yesterday i see that the SATA Hat for the Nanopi is available now
is it possible to install Armbian on a SSD when i use the Sata Hat ?
Or is the EMMC or SD Card required for the OS ?
22 minutes ago, perlian said:
You can't boot directly from SATA if that's what you are asking. You need SD/eMMC/SPI at least for boot loader.
Procedure for installing is standard https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb
thats exactly what i wanted to know
Many thanks Igor
 ....next time i read the  manual first :-)
