1 1
Z11ntal33r
armbian-ramlog spin-up all HDDs once every day
I've two Tinker Board servers running latest Armbian stable Debian GNU/Linux 9 with 4.19.*-rockchip. In that regard, I've connected some HDDs and from the log I see that every day at a specific time all HDDs are spinning up as seen below in the spoiler. This happens for both servers at the same specific time every day..
# Server 1
May 13 06:25:26 Tinkerboard hd-idle[29538]: sda spinup
May 13 06:25:26 Tinkerboard hd-idle[29538]: sdc spinup
May 13 06:25:26 Tinkerboard hd-idle[29538]: sdb spinup
May 13 06:35:36 Tinkerboard hd-idle[29538]: sda spindown
May 13 06:35:45 Tinkerboard hd-idle[29538]: sdc spindown
May 13 06:35:45 Tinkerboard hd-idle[29538]: sdb spindown
May 14 06:26:07 Tinkerboard hd-idle[29538]: sda spinup
May 14 06:26:07 Tinkerboard hd-idle[29538]: sdc spinup
May 14 06:26:07 Tinkerboard hd-idle[29538]: sdb spinup
May 14 06:36:17 Tinkerboard hd-idle[29538]: sda spindown
May 14 06:36:26 Tinkerboard hd-idle[29538]: sdc spindown
May 14 06:36:26 Tinkerboard hd-idle[29538]: sdb spindown
May 15 06:25:51 Tinkerboard hd-idle[29538]: sda spinup
May 15 06:25:51 Tinkerboard hd-idle[29538]: sdc spinup
May 15 06:25:51 Tinkerboard hd-idle[29538]: sdb spinup
May 15 06:36:01 Tinkerboard hd-idle[29538]: sda spindown
May 15 06:36:10 Tinkerboard hd-idle[29538]: sdc spindown
May 15 06:36:10 Tinkerboard hd-idle[29538]: sdb spindown
May 16 06:25:33 Tinkerboard hd-idle[29538]: sda spinup
May 16 06:25:33 Tinkerboard hd-idle[29538]: sdc spinup
May 16 06:25:33 Tinkerboard hd-idle[29538]: sdb spinup
May 16 06:35:43 Tinkerboard hd-idle[29538]: sda spindown
May 16 06:35:52 Tinkerboard hd-idle[29538]: sdc spindown
May 16 06:35:52 Tinkerboard hd-idle[29538]: sdb spindown
# Server 2
May 13 06:25:37 Tinkerboard hd-idle[794]: sda spinup
May 13 06:25:37 Tinkerboard hd-idle[794]: sdb spinup
May 13 06:35:42 Tinkerboard hd-idle[794]: sda spindown
May 13 06:35:43 Tinkerboard hd-idle[794]: sdb spindown
May 14 06:25:45 Tinkerboard hd-idle[794]: sda spinup
May 14 06:25:45 Tinkerboard hd-idle[794]: sdb spinup
May 14 06:35:52 Tinkerboard hd-idle[794]: sda spindown
May 14 06:35:53 Tinkerboard hd-idle[794]: sdb spindown
May 15 06:25:48 Tinkerboard hd-idle[794]: sda spinup
May 15 06:25:48 Tinkerboard hd-idle[794]: sdb spinup
May 15 06:35:56 Tinkerboard hd-idle[794]: sda spindown
May 15 06:35:56 Tinkerboard hd-idle[794]: sdb spindown
May 16 06:25:44 Tinkerboard hd-idle[794]: sda spinup
May 16 06:25:44 Tinkerboard hd-idle[794]: sdb spinup
May 16 06:35:54 Tinkerboard hd-idle[794]: sda spindown
May 16 06:35:54 Tinkerboard hd-idle[794]: sdb spindown
I've been thinking of using fatrace to trace file access events around the specific time to find which service that spins up my HDDs, however, when I try to use fatrace by running the code below I get the message "Cannot initialize fanotify: Function not implemented". I've come across two bug reports which seems to be related to this issue: some archs/kernels define O_LARGEFILE and Hardcoded KERNEL_O_LARGEFILE does not work on ARM. So, I guess fatrace is not an option given that it's not enabled in the kernel configuration.
$ sudo fatrace -o /tmp/trace -s 60
btrace doesn't seem to be working either as seen below.
$ sudo btrace /dev/sdb
BLKTRACESETUP(2) /dev/sdb failed: 5/Input/output error
Neither is iotop as seen below.
$ sudo iotop
Could not run iotop as some of the requirements are not met:
- Linux >= 2.6.20 with
  - I/O accounting support (CONFIG_TASKSTATS, CONFIG_TASK_DELAY_ACCT, CONFIG_TASK_IO_ACCOUNTING)
Any recommendation for tools that I can use to find out which process that is spinning up my HDDs every day?
Thanks in advance!:)
Share this post
Link to post
Share on other sites
I suspected that "Function not implemented" was related to some kernel configuration, however, I'm looking for an alternative to find processes which are accessing all three HDDs every day at the same time without disabling processes one by one...
I've found blktrace which seems to give some relevant information as seen below. So, I'm going to run the following command a minute before the timestamp my HDDs are spinning up
$ sudo blktrace -d /dev/sdb -o - | blkparse -i -
  8,16   1        1     0.000000000    17  C   N [0]
  8,16   2        1 1266874889.708500152   888  G   N [smartd]
  8,16   2        2 1266874889.708505985   888  I   N 0 [smartd]
  8,16   2        3 1266874889.708510360   888  D   N 0 [smartd]
  8,16   1        2     5.001279610    17  C   N [0]
  8,16   1        3     5.002521825    17  C   N [65531]
  8,16   2        4     5.000177978   888  G   N [smartd]
  8,16   2        5     5.000184978   888  I   N 0 [smartd]
  8,16   2        6     5.000188770   888  D   N 0 [smartd]
  8,16   2        7     5.001649445 30968  G   N [kworker/2:2]
  8,16   2        8     5.001652070 30968  I   N 0 [kworker/2:2]
  8,16   2        9     5.001653528 30968  D   N 0 [kworker/2:2]
I'll also run strace to see if I can get some more information regarding this
sudo strace -f -e open -t ls 2>&1
Tracking syscalls with auditctl (Audit framework) is also a possibility I've found and might be possible if kernels CONFIG_AUDIT is enabled. I'll look more into auditctl tomorrow if I don't find some relevant information from blktrace or strace.
Share this post
Link to post
As I was in the middle of the exam period when I posted this thread, I stopped all daily cron jobs as a shortcut, which fixed this issue. I've since found out that the daily cron job etc/cron.daily/armbian-ram-logging is the problem. armbian-ram-logging contains
#!/bin/sh
/usr/lib/armbian/armbian-ramlog write >/dev/null 2>&1
/usr/lib/armbian/armbian-ramlog contains
#!/bin/bash
# Copyright (c) Authors: http://www.armbian.com/authors
# This file is licensed under the terms of the GNU General Public
# License version 2. This program is licensed "as is" without any
# warranty of any kind, whether express or implied.
SIZE=50M
USE_RSYNC=true
ENABLED=false
[ -f /etc/default/armbian-ramlog ] && . /etc/default/armbian-ramlog
[ "$ENABLED" != true ] && exit 0
# Never touch anything below here. Only edit /etc/default/armbian-ramlog
HDD_LOG=/var/log.hdd/
RAM_LOG=/var/log/
LOG2RAM_LOG="${HDD_LOG}armbian-ramlog.log"
LOG_OUTPUT="tee -a $LOG2RAM_LOG"
isSafe () {
    [ -d $HDD_LOG ] || (echo "ERROR: $HDD_LOG doesn't exist! Can't sync." >&2 ; exit 1)
    NoCache=$(which nocache 2>/dev/null)
RecreateLogs (){
    # in case of crash those services don't start if there are no dirs & logs
    check_if_installed apache2 && [ ! -d /var/log/apache2 ] && mkdir -p /var/log/apache2
    check_if_installed cron-apt && [ ! -d /var/log/cron-apt ] && \
        (mkdir -p /var/log/cron-apt ; touch /var/log/cron-apt/log)
    check_if_installed proftpd-basic && [ ! -d /var/log/proftpd ] && \
        (mkdir -p /var/log/proftpd ; touch /var/log/proftpd/controls.log)
    check_if_installed nginx && [ ! -d /var/log/nginx ] && \
        (mkdir -p /var/log/nginx ; touch /var/log/nginx/access.log ; touch /var/log/nginx/error.log)
    check_if_installed samba && [ ! -d /var/log/samba ] && mkdir -p /var/log/samba
    check_if_installed unattended-upgrades && [ ! -d /var/log/unattended-upgrades ] && mkdir -p /var/log/unattended-upgrades
    return 0
syncToDisk () {
    isSafe
    echo -e "\n\n$(date): Syncing logs from $LOG_TYPE to storage\n" | $LOG_OUTPUT
    if [ "$USE_RSYNC" = true ]; then
        ${NoCache} rsync -aXWv --delete --exclude armbian-ramlog.log --links $RAM_LOG $HDD_LOG 2>&1 | $LOG_OUTPUT
    else
        ${NoCache} cp -rfup $RAM_LOG -T $HDD_LOG 2>&1 | $LOG_OUTPUT
    fi
    sync
syncFromDisk () {
    isSafe
    echo -e "\n\n$(date): Loading logs from storage to $LOG_TYPE\n" | $LOG_OUTPUT
        ${NoCache} rsync -aXWv --delete --exclude armbian-ramlog.log --exclude *.gz --exclude='*.[0-9]' --links $HDD_LOG $RAM_LOG 2>&1 | $LOG_OUTPUT
    else
        ${NoCache} find $HDD_LOG* -maxdepth 1 -type f -not \( -name '*.[0-9]' -or -name '*.xz*' -or -name '*.gz' \) | xargs cp -ut $RAM_LOG
    fi
    sync
check_if_installed () {
    local DPKG_Status="$(dpkg -s "$1" 2>/dev/null | awk -F": " '/^Status/ {print $2}')"
    if [[ "X${DPKG_Status}" = "X" || "${DPKG_Status}" = *deinstall* ]]; then
        return 1
    else
        return 0
    fi
# Check whether zram device is available or we need to use tmpfs
if [ "$(blkid -s TYPE /dev/zram0 | awk ' { print $2 } ' | grep ext4)" ]; then
    LOG_TYPE="zram"
else
    LOG_TYPE="tmpfs"
fi
case "$1" in
    start)
        [ -d $HDD_LOG ] || mkdir -p $HDD_LOG
        mount --bind $RAM_LOG $HDD_LOG
        mount --make-private $HDD_LOG
        case $LOG_TYPE in
            zram)
                echo -e "Mounting /dev/zram0 as $RAM_LOG \c" | $LOG_OUTPUT
                mount -o discard /dev/zram0 $RAM_LOG 2>&1 | $LOG_OUTPUT
            tmpfs)
                echo -e "Setting up $RAM_LOG as tmpfs \c" | $LOG_OUTPUT
                mount -t tmpfs -o nosuid,noexec,nodev,mode=0755,size=$SIZE armbian-ramlog $RAM_LOG 2>&1 | $LOG_OUTPUT
        esac
        syncFromDisk
        RecreateLogs
    stop)
        syncToDisk
        umount -l $RAM_LOG
        umount -l $HDD_LOG
    write)
        syncToDisk
        echo "Usage: ${0##*/} {start|stop|write}" >&2
        exit 1
esac
/etc/default/armbian-ramlog contains
# configuration values for the armbian-ram-logging service
# enable the armbian-ram-logging service?
ENABLED=true
# size of the tmpfs mount -- please keep in mind to adjust /etc/default/armbian-zram-config too when increasing
SIZE=50M
# use rsync instead of cp -r
# requires rsync installed, may provide better performance
# due to copying only new and changed files
USE_RSYNC=true
So, I'm going to modify the file /etc/default/armbian-ramlog to prevent it from waking up my external hard drives every day. In that regard, it's much appreciated if anyone could point out which lines in the file that might wake up the hard drives. I'm thinking about line:
  • 81 with "... blkid -s TYPE /dev/zram0 ..." which I think wake up all drives. What do you think?
  • 65 with the find command "... find $HDD_LOG ...", yet it should only search for folders in the folder $HDD_LOG (/var/log.hdd/).
@Igor, this issue is likely something that others might find interesting as armbian-ramlog currently is spinning up all connected drives, which shouldn't be necessary.
Share this post
Link to post
Yes, it looks like that is the problem so this part needs to be done differently.
Share this post
Link to post
Something like this would probably be just fine:
--- a/packages/bsp/common/usr/lib/armbian/armbian-ramlog
+++ b/packages/bsp/common/usr/lib/armbian/armbian-ramlog
@@ -43,7 +43,7 @@ RecreateLogs (){
 syncToDisk () {
        isSafe
-       echo -e "\n\n$(date): Syncing logs from $LOG_TYPE to storage\n" | $LOG_OUTPUT
+       echo -e "\n\n$(date): Syncing logs to storage\n" | $LOG_OUTPUT
                ${NoCache} rsync -aXWv --delete --exclude "lost+found" --exclude armbian-ramlog.log --links $RAM_LOG $HDD_LOG 2>&1 | $LOG_OUTPUT
@@ -57,7 +57,7 @@ syncToDisk () {
 syncFromDisk () {
        isSafe
-       echo -e "\n\n$(date): Loading logs from storage to $LOG_TYPE\n" | $LOG_OUTPUT
+       echo -e "\n\n$(date): Loading logs from storage\n" | $LOG_OUTPUT
                ${NoCache} rsync -aXWv --delete --exclude "lost+found" --exclude armbian-ramlog.log --exclude *.gz --exclude='*.[0-9]' --links $HDD_LOG $RAM_LOG 2>&1 | $LOG_OUTPUT
@@ -77,19 +77,19 @@ check_if_installed () {
        fi
-# Check whether zram device is available or we need to use tmpfs
-if [ "$(blkid -s TYPE /dev/zram0 | awk ' { print $2 } ' | grep ext4)" ]; then
-       LOG_TYPE="zram"
-else
-       LOG_TYPE="tmpfs"
-fi
 case "$1" in
        start)
+               # Check whether zram device is available or we need to use tmpfs
+               if [ "$(blkid -s TYPE /dev/zram0 | awk ' { print $2 } ' | grep ext4)" ]; then
+                       LOG_TYPE="zram"
+               else
+                       LOG_TYPE="tmpfs"
+               fi
                case $LOG_TYPE in
                        zram)
Share this post
Link to post
I changed /usr/lib/armbian/armbian-ramlog directly given your changes (Bugfix: check LOG_TYPE only at script start #1417), made it executable and rebooted the server, yet it spun up the hard drives when I changed the time for daily cron jobs to trigger etc/cron.daily/armbian-ram-logging. So, we are still not there yet... Please let me know if you want more testing etc
Share this post
Link to post
But now it should not touch hard drive at all ... unless your /var/log is the hard drive.
Edit: it works for me. HDD remain sleeping after executing command found in cronjob
Share this post
Link to post
I know, yet the hard drives spins up... :mellow: /var/log is on my Micro SD card. My hard drives are mounted with fstab to folders in "/mnt/usb*". Everything else is on my Micro SD card, so I've no clue why armbian-ramlog is still spinning up my hard drives...
Share this post
Link to post
Perhaps restarting crond?
service cron restart
or by rebooting?
Share this post
Link to post
I rebooted after the changes last time, and tried again now by restarting cron, yet still the same result. All hard drives spin up during daily cron and spin down after 10 minutes. So there seems to be something we are missing.
Share this post
Link to post
Armbian-ramlog part only execute: "armbian-ramlog write" and if that command doesn't spin the HDD ... ?
Do you have anything else in daily cron?
Share this post
Link to post
I’ve several other jobs in daily cron, but none of them trigger HDD spin ups. I started to look into this by removing all jobs and adding one by one until HDDs are spun up during daily cron task. So commenting /etc/cron.daily/armbian-ram-logging without removing the file stops my HDDs from spinning up.
I’ll look into this later today when I get home. The way you have tested this is by running “/usr/lib/armbian/armbian-ramlog write”, correct?
Share this post
Link to post
Exactly. Because there was a problem in our script ... command blkid -s TYPE /dev/zram0 spins all hard drives up but now it only gets executed at boot time, when service is enabled.
Share this post
Link to post
could it be a correlation?
After updating the code you could try again by removing all of your jobs and adding one by one.
Share this post
Link to post
I've found the issue. As I did only check hd-idle log to see if the HDD's are spinning or not, it seems to be saying that the HDDs are spinning up when they actually are not. This is likely related to that hd-idle is using /proc/diskstats to read disk statistics and then writes the log to systemd as seen below. The hard drives are not spinning up and everything seems fine, disregarding the wrong logging. Thanks for the great support! :)
Server 1
| => sudo /usr/lib/armbian/armbian-ramlog write
Mon Jun 17 17:36:44 CEST 2019: Syncing logs to storage
sending incremental file list
auth.log
daemon.log
lastlog
messages
syslog
user.log
wtmp
sent 10,126,622 bytes  received 159 bytes  20,253,562.00 bytes/sec
total size is 27,876,771  speedup is 2.75
 => journalctl -u hd-idle
Jun 17 17:36:59 Tinkerboard hd-idle[774]: sda spinup
Jun 17 17:36:59 Tinkerboard hd-idle[774]: sdb spinup
Running the same command again gives
Mon Jun 17 18:06:37 CEST 2019: Syncing logs to storage
aptitude
auth.log
daemon.log
dpkg.log
fail2ban.log
syslog
apt/
apt/eipp.log.xz
apt/history.log
apt/term.log
nginx/access.log
Jun 17 17:47:09 Tinkerboard hd-idle[774]: sda spindown
Jun 17 17:47:09 Tinkerboard hd-idle[774]: sdb spindown
Third time running the command gives
Mon Jun 17 18:11:57 CEST 2019: Syncing logs to storage
auth.log
daemon.log
syslog
Jun 17 18:07:29 Tinkerboard hd-idle[774]: sda spinup
Jun 17 18:07:29 Tinkerboard hd-idle[774]: sdb spinup
However, checking both drives with smartctl verifies that the hard drives are not spinning up, even when the log says they are.
| => sudo smartctl -i -d sat -n standby /dev/sda
smartctl 6.6 2017-11-05 r4594 [armv7l-linux-4.19.41-rockchip] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Device is in STANDBY mode, exit(2)
________________________________________________________________________________
| => sudo smartctl -i -d sat -n standby /dev/sdb
Jun 17 18:22:44 Tinkerboard hd-idle[774]: sda spindown
Jun 17 18:22:44 Tinkerboard hd-idle[774]: sdb spindown
Server 2
Mon 17 Jun 2019 18:37:24 CEST: Syncing logs to storage
deleting user.log.1
deleting syslog.1
deleting php7.0-fpm.log.1
deleting messages.1
deleting kern.log.1
deleting fail2ban.log.1
deleting debug.1
deleting daemon.log.1
deleting auth.log.1
deleting armbian-hardware-monitor.log.1.gz
deleting nginx/access.log.1
deleting samba/log.smbd.1
deleting samba/log.nmbd.1
aptitude
auth.log
daemon.log
debug
dpkg.log
fail2ban.log
kern.log
lastlog
messages
openvpn.log
php7.0-fpm.log
syslog
user.log
wtmp
apt/
apt/eipp.log.xz
apt/history.log
apt/term.log
nginx/
nginx/access.log
samba/
samba/log.nmbd
samba/log.smbd
sent 18,116,509 bytes  received 681 bytes  36,234,380.00 bytes/sec
total size is 18,110,220  speedup is 1.00
Jun 17 18:37:32 Tinkerboard hd-idle[862]: sda spinup
Jun 17 18:37:32 Tinkerboard hd-idle[862]: sdb spinup
Jun 17 18:37:32 Tinkerboard hd-idle[862]: sdc spinup
smartctl 6.6 2016-05-31 r4324 [armv7l-linux-4.19.41-rockchip] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
| => sudo smartctl -i -d sat -n standby /dev/sdc
Share this post
Link to post
1 1
