Armbianmonitor:
Lime2 A20 not even detecting mini usb ethernet, which was working perfectly fine on 3.xx.
Manfu: Netgear
USB: USB 2.0 Ethernet Adapter
P/N: 322-10167-01
dmesg doesn't even list the device. Could board's port be damaged? I tired usb port with usb ethernet, it lists as:
asix 1-1:1.0 eth1: register 'asix' at usb-1c14000.usb-1, ASIX AX88772 USB 2.0 Ethernet, 00:14:xx:xx:xx:xx
Expand
I'm using arbmian Ubuntu 18.04 with beta packages.
Thanks
Expand
You mean plugging something to the OTG USB port near to HDMI? It is possible that is default disabled.
Yes. Nothing is begin logged in dmesg. But when tried USB to ethernet on USB hub it works fine.
When you said it's disabled? Is it this message
"[ 2.961666] usb0-vbus: disabling"
How do I enable it?
