jernej Posted August 24, 2019 Posted August 24, 2019 @hexdump One of the mysteries is solved. Tanix TX6 doesn't have external 32768 Hz crystal, so it has to use internal one. After a quick hack in RTC driver, which takes care for that, there is no more RTC issues reported in dmesg and HDMI-CEC works from the beginning. I wonder if this also helps with Eachlink HDMI issue. Can you test this LE image on Eachlink box?
hexdump Posted August 24, 2019 Posted August 24, 2019 @jernej - no change: without video=HDMI-A-1:e no hdmi output - with that option hdmi works ...
jernej Posted August 24, 2019 Posted August 24, 2019 strange, then I have no idea and without HW I'm not sure I can do much. Maybe it's connected to DRAM issue
jernej Posted August 27, 2019 Posted August 27, 2019 @hexdump can you test patches from Maxime? It would be nice to respond with Tested-by tag if it works.
hexdump Posted August 27, 2019 Posted August 27, 2019 @jernej - sure will do - thanks for the hint - did not check my email yet ... not sure if i'll get to it today, but during the next days for sure ... in case the tests would be ok, shall i then respond with tested-by to all four of them?
jernej Posted August 27, 2019 Posted August 27, 2019 On 8/27/2019 at 6:52 PM, hexdump said: not sure if i'll get to it today, but during the next days for sure Expand Note that 5.3 will be released in about 2 weeks so don't delay too much On 8/27/2019 at 6:52 PM, hexdump said: in case the tests would be ok, shall i then respond with tested-by to all four of them? Expand I would say that you can just reply to cover letter, but in this case there isn't any, so yes. You can also reply with reviewed-by if you understand the code, but tested-by already helps.
hexdump Posted August 27, 2019 Posted August 27, 2019 @jernej - already tested and responded - it fixes the problem i'm too tired tonight and too slow to review them as well - maybe you can have a look?
jernej Posted August 27, 2019 Posted August 27, 2019 On 8/27/2019 at 7:39 PM, hexdump said: i'm too tired tonight and too slow to review them as well - maybe you can have a look? Expand Not today, I'm tired too. But I'm pretty sure someone would reviewed them because others complained too.
Tarzanus Posted August 31, 2019 Posted August 31, 2019 So there's actually no way to address more than 2GB of memory on H6 based boxes? How come they started selling and advertising 4GB models? I checked the Allwinner H6 tech docs and it clearly says it only supports 2GB of memory.
hexdump Posted September 1, 2019 Posted September 1, 2019 it is 3gb except for the eachlink h6 mini with its strange memory setup - this 4gb advertising thing is simply marketing i guess: most of those boxes really have 4gb, just that it is not useable it would be interesting if those 3gb are a hard limit of the hardware or if there are any ways to maybe move it to 3.5gb ... i know the h6 has 32bit memory addressing, but i think on other even full 32bit systems one can address close to 4gb ...
jernej Posted September 1, 2019 Posted September 1, 2019 On 9/1/2019 at 10:52 AM, hexdump said: it would be interesting if those 3gb are a hard limit of the hardware or if there are any ways to maybe move it to 3.5gb ... i know the h6 has 32bit memory addressing, but i think on other even full 32bit systems one can address close to 4gb ... Expand It's hard limit - address space is 32-bit and first byte from DRAM can be reached at address 0x40000000 (1G). If Allwinner would re-arrange peripherals below 1G, it could squeeze out another 512M or so, but in that case memory address decoder becomes more complicated (slower).
PiotrO Posted September 4, 2019 Posted September 4, 2019 Guys, Just quick Q: on 5.3-rc7 I still have blackscreen on Eachlink H6 (even with video=HDMI-A-1:e). Is this 5.3 kernel issue or rather something else? btw: I switch to beelink Gs1 and got almost fully working with mainline 5.3-rc7 (so far except: thermal, cpu freq. scaling and t720 gpu - but this is different story...)
jernej Posted September 4, 2019 Posted September 4, 2019 On 9/4/2019 at 3:48 PM, PiotrO said: Is this 5.3 kernel issue or rather something else? Expand Yes and fixes are here. Not sure when they'll be merged to 5.3 though.
jernej Posted September 8, 2019 Posted September 8, 2019 @PiotrO 5.3-rc8 contains fixes needed for this workaround to work. Can you try again?
PiotrO Posted September 9, 2019 Posted September 9, 2019 On 9/8/2019 at 11:27 PM, jernej said: @PiotrO 5.3-rc8 contains fixes needed for this workaround to work. Can you try again? Expand @jernej, thx for hint! for sure i'll test it. rc7+patches You mention gives me working screen on eachlink h6 mini. Last days I'm playing a bit with DVFS on h6 (beelink gs1). I'm using 5.3-rc7 mainline + and megous patches (also verified with Yours libreelec patches for h6). I got ths working (as I see entries in /sys/class/thermal) So next I tried to play with cpufreq. I added clk to cpu cores (like in https://github.com/megous/linux/commit/19a1b4942b8f040f2b8f2d322368518c5776025b), OPP tables (like in https://github.com/megous/linux/commit/b4aca20e5ce774f6f91bc79317d232ead36e8ede) and trip points/cooling maps (like in https://github.com/megous/linux/commit/b1a1c764c50b6d2d86d1c9124d01ca1726836e9b ). Next I enabled cpu0 power from dcdca reg and my gs1 boots. but here is no any entries in /sys/class/cpufreq What intriguing me: in megous & Yours patches there is no any touch in cpufreq-dt-platdev for H6 ( https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/drivers/cpufreq/cpufreq-dt-platdev.c?id=089cf7f6ecb266b6a4164919a2e69bd2f938374a#n28 so cpufreq-dt will not load for h6. By curiosity I added 'sun50i-h6' entry in cpufreq-dt-platdev.c and now kernel tries to load cpufreq-dt module but fails with error -2 (cant get cpu0 clock). interesting. maybe clock framework not provides required method clock_get to cpufreq?
jernej Posted September 9, 2019 Posted September 9, 2019 I haven't work on thermal nor on cpufreq driver for any SoC yet in LibreELEC, so I'm not familiar with possible issues.
hexdump Posted September 9, 2019 Posted September 9, 2019 @PiotrO - did you add a supply to your cpu too? - like https://github.com/megous/linux/blob/orange-pi-5.1/arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-3.dts#L122 on the h6 tv boxes this is getting a bit tricky as they do not have a real regulator for the cpu voltage - you might have a look at my hack in the patch in the link below: see vcccpu (as some kind of dummy regulator) in the dts and the hacked opp tables in the h6 dtsi to allow this single voltage for all frequencies - but this is just a hack for now ... on the megous 5.2 kernel both the temp sensor and cpufreq are working well this way. best wishes - hexdump
PiotrO Posted September 9, 2019 Posted September 9, 2019 On 9/9/2019 at 5:04 PM, hexdump said: @PiotrO - did you add a supply to your cpu too? - like https://github.com/megous/linux/blob/orange-pi-5.1/arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-3.dts#L122 on the h6 tv boxes this is getting a bit tricky as they do not have a real regulator for the cpu voltage - you might have a look at my hack in the patch in the link below: see vcccpu (as some kind of dummy regulator) in the dts and the hacked opp tables in the h6 dtsi to allow this single voltage for all frequencies - but this is just a hack for now ... on the megous 5.2 kernel both the temp sensor and cpufreq are working well this way. Expand @hexdump, Yes. I added these entries as indeed adding cpu supply is a must to get my GS1 and eachlink working. I understand You have working DVFS on Yours H6 hw. Do You have any entries in /sys/class/cpufreq ? Also - what is best way to see what is current cpu freq/voltage & also to see how system walks on dvfs trips?
hexdump Posted September 9, 2019 Posted September 9, 2019 @PiotrO - with megous 5.2 tree i have a normal /sys/devices/cpu/cpu0/cpufreq and i can see all the frequencies (up to 1.8ghz is possible) i have hacked the voltage for into the h6 dtsi and thermal throttling is working perfectly well too as long as there is enough airflow so that just reducing the frequency can cool the cpu enough down (as there is no voltage scaling, which usually reduces heat the most)
PiotrO Posted September 10, 2019 Posted September 10, 2019 On 9/9/2019 at 10:30 PM, hexdump said: @PiotrO - with megous 5.2 tree i have a normal /sys/devices/cpu/cpu0/cpufreq and i can see all the frequencies (up to 1.8ghz is possible) i have hacked the voltage for into the h6 dtsi and thermal throttling is working perfectly well too as long as there is enough airflow so that just reducing the frequency can cool the cpu enough down (as there is no voltage scaling, which usually reduces heat the most) Expand Hmm - interesting: in my case on 5.3-rc8 it looks I need to look in: /sys/devices/system/cpu/cpufreq/policy0 And indeed i.e.: cat /sys/devices/system/cpu/cpufreq/policy0/stats/trans_table From : To : 480000 720000 816000 888000 1080000 1320000 1488000 1800000 480000: 0 0 0 0 0 0 0 0 720000: 0 0 0 0 0 0 0 0 816000: 0 0 0 0 0 0 0 0 888000: 0 0 0 0 0 0 0 0 1080000: 0 0 0 0 0 0 0 1 1320000: 0 0 0 0 0 0 0 0 1488000: 0 0 0 0 0 0 0 0 1800000: 0 0 0 0 0 0 0 0 but cat /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed <unsupported> echo 1080000 > /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed ash: write error: Invalid argument is it setspeed working for You on 5.2?
hexdump Posted September 10, 2019 Posted September 10, 2019 i am getting the same error on the megous 5.2 tree, but i must admin that i never used this scaling_setspeed functionality yet ... frequency scaling as such is working well though: root@eachlink:~# cat /sys/devices/system/cpu/cpufreq/policy0/stats/time_in_state 480000 14726 720000 231 816000 96 888000 120 1080000 458 1320000 136 1488000 149 1800000 3333
vlad59 Posted October 3, 2019 Posted October 3, 2019 Hi all, I have a Tanix TX6 4Gb/32Gb on the way. I hope to use it with armbian (if that does not work, I'll use libreelec but I'd prefer having a generic linux). Is there a step by step guide on how to build an armbian image. I read the whole thread and saw that megous tree is almost good to go especially with 5.4 that got a lot of patch included. It's less clear for uboot, is latest uboot good to use or is there some patch to use. Is there a fork of armbian/build with everything included maybe ? Thanks in advance for any help
balbes150 Posted December 19, 2019 Posted December 19, 2019 On 7/12/2019 at 11:16 PM, hexdump said: maybe its time to start your armbian image build machinery to spin a test image .. Expand Sorry, I just now saw the messages for me (I was on vacation when these messages were written and missed them). I have now started preparing to run Armbian on H6 and discovered these messages. Launch Armbian on TV box H6 still someone interestingly ? 1
Ruediger Posted December 19, 2019 Posted December 19, 2019 On 12/19/2019 at 12:44 PM, balbes150 said: Sorry, I just now saw the messages for me (I was on vacation when these messages were written and missed them). I have now started preparing to run Armbian on H6 and discovered these messages. Launch Armbian on TV box H6 still someone interestingly ? Expand Oh sure the H6 is a nice processor, and the Tanix is a sweet hardware!
hexdump Posted December 20, 2019 Posted December 20, 2019 hi @balbes150, sure there is still a lot of interest in h6 tv box support - they are easily available, they are usually quite cheap (around 30+ euro for 4/32g), their performance is very good (4x1.8ghz if cooled well) and the h6 mainline support including panfrost is progressing very well ... as a base i would recommend the megous tree as it already has a lot of h6 patches not yet in mainline in it (it has v5.4 and v5.5 branches) -> https://github.com/megous/linux/tree/orange-pi-5.4 i have some patches on top of it to add tv box ethernet support and to fake the opp tables and gpu power to give access to all cpu frequencies and the gpu as there is no software controllable power in tv boxes (like for instance in the orange pi 3) - i'll recheck them against 5.4 in the next days and upload some updated ones here other ressources of interest: @jernej has brought the h6 support for libreelec quite far -> https://forum.libreelec.tv/thread/17636-tanix-tx6/ and his github at https://github.com/jernejsk/LibreELEC.tv (for patches - not sure which branch is most up to date for the h6 right now) @PiotrO has a patched up tree for h6 as well with lots of patches -> see https://forum.armbian.com/topic/12284-eachlink-h6-support-with-mainline-kernel/ for more details best wishes - hexdump
balbes150 Posted December 21, 2019 Posted December 21, 2019 On 12/20/2019 at 7:01 PM, hexdump said: i have some patches on top of it to add tv box ethernet support and to fake the opp tables and gpu power to give access to all cpu frequencies and the gpu as there is no software controllable power in tv boxes (like for instance in the orange pi 3) - i'll recheck them against 5.4 in the next days and upload some updated ones here Expand Ok On 12/20/2019 at 7:01 PM, hexdump said: has brought the h6 support for libreelec quite far Expand Yes, I used these developments to create my (I added the familiar features I use in all other LE builds) Le variant for Tanix TX6 https://yadi.sk/d/GJbDt3-FjQ-dQA I use these sources to create a version of Armbian (I'm currently testing the first alpha version of the image Armbian on TX6). @hexdump I don't have a UART console on the TX6 (I haven't found how to connect it to this model). Can you show UART console output from your h6 model if you write only u-boot to SD card (no system) ? Did I understand correctly that you have an Eachlink H6 model ? And do you have a u-boot file for this model ?
jernej Posted December 21, 2019 Posted December 21, 2019 On 12/21/2019 at 10:05 AM, balbes150 said: I haven't found how to connect it to this model Expand Here you have description and images how to do that: http://linux-sunxi.org/Tanix_TX6#Adding_a_serial_port_.28voids_warranty.29 1
balbes150 Posted December 21, 2019 Posted December 21, 2019 On 12/21/2019 at 10:33 AM, jernej said: Here you have description and images how to do that: Expand Tnx. I'll try to use it.
balbes150 Posted December 22, 2019 Posted December 22, 2019 Took "clean" config from LE and built Armbian with It (version 20191222). Now the wired network works. Perhaps when using the universal kernel config, some options are not in the state that would ensure the operation of a wired network. @hexdump @PiotrO Can you drop me a copy of the u-boot and dtb you use for Eachlink H6 ? For u-boot, you can simply make a copy of the DD - 4M from your working SD card.
