sgjava
Everything posted by sgjava
  1. Just a note the download of latest release Armbian_25.8.1_Odroidxu4_noble_current_6.6.102.img works fine, so something in the build system.
  2. @Igor @belegdol I was able to get it working, but maybe this can be fixed in the build? Fix: Odroid XU4 – Armbian-unofficial_25.11.0-trunk_Noble_6.6.108 fails to boot from SATA after nand-sata-install Problem After running nand-sata-install on an Odroid XU4 (kernel 6.6.108), the system copies to SATA correctly but fails to boot afterward, dropping into the initramfs shell. Checking the loaded modules shows only: usbhid meaning no USB or SCSI drivers are available to detect /dev/sda1. Inspecting the initramfs with: lsinitramfs /boot/initrd.img-6.6.108-current-odroidxu4 | grep usb reveals that usb-storage.ko, uas.ko, and other USB mass-storage modules are missing. Root Cause The file /etc/initramfs-tools/initramfs.conf already had: MODULES=most so the base configuration was fine. However, Armbian’s initramfs build process did not automatically include the USB/SCSI modules, because the system was booted from SD and those drivers were not "in use" during image generation. As a result, the cloned SATA system lacked the drivers needed to mount its root filesystem. Solution Fix the SD card initramfs before running nand-sata-install. This ensures the SATA copy inherits a working image with all required modules. 1️⃣ Boot from SD and verify Confirm you are booted from SD: df -h / You should see /dev/mmcblk0p* as /. 2️⃣ Verify initramfs configuration Open /etc/initramfs-tools/initramfs.conf and confirm it contains: MODULES=most 3️⃣ Add required USB and SCSI modules Create or edit /etc/initramfs-tools/modules: USB host + storage + SCSI stack for SATA boot usbcore usb-common ehci-hcd ehci-platform ehci-fsl fsl-mph-dr-of xhci-hcd xhci-pci xhci-plat-hcd scsi_mod sd_mod sg uas usb-storage 4️⃣ Rebuild the initramfs and regenerate uInitrd sudo update-initramfs -c -k $(uname -r) cd /boot sudo mkimage -A arm -O linux -T ramdisk -C none -n uInitrd -d initrd.img-$(uname -r) uInitrd sync 5️⃣ Verify the new initramfs lsinitramfs /boot/initrd.img-$(uname -r) | grep usb/storage Expected output (partial): .../usb-storage.ko .../uas.ko .../ums-*.ko 6️⃣ Reboot from SD to confirm it works sudo reboot If it boots normally, the rebuilt initramfs is valid. 7️⃣ Run nand-sata-install sudo nand-sata-install Select your SATA target. Because the SD image is now fixed, the SATA copy will contain a working initramfs. 8️⃣ Update boot.ini Edit /media/mmcboot/boot.ini and set: setenv rootdev "UUID=<your SATA UUID>" 9️⃣ Reboot and verify SATA root df -h / Expected result: /dev/sda1 → / /dev/mmcblk0p1 → /media/mmcboot Result ✅ SATA boots successfully ✅ Kernel loads usb-storage, uas, sd_mod, scsi_mod early ✅ / mounts from SATA cleanly — no initramfs prompt ✅ nand-sata-install works correctly on Odroid XU4 (Noble 6.6.108) Summary Even though MODULES=most was already set, the USB/SCSI stack was not automatically included in the initramfs when booting from SD. Manually listing the required modules in /etc/initramfs-tools/modules before rebuilding ensures the image contains usb-storage.ko, uas.ko, and related drivers. Once rebuilt, both SD and SATA boots work reliably.
  3. ls /lib/modules/$(uname -r)/kernel/ arch block crypto drivers fs kernel lib mm net sound Not sure why @belegdol stuff is under usr/lib/modules?
  4. @IgorI'm back from the brink. New job, new house build 3 hurricanes. I'm still working on my 1 acre lot to clean up the vines and stuff, but I'm starting to have more time for this kind of stuff. I need to get all my old boards up to date, hahaha
  5. @belegdol This is from an image I built, but even the downloaded one wouldn't work with nand-sata-install. lsinitramfs /boot/initrd.img-6.6.108-current-odroidxu4 | grep usb usr/lib/modules/6.6.108-current-odroidxu4/kernel/drivers/hid/usbhid usr/lib/modules/6.6.108-current-odroidxu4/kernel/drivers/hid/usbhid/usbhid.ko usr/lib/modules/6.6.108-current-odroidxu4/kernel/drivers/usb usr/lib/modules/6.6.108-current-odroidxu4/kernel/drivers/usb/host usr/lib/modules/6.6.108-current-odroidxu4/kernel/drivers/usb/host/ehci-fsl.ko usr/lib/modules/6.6.108-current-odroidxu4/kernel/drivers/usb/host/fsl-mph-dr-of.ko usr/lib/systemd/network/73-usb-net-by-mac.link usr/lib/udev/rules.d/50-usb-realtek-net.rules
  6. OK, good thing I don't give up easily. I found the cause, but now I need to figure out a fix. Using Armbian_23.11.1_Odroidxu4_jammy_current_6.1.63.img I changed the setenv rootdev to a bad UUID. I get the same error as latest image, but cat /proc/modules shows what's happening. Armbian_23.11.1_Odroidxu4_jammy_current_6.1.63.img initramfs loads: Module Function ------------------ ------------------------------------------------------------- scsi_mod Core SCSI subsystem. (Crucial) sd_mod SCSI disk driver (used for all block devices like SD, USB, SATA). (Crucial) t10_pi T10 Protection Information (disk data integrity). crc64_rocksoft_generic CRC algorithm. crc64_rocksoft CRC algorithm. sg SCSI Generic (raw access to SCSI devices). uas USB Attached SCSI (Driver for USB-to-SATA adapter). (Crucial) usb_storage Generic USB Mass Storage driver. (Crucial) scsi_common Common SCSI routines. zram Compressed RAM block device. zsmalloc ZRAM memory allocator. sch_fq_codel Network queue scheduler. Armbian-unofficial_25.11.0-trunk_Odroidxu4_noble_current_6.6.108.img initramfs only loads usbhid. Not sure how nand-sata-install works, but I'm assuming the something is hosed in initrd.img. Maybe @Igor knows where to look. I'm going to see if I can get the SD initrd.img on the SSD.
  7. I know this is older, but you need fping6 as well. See inside my install script for Zabbix server https://github.com/sgjava/install-zabbix/blob/589abd9527b1dbd505776a4c80afe8e515aef878/scripts/install.sh#L210
  8. OK, tried build my own full server image and the same error. It cannot find SSD, but nand-sata-install had no problem copying the file system over from the SD. The fstabs and boot.ini looks fine. I guess no one has tested this for a while. I'm just going to use Jammy version for now since it still works.
  9. Just saw this. I'm getting back into the game.
  10. Using Armbian_25.8.1_Odroidxu4_noble_current_6.6.102.img I can boot off SD. Then when I run nand-sata-install it sharts and comes up with initramfs prompt. I'll try to fix it there next time, but I'm just using a 3.5" SATA laptop disk with USB controller. .oading, please wait.. .tarting systemd-udevd version 255.4-1ubuntu0.11 .begin: Loading essential drivers ... done. .begin: Running /scripts/init-premount ... done. .begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. .begin: Running /scripts/local-premount ... done. .begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. done. Save up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay=(did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=546a0798-29c9-4f3c-beea-1563d848abd0 does not exist. Dropping to a shell! BusyBox v1.36.1 (Ubuntu 1:1.36.1-6ubuntu3.1) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) _ I had old image Armbian_23.11.1_Odroidxu4_jammy_current_6.1.63.img and it works fine.
  11. I'll try that first, then I'll try building it myself. Thank you.
  12. Tried installing Armbian_23.11.1_Nanopineoplus2_jammy_current_6.1.63.img and it is super slow during first boot process regardless of SD type. Localization craps out with "Failed to set time zone: Transport endpoint is not connected". I boot with wired Ethernet and when I get to a prompt I can ping outside locations. apt update produces "Hash Sum mismatch" Anyways, doing my part testing legacy boards, hahahaha
  13. Java UIO offers robust Java interfaces optimized for Linux Userspace IO, emphasizing high performance. Engineered from scratch, it leverages contemporary kernel APIs, libraries, and cutting-edge code generation methodologies, embodying a state-of-the-art cross-platform solution. Rather than reinventing established paradigms, Java UIO harnesses existing standards, avoiding redundant development commonly observed in other IO libraries. Seamlessly supporting JDK 21 LTS, this framework integrates Project Lombok to streamline code, enhancing readability and conciseness. https://github.com/sgjava/javauio
  14. I switched to a laptop mechanical drive and performance is better than SSD. Also, it works with UAS.
  15. armbianEnv.txt doesn't exist on Armbian_23.11.1_Odroidxu4_jammy_current_6.1.63.img or Armbian_23.11.1_Odroidxu4_bookworm_current_6.1.63.img. I built image from dev branch and same deal. Stable branch (23.11) dies and doesn't build. Oh crap I just read on the download page That creates the armbianEnv.txt file. I don't remember having to do that before. It's been a while since I've installed on XU4. OK that was it: sudo hdparm -Tt /dev/sda /dev/sda: Timing cached reads: 2042 MB in 2.00 seconds = 1022.35 MB/sec Timing buffered disk reads: 136 MB in 4.29 seconds = 31.68 MB/sec
  16. OK, tried this: lsusb Bus 004 Device 003: ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge sudo nano /etc/modprobe.d/disable-uas.conf options usb-storage quirks=174c:55aa:u sudo hdparm -Tt /dev/sda /dev/sda: Timing cached reads: 656 MB in 2.00 seconds = 327.95 MB/sec Timing buffered disk reads: 62 MB in 35.03 seconds = 1.77 MB/sec lsusb -t /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/2p, 5000M |__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=uas, 5000M |__ Port 2: Dev 4, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M Still in UAS mode. Do you really need to recompile the kernel?
  17. I just installed latest Jammy on XU-4 and it was running fine off SD. Then I did nand-sata-install and you can see below what happened. This used to work fine with older versions. sudo hdparm -Tt /dev/sda /dev/sda: Timing cached reads: 2 MB in 5.54 seconds = 369.48 kB/sec Timing buffered disk reads: 2 MB in 10.33 seconds = 198.19 kB/sec
  18. c-periphery was just updated, so I need to test build with u8g2 and UIO. What issue are you having?
  19. @goingSo you can get USB wifi to work? What about reboot? uboot used to not build, thus why I had to pull the debs.
  20. @goingIf you could just fix uboot and dtb we'd be all set, hahahaha
  21. @goingYes, as of last time I built, but you could try main or whatever new "master" branch is.
  22. sgjava
    Odroid C1
    @Tomasz Grzegurzko That's good to hear. I had the same results.
  23. I tested a Realtek RTL8152B 10/100 adapter, so storage probably works as well. Wifi would corrupt the SD, so I never got that working.
  24. I already mentioned that. If you stick with Ethernet then it's stable. nmtui adding wifi will hose your system.
  25. @Tim Makarios Yeah, I suspect there's going to be consistency issues depending on the distro and board. I'll go ahead and add the build stuff since it wont hurt if it's already there.
