Jean-Marc Posted June 20, 2019 Posted June 20, 2019 Hi, I have following error on Rock64 when trying to update with apt tools: -1- My config file is : root@srv-rock64-130:~# cat /etc/apt/sources.list.d/armbian_apt_v_9_stretch.list |grep -v "#" deb http://apt.armbian.com stretch main stretch-utils stretch-desktop -2- to get all keys, i run ... /usr/bin/wget \ --tries=3 \ --output-document=/tmp/Release.key \ --quiet \ --no-check-certificate \ http://apt.armbian.com/armbian.key \ && \ /usr/bin/apt-key add - < /tmp/Release.key \ && \ /bin/rm -f /tmp/Release.key root@srv-rock64-130:~# /usr/bin/wget \ > --tries=3 \ > --output-document=/tmp/Release.key \ > --quiet \ > --no-check-certificate \ > http://apt.armbian.com/armbian.key \ > && \ > /usr/bin/apt-key add - < /tmp/Release.key \ > && \ > /bin/rm -f /tmp/Release.key OK -3- Issue ? but when launching apt update root@srv-rock64-130:~# apt update Réception de:1 http://security.debian.org stretch/updates InRelease [94,3 kB] Atteint:2 http://ftp.fr.debian.org/debian stretch-backports InRelease Ign:3 http://ftp.debian.org/debian stretch InRelease Atteint:4 http://ftp.debian.org/debian buster InRelease Atteint:6 http://ftp.fr.debian.org/debian stretch-updates InRelease Atteint:7 http://ftp.debian.org/debian stretch Release Réception de:8 http://deb.ayufan.eu/orgs/ayufan-rock64/releases InRelease [1 339 B] Réception de:9 http://deb.ayufan.eu/orgs/ayufan-rock64/pre-releases InRelease [1 339 B] Ign:5 https://apt.armbian.com stretch InRelease Err:10 https://apt.armbian.com stretch Release server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none Lecture des listes de paquets... Fait E: The repository 'http://apt.armbian.com stretch Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Thanks in advance for your help
guidol Posted June 20, 2019 Posted June 20, 2019 As you could read unsecure http is disabled by default. For temporarly use unsecure http and getting your system in a proper state you could try sudo apt-get update --no-allow-insecure-repositories You are using debian stretch, so I dont understand why you also got a line for a debian buster repository: "Atteint:4 http://ftp.debian.org/debian buster InRelease" That could also create problem if you mix distributions or you could (temprarly) use my ca-certficates.crt out of my strech-installation? see attachment [EDIT] Yes at https is no Rellease file because: wget http://apt.armbian.com/dists/stretch/Release Connecting to apt.armbian.com (apt.armbian.com)|193.40.103.96|:80... connected.HTTP request sent, awaiting response... 301 Moved Permanently Location: https://apt.armbian.com/dists/stretch/Release [following] ca-certificates.zip
Jean-Marc Posted June 20, 2019 Author Posted June 20, 2019 Thanks for proposal.... but .... root@srv-rock64-130:~# apt-get update --no-allow-insecure-repositories Ign:1 http://ftp.debian.org/debian stretch InRelease Atteint:2 http://security.debian.org stretch/updates InRelease Atteint:3 http://ftp.fr.debian.org/debian stretch-backports InRelease Atteint:4 http://ftp.debian.org/debian buster InRelease Atteint:5 http://ftp.fr.debian.org/debian stretch-updates InRelease Réception de:6 http://deb.ayufan.eu/orgs/ayufan-rock64/releases InRelease [1 339 B] Atteint:8 http://ftp.debian.org/debian stretch Release Réception de:9 http://deb.ayufan.eu/orgs/ayufan-rock64/pre-releases InRelease [1 339 B] Ign:7 https://apt.armbian.com stretch InRelease Err:10 https://apt.armbian.com stretch Release server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none Lecture des listes de paquets... Fait E: The repository 'http://apt.armbian.com stretch Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. root@srv-rock64-130:~# echo $? 100 So that this solution is not possible for me because apt management is done accross Ansible tools in a production board ....
Jean-Marc Posted June 26, 2019 Author Posted June 26, 2019 At this time, all access is now ok, it is possible to download from Armbian site. Thanks to the team Regards
Guest Posted June 26, 2019 Posted June 26, 2019 http://mirrors.netix.net/ is down for some time. I had the same problem and switching to other mirror trough armbian-config was the fix for me.
Guest Posted July 10, 2019 Posted July 10, 2019 @Igor, Can we get back netix mirror in armbian-config. I saw today it's up.
Igor Posted July 10, 2019 Posted July 10, 2019 32 minutes ago, chocho said: @Igor, Can we get back netix mirror in armbian-config. I saw today it's up. If its working, sent a PR with changes.
Jean-Marc Posted July 28, 2019 Author Posted July 28, 2019 Igor, It seems there is today the same behaviour ? Quote ansible@srv-nanopir1-170:~$ sudo apt update Atteint:1 http://security.debian.org stretch/updates InRelease Atteint:2 http://ftp.fr.debian.org/debian stretch-backports InRelease Atteint:3 http://ftp.fr.debian.org/debian stretch-updates InRelease Ign:4 http://ftp.debian.org/debian stretch InRelease Atteint:5 http://ftp.debian.org/debian buster InRelease Atteint:7 http://ftp.debian.org/debian stretch Release Ign:6 https://apt.armbian.com stretch InRelease Err:8 https://apt.armbian.com stretch Release Lecture des listes de paquets... Fait E: The repository 'http://apt.armbian.com stretch Release' does no longer have a Release file. Many thanks if you have one solution ? Spoiler
Jean-Marc Posted July 28, 2019 Author Posted July 28, 2019 Guidol, About .... Quote You are using debian stretch, so I dont understand why you also got a line for a debian buster repository: .... This is due to the fact that sometimes on stable Debian system, i install one new package from another release with capabilities to remove it later simply with very few impact on the stability. For example, one years ago, on package hostapd on Debian stretch release, it was not possible to use multiples NIC interfaces, this feature was only available on Debian buster. As a result, when installing for example new package with : sudo apt -t buster hostpad, it is then possible to test without any other efforts.
Igor Posted July 28, 2019 Posted July 28, 2019 2 hours ago, Jean-Marc said: it was not possible to use multiples NIC interfaces, this feature was only available on Debian buster Just use hostapd provided by Armbian. It provides this feature and more than (any) Debian version. 2 hours ago, Jean-Marc said: Many thanks if you have one solution ? I can't recreate. Try disabling IPV6 in armbian-config -> network .... then try again.
Jean-Marc Posted August 2, 2019 Author Posted August 2, 2019 One minute ago ..... on Pinebook buster .... ansible@pinebook:~$ LANG=C LANGUAGE=C sudo apt update Hit:1 http://ftp.fr.debian.org/debian buster-backports InRelease Hit:2 http://ftp.debian.org/debian buster InRelease Hit:3 http://security.debian.org buster/updates InRelease Hit:4 http://ftp.fr.debian.org/debian buster-updates InRelease Ign:5 http://ftp.debian.org/debian stretch InRelease Hit:7 http://ftp.debian.org/debian stretch Release Ign:6 https://apt.armbian.com buster InRelease Err:8 https://apt.armbian.com buster Release Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 193.40.103.96 443] Reading package lists... Done W: http://apt.armbian.com/dists/buster/InRelease: No system certificates available. Try installing ca-certificates. W: http://apt.armbian.com/dists/buster/Release: No system certificates available. Try installing ca-certificates. E: The repository 'http://apt.armbian.com buster Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
Jean-Marc Posted August 4, 2019 Author Posted August 4, 2019 Sorry, i have no idea ... I have also try to change behaviour on one another board (orangepir1), but results sems identicals as shown in following logs with pattern [trusted=yes] ansible@srv-orangepir1-150:~$ grep -iR deb /etc/apt/sources.li* |grep -v "#" /etc/apt/sources.list.d/debian_apt_v_9_stretch_backports.list:deb http://ftp.fr.debian.org/debian stretch-backports main contrib non-free /etc/apt/sources.list.d/armbian_apt_v_9_stretch.list:deb [trusted=yes] http://apt.armbian.com stretch main stretch-utils stretch-desktop /etc/apt/sources.list.d/debian_apt_v_9_stretch_current.list:deb http://ftp.debian.org/debian/ stretch main contrib non-free /etc/apt/sources.list.d/debian_apt_v_9_stretch_update_security.list:deb http://security.debian.org stretch/updates main contrib non-free /etc/apt/sources.list.d/debian_apt_v_9_stretch_updates.list:deb http://ftp.fr.debian.org/debian stretch-updates main contrib non-free /etc/apt/sources.list.d/debian_apt_v_9_stretch_next.list:deb http://ftp.debian.org/debian/ buster main contrib non-free ansible@srv-orangepir1-150:~$ sudo update-ca-certificates -f Clearing symlinks in /etc/ssl/certs... done. Updating certificates in /etc/ssl/certs... 151 added, 0 removed; done. Running hooks in /etc/ca-certificates/update.d... done. ansible@srv-orangepir1-150:~$ sudo apt update Atteint:1 http://ftp.fr.debian.org/debian stretch-backports InRelease Atteint:3 http://ftp.fr.debian.org/debian stretch-updates InRelease Ign:4 http://ftp.debian.org/debian stretch InRelease Atteint:5 http://ftp.debian.org/debian buster InRelease Atteint:6 http://security.debian.org stretch/updates InRelease Atteint:7 http://ftp.debian.org/debian stretch Release Ign:2 https://apt.armbian.com stretch InRelease Err:8 https://apt.armbian.com stretch Release server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none Lecture des listes de paquets... Fait E: The repository 'http://apt.armbian.com stretch Release' does no longer have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. ansible@srv-orangepir1-150:~$ echo $? 100
Jean-Marc Posted August 4, 2019 Author Posted August 4, 2019 I have also tried this solution .... ( From Ubuntu forum) but still one issue .... Quote ansible@srv-orangepir1-150:~$ LANG=C LANGUAGE=C sudo apt-get update -o Acquire::https::apt.armbian.com::Verify-Peer=false Hit:1 http://ftp.fr.debian.org/debian stretch-backports InRelease Hit:3 http://ftp.fr.debian.org/debian stretch-updates InRelease Ign:4 http://ftp.debian.org/debian stretch InRelease Hit:5 http://ftp.debian.org/debian buster InRelease Hit:6 http://security.debian.org stretch/updates InRelease Hit:7 http://ftp.debian.org/debian stretch Release Hit:2 https://apt.armbian.com stretch InRelease Reading package lists... Done Quote ansible@srv-orangepir1-150:~$ LANG=C LANGUAGE=C sudo apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: linux-dtb-next-sunxi linux-image-next-sunxi 2 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. Need to get 21,4 MB of archives. After this operation, 13,3 kB of additional disk space will be used. Do you want to continue? [O/n] O Err:1 https://apt.armbian.com stretch/main armhf linux-dtb-next-sunxi armhf 5.92 server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none Err:2 https://apt.armbian.com stretch/main armhf linux-image-next-sunxi armhf 5.92 server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none E: Failed to fetch https://apt.armbian.com/pool/main/l/linux-4.19.62-sunxi/linux-dtb-next-sunxi_5.92_armhf.deb server certificate verification failed. CAile: /etc/ssl/certs/ca-certificates.crt CRLfile: none E: Failed to fetch https://apt.armbian.com/pool/main/l/linux-4.19.62-sunxi/linux-image-next-sunxi_5.92_armhf.deb server certificate verification failed. Afile: /etc/ssl/certs/ca-certificates.crt CRLfile: none E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? ansible@srv-orangepir1-150:~$
Jean-Marc Posted August 15, 2019 Author Posted August 15, 2019 Hi, this day, always the same behaviour ????, but on target nanopiR1 for Debian stretch ansible@srv-nanopir1-170:~$ LANG=C LANGUAGE=C sudo apt-get update Hit:1 http://ftp.fr.debian.org/debian stretch-backports InRelease Ign:2 http://ftp.debian.org/debian stretch InRelease Hit:3 http://security.debian.org stretch/updates InRelease Hit:5 http://ftp.fr.debian.org/debian stretch-updates InRelease Hit:6 http://ftp.debian.org/debian buster InRelease Ign:4 https://apt.armbian.com stretch InRelease Hit:7 http://ftp.debian.org/debian stretch Release Ign:8 https://apt.armbian.com stretch Release Ign:9 https://apt.armbian.com stretch/main armhf Packages Ign:10 https://apt.armbian.com stretch/main all Packages Ign:11 https://apt.armbian.com stretch/main Translation-C Ign:12 https://apt.armbian.com stretch/main Translation-fr_FR Ign:13 https://apt.armbian.com stretch/main Translation-en Ign:14 https://apt.armbian.com stretch/main Translation-fr Ign:15 https://apt.armbian.com stretch/main all Contents (deb) Ign:16 https://apt.armbian.com stretch/main armhf Contents (deb) Ign:17 https://apt.armbian.com stretch armhf Contents (deb) Ign:18 https://apt.armbian.com stretch all Contents (deb) Ign:19 https://apt.armbian.com stretch/stretch-utils armhf Packages Ign:20 https://apt.armbian.com stretch/stretch-utils all Packages Ign:21 https://apt.armbian.com stretch/stretch-utils Translation-fr Ign:22 https://apt.armbian.com stretch/stretch-utils Translation-en Ign:23 https://apt.armbian.com stretch/stretch-utils Translation-C Ign:24 https://apt.armbian.com stretch/stretch-utils Translation-fr_FR Ign:25 https://apt.armbian.com stretch/stretch-utils armhf Contents (deb) Ign:26 https://apt.armbian.com stretch/stretch-utils all Contents (deb) Ign:27 https://apt.armbian.com stretch/stretch-desktop all Packages Ign:28 https://apt.armbian.com stretch/stretch-desktop armhf Packages Ign:29 https://apt.armbian.com stretch/stretch-desktop Translation-fr Ign:30 https://apt.armbian.com stretch/stretch-desktop Translation-en Ign:31 https://apt.armbian.com stretch/stretch-desktop Translation-fr_FR Ign:32 https://apt.armbian.com stretch/stretch-desktop Translation-C Ign:33 https://apt.armbian.com stretch/stretch-desktop all Contents (deb) Ign:34 https://apt.armbian.com stretch/stretch-desktop armhf Contents (deb) Ign:9 https://apt.armbian.com stretch/main armhf Packages Ign:10 https://apt.armbian.com stretch/main all Packages Ign:11 https://apt.armbian.com stretch/main Translation-C Ign:12 https://apt.armbian.com stretch/main Translation-fr_FR Ign:13 https://apt.armbian.com stretch/main Translation-en Ign:14 https://apt.armbian.com stretch/main Translation-fr Ign:15 https://apt.armbian.com stretch/main all Contents (deb) Ign:16 https://apt.armbian.com stretch/main armhf Contents (deb) Ign:17 https://apt.armbian.com stretch armhf Contents (deb) Ign:18 https://apt.armbian.com stretch all Contents (deb) Ign:19 https://apt.armbian.com stretch/stretch-utils armhf Packages Ign:20 https://apt.armbian.com stretch/stretch-utils all Packages Ign:21 https://apt.armbian.com stretch/stretch-utils Translation-fr Ign:22 https://apt.armbian.com stretch/stretch-utils Translation-en Ign:23 https://apt.armbian.com stretch/stretch-utils Translation-C Ign:24 https://apt.armbian.com stretch/stretch-utils Translation-fr_FR Ign:25 https://apt.armbian.com stretch/stretch-utils armhf Contents (deb) Ign:26 https://apt.armbian.com stretch/stretch-utils all Contents (deb) Ign:27 https://apt.armbian.com stretch/stretch-desktop all Packages Ign:28 https://apt.armbian.com stretch/stretch-desktop armhf Packages Ign:29 https://apt.armbian.com stretch/stretch-desktop Translation-fr Ign:30 https://apt.armbian.com stretch/stretch-desktop Translation-en Ign:31 https://apt.armbian.com stretch/stretch-desktop Translation-fr_FR Ign:32 https://apt.armbian.com stretch/stretch-desktop Translation-C Ign:33 https://apt.armbian.com stretch/stretch-desktop all Contents (deb) Ign:34 https://apt.armbian.com stretch/stretch-desktop armhf Contents (deb) Ign:9 https://apt.armbian.com stretch/main armhf Packages Ign:10 https://apt.armbian.com stretch/main all Packages Ign:11 https://apt.armbian.com stretch/main Translation-C Ign:12 https://apt.armbian.com stretch/main Translation-fr_FR Ign:13 https://apt.armbian.com stretch/main Translation-en Ign:14 https://apt.armbian.com stretch/main Translation-fr Ign:15 https://apt.armbian.com stretch/main all Contents (deb) Ign:16 https://apt.armbian.com stretch/main armhf Contents (deb) Ign:17 https://apt.armbian.com stretch armhf Contents (deb) Ign:18 https://apt.armbian.com stretch all Contents (deb) Ign:19 https://apt.armbian.com stretch/stretch-utils armhf Packages Ign:20 https://apt.armbian.com stretch/stretch-utils all Packages Ign:21 https://apt.armbian.com stretch/stretch-utils Translation-fr Ign:22 https://apt.armbian.com stretch/stretch-utils Translation-en Ign:23 https://apt.armbian.com stretch/stretch-utils Translation-C Ign:24 https://apt.armbian.com stretch/stretch-utils Translation-fr_FR Ign:25 https://apt.armbian.com stretch/stretch-utils armhf Contents (deb) Ign:26 https://apt.armbian.com stretch/stretch-utils all Contents (deb) Ign:27 https://apt.armbian.com stretch/stretch-desktop all Packages Ign:28 https://apt.armbian.com stretch/stretch-desktop armhf Packages Ign:29 https://apt.armbian.com stretch/stretch-desktop Translation-fr Ign:30 https://apt.armbian.com stretch/stretch-desktop Translation-en Ign:31 https://apt.armbian.com stretch/stretch-desktop Translation-fr_FR Ign:32 https://apt.armbian.com stretch/stretch-desktop Translation-C Ign:33 https://apt.armbian.com stretch/stretch-desktop all Contents (deb) Ign:34 https://apt.armbian.com stretch/stretch-desktop armhf Contents (deb) Ign:9 https://apt.armbian.com stretch/main armhf Packages Ign:10 https://apt.armbian.com stretch/main all Packages Ign:11 https://apt.armbian.com stretch/main Translation-C Ign:12 https://apt.armbian.com stretch/main Translation-fr_FR Ign:13 https://apt.armbian.com stretch/main Translation-en Ign:14 https://apt.armbian.com stretch/main Translation-fr Ign:15 https://apt.armbian.com stretch/main all Contents (deb) Ign:16 https://apt.armbian.com stretch/main armhf Contents (deb) Ign:17 https://apt.armbian.com stretch armhf Contents (deb) Ign:18 https://apt.armbian.com stretch all Contents (deb) Ign:19 https://apt.armbian.com stretch/stretch-utils armhf Packages Ign:20 https://apt.armbian.com stretch/stretch-utils all Packages Ign:21 https://apt.armbian.com stretch/stretch-utils Translation-fr Ign:22 https://apt.armbian.com stretch/stretch-utils Translation-en Ign:23 https://apt.armbian.com stretch/stretch-utils Translation-C Ign:24 https://apt.armbian.com stretch/stretch-utils Translation-fr_FR Ign:25 https://apt.armbian.com stretch/stretch-utils armhf Contents (deb) Ign:26 https://apt.armbian.com stretch/stretch-utils all Contents (deb) Ign:27 https://apt.armbian.com stretch/stretch-desktop all Packages Ign:28 https://apt.armbian.com stretch/stretch-desktop armhf Packages Ign:29 https://apt.armbian.com stretch/stretch-desktop Translation-fr Ign:30 https://apt.armbian.com stretch/stretch-desktop Translation-en Ign:31 https://apt.armbian.com stretch/stretch-desktop Translation-fr_FR Ign:32 https://apt.armbian.com stretch/stretch-desktop Translation-C Ign:33 https://apt.armbian.com stretch/stretch-desktop all Contents (deb) Ign:34 https://apt.armbian.com stretch/stretch-desktop armhf Contents (deb) Ign:9 https://apt.armbian.com stretch/main armhf Packages Ign:10 https://apt.armbian.com stretch/main all Packages Ign:11 https://apt.armbian.com stretch/main Translation-C Ign:12 https://apt.armbian.com stretch/main Translation-fr_FR Ign:13 https://apt.armbian.com stretch/main Translation-en Ign:14 https://apt.armbian.com stretch/main Translation-fr Ign:15 https://apt.armbian.com stretch/main all Contents (deb) Ign:16 https://apt.armbian.com stretch/main armhf Contents (deb) Ign:17 https://apt.armbian.com stretch armhf Contents (deb) Ign:18 https://apt.armbian.com stretch all Contents (deb) Ign:19 https://apt.armbian.com stretch/stretch-utils armhf Packages Ign:20 https://apt.armbian.com stretch/stretch-utils all Packages Ign:21 https://apt.armbian.com stretch/stretch-utils Translation-fr Ign:22 https://apt.armbian.com stretch/stretch-utils Translation-en Ign:23 https://apt.armbian.com stretch/stretch-utils Translation-C Ign:24 https://apt.armbian.com stretch/stretch-utils Translation-fr_FR Ign:25 https://apt.armbian.com stretch/stretch-utils armhf Contents (deb) Ign:26 https://apt.armbian.com stretch/stretch-utils all Contents (deb) Ign:27 https://apt.armbian.com stretch/stretch-desktop all Packages Ign:28 https://apt.armbian.com stretch/stretch-desktop armhf Packages Ign:29 https://apt.armbian.com stretch/stretch-desktop Translation-fr Ign:30 https://apt.armbian.com stretch/stretch-desktop Translation-en Ign:31 https://apt.armbian.com stretch/stretch-desktop Translation-fr_FR Ign:32 https://apt.armbian.com stretch/stretch-desktop Translation-C Ign:33 https://apt.armbian.com stretch/stretch-desktop all Contents (deb) Ign:34 https://apt.armbian.com stretch/stretch-desktop armhf Contents (deb) Err:9 https://apt.armbian.com stretch/main armhf Packages Reading package lists... Done W: The repository 'http://apt.armbian.com stretch Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. E: Failed to fetch https://apt.armbian.com/dists/stretch/main/binary-armhf/Packages E: Failed to fetch https://apt.armbian.com/dists/stretch/main/binary-all/Packages E: Failed to fetch https://apt.armbian.com/dists/stretch/main/i18n/Translation-C E: Failed to fetch https://apt.armbian.com/dists/stretch/main/i18n/Translation-fr_FR E: Failed to fetch https://apt.armbian.com/dists/stretch/main/i18n/Translation-en E: Failed to fetch https://apt.armbian.com/dists/stretch/main/i18n/Translation-fr E: Failed to fetch https://apt.armbian.com/dists/stretch/main/Contents-all E: Failed to fetch https://apt.armbian.com/dists/stretch/main/Contents-armhf E: Failed to fetch https://apt.armbian.com/dists/stretch/Contents-armhf E: Failed to fetch https://apt.armbian.com/dists/stretch/Contents-all E: Failed to fetch https://apt.armbian.com/dists/stretch/stretch-utils/binary-armhf/Packages E: Some index files failed to download. They have been ignored, or old ones used instead. ansible@srv-nanopir1-170:~$ My configuration is : ansible@srv-nanopir1-170:~$ grep -iR deb /etc/apt/sources* |grep -v "#" /etc/apt/sources.list.d/debian_apt_v_9_stretch_backports.list:deb http://ftp.fr.debian.org/debian stretch-backports main contrib non-free /etc/apt/sources.list.d/armbian_apt_v_9_stretch.list:deb http://apt.armbian.com stretch main stretch-utils stretch-desktop /etc/apt/sources.list.d/debian_apt_v_9_stretch_current.list:deb http://ftp.debian.org/debian/ stretch main contrib non-free /etc/apt/sources.list.d/debian_apt_v_9_stretch_update_security.list:deb http://security.debian.org stretch/updates main contrib non-free /etc/apt/sources.list.d/debian_apt_v_9_stretch_updates.list:deb http://ftp.fr.debian.org/debian stretch-updates main contrib non-free /etc/apt/sources.list.d/debian_apt_v_9_stretch_next.list:deb http://ftp.debian.org/debian/ buster main contrib non-free
Jean-Marc Posted August 15, 2019 Author Posted August 15, 2019 ....but at the same time, on one another target (orangepiR1), but running Buster armbain & Debian, access is without any error? ansible@srv-orangepir1-150:~$ sudo grep -iR deb /etc/apt/sources* |grep -v "#" /etc/apt/sources.list.d/debian_apt_v_10_buster_backports.list:deb http://ftp.fr.debian.org/debian buster-backports main contrib non-free /etc/apt/sources.list.d/debian_apt_v_10_buster_previous.list:deb http://ftp.debian.org/debian/ stretch main contrib non-free /etc/apt/sources.list.d/debian_apt_v_10_buster_update_security.list:deb http://security.debian.org buster/updates main contrib non-free /etc/apt/sources.list.d/armbian_apt_v_10_buster.list:deb http://apt.armbian.com buster main buster-utils buster-desktop /etc/apt/sources.list.d/debian_apt_v_10_buster_current.list:deb http://ftp.debian.org/debian/ buster main contrib non-free /etc/apt/sources.list.d/debian_apt_v_10_buster_updates.list:deb http://ftp.fr.debian.org/debian buster-updates main contrib non-free ansible@srv-orangepir1-150:~$ LANG=C LC_ALL=C sudo apt update Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://ftp.fr.debian.org/debian buster-backports InRelease Hit:3 http://ftp.debian.org/debian buster InRelease Hit:5 http://ftp.fr.debian.org/debian buster-updates InRelease Ign:6 http://ftp.debian.org/debian stretch InRelease Hit:7 http://ftp.debian.org/debian stretch Release Hit:4 https://apt.armbian.com buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. ansible@srv-orangepir1-150:~$ ansible@srv-orangepir1-150:~$ LANG=C LC_ALL=C sudo apt upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. Strange ?
