MacBreaker
Profile Information
  • Gender
    Male
  • Location
    35708 Haiger, Hessen, Germany
  • Interests
    Arm Devices
13767 profile views
  1. Hello @greg396 What exactly are you trying to achieve? I assume you want to run Home Assistant in a virtual machine on ARM64. That's possible, but you need to install some prerequisites. According to your links, you're using an Orange Pi 5 Plus (RAM unknown). It's powerful enough, but I recommend at least 8GB. 🙂 First, install an ARM64 clone of Proxmox Virtual Environment (PXVirt). https://github.com/jiangcuo/pxvirt Then install HA: https://pimox-scripts.com/scripts?id=pimox-haos-vm `bash -c "$(curl -fsSL https://raw.githubusercontent.com/asylumexp/Proxmox/main/vm/pimox-haos-vm.sh)"` Done. If you run it on a home server it's OK! --- I personally use a Raspberry Pi 4 with 8GB of RAM running Armbian (trixie) since 1,5 year with PXVirt. It's running: Home Assistant (ARM64) Pi-hole OMV VM-Trixie Everything performs very well. 😃 Regards, Markus
  2. ->a bit off topic<- Okay, if you have enough time, you can play around with PXVIRT (formerly the Proxmox port). 🙂 (https://github.com/jiangcuo/pxvirt) It's like Proxmox for ARM64 devices. I've been playing around with an 8 GB Raspberry Pi 4 with a 256 GB USB SSD lying around. In short: I installed a self-made minimal image (RPi4b). Installed PXVIRT (https://docs.pxvirt.lierfang.com/en/installfromdebian.html) Created some LXC containers (e.g., Lyrion Media Server, Heimdall, Pihole, Portainer, etc.) Created a virtual machine (Bookworm with OMV) Created a virtual machine with HAOS / -> bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/vm/pimox-haos-vm.sh)" It's been running perfectly stable for 56 days now. 👍 Okay, it wasn't easy to set up and compile all the software components, but it's running perfectly. I plan to buy an Orange Pi 5 Plus with 32 GB RAM for these tasks next time. Regards, Markus
  3. Hi @Skalistan, see here.. Build your own image with the Build Framework. Markus
  4. Small hint.. try this: sudo rm -rf build git clone --depth=1 --branch=main https://github.com/armbian/build ..and compile again. In the most cases for me i'ts working again. Markus
  5. Hello @AlexVS, you wrote: That is no image with preinstalled OMV but with preinstalled openhab. There is no image for ri4 with OMV preinstalled (as far as i see..). You have to build it by yorself. See DIY on post 1. Markus
  6. Ahh, okay, i didn't know Now it's working.. 👍 Thank's Werner
  7. Hello Igor, try to build OMV for rpi4. ./compile.sh BOARD="rpi4b" BRANCH=current RELEASE=bookworm ENABLE_EXTENSIONS="omv" KERNEL_CONFIGURE="no" BUILD_MINIMAL="yes" Got these error messages: [🌿] Enabling extension [ omv ] [🔨] ERR: Extension problem -- cant find extension 'omv' anywhere - called by /home/master/build/lib/functions/general/extensions.sh [💥] Exiting with error 17 [ at /home/master/build/lib/functions/general/extensions.sh:1 enable_extension() --> lib/functions/general/extensions.sh:1 initialize_extension_manager() --> lib/functions/general/extensions.sh:135 do_main_configuration() --> lib/functions/configuration/main-config.sh:317 do_with_logging() --> lib/functions/logging/section-logging.sh:81 do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:29 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] What I'm doing wrong? Markus
  8. Hello @hyungjuk, try to build a image with this command: ./compile.sh BOARD=orangepiplus BRANCH=current RELEASE=bookworm BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,img As you can see the differend about Plus und Plus 2 is only the size of RAM. E. g. Plus = 1GB, Plus 2 = 2GB See in the build framework: Good luck, it should work.. I run Home Assistant for (small) tasks, without Problems.. Markus
  9. As far as i know Plus and Plus 2 share the same image. The Plus2e image didn't work. Maybe about the different USB ports. Last weekend i build a image for my Plus, it works perfect oob. Markus
  10. Had the problem many years ago with my Orange Pi PC Plus (ok, Kernel 3.4.x) The trick was to create 2 partitions on the SD card. E.g. the first with FAT16, only a few MB in size, and the 2nd with EXT4. Then it boots via MMC. Greetings Markus
