0:0: Attached scsi generic sg0 type 0 [ 67.818956] sd 2:0:0:0: Attached scsi generic sg1 type 0 [ 67.914746] rockchip-iep ff670000.iep: Device rockchip-iep registered as /dev/video0 [ 67.928725] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 67.935676] rockchip-rga ff680000.rga: HW Version: 0x03.02 [ 67.950103] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned. [ 67.981471] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video1 [ 67.984266] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 68.010586] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [ 68.019663] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 68.021040] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video3 [ 68.032817] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video4 [ 68.131515] panfrost ff9a0000.gpu: clock rate = 500000000 [ 68.194795] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) [ 68.194969] [drm] unsupported AFBC format[3231564e] [ 68.196796] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) [ 68.197418] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops) [ 68.201673] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 68.203396] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 68.215852] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1 [ 68.271185] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 68.272400] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3 [ 68.272531] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 [ 68.272552] xhci-hcd xhci-hcd.3.auto: irq 74, io mem 0xfe800000 [ 68.272656] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 68.272664] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4 [ 68.272670] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ 68.272770] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 68.272775] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.272779] usb usb3: Product: xHCI Host Controller [ 68.272783] usb usb3: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 68.272786] usb usb3: SerialNumber: xhci-hcd.3.auto [ 68.273197] ehci-platform fe380000.usb: EHCI Host Controller [ 68.281431] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 68.281458] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400 [ 68.281467] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 68.281478] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 68.291991] hub 3-0:1.0: USB hub found [ 68.292019] hub 3-0:1.0: 1 port detected [ 68.292299] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 68.292369] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 68.292374] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.292379] usb usb4: Product: xHCI Host Controller [ 68.292382] usb usb4: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 68.292385] usb usb4: SerialNumber: xhci-hcd.3.auto [ 68.303795] hub 4-0:1.0: USB hub found [ 68.303849] hub 4-0:1.0: 1 port detected [ 68.306660] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 68.312297] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 0 [ 68.357318] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 [ 68.357688] ehci-platform fe380000.usb: irq 34, io mem 0xfe380000 [ 68.371190] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 68.373813] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 68.373839] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.373846] usb usb5: Product: EHCI Host Controller [ 68.373852] usb usb5: Manufacturer: Linux 5.15.93-rockchip64 ehci_hcd [ 68.373857] usb usb5: SerialNumber: fe380000.usb [ 68.455792] hub 5-0:1.0: USB hub found [ 68.455834] hub 5-0:1.0: 1 port detected [ 68.562994] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 68.564446] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 [ 68.564739] ohci-platform fe3a0000.usb: irq 35, io mem 0xfe3a0000 [ 68.621598] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 68.627303] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 68.627315] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.627320] usb usb6: Product: Generic Platform OHCI controller [ 68.627324] usb usb6: Manufacturer: Linux 5.15.93-rockchip64 ohci_hcd [ 68.627327] usb usb6: SerialNumber: fe3a0000.usb [ 68.627873] hub 6-0:1.0: USB hub found [ 68.627900] hub 6-0:1.0: 1 port detected [ 68.680671] EXT4-fs (sdb1): recovery complete [ 68.680697] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [ 68.807792] usb 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 68.829899] EXT4-fs (sda1): recovery complete [ 68.829913] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [ 68.846117] r8152 2-1.4:1.0: Direct firmware load for rtl_nic/rtl8156a-2.fw failed with error -2 [ 68.846155] r8152 2-1.4:1.0: unable to load firmware patch rtl_nic/rtl8156a-2.fw (-2) [ 68.887755] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256 [ 68.903489] r8152 2-1.4:1.0 eth1: v1.12.13 [ 68.903688] usbcore: registered new interface driver r8152 [ 69.000196] random: systemd: uninitialized urandom read (16 bytes read) [ 69.000248] random: systemd: uninitialized urandom read (16 bytes read) [ 69.588914] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 72.831526] random: crng init done [ 72.831543] random: 99 urandom warning(s) missed due to ratelimiting [ 156.715598] systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start timed out. [ 156.715646] systemd[1]: Timed out waiting for device /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80. [ 156.716005] systemd[1]: Dependency failed for /data/glusterfs/sda1. [ 156.716313] systemd[1]: Dependency failed for Local File Systems. [ 156.716609] systemd[1]: Dependency failed for Mark the need to relabel after reboot. [ 156.716924] systemd[1]: selinux-autorelabel-mark.service: Job selinux-autorelabel-mark.service/start failed with result 'dependency'. [ 156.716977] systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'. [ 156.717002] systemd[1]: local-fs.target: Triggering OnFailure= dependencies. [ 156.718933] systemd[1]: data-glusterfs-sda1.mount: Job data-glusterfs-sda1.mount/start failed with result 'dependency'. [ 156.718982] systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start failed with result 'timeout'. [ 156.900586] zram: Added device: zram0 [ 156.901201] zram: Added device: zram1 [ 156.901843] zram: Added device: zram2 [ 156.915238] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 156.918923] rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 156.927175] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found [ 156.927210] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW [ 156.927768] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode [ 156.956618] zram0: detected capacity change from 0 to 3956192 [ 157.006138] Adding 1978092k swap on /dev/zram0. Priority:5 extents:1 across:1978092k SSFS [ 157.170458] zram1: detected capacity change from 0 to 102400 [ 157.268107] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. [ 157.268158] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) [ 159.706322] systemd-journald[1325]: Received request to flush runtime journal from PID 1 [ 161.056445] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 161.056494] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready root@helios2:~# journalctl | cat -- Logs begin at Thu 2024-05-09 20:44:18 BST, end at Thu 2024-05-09 20:50:27 BST. -- May 09 20:44:18 helios2 kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034] May 09 20:44:18 helios2 kernel: Linux version 5.15.93-rockchip64 (root@cf2b4ed83279) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 May 09 20:44:18 helios2 kernel: Machine model: Helios64 May 09 20:44:18 helios2 kernel: efi: UEFI not found. May 09 20:44:18 helios2 kernel: NUMA: No NUMA configuration found May 09 20:44:18 helios2 kernel: NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: NUMA: NODE_DATA [mem 0xf77cc100-0xf77cdfff] May 09 20:44:18 helios2 kernel: Zone ranges: May 09 20:44:18 helios2 kernel: DMA [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: DMA32 empty May 09 20:44:18 helios2 kernel: Normal empty May 09 20:44:18 helios2 kernel: Movable zone start for each node May 09 20:44:18 helios2 kernel: Early memory node ranges May 09 20:44:18 helios2 kernel: node 0: [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: On node 0, zone DMA: 512 pages in unavailable ranges May 09 20:44:18 helios2 kernel: cma: Reserved 128 MiB at 0x00000000e9000000 May 09 20:44:18 helios2 kernel: psci: probing for conduit method from DT. May 09 20:44:18 helios2 kernel: psci: PSCIv1.0 detected in firmware. May 09 20:44:18 helios2 kernel: psci: Using standard PSCI v0.2 function IDs May 09 20:44:18 helios2 kernel: psci: MIGRATE_INFO_TYPE not supported. May 09 20:44:18 helios2 kernel: psci: SMC Calling Convention v1.0 May 09 20:44:18 helios2 kernel: percpu: Embedded 29 pages/cpu s80984 r8192 d29608 u118784 May 09 20:44:18 helios2 kernel: pcpu-alloc: s80984 r8192 d29608 u118784 alloc=29*4096 May 09 20:44:18 helios2 kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU0 May 09 20:44:18 helios2 kernel: CPU features: detected: GIC system register CPU interface May 09 20:44:18 helios2 kernel: CPU features: detected: ARM erratum 845719 May 09 20:44:18 helios2 kernel: Built 1 zonelists, mobility grouping on. Total pages: 999432 May 09 20:44:18 helios2 kernel: Policy zone: DMA May 09 20:44:18 helios2 kernel: Kernel command line: root=UUID=d82ec6f7-ac67-4a80-a092-295ebfdbbd1d rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=306d94a6-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 May 09 20:44:18 helios2 kernel: Unknown kernel command line parameters "ubootpart=306d94a6-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space. May 09 20:44:18 helios2 kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) May 09 20:44:18 helios2 kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) May 09 20:44:18 helios2 kernel: mem auto-init: stack:off, heap alloc:on, heap free:off May 09 20:44:18 helios2 kernel: Memory: 3807704K/4061184K available (16000K kernel code, 2692K rwdata, 6712K rodata, 4352K init, 593K bss, 122408K reserved, 131072K cma-reserved) May 09 20:44:18 helios2 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 May 09 20:44:18 helios2 kernel: trace event string verifier disabled May 09 20:44:18 helios2 kernel: rcu: Preemptible hierarchical RCU implementation. May 09 20:44:18 helios2 kernel: rcu: RCU event tracing is enabled. May 09 20:44:18 helios2 kernel: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. May 09 20:44:18 helios2 kernel: Trampoline variant of Tasks RCU enabled. May 09 20:44:18 helios2 kernel: Rude variant of Tasks RCU enabled. May 09 20:44:18 helios2 kernel: Tracing variant of Tasks RCU enabled. May 09 20:44:18 helios2 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. May 09 20:44:18 helios2 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 May 09 20:44:18 helios2 kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 May 09 20:44:18 helios2 kernel: GICv3: GIC: Using split EOI/Deactivate mode May 09 20:44:18 helios2 kernel: GICv3: 256 SPIs implemented May 09 20:44:18 helios2 kernel: GICv3: 0 Extended SPIs implemented May 09 20:44:18 helios2 kernel: GICv3: Distributor has no Range Selector support May 09 20:44:18 helios2 kernel: Root IRQ handler: gic_handle_irq May 09 20:44:18 helios2 kernel: GICv3: 16 PPIs implemented May 09 20:44:18 helios2 kernel: GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 May 09 20:44:18 helios2 kernel: ITS [mem 0xfee20000-0xfee3ffff] May 09 20:44:18 helios2 kernel: ITS@0x00000000fee20000: allocated 65536 Devices @500000 (flat, esz 8, psz 64K, shr 0) May 09 20:44:18 helios2 kernel: ITS: using cache flushing for cmd queue May 09 20:44:18 helios2 kernel: GICv3: using LPI property table @0x00000000004d0000 May 09 20:44:18 helios2 kernel: GIC: using cache flushing for LPI property table May 09 20:44:18 helios2 kernel: GICv3: CPU0: using allocated LPI pending table @0x00000000004e0000 May 09 20:44:18 helios2 kernel: GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } May 09 20:44:18 helios2 kernel: GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } May 09 20:44:18 helios2 kernel: arch_timer: cp15 timer(s) running at 24.00MHz (phys). May 09 20:44:18 helios2 kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns May 09 20:44:18 helios2 kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns May 09 20:44:18 helios2 kernel: Console: colour dummy device 80x25 May 09 20:44:18 helios2 kernel: printk: console [tty1] enabled May 09 20:44:18 helios2 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) May 09 20:44:18 helios2 kernel: pid_max: default: 32768 minimum: 301 May 09 20:44:18 helios2 kernel: LSM: Security Framework initializing May 09 20:44:18 helios2 kernel: Yama: becoming mindful. May 09 20:44:18 helios2 kernel: AppArmor: AppArmor initialized May 09 20:44:18 helios2 kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: rcu: Hierarchical SRCU implementation. May 09 20:44:18 helios2 kernel: Platform MSI: interrupt-controller@fee20000 domain created May 09 20:44:18 helios2 kernel: PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created May 09 20:44:18 helios2 kernel: EFI services will not be available. May 09 20:44:18 helios2 kernel: smp: Bringing up secondary CPUs ... May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU1 May 09 20:44:18 helios2 kernel: GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 May 09 20:44:18 helios2 kernel: GICv3: CPU1: using allocated LPI pending table @0x00000000004f0000 May 09 20:44:18 helios2 kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034] May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU2 May 09 20:44:18 helios2 kernel: GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 May 09 20:44:18 helios2 kernel: GICv3: CPU2: using allocated LPI pending table @0x0000000000580000 May 09 20:44:18 helios2 kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034] May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU3 May 09 20:44:18 helios2 kernel: GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 May 09 20:44:18 helios2 kernel: GICv3: CPU3: using allocated LPI pending table @0x0000000000590000 May 09 20:44:18 helios2 kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034] May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-v2 May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-v3a May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-v4 May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-BHB May 09 20:44:18 helios2 kernel: CPU features: detected: ARM erratum 1742098 May 09 20:44:18 helios2 kernel: CPU features: detected: ARM errata 1165522, 1319367, or 1530923 May 09 20:44:18 helios2 kernel: Detected PIPT I-cache on CPU4 May 09 20:44:18 helios2 kernel: GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 May 09 20:44:18 helios2 kernel: GICv3: CPU4: using allocated LPI pending table @0x00000000005a0000 May 09 20:44:18 helios2 kernel: CPU4: Booted secondary processor 0x0000000100 [0x410fd082] May 09 20:44:18 helios2 kernel: Detected PIPT I-cache on CPU5 May 09 20:44:18 helios2 kernel: GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 May 09 20:44:18 helios2 kernel: GICv3: CPU5: using allocated LPI pending table @0x00000000005b0000 May 09 20:44:18 helios2 kernel: CPU5: Booted secondary processor 0x0000000101 [0x410fd082] May 09 20:44:18 helios2 kernel: smp: Brought up 1 node, 6 CPUs May 09 20:44:18 helios2 kernel: SMP: Total of 6 processors activated. May 09 20:44:18 helios2 kernel: CPU features: detected: 32-bit EL0 Support May 09 20:44:18 helios2 kernel: CPU features: detected: 32-bit EL1 Support May 09 20:44:18 helios2 kernel: CPU features: detected: CRC32 instructions May 09 20:44:18 helios2 kernel: CPU: All CPU(s) started at EL2 May 09 20:44:18 helios2 kernel: alternatives: patching kernel code May 09 20:44:18 helios2 kernel: devtmpfs: initialized May 09 20:44:18 helios2 kernel: Registered cp15_barrier emulation handler May 09 20:44:18 helios2 kernel: Registered setend emulation handler May 09 20:44:18 helios2 kernel: KASLR disabled due to lack of seed May 09 20:44:18 helios2 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns May 09 20:44:18 helios2 kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear) May 09 20:44:18 helios2 kernel: pinctrl core: initialized pinctrl subsystem May 09 20:44:18 helios2 kernel: DMI not present or invalid. May 09 20:44:18 helios2 kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family May 09 20:44:18 helios2 kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations May 09 20:44:18 helios2 kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations May 09 20:44:18 helios2 kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations May 09 20:44:18 helios2 kernel: audit: initializing netlink subsys (disabled) May 09 20:44:18 helios2 kernel: audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1 May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'fair_share' May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'bang_bang' May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'step_wise' May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'user_space' May 09 20:44:18 helios2 kernel: cpuidle: using governor menu May 09 20:44:18 helios2 kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. May 09 20:44:18 helios2 kernel: ASID allocator initialised with 65536 entries May 09 20:44:18 helios2 kernel: Serial: AMBA PL011 UART driver May 09 20:44:18 helios2 kernel: platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc May 09 20:44:18 helios2 kernel: platform ff8f0000.vop: Fixing up cyclic dependency with fec00000.dp May 09 20:44:18 helios2 kernel: platform ff900000.vop: Fixing up cyclic dependency with fec00000.dp May 09 20:44:18 helios2 kernel: rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000 May 09 20:44:18 helios2 kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: cryptd: max_cpu_qlen set to 1000 May 09 20:44:18 helios2 kernel: raid6: neonx8 gen() 1666 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx8 xor() 1222 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx4 gen() 1727 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx4 xor() 1269 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx2 gen() 1541 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx2 xor() 1177 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx1 gen() 1200 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx1 xor() 932 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x8 gen() 1001 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x8 xor() 577 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x4 gen() 1001 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x4 xor() 591 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x2 gen() 943 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x2 xor() 524 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x1 gen() 724 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x1 xor() 391 MB/s May 09 20:44:18 helios2 kernel: raid6: using algorithm neonx4 gen() 1727 MB/s May 09 20:44:18 helios2 kernel: raid6: .... xor() 1269 MB/s, rmw enabled May 09 20:44:18 helios2 kernel: raid6: using neon recovery algorithm May 09 20:44:18 helios2 kernel: vcc12v_dcin_bkup: supplied by vcc12v_dcin May 09 20:44:18 helios2 kernel: vcc12v_hdd: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: vcc5v0_perdev: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: vcc5v0_hdd: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: vcc5v0_sys: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: iommu: Default domain type: Translated May 09 20:44:18 helios2 kernel: iommu: DMA domain TLB invalidation policy: strict mode May 09 20:44:18 helios2 kernel: vgaarb: loaded May 09 20:44:18 helios2 kernel: SCSI subsystem initialized May 09 20:44:18 helios2 kernel: libata version 3.00 loaded. May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver usbfs May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver hub May 09 20:44:18 helios2 kernel: usbcore: registered new device driver usb May 09 20:44:18 helios2 kernel: pps_core: LinuxPPS API ver. 1 registered May 09 20:44:18 helios2 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> May 09 20:44:18 helios2 kernel: PTP clock support registered May 09 20:44:18 helios2 kernel: EDAC MC: Ver: 3.0.0 May 09 20:44:18 helios2 kernel: NetLabel: Initializing May 09 20:44:18 helios2 kernel: NetLabel: domain hash size = 128 May 09 20:44:18 helios2 kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO May 09 20:44:18 helios2 kernel: NetLabel: unlabeled traffic allowed by default May 09 20:44:18 helios2 kernel: clocksource: Switched to clocksource arch_sys_counter May 09 20:44:18 helios2 kernel: VFS: Disk quotas dquot_6.6.0 May 09 20:44:18 helios2 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) May 09 20:44:18 helios2 kernel: AppArmor: AppArmor Filesystem Enabled May 09 20:44:18 helios2 kernel: NET: Registered PF_INET protocol family May 09 20:44:18 helios2 kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) May 09 20:44:18 helios2 kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) May 09 20:44:18 helios2 kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) May 09 20:44:18 helios2 kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) May 09 20:44:18 helios2 kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) May 09 20:44:18 helios2 kernel: TCP: Hash tables configured (established 32768 bind 32768) May 09 20:44:18 helios2 kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family May 09 20:44:18 helios2 kernel: NET: Registered PF_XDP protocol family May 09 20:44:18 helios2 kernel: PCI: CLS 0 bytes, default 64 May 09 20:44:18 helios2 kernel: Trying to unpack rootfs image as initramfs... May 09 20:44:18 helios2 kernel: hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available May 09 20:44:18 helios2 kernel: hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available May 09 20:44:18 helios2 kernel: kvm [1]: IPA Size Limit: 40 bits May 09 20:44:18 helios2 kernel: kvm [1]: vgic-v2@fff20000 May 09 20:44:18 helios2 kernel: kvm [1]: GIC system register CPU interface enabled May 09 20:44:18 helios2 kernel: kvm [1]: vgic interrupt IRQ18 May 09 20:44:18 helios2 kernel: kvm [1]: Hyp mode initialized successfully May 09 20:44:18 helios2 kernel: Initialise system trusted keyrings May 09 20:44:18 helios2 kernel: Key type blacklist registered May 09 20:44:18 helios2 kernel: workingset: timestamp_bits=44 max_order=20 bucket_order=0 May 09 20:44:18 helios2 kernel: zbud: loaded May 09 20:44:18 helios2 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher May 09 20:44:18 helios2 kernel: fuse: init (API version 7.34) May 09 20:44:18 helios2 kernel: integrity: Platform Keyring initialized May 09 20:44:18 helios2 kernel: xor: measuring software checksum speed May 09 20:44:18 helios2 kernel: 8regs : 2541 MB/sec May 09 20:44:18 helios2 kernel: 32regs : 2933 MB/sec May 09 20:44:18 helios2 kernel: arm64_neon : 2353 MB/sec May 09 20:44:18 helios2 kernel: xor: using function: 32regs (2933 MB/sec) May 09 20:44:18 helios2 kernel: Key type asymmetric registered May 09 20:44:18 helios2 kernel: Asymmetric key parser 'x509' registered May 09 20:44:18 helios2 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) May 09 20:44:18 helios2 kernel: io scheduler mq-deadline registered May 09 20:44:18 helios2 kernel: io scheduler kyber registered May 09 20:44:18 helios2 kernel: io scheduler bfq registered May 09 20:44:18 helios2 kernel: dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 May 09 20:44:18 helios2 kernel: dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 May 09 20:44:18 helios2 kernel: dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 May 09 20:44:18 helios2 kernel: dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 May 09 20:44:18 helios2 kernel: vdd_log: supplied by regulator-dummy May 09 20:44:18 helios2 kernel: Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled May 09 20:44:18 helios2 kernel: ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 40, base_baud = 1500000) is a 16550A May 09 20:44:18 helios2 kernel: ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 41, base_baud = 1500000) is a 16550A May 09 20:44:18 helios2 kernel: printk: console [ttyS2] enabled May 09 20:44:18 helios2 kernel: Serial: AMBA driver May 09 20:44:18 helios2 kernel: rockchip-vop ff8f0000.vop: Adding to iommu group 2 May 09 20:44:18 helios2 kernel: rockchip-vop ff900000.vop: Adding to iommu group 3 May 09 20:44:18 helios2 kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0 May 09 20:44:18 helios2 kernel: loop: module loaded May 09 20:44:18 helios2 kernel: tun: Universal TUN/TAP device driver, 1.6 May 09 20:44:18 helios2 kernel: thunder_xcv, ver 1.0 May 09 20:44:18 helios2 kernel: thunder_bgx, ver 1.0 May 09 20:44:18 helios2 kernel: nicpf, ver 1.0 May 09 20:44:18 helios2 kernel: e1000e: Intel(R) PRO/1000 Network Driver May 09 20:44:18 helios2 kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation. May 09 20:44:18 helios2 kernel: igb: Intel(R) Gigabit Ethernet Network Driver May 09 20:44:18 helios2 kernel: igb: Copyright (c) 2007-2014 Intel Corporation. May 09 20:44:18 helios2 kernel: igbvf: Intel(R) Gigabit Virtual Function Network Driver May 09 20:44:18 helios2 kernel: igbvf: Copyright (c) 2009 - 2012 Intel Corporation. May 09 20:44:18 helios2 kernel: sky2: driver version 1.30 May 09 20:44:18 helios2 kernel: VFIO - User Level meta-driver version: 0.3 May 09 20:44:18 helios2 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver May 09 20:44:18 helios2 kernel: ehci-pci: EHCI PCI platform driver May 09 20:44:18 helios2 kernel: ehci-platform: EHCI generic platform driver May 09 20:44:18 helios2 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver May 09 20:44:18 helios2 kernel: ohci-pci: OHCI PCI platform driver May 09 20:44:18 helios2 kernel: ohci-platform: OHCI generic platform driver May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: irq 75, io mem 0xfe900000 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed May 09 20:44:18 helios2 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb1: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb1: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb1: SerialNumber: xhci-hcd.0.auto May 09 20:44:18 helios2 kernel: hub 1-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 1-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. May 09 20:44:18 helios2 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb2: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb2: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb2: SerialNumber: xhci-hcd.0.auto May 09 20:44:18 helios2 kernel: hub 2-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 2-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver usb-storage May 09 20:44:18 helios2 kernel: mousedev: PS/2 mouse device common for all mice May 09 20:44:18 helios2 kernel: i2c_dev: i2c /dev entries driver May 09 20:44:18 helios2 kernel: fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! May 09 20:44:18 helios2 kernel: vdd_cpu_b: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! May 09 20:44:18 helios2 kernel: vdd_gpu: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: dw_wdt ff848000.watchdog: No valid TOPs array specified May 09 20:44:18 helios2 kernel: sdhci: Secure Digital Host Controller Interface driver May 09 20:44:18 helios2 kernel: sdhci: Copyright(c) Pierre Ossman May 09 20:44:18 helios2 kernel: Synopsys Designware Multimedia Card Interface Driver May 09 20:44:18 helios2 kernel: sdhci-pltfm: SDHCI platform and OF driver helper May 09 20:44:18 helios2 kernel: ledtrig-cpu: registered to indicate activity on CPUs May 09 20:44:18 helios2 kernel: hid: raw HID events driver (C) Jiri Kosina May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver usbhid May 09 20:44:18 helios2 kernel: usbhid: USB HID core driver May 09 20:44:18 helios2 kernel: drop_monitor: Initializing network drop monitor service May 09 20:44:18 helios2 kernel: NET: Registered PF_INET6 protocol family May 09 20:44:18 helios2 kernel: usb 1-1: new high-speed USB device number 2 using xhci-hcd May 09 20:44:18 helios2 kernel: Freeing initrd memory: 13060K May 09 20:44:18 helios2 kernel: usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04 May 09 20:44:18 helios2 kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 May 09 20:44:18 helios2 kernel: usb 1-1: Product: USB2.0 Hub May 09 20:44:18 helios2 kernel: usb 1-1: Manufacturer: VIA Labs, Inc. May 09 20:44:18 helios2 kernel: hub 1-1:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 1-1:1.0: 4 ports detected May 09 20:44:18 helios2 kernel: Segment Routing with IPv6 May 09 20:44:18 helios2 kernel: In-situ OAM (IOAM) with IPv6 May 09 20:44:18 helios2 kernel: NET: Registered PF_PACKET protocol family May 09 20:44:18 helios2 kernel: 8021q: 802.1Q VLAN Support v1.8 May 09 20:44:18 helios2 kernel: Key type dns_resolver registered May 09 20:44:18 helios2 kernel: registered taskstats version 1 May 09 20:44:18 helios2 kernel: Loading compiled-in X.509 certificates May 09 20:44:18 helios2 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 1fb701576c47097ebe5805564f004ecdeffa983a' May 09 20:44:18 helios2 kernel: zswap: loaded using pool zstd/z3fold May 09 20:44:18 helios2 kernel: Key type .fscrypt registered May 09 20:44:18 helios2 kernel: Key type fscrypt-provisioning registered May 09 20:44:18 helios2 kernel: Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes May 09 20:44:18 helios2 kernel: Key type encrypted registered May 09 20:44:18 helios2 kernel: AppArmor: AppArmor sha1 policy hashing enabled May 09 20:44:18 helios2 kernel: usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd May 09 20:44:18 helios2 kernel: pcie_power: supplied by vcc5v0_perdev May 09 20:44:18 helios2 kernel: vcc3v3_sys_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v0_sd: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: vcc5v0_usb: supplied by vcc5v0_perdev May 09 20:44:18 helios2 kernel: vcc5v0_typec: supplied by vcc5v0_usb May 09 20:44:18 helios2 kernel: usblan_power: supplied by vcc5v0_usb May 09 20:44:18 helios2 kernel: pca953x 2-0020: using no AI May 09 20:44:18 helios2 kernel: rk808 0-001b: chip id: 0x0 May 09 20:44:18 helios2 kernel: rk808-regulator rk808-regulator: there is no dvs0 gpio May 09 20:44:18 helios2 kernel: rk808-regulator rk808-regulator: there is no dvs1 gpio May 09 20:44:18 helios2 kernel: rk808-regulator rk808-regulator: max buck steps per change: 4 May 09 20:44:18 helios2 kernel: vdd_center: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vdd_cpu_l: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc_ddr_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v8_sys_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v8_dvp: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v0_touch: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v8_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV May 09 20:44:18 helios2 kernel: vcc_sdio_s0: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcca3v0_codec: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v5_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcca1v8_codec: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v0_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER May 09 20:44:18 helios2 kernel: vcc3v3_sys_s0: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: vcc3v3_s0: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: rk808-rtc rk808-rtc: registered as rtc0 May 09 20:44:18 helios2 kernel: rk808-rtc rk808-rtc: setting system clock to 2024-05-09T19:41:41 UTC (1715283701) May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode. May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: Using internal DMA controller. May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: Version ID is 270a May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: Got CD GPIO May 09 20:44:18 helios2 kernel: vcc1v8_sys_s0: supplied by vcc1v8_sys_s3 May 09 20:44:18 helios2 kernel: vcc0v9_s3: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: avdd_0v9_s0: supplied by vcc1v8_sys_s3 May 09 20:44:18 helios2 kernel: avdd_1v8_s0: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms May 09 20:44:18 helios2 kernel: mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 May 09 20:44:18 helios2 kernel: pci_bus 0000:00: root bus resource [bus 00-1f] May 09 20:44:18 helios2 kernel: pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] May 09 20:44:18 helios2 kernel: pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: supports D1 May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: PME# supported from D0 D1 D3hot May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: [197b:0585] type 00 class 0x010601 May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x10: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x14: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x18: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x1c: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: usb 2-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04 May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x20: [io size 0x0080] May 09 20:44:18 helios2 kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 May 09 20:44:18 helios2 kernel: usb 2-1: Product: USB3.0 Hub May 09 20:44:18 helios2 kernel: usb 2-1: Manufacturer: VIA Labs, Inc. May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512) May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: PME# supported from D3hot May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link) May 09 20:44:18 helios2 kernel: pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01 May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 0: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 1: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 2: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 3: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 4: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: PCI bridge to [bus 01] May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] May 09 20:44:18 helios2 kernel: pcieport 0000:00:00.0: enabling device (0000 -> 0002) May 09 20:44:18 helios2 kernel: pcieport 0000:00:00.0: PME: Signaling with IRQ 89 May 09 20:44:18 helios2 kernel: pcieport 0000:00:00.0: AER: enabled with IRQ 89 May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: version 3.0 May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: enabling device (0000 -> 0002) May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh May 09 20:44:18 helios2 kernel: scsi host0: ahci May 09 20:44:18 helios2 kernel: scsi host1: ahci May 09 20:44:18 helios2 kernel: hub 2-1:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 2-1:1.0: 4 ports detected May 09 20:44:18 helios2 kernel: scsi host2: ahci May 09 20:44:18 helios2 kernel: scsi host3: ahci May 09 20:44:18 helios2 kernel: scsi host4: ahci May 09 20:44:18 helios2 kernel: ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 90 May 09 20:44:18 helios2 kernel: ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 91 May 09 20:44:18 helios2 kernel: ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 92 May 09 20:44:18 helios2 kernel: ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 93 May 09 20:44:18 helios2 kernel: ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 94 May 09 20:44:18 helios2 kernel: mmc1: CQHCI version 5.10 May 09 20:44:18 helios2 kernel: WCN: marlin_init entry! May 09 20:44:18 helios2 kernel: input: gpio-keys as /devices/platform/gpio-keys/input/input0 May 09 20:44:18 helios2 kernel: of_cfs_init May 09 20:44:18 helios2 kernel: of_cfs_init: OK May 09 20:44:18 helios2 kernel: mmc1: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA May 09 20:44:18 helios2 kernel: mmc1: Command Queue Engine enabled May 09 20:44:18 helios2 kernel: mmc1: new HS200 MMC card at address 0001 May 09 20:44:18 helios2 kernel: mmcblk1: mmc1:0001 AJTD4R 14.6 GiB May 09 20:44:18 helios2 kernel: mmcblk1: p1 May 09 20:44:18 helios2 kernel: mmcblk1boot0: mmc1:0001 AJTD4R 4.00 MiB May 09 20:44:18 helios2 kernel: mmcblk1boot1: mmc1:0001 AJTD4R 4.00 MiB May 09 20:44:18 helios2 kernel: mmcblk1rpmb: mmc1:0001 AJTD4R 4.00 MiB, chardev (241:0) May 09 20:44:18 helios2 kernel: usb 2-1.4: new SuperSpeed USB device number 3 using xhci-hcd May 09 20:44:18 helios2 kernel: usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00 May 09 20:44:18 helios2 kernel: usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6 May 09 20:44:18 helios2 kernel: usb 2-1.4: Product: USB 10/100/1G/2.5G LAN May 09 20:44:18 helios2 kernel: usb 2-1.4: Manufacturer: Realtek May 09 20:44:18 helios2 kernel: usb 2-1.4: SerialNumber: 000000001 May 09 20:44:18 helios2 kernel: ata1: softreset failed (1st FIS failed) May 09 20:44:18 helios2 kernel: ata1: softreset failed (1st FIS failed) May 09 20:44:18 helios2 kernel: vcc3v0_sd: disabling May 09 20:44:18 helios2 kernel: ata1: softreset failed (1st FIS failed) May 09 20:44:18 helios2 kernel: ata1: limiting SATA link speed to 3.0 Gbps May 09 20:44:18 helios2 kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320) May 09 20:44:18 helios2 kernel: ata1: link online but 1 devices misclassified, device detection might fail May 09 20:44:18 helios2 kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) May 09 20:44:18 helios2 kernel: ata2.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 May 09 20:44:18 helios2 kernel: ata2.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA May 09 20:44:18 helios2 kernel: ata2.00: configured for UDMA/133 May 09 20:44:18 helios2 kernel: scsi 1:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] 4096-byte physical blocks May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Write Protect is off May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA May 09 20:44:18 helios2 kernel: sda: sda1 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Attached SCSI disk May 09 20:44:18 helios2 kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) May 09 20:44:18 helios2 kernel: ata3.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 May 09 20:44:18 helios2 kernel: ata3.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA May 09 20:44:18 helios2 kernel: ata3.00: configured for UDMA/133 May 09 20:44:18 helios2 kernel: scsi 2:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] 4096-byte physical blocks May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Write Protect is off May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA May 09 20:44:18 helios2 kernel: sdb: sdb1 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Attached SCSI disk May 09 20:44:18 helios2 kernel: ata4: SATA link down (SStatus 0 SControl 300) May 09 20:44:18 helios2 kernel: ata5: SATA link down (SStatus 0 SControl 300) May 09 20:44:18 helios2 kernel: Freeing unused kernel memory: 4352K May 09 20:44:18 helios2 kernel: Run /init as init process May 09 20:44:18 helios2 kernel: with arguments: May 09 20:44:18 helios2 kernel: /init May 09 20:44:18 helios2 kernel: with environment: May 09 20:44:18 helios2 kernel: HOME=/ May 09 20:44:18 helios2 kernel: TERM=linux May 09 20:44:18 helios2 kernel: ubootpart=306d94a6-01 May 09 20:44:18 helios2 kernel: cgroup_enable=memory May 09 20:44:18 helios2 kernel: cgroup_memory=1 May 09 20:44:18 helios2 kernel: input: adc-keys as /devices/platform/adc-keys/input/input1 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: PTP uses main clock May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: RX delay(0x20). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: clock input from PHY May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: init for RGMII May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: DWMAC1000 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: COE Type 2 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Normal descriptors May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Ring mode enabled May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer May 09 20:44:18 helios2 kernel: RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL) May 09 20:44:18 helios2 kernel: RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL) May 09 20:44:18 helios2 kernel: async_tx: api initialized (async) May 09 20:44:18 helios2 kernel: EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. May 09 20:44:18 helios2 systemd[1]: Inserted module 'autofs4' May 09 20:44:18 helios2 systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) May 09 20:44:18 helios2 systemd[1]: Detected architecture arm64. May 09 20:44:18 helios2 systemd[1]: Set hostname to <helios2>. May 09 20:44:18 helios2 kernel: dw-apb-uart ff1a0000.serial: forbid DMA for kernel console May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 systemd[1]: /lib/systemd/system/haveged.service:19: Unknown lvalue 'ProtectHostname' in section 'Service', ignoring May 09 20:44:18 helios2 systemd[1]: /lib/systemd/system/haveged.service:20: Unknown lvalue 'ProtectKernelLogs' in section 'Service', ignoring May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 systemd[1]: Listening on udev Control Socket. May 09 20:44:18 helios2 systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 systemd[1]: Listening on fsck to fsckd communication Socket. May 09 20:44:18 helios2 systemd[1]: Listening on initctl Compatibility Named Pipe. May 09 20:44:18 helios2 systemd[1]: Reached target Swap. May 09 20:44:18 helios2 kernel: lm75 2-004c: supply vs not found, using dummy regulator May 09 20:44:18 helios2 kernel: hwmon hwmon2: temp1_input not attached to any thermal zone May 09 20:44:18 helios2 kernel: lm75 2-004c: hwmon2: sensor 'lm75' May 09 20:44:18 helios2 kernel: EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. May 09 20:44:18 helios2 kernel: mc: Linux media interface: v0.10 May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 kernel: videodev: Linux video capture interface: v2.00 May 09 20:44:18 helios2 kernel: input: beeper as /devices/platform/beeper/input/input2 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0 May 09 20:44:18 helios2 kernel: rockchip-iep ff670000.iep: Device rockchip-iep registered as /dev/video0 May 09 20:44:18 helios2 kernel: rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned. May 09 20:44:18 helios2 kernel: rockchip-rga ff680000.rga: HW Version: 0x03.02 May 09 20:44:18 helios2 kernel: hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned. May 09 20:44:18 helios2 kernel: rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video1 May 09 20:44:18 helios2 kernel: rkvdec ff660000.video-codec: Adding to iommu group 1 May 09 20:44:18 helios2 kernel: OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 May 09 20:44:18 helios2 kernel: hantro-vpu ff650000.video-codec: Adding to iommu group 0 May 09 20:44:18 helios2 kernel: hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video3 May 09 20:44:18 helios2 kernel: hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video4 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: clock rate = 500000000 May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) May 09 20:44:18 helios2 kernel: [drm] unsupported AFBC format[3231564e] May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops) May 09 20:44:18 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes May 09 20:44:18 helios2 kernel: [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: irq 74, io mem 0xfe800000 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed May 09 20:44:18 helios2 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb3: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb3: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb3: SerialNumber: xhci-hcd.3.auto May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: EHCI Host Controller May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 May 09 20:44:18 helios2 kernel: hub 3-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 3-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. May 09 20:44:18 helios2 kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb4: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb4: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb4: SerialNumber: xhci-hcd.3.auto May 09 20:44:18 helios2 kernel: hub 4-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 4-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:18 helios2 kernel: [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 0 May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: irq 34, io mem 0xfe380000 May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 May 09 20:44:18 helios2 kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb5: Product: EHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb5: Manufacturer: Linux 5.15.93-rockchip64 ehci_hcd May 09 20:44:18 helios2 kernel: usb usb5: SerialNumber: fe380000.usb May 09 20:44:18 helios2 kernel: hub 5-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 5-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: ohci-platform fe3a0000.usb: Generic Platform OHCI controller May 09 20:44:18 helios2 kernel: ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 May 09 20:44:18 helios2 kernel: ohci-platform fe3a0000.usb: irq 35, io mem 0xfe3a0000 May 09 20:44:18 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:18 helios2 kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 May 09 20:44:19 helios2 kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:19 helios2 kernel: usb usb6: Product: Generic Platform OHCI controller May 09 20:44:19 helios2 kernel: usb usb6: Manufacturer: Linux 5.15.93-rockchip64 ohci_hcd May 09 20:44:19 helios2 kernel: usb usb6: SerialNumber: fe3a0000.usb May 09 20:44:19 helios2 kernel: hub 6-0:1.0: USB hub found May 09 20:44:19 helios2 kernel: hub 6-0:1.0: 1 port detected May 09 20:44:19 helios2 kernel: EXT4-fs (sdb1): recovery complete May 09 20:44:19 helios2 kernel: EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. May 09 20:44:19 helios2 kernel: usb 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd May 09 20:44:19 helios2 kernel: EXT4-fs (sda1): recovery complete May 09 20:44:19 helios2 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0: Direct firmware load for rtl_nic/rtl8156a-2.fw failed with error -2 May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0: unable to load firmware patch rtl_nic/rtl8156a-2.fw (-2) May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256 May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0 eth1: v1.12.13 May 09 20:44:19 helios2 kernel: usbcore: registered new interface driver r8152 May 09 20:44:19 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:19 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:19 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:19 helios2 kernel: random: crng init done May 09 20:44:19 helios2 kernel: random: 99 urandom warning(s) missed due to ratelimiting May 09 20:44:19 helios2 systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start timed out. May 09 20:44:19 helios2 systemd[1]: Timed out waiting for device /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80. May 09 20:44:19 helios2 systemd[1]: Dependency failed for /data/glusterfs/sda1. May 09 20:44:19 helios2 systemd[1]: Dependency failed for Local File Systems. May 09 20:44:19 helios2 systemd[1]: Dependency failed for Mark the need to relabel after reboot. May 09 20:44:19 helios2 systemd[1]: selinux-autorelabel-mark.service: Job selinux-autorelabel-mark.service/start failed with result 'dependency'. May 09 20:44:19 helios2 systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'. May 09 20:44:19 helios2 systemd[1]: local-fs.target: Triggering OnFailure= dependencies. May 09 20:44:19 helios2 systemd[1]: data-glusterfs-sda1.mount: Job data-glusterfs-sda1.mount/start failed with result 'dependency'. May 09 20:44:19 helios2 systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start failed with result 'timeout'. May 09 20:44:19 helios2 kernel: zram: Added device: zram0 May 09 20:44:19 helios2 kernel: zram: Added device: zram1 May 09 20:44:19 helios2 kernel: zram: Added device: zram2 May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL) May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode May 09 20:44:19 helios2 kernel: zram0: detected capacity change from 0 to 3956192 May 09 20:44:19 helios2 kernel: Adding 1978092k swap on /dev/zram0. Priority:5 extents:1 across:1978092k SSFS May 09 20:44:19 helios2 kernel: zram1: detected capacity change from 0 to 102400 May 09 20:44:19 helios2 kernel: EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. May 09 20:44:19 helios2 kernel: ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) May 09 20:44:19 helios2 systemd-journald[1325]: Journal started May 09 20:44:19 helios2 systemd-journald[1325]: Runtime journal (/run/log/journal/25f3942c18884f46bd8ed710d6b0edb4) is 4.8M, max 38.6M, 33.8M free. May 09 20:44:19 helios2 systemd-modules-load[410]: Inserted module 'lm75' May 09 20:44:19 helios2 systemd-modules-load[410]: Inserted module 'ledtrig_netdev' May 09 20:44:19 helios2 systemd-udevd[469]: Using default interface naming scheme 'v240'. May 09 20:44:19 helios2 systemd-udevd[448]: Process '/bin/ln -sf /sys/devices/platform/ff120000.i2c/i2c-2/2-004c/hwmon/hwmon2 /dev/thermal-board' failed with exit code 1. May 09 20:44:19 helios2 systemd-udevd[469]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. May 09 20:44:19 helios2 systemd-udevd[469]: link_config: could not get ethtool features for eth0 May 09 20:44:19 helios2 systemd-udevd[469]: Could not set offload features of eth0: Device or resource busy May 09 20:44:19 helios2 systemd-udevd[452]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. May 09 20:44:19 helios2 systemd-udevd[443]: Process '/bin/ln -sf /sys/devices/virtual/thermal/thermal_zone0/hwmon0 /dev/thermal-cpu' failed with exit code 1. May 09 20:44:19 helios2 systemd-udevd[441]: Using default interface naming scheme 'v240'. May 09 20:44:19 helios2 systemd-udevd[441]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. May 09 20:44:19 helios2 ifup[558]: ifup: waiting for lock on /run/network/ifstate.eth0 May 09 20:44:19 helios2 sh[560]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf May 09 20:44:19 helios2 sh[560]: eth0=eth0 May 09 20:44:19 helios2 armbian-zram-config[562]: Setting up swapspace version 1, size = 1.9 GiB (2025566208 bytes) May 09 20:44:19 helios2 armbian-zram-config[562]: no label, UUID=ed7bfb56-a4cb-453e-9cbd-5fe82531227e May 09 20:44:19 helios2 armbian-zram-config[562]: mke2fs 1.46.2 (28-Feb-2021) May 09 20:44:19 helios2 armbian-zram-config[562]: [74B blob data] May 09 20:44:19 helios2 armbian-zram-config[562]: Creating filesystem with 12800 4k blocks and 12800 inodes May 09 20:44:19 helios2 armbian-zram-config[562]: [41B blob data] May 09 20:44:19 helios2 armbian-zram-config[562]: [38B blob data] May 09 20:44:19 helios2 armbian-zram-config[562]: [75B blob data] May 09 20:44:19 helios2 armbian-hardware-optimization[585]: aplay: device_list:272: no soundcards found... May 09 20:44:19 helios2 armbian-ramlog[975]: e2label: Bad magic number in super-block while trying to open /dev/zram0 May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting bfq I/O scheduler for sda May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting bfq I/O scheduler for sdb May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting none I/O scheduler for mmcblk1 May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting none I/O scheduler for mmcblk1boot0 May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting none I/O scheduler for mmcblk1boot1 May 09 20:44:19 helios2 armbian-ramlog[975]: Mounting /dev/zram1 as /var/log/ May 09 20:44:19 helios2 armbian-ramlog[975]: Thu 09 May 2024 08:44:16 PM BST: Loading logs from storage May 09 20:44:19 helios2 armbian-ramlog[975]: sending incremental file list May 09 20:44:19 helios2 armbian-ramlog[975]: ./ May 09 20:44:19 helios2 armbian-ramlog[975]: alternatives.log May 09 20:44:19 helios2 armbian-ramlog[975]: armbian-hardware-monitor.log May 09 20:44:19 helios2 armbian-ramlog[975]: auth.log May 09 20:44:19 helios2 armbian-ramlog[975]: bootstrap.log May 09 20:44:19 helios2 armbian-ramlog[975]: btmp May 09 20:44:19 helios2 armbian-ramlog[975]: daemon.log May 09 20:44:19 helios2 armbian-ramlog[975]: debug May 09 20:44:19 helios2 armbian-ramlog[975]: dpkg.log May 09 20:44:19 helios2 armbian-ramlog[975]: faillog May 09 20:44:19 helios2 armbian-ramlog[975]: kern.log May 09 20:44:19 helios2 armbian-ramlog[975]: lastlog May 09 20:44:19 helios2 armbian-ramlog[975]: messages May 09 20:44:19 helios2 armbian-ramlog[975]: nand-sata-install.log May 09 20:44:19 helios2 armbian-ramlog[975]: syslog May 09 20:44:19 helios2 armbian-ramlog[975]: user.log May 09 20:44:19 helios2 armbian-ramlog[975]: wtmp May 09 20:44:19 helios2 armbian-ramlog[975]: apt/ May 09 20:44:19 helios2 armbian-ramlog[975]: apt/history.log May 09 20:44:19 helios2 armbian-ramlog[975]: apt/term.log May 09 20:44:19 helios2 armbian-ramlog[975]: chrony/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bitd.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/cli.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/cmd_history.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/data-media.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/glusterd.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/media-rebalance.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/scrub.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/data-glusterfs-sda1-brick1.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/data-glusterfs-sdb1-brick1.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/data-glusterfs-sdc1-brick1.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/geo-replication-slaves/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/geo-replication-slaves/mbr/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/geo-replication/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/gfproxy/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/gfproxy/media/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/snaps/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/snaps/media/ May 09 20:44:19 helios2 armbian-ramlog[975]: private/ May 09 20:44:19 helios2 armbian-ramlog[975]: runit/ May 09 20:44:19 helios2 armbian-ramlog[975]: runit/ssh/ May 09 20:44:19 helios2 armbian-ramlog[975]: sysstat/ May 09 20:44:19 helios2 armbian-ramlog[975]: unattended-upgrades/ May 09 20:44:19 helios2 armbian-ramlog[975]: unattended-upgrades/unattended-upgrades-shutdown.log May 09 20:44:19 helios2 armbian-ramlog[975]: sent 9,084,219 bytes received 650 bytes 6,056,579.33 bytes/sec May 09 20:44:19 helios2 armbian-ramlog[975]: total size is 9,079,468 speedup is 1.00 May 09 20:44:19 helios2 systemd[1]: Starting Flush Journal to Persistent Storage... May 09 20:44:19 helios2 systemd-journald[1325]: Runtime journal (/run/log/journal/25f3942c18884f46bd8ed710d6b0edb4) is 4.8M, max 38.6M, 33.8M free. May 09 20:44:19 helios2 systemd[1]: Started Flush Journal to Persistent Storage. May 09 20:44:19 helios2 systemd[1]: Starting Create Volatile Files and Directories... May 09 20:44:19 helios2 systemd[1]: Started Create Volatile Files and Directories. May 09 20:44:19 helios2 systemd[1]: Starting RPC bind portmap service... May 09 20:44:19 helios2 systemd[1]: Starting Update UTMP about System Boot/Shutdown... May 09 20:44:19 helios2 systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm. May 09 20:44:19 helios2 systemd[1]: Started RPC bind portmap service. May 09 20:44:19 helios2 systemd[1]: Reached target RPC Port Mapper. May 09 20:44:19 helios2 systemd[1]: Reached target Remote File Systems (Pre). May 09 20:44:19 helios2 haveged[1354]: haveged: command socket is listening at fd 3 May 09 20:44:19 helios2 systemd[1]: Mounting /data/media... May 09 20:44:19 helios2 systemd[1]: Started Update UTMP about System Boot/Shutdown. May 09 20:44:19 helios2 systemd[1]: Starting Update UTMP about System Runlevel Changes... May 09 20:44:19 helios2 systemd[1]: systemd-update-utmp-runlevel.service: Succeeded. May 09 20:44:19 helios2 systemd[1]: Started Update UTMP about System Runlevel Changes. May 09 20:44:19 helios2 haveged[1354]: haveged: ver: 1.9.14; arch: generic; vend: ; build: (gcc 10.2.1 CTV); collect: 128K May 09 20:44:19 helios2 haveged[1354]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15456/64452 May 09 20:44:19 helios2 haveged[1354]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B): last entropy estimate 7.99723 May 09 20:44:19 helios2 haveged[1354]: haveged: fills: 0, generated: 0 May 09 20:44:20 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off May 09 20:44:20 helios2 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready May 09 20:44:21 helios2 systemd[579]: emergency.service: Executable /bin/plymouth missing, skipping: No such file or directory May 09 20:44:22 helios2 mount[1355]: Mounting glusterfs on /data/media failed. May 09 20:44:22 helios2 systemd[1]: data-media.mount: Mount process exited, code=exited, status=1/FAILURE May 09 20:44:22 helios2 systemd[1]: Mounted /data/media. May 09 20:44:22 helios2 systemd[1]: Reached target Remote File Systems. May 09 20:44:22 helios2 systemd[1]: Startup finished in 1min 6.014s (kernel) + 1min 37.173s (userspace) = 2min 43.188s. May 09 20:48:11 helios2 sudo[1764]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/bin/apt info armbian-bsp-cli-helios64 May 09 20:48:11 helios2 sudo[1764]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) May 09 20:48:12 helios2 sudo[1764]: pam_unix(sudo:session): session closed for user root May 09 20:49:01 helios2 sudo[2123]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/bin/apt info armbian-bsp-cli-helios64 May 09 20:49:01 helios2 sudo[2123]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) May 09 20:49:02 helios2 sudo[2123]: pam_unix(sudo:session): session closed for user root May 09 20:50:27 helios2 sudo[2130]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/sbin/service status --all May 09 20:50:27 helios2 sudo[2130]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) May 09 20:50:27 helios2 sudo[2130]: pam_unix(sudo:session): session closed for user root```
@Charlie Romer Thanks for the explaination. And thanks for the help. But since you aren't running Armbian, this won't help your DietPi situation. Often users come here to get help with DietPi thinking that because it is forked from Armbian that we can help them, but we can't.
That was a suggested troubleshooting step from a previous post - installing official orange pi images and running memtester to see if it would also panic... So thats what I just did (as others seem to have done in previous posts as well)... Unless I completely misunderstood the conversation taking place I don't think I'm out of line here. If anyone wants my help (little that it may be I do at least have the hardware in hand) let me know otherwise I can just sit back watch.
That is not an Armbian build. If that is what you have installed it isn't relevant to discussions here.
@SUPA The warpme patches need work to implement into Armbian. That is what I have been trying to do. When and if we get it right, they should be included into the Armbian system. In the meantime clone my repository, which has the patches implemented, and build your flavour of system from there. cd ~/ git clone https://github.com/stephengraf/armbian_build_sg.git cd armbian_build_sg ./compile.sh The HDMI sound should work immediately. The analog needs to be enabled as @sasa suggested: /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute
- 14 replies
- Banana Pi M4 Zero
- Orange Pi Zero 2
(and 1 more)
Tagged with:
Oh you misunderstand - I am here because I originally started with DietPi - now I just want to figure out why this thing kernel panics at all on whatever OS. This forum seems to be the only place currently discussing it and y'all seemed like you needed help...
@Charlie Romer This site is for Armbian issues not DietPi issues. You need to direct your question to DietPi forums as we can't help you here.
I just want to jump in here as I started running into these issues while upgrading my homelab server running DietPi from a 16GB to 32GB unit (or at least hoping to but thats on pause for now haha). As a test I just installed a fresh copy of Orangepi5plus_1.0.8_debian_bookworm_server_linux6.1.43 and ran sudo memtester 30G and it resulted in a panic. I also tried the same command starting at 8G (fine), 10G (fine) and then 11G and it panic'd. A fresh install and only running sudo memtester 11G resulted in a panic too. The only unique aspect that I can add about my setup is that I did run the SPI bootloader update to be able to boot from NVME (however the only storage drive attached is an the boot SD card). I can also install to eMMC as well if that would be helpful. I managed to capture a slow mo video of the start of the panic and have posted a screenshot of the start of the panic here in case it's useful in any way. This is all a bit over my head but I'd be happy to help if there's anything I test and report back on if someone doesn't mind walking me through things.
Pi 5 - can't build ZFS module due to kernel headers
Hank Barta replied to Hank Barta's topic in Beginners
Thanks for the suggestion. There was no option for kernels in armbian-config -> software. I there was an option to switch to nightly in armbian-config -> system and I executed that. It installed a new kernel and now the system hangs on the 4 pixel rainbow screen. I should probably have mentioned that this is on a Pi CM4 booting from an NVME SSD. I'm trying things out on that to avoid swapping NVME SSDs on my Pi 5. I'm aware that RpiOS runs different kernels on Pi 4 vs. Pi 4B/CM4 but they install both and choose the correct one during boot. -
Description Some boards needs to be re-promoted, some retired. Welcome to add commits to this PR by the end of February. Please check https://docs.armbian.com/User-Guide_Board-Support-Rules/ prior to proposing. Checklist: [x] My code follows the style guidelines of this project View the full article
updating template for building standard support images. Keeping Jammy CLI and Jammy XFCE desktop, upgrade other Jammy to Noble. Keeping old stable user-land with more recent kernel is actually a perfect combination. download pages were adjusted to current status. release candidate images upload locations: https://armbian.site-meganet.com/incoming/ https://k-space.ee.armbian.com/incoming/ https://stpete-mirror.armbian.com/incoming/ https://fi.mirror.armbian.de/incoming/
Headers package version mismatch 24.2.5 vs 24.2.1
Hank Barta replied to Michal Fita's topic in Raspberry Pi
sudo apt install linux-image-current-bcm2712=24.2.1 Did this solve the kernel/header mismatch? I ran into the same issue (and posted separately - not sure that's public yet.) My search-foo was not sufficient to find this post. best,
